There is none that I know of. I have stated what I know.
dmseg
[mak@mak-pc ~]$ dmesg
[ 0.000000] Linux version 5.9.9-arch1-1 (linux@archlinux) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #1 SMP PREEMPT Wed, 18 Nov 2020 19:52:04 +0000
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=04b34b9c-f4f3-4981-a30e-af62594bbac4 rw quiet loglevel=3 nowatchdog
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] random: get_random_u32 called from bsp_init_amd+0x2b3/0x2f0 with crng_init=0
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009e7ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009e800-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bd06bfff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000bd06c000-0x00000000bd09bfff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000bd09c000-0x00000000bd0cefff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000bd0cf000-0x00000000bd189fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000bd18a000-0x00000000bd9f5fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000bd9f6000-0x00000000bd9f6fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000bd9f7000-0x00000000bdbfcfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000bdbfd000-0x00000000bdd53fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000bdd54000-0x00000000be947fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000be948000-0x00000000be97ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000be980000-0x00000000beff0fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000beff1000-0x00000000beffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000043effffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.8 present.
[ 0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./FM2A78M Pro4+, BIOS P2.40 02/05/2016
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 4192.321 MHz processor
[ 0.000704] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000705] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000711] last_pfn = 0x43f000 max_arch_pfn = 0x400000000
[ 0.000715] MTRR default type: uncachable
[ 0.000716] MTRR fixed ranges enabled:
[ 0.000717] 00000-9FFFF write-back
[ 0.000718] A0000-BFFFF write-through
[ 0.000718] C0000-CEFFF write-protect
[ 0.000719] CF000-E7FFF uncachable
[ 0.000720] E8000-FFFFF write-protect
[ 0.000720] MTRR variable ranges enabled:
[ 0.000721] 0 base 000000000000 mask FFFF80000000 write-back
[ 0.000723] 1 base 000080000000 mask FFFFC0000000 write-back
[ 0.000723] 2 disabled
[ 0.000723] 3 disabled
[ 0.000724] 4 disabled
[ 0.000724] 5 disabled
[ 0.000725] 6 disabled
[ 0.000725] 7 disabled
[ 0.000726] TOM2: 000000043f000000 aka 17392M
[ 0.001061] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001168] e820: update [mem 0xc0000000-0xffffffff] usable ==> reserved
[ 0.001173] last_pfn = 0xbf000 max_arch_pfn = 0x400000000
[ 0.005001] found SMP MP-table at [mem 0x000fd880-0x000fd88f]
[ 0.030550] check: Scanning 1 areas for low memory corruption
[ 0.030555] Using GB pages for direct mapping
[ 0.031071] RAMDISK: [mem 0x371e9000-0x378ebfff]
[ 0.031078] ACPI: Early table checksum verification disabled
[ 0.031082] ACPI: RSDP 0x00000000000F04A0 000024 (v02 ALASKA)
[ 0.031085] ACPI: XSDT 0x00000000BD153088 00008C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.031090] ACPI: FACP 0x00000000BD159AD0 00010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.031094] ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20200717/tbfadt-615)
