Also, I set this up with f2fs instead of ext4. For anyone interested in doing the same, you can see my post here… just one small edit to the installation instructions.
Ya there were a few quirks that I noticed so far. Otherwise, everything I tested seems to work well.
No xorg-server
No sudo
NetworkManager not enabled by default
No browser installed (that might be intentional)
Edit: Also, there was no EndeavourOS styling for the XFCE theme like the standard installers provide (again, maybe intentional) Edit2: I think it is failing to install dotfiles from endeavouros-xfce4-theming
Edit3: No welcome app installed, yay also missing
This is what the installation looks like by default for me (no EOS styling):
I had a problem recently with f2fs after setting up an encrypted file system on an SD card (after some use the structure needed cleaning, this happened twice so I gave up), but the SD card might me defective, ext4 also gives me trouble, only fat seems to work.
So probably it is nothing to do with f2fs but SD cards can be problematic.
