You do realize that this is a service that runs at shutdown?
Description=Remove nvidia modules before shutdown
Manually starting it isn’t going to remove modules from the system that is still in use. It will be triggered at shutdown.
The service is enabled; it is currently inactive because you’re not shutting down.
As to this:
The unit file, source configuration file or drop-ins of nvidia-unload-shutdown.service changed on disk. Run 'systemctl daemon-reload' to reload units.
That’s because you created a drop-in file that changed the configuration of the unit; if you don’t reboot, you can load the new configuration by this command.
Since it would appear that the steps you have taken aren’t helping in any way (was there any indication that this was a problem with nvidia modules?), you might want to consider undoing what you’ve done, reboot twice, and then check your journal from the previous boot to try and identify what your issue actually is:
journalctl -e -b-1
If you want to just get the last 100 lines, you can use the -n option with a number:
Remove the file you created (or remove the lines you added to an existing file, if that was the case).
Then you can either use systemctl daemon-reload to reload the original (default) config, or reboot. Personally I would reboot. Then reboot again, just to be sure that no config changes remained lingering after you stopped/disabled them, and then check your journal.
I created this file sudo nano /etc/systemd/system/nvidia-unload-shutdown.service so is it better to delete the lines in the file and save it so it’s basically just blank or is there a certain remove command to remove the entire file itself? Thanks for the help, btw
Thank you, I just checked man rm (and added it to my common cmd list), I see there’s a few options to choose from but I think it I’d probably be just fine with rm for this.
So sudo rm /etc/systemd/system/nvidia-unload-shutdown.service would be acceptable?
I didn’t run systemctl daemon-reload but instead rebooted twice, then:
[scott@endeavourOS ~]$ journalctl -e -n100 -b-1
Nov 13 17:38:13 endeavourOS systemd[1]: Unmounting /tmp...
Nov 13 17:38:13 endeavourOS audit: BPF prog-id=0 op=UNLOAD
Nov 13 17:38:13 endeavourOS systemd[1]: boot-efi.mount: Deactivated successfully.
Nov 13 17:38:13 endeavourOS systemd[1]: Unmounted /boot/efi.
Nov 13 17:38:13 endeavourOS systemd[1]: systemd-fsck@dev-disk-by\x2duuid-BB5D\x2d4A9F.service: Deactivated successfully.
Nov 13 17:38:13 endeavourOS systemd[1]: Stopped File System Check on /dev/disk/by-uuid/BB5D-4A9F.
Nov 13 17:38:13 endeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-BB5D\x2d4A9F comm="systemd" exe="/usr/lib/systemd/sys>
Nov 13 17:38:13 endeavourOS systemd[1]: Removed slice Slice /system/systemd-fsck.
Nov 13 17:38:13 endeavourOS systemd[1]: run-credentials-systemd\x2dsysusers.service.mount: Deactivated successfully.
Nov 13 17:38:13 endeavourOS systemd[1]: Unmounted /run/credentials/systemd-sysusers.service.
Nov 13 17:38:13 endeavourOS systemd[1]: tmp.mount: Deactivated successfully.
Nov 13 17:38:13 endeavourOS systemd[1]: Unmounted /tmp.
Nov 13 17:38:13 endeavourOS systemd[1]: Stopped target Preparation for Local File Systems.
Nov 13 17:38:13 endeavourOS systemd[1]: Stopped target Swaps.
Nov 13 17:38:13 endeavourOS systemd[1]: Deactivating swap /swapfile...
Nov 13 17:38:13 endeavourOS systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Nov 13 17:38:13 endeavourOS systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
Nov 13 17:38:13 endeavourOS systemd[1]: Stopped Create Static Device Nodes in /dev.
Nov 13 17:38:13 endeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? ad>
Nov 13 17:38:13 endeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysusers comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? termi>
Nov 13 17:38:13 endeavourOS systemd[1]: systemd-sysusers.service: Deactivated successfully.
Nov 13 17:38:13 endeavourOS systemd[1]: Stopped Create System Users.
Nov 13 17:38:13 endeavourOS systemd[1]: swapfile.swap: Deactivated successfully.
Nov 13 17:38:13 endeavourOS systemd[1]: Deactivated swap /swapfile.
Nov 13 17:38:13 endeavourOS systemd[1]: Reached target Unmount All Filesystems.