[ 0.031097] ACPI: DSDT 0x00000000BD1531A8 006922 (v02 ALASKA A M I 00000000 INTL 20051117)
[ 0.031100] ACPI: FACS 0x00000000BD180F80 000040
[ 0.031102] ACPI: APIC 0x00000000BD159BE0 00007E (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.031104] ACPI: FPDT 0x00000000BD159C60 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.031106] ACPI: FIDT 0x00000000BD159CA8 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.031108] ACPI: MCFG 0x00000000BD159D48 00003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.031111] ACPI: HPET 0x00000000BD159D88 000038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.031113] ACPI: AAFT 0x00000000BD159DC0 0002BC (v01 ALASKA OEMAAFT 01072009 MSFT 00000097)
[ 0.031115] ACPI: UEFI 0x00000000BD15A080 000042 (v01 ALASKA A M I 01072009 00000000)
[ 0.031117] ACPI: SSDT 0x00000000BD15A0C8 000EE4 (v01 AMD BANTRY 00000001 AMD 00000001)
[ 0.031119] ACPI: SSDT 0x00000000BD15AFB0 000346 (v02 AMD BANTRY 00000002 MSFT 04000000)
[ 0.031121] ACPI: CRAT 0x00000000BD15B2F8 000528 (v01 AMD BANTRY 00000001 AMD 00000001)
[ 0.031123] ACPI: SSDT 0x00000000BD15B820 0016E4 (v01 AMD CPMCMN 00000001 INTL 20051117)
[ 0.031125] ACPI: SSDT 0x00000000BD15CF08 001519 (v01 AMD CPMDFIGP 00000001 INTL 20051117)
[ 0.031133] ACPI: Local APIC address 0xfee00000
[ 0.031175] No NUMA configuration found
[ 0.031176] Faking a node at [mem 0x0000000000000000-0x000000043effffff]
[ 0.031179] NODE_DATA(0) allocated [mem 0x43effa000-0x43effdfff]
[ 0.031210] Zone ranges:
[ 0.031211] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.031212] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.031213] Normal [mem 0x0000000100000000-0x000000043effffff]
[ 0.031214] Device empty
[ 0.031214] Movable zone start for each node
[ 0.031215] Early memory node ranges
[ 0.031216] node 0: [mem 0x0000000000001000-0x000000000009dfff]
[ 0.031217] node 0: [mem 0x0000000000100000-0x00000000bd06bfff]
[ 0.031217] node 0: [mem 0x00000000bd09c000-0x00000000bd0cefff]
[ 0.031218] node 0: [mem 0x00000000bd9f6000-0x00000000bd9f6fff]
[ 0.031219] node 0: [mem 0x00000000bdbfd000-0x00000000bdd53fff]
[ 0.031219] node 0: [mem 0x00000000be948000-0x00000000be97ffff]
[ 0.031219] node 0: [mem 0x00000000beff1000-0x00000000beffffff]
[ 0.031220] node 0: [mem 0x0000000100000000-0x000000043effffff]
[ 0.031382] Zeroed struct page in unavailable ranges: 15909 pages
[ 0.031383] Initmem setup node 0 [mem 0x0000000000001000-0x000000043effffff]
[ 0.031384] On node 0 totalpages: 4178395
[ 0.031385] DMA zone: 64 pages used for memmap
[ 0.031385] DMA zone: 21 pages reserved
[ 0.031386] DMA zone: 3997 pages, LIFO batch:0
[ 0.031420] DMA32 zone: 12041 pages used for memmap
[ 0.031420] DMA32 zone: 770622 pages, LIFO batch:63
[ 0.040953] Normal zone: 53184 pages used for memmap
[ 0.040954] Normal zone: 3403776 pages, LIFO batch:63
[ 0.083182] ACPI: PM-Timer IO Port: 0x808
[ 0.083183] ACPI: Local APIC address 0xfee00000
[ 0.083188] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.083196] IOAPIC[0]: apic_id 0, version 33, address 0xfec00000, GSI 0-23
[ 0.083199] IOAPIC[1]: apic_id 1, version 33, address 0xfec01000, GSI 24-55
[ 0.083200] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.083202] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.083203] ACPI: IRQ0 used by override.
[ 0.083204] ACPI: IRQ9 used by override.
