Hi, I’ve been trying to setup my (wired) headphones successfully on EOS (KDE) for the past few days without luck.
My issue is that the headphones are listed as “Headphones (unplugged)” in both pavucontrol as well as the audio settings of KDE.
But, when I select that as an output channel instead of my laptop speakers, and tap the volume bar (which tests the audio with pop sounds), the headphones do play the sounds.
What is weirder is that every time, given enough time (like 15-20 minutes from login), it suddenly recognizes the headphones when I check the sound settings again and then it plays using it without any issues (including while typing this very post).
I’ve tried alsamixer, which has entries for sound cards as shown:
- (default)
default:0 HDA Intel PCH
Selecting the first one (which is default), it gives only one slider labelled “Master” going from 0-100 and changing it only changes the speaker volume.
Selecting the second entry gives 8 sliders, first being for “Headphone”, second to “Speaker”, and third for “PCM” and so on.
When the headphones are detected as “unplugged”, increasing “Headphone” volume (it starts from 0) does allow audio to start playing at specified volume in my headphones, but at the same time it also plays it with the same volume on my speakers as well. Also, muting the speakers in this situation mutes both headphones and speaker as well.
I don’t exactly know what details to put here, so I’ll add the details I saw in other similar forum posts. Please do let me know if you need anything else.
$ pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 681
Tile Size: 65472
User Name: resyfer
Host Name: EOS
Server Name: PulseAudio (on PipeWire 1.0.0)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_1f.3.analog-stereo
Default Source: alsa_input.pci-0000_00_1f.3.analog-stereo
Cookie: 72df:2f8e
$ inxi -Fzx 130 ↵
Kernel: 6.6.9-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: KDE Plasma v: 5.27.10 Distro: EndeavourOS base: Arch Linux
Type: Laptop System: Dell product: Inspiron 3501 v: N/A
serial: <superuser required>
Mobo: Dell model: 0XGX0C v: A00 serial: <superuser required> UEFI: Dell
v: 1.27.1 date: 10/03/2023
Battery:
ID-1: BAT0 charge: 29.6 Wh (100.0%) condition: 29.6/42.0 Wh (70.5%)
volts: 12.6 min: 11.4 model: SMP DELL VM73283 status: full
Info: quad core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake rev: 1 cache: L1: 320 KiB L2: 5 MiB L3: 8 MiB
Speed (MHz): avg: 549 high: 850 min/max: 400/4200 cores: 1: 400 2: 733
3: 400 4: 400 5: 813 6: 400 7: 400 8: 850 bogomips: 38720
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Gen-12.1 bus-ID: 00:02.0
Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
bus-ID: 1-6:4
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3 driver: X:
loaded: modesetting dri: iris gpu: i915 resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: iris,swrast platforms:
active: x11,surfaceless,device inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
API: ALSA v: k6.6.9-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.0.0 status: active
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB bus-ID: 1-10:5
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.1 lmp-v: 10
Local Storage: total: 1.14 TiB used: 135.79 GiB (11.6%)
ID-1: /dev/nvme0n1 vendor: A-Data model: IM2P33F3A NVMe 256GB
size: 238.47 GiB temp: 29.9 C
ID-2: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
ID-1: / size: 75.44 GiB used: 13.53 GiB (17.9%) fs: xfs dev: /dev/nvme0n1p6
ID-2: /boot/efi size: 511 MiB used: 300 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p4
ID-3: /home size: 400 GiB used: 122.26 GiB (30.6%) fs: btrfs
dev: /dev/sda3
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p5
System Temperatures: cpu: 56.0 C mobo: 41.0 C
Fan Speeds (rpm): cpu: 0
Processes: 265 Uptime: 8m Memory: total: 8 GiB note: est.
available: 7.49 GiB used: 2.63 GiB (35.1%) Init: systemd Compilers:
gcc: 13.2.1 Packages: 1216 Shell: Zsh v: 5.9 inxi: 3.3.31