Nov 13 17:38:13 endeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? ter>
Nov 13 17:38:13 endeavourOS systemd[1]: systemd-remount-fs.service: Deactivated successfully.
Nov 13 17:38:13 endeavourOS systemd[1]: Stopped Remount Root and Kernel File Systems.
Nov 13 17:38:13 endeavourOS systemd[1]: lvm2-monitor.service: Deactivated successfully.
Nov 13 17:38:13 endeavourOS systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Nov 13 17:38:13 endeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=>
Nov 13 17:38:13 endeavourOS systemd[1]: Reached target System Shutdown.
Nov 13 17:38:13 endeavourOS systemd[1]: Reached target Late Shutdown Services.
Nov 13 17:38:13 endeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? termin>
Nov 13 17:38:13 endeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? termina>
Nov 13 17:38:13 endeavourOS systemd[1]: systemd-reboot.service: Deactivated successfully.
Nov 13 17:38:13 endeavourOS systemd[1]: Finished System Reboot.
Nov 13 17:38:13 endeavourOS systemd[1]: Reached target System Reboot.
Nov 13 17:38:13 endeavourOS systemd[1]: Shutting down.
Nov 13 17:38:13 endeavourOS systemd[1]: Using hardware watchdog 'iTCO_wdt', version 0, device /dev/watchdog
Nov 13 17:38:13 endeavourOS systemd[1]: Set hardware watchdog to 10min.
Nov 13 17:38:13 endeavourOS kernel: watchdog: watchdog0: watchdog did not stop!
Nov 13 17:38:13 endeavourOS systemd-shutdown[1]: Syncing filesystems and block devices.
Nov 13 17:38:13 endeavourOS systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Nov 13 17:38:13 endeavourOS systemd-journald[254]: Journal stopped
lines 51-101/101 (END)
Edit: I run my terminal in window mode most times, I noticed the output cut a bunch of messages off, so I went full screen, ran the command again, so it’s easier to read now.
I’m still able to reboot just fine, but I still see these messages show, specifically the last 3 lines only started to display after a systemd update. The watchdog messages I’m not concerned about. It’s a random issues I’ve seen people report earlier this year and last year and ever before that, but for whatever reason it only started to show up for me this year.
[ 40.550004] watchdog: watchdog0: watchdog did not stop!
[ 40.719409] watchdog: watchdog0: watchdog did not stop!
[ 40.769894] sd-unmoun[1704]: Failed to unmount /oldroot: Device or resource busy
[ 40.770754] sd-unomun[1785]: Failed to unmount /oldroot/sys: Device or resource busy
[ 40.771918] shutdown[1]: Failed to finalize file systems, ignoring.
Yeah, systemd just updated yesterday, and /oldroot is a systemd thing. There have been several times in the past few years that systemd has had bugs involving the unmounting of /oldroot.
If you’re not seeing any specific issues, if it were me, I would wait and see if there is a systemd update in the next few days. I would suspect a bug that has been around in the past has shown its head again. That’s just what I would do, feel free to do whatever you feel is best for your system.
If it persists, and there are no bug reports on systemd’s github site, then you might want to dig in deeper.
Yeah that’s some pretty solid advice, thank you. There’s been maybe one or two systemd updates since then, but it has’t removed these messages. Luckily I haven’t noticed any issues at all other than these shutdown messages.
Just checked out the systemd github, they’ve got over 1.5k issues at the moment. I’ll see if my issue has already been reported recently and if not I’ll create a new issue if need be and just go from there. In the meantime, thanks again for all your help, very much appreciate it and I learned a little bit more today so thank you
The messages suggest that your / partition may not be unmounted cleanly before shutdown. This could prove problematic, causing corruption; assuming it is a temporary issue, though, I personally wouldn’t sweat it. If you get fsck warnings, or you see a list of orphaned inodes on your boot, then you may want to dig deeper, like, right away .
I have learned that systemd bugs generally tend to get sorted out pretty quickly, and again, if it were me, I would assume that the fact that these warnings first appeared after a systemd update means it’s probably a systemd bug.
I’ll for sure keep an eye on any boot messages like that and let y’all know. I think I’ll wait for the next systemd update and if I still see it I’ll report it to them upstream. Thanks again!
