I am using KDE Plasma, installed by the EOS Calamares installer. From last couple of weeks, I have been having this issue where my wired headphones are not being detected by PipeWire / AlsaMixer / Plasma Audio Settings.
- Doesn’t show up as a sound card in AlsaMixer
- Shows up in Plasma Audio Settings as
Headphones (Unplugged)
The weird part is that when I select the Headphones (Unplugged) port in Plasma Audio Settings and use the test button to test front left and front right sounds, the headphone produces sound accordingly - including the distinct left right sounds and volume control.
Then after selecting the port, when I try to playback some other media, the playback stream disappears and no sound is produced.
I am in a bit of a pickle and can’t figure out what is wrong after trying to read many posts on this as well as other forums so here I am. Kindly help and let me know if I need to provide more information.
My System Information - output from inxi -Fxxc0z
Kernel: 6.5.5-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop K3605VC_K3605VC
v: 1.0 serial:
Mobo: ASUSTeK model: K3605VC v: 1.0 serial:
UEFI: American Megatrends LLC. v: K3605VC.305 date: 03/31/2023
Battery:
ID-1: BAT1 charge: 47.3 Wh (100.0%) condition: 47.3/50.1 Wh (94.4%)
volts: 13.0 min: 11.9 model: ASUS A32-K55 serial: N/A status: full
Info: 12-core (4-mt/8-st) model: 13th Gen Intel Core i5-13500H bits: 64
type: MST AMCP arch: Raptor Lake rev: 2 cache: L1: 1.1 MiB L2: 9 MiB
L3: 18 MiB
Speed (MHz): avg: 1114 high: 3400 min/max: 400/4700:3500 cores: 1: 3222
2: 535 3: 400 4: 400 5: 1022 6: 3400 7: 693 8: 1914 9: 400 10: 1857 11: 1571
12: 400 13: 400 14: 400 15: 817 16: 400 bogomips: 102016
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-13 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:a7a0
Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-7:3 chip-ID: 13d3:5463
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96
Monitor-1: eDP-1 model: BOE Display 0x0b2b res: 1920x1200 dpi: 141
diag: 407mm (16")
API: EGL v: 1.5 platforms: device: 0 drv: iris device: 1 drv: swrast gbm:
drv: iris surfaceless: drv: iris x11: drv: iris inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-P)
device-ID: 8086:a7a0
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: ASUSTeK
driver: sof-audio-pci-intel-tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:51ca
API: ALSA v: k6.5.5-arch1-1 status: kernel-api
Server-1: PipeWire v: 0.3.80 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f1
IF: wlan0 state: up mac:
IF-ID-1: CloudflareWARP state: unknown speed: 10000 Mbps duplex: full
mac: N/A
Bluetooth:
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 bus-ID: 1-10:4 chip-ID: 8087:0033
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: bt-v: 5.3 lmp-v: 12
RAID:
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f
Local Storage: total: 476.94 GiB used: 224.46 GiB (47.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVL4512HBLU-00BTW
size: 476.94 GiB speed: 63.2 Gb/s lanes: 4 serial: temp: 35.9 C
ID-1: / size: 73.27 GiB used: 27.51 GiB (37.5%) fs: ext4 dev: /dev/nvme0n1p6
ID-2: /boot/efi size: 256 MiB used: 84.8 MiB (33.1%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (rpm): cpu: 1500
Processes: 310 Uptime: 4h 3m Memory: total: 16 GiB available: 15.3 GiB
used: 4.32 GiB (28.2%) Init: systemd v: 254 default: graphical Compilers:
gcc: 13.2.1 Packages: pm: pacman pkgs: 1301 Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.30