[ 0.083205] Using ACPI (MADT) for SMP configuration information
[ 0.083206] ACPI: HPET id: 0x10228210 base: 0xfed00000
[ 0.083210] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.083232] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.083233] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009efff]
[ 0.083234] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.083234] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.083235] PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.083236] PM: hibernation: Registered nosave memory: [mem 0xbd06c000-0xbd09bfff]
[ 0.083237] PM: hibernation: Registered nosave memory: [mem 0xbd0cf000-0xbd189fff]
[ 0.083238] PM: hibernation: Registered nosave memory: [mem 0xbd18a000-0xbd9f5fff]
[ 0.083239] PM: hibernation: Registered nosave memory: [mem 0xbd9f7000-0xbdbfcfff]
[ 0.083240] PM: hibernation: Registered nosave memory: [mem 0xbdd54000-0xbe947fff]
[ 0.083242] PM: hibernation: Registered nosave memory: [mem 0xbe980000-0xbeff0fff]
[ 0.083243] PM: hibernation: Registered nosave memory: [mem 0xbf000000-0xdfffffff]
[ 0.083244] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.083244] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfeb7ffff]
[ 0.083244] PM: hibernation: Registered nosave memory: [mem 0xfeb80000-0xfec01fff]
[ 0.083245] PM: hibernation: Registered nosave memory: [mem 0xfec02000-0xfec0ffff]
[ 0.083245] PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[ 0.083246] PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfecfffff]
[ 0.083246] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ 0.083247] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed3ffff]
[ 0.083247] PM: hibernation: Registered nosave memory: [mem 0xfed40000-0xfed44fff]
[ 0.083248] PM: hibernation: Registered nosave memory: [mem 0xfed45000-0xfed7ffff]
[ 0.083248] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
[ 0.083248] PM: hibernation: Registered nosave memory: [mem 0xfed90000-0xfeffffff]
[ 0.083249] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.083251] [mem 0xbf000000-0xdfffffff] available for PCI devices
[ 0.083252] Booting paravirtualized kernel on bare hardware
[ 0.083255] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.086922] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[ 0.087296] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u524288
[ 0.087302] pcpu-alloc: s192512 r8192 d28672 u524288 alloc=1*2097152
[ 0.087303] pcpu-alloc: [0] 0 1 2 3
[ 0.087323] Built 1 zonelists, mobility grouping on. Total pages: 4113085
[ 0.087324] Policy zone: Normal
[ 0.087325] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=04b34b9c-f4f3-4981-a30e-af62594bbac4 rw quiet loglevel=3 nowatchdog
[ 0.090260] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.091697] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.091720] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[ 0.159877] Memory: 16317572K/16713580K available (14339K kernel code, 1505K rwdata, 7948K rodata, 1660K init, 2944K bss, 395748K reserved, 0K cma-reserved)
[ 0.159992] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.160003] ftrace: allocating 40882 entries in 160 pages
[ 0.172960] ftrace: allocated 160 pages with 2 groups
[ 0.173091] rcu: Preemptible hierarchical RCU implementation.
[ 0.173091] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.173092] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[ 0.173093] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.173094] Trampoline variant of Tasks RCU enabled.
[ 0.173094] Rude variant of Tasks RCU enabled.
[ 0.173095] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.173095] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.176186] NR_IRQS: 20736, nr_irqs: 1000, preallocated irqs: 16
[ 0.176428] spurious 8259A interrupt: IRQ7.
[ 0.176444] Console: colour dummy device 80x25
[ 0.176448] printk: console [tty0] enabled
[ 0.176465] ACPI: Core revision 20200717
[ 0.176555] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.176568] APIC: Switch to symmetric I/O mode setup
[ 0.176968] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.193235] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x3c6e0aef3f6, max_idle_ns: 440795228885 ns
[ 0.193240] Calibrating delay loop (skipped), value calculated using timer frequency.. 8387.00 BogoMIPS (lpj=13974403)
[ 0.193242] pid_max: default: 32768 minimum: 301
[ 0.193267] LSM: Security Framework initializing
[ 0.193271] Yama: becoming mindful.
[ 0.193329] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.193376] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.193611] LVT offset 1 assigned for vector 0xf9
[ 0.193617] Last level iTLB entries: 4KB 512, 2MB 1024, 4MB 512
[ 0.193618] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 512, 1GB 0
[ 0.193621] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.193622] Spectre V2 : Mitigation: Full AMD retpoline
[ 0.193622] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.193624] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.193843] Freeing SMP alternatives memory: 32K
[ 0.305454] smpboot: CPU0: AMD Athlon(tm) X4 880K Quad Core Processor (family: 0x15, model: 0x38, stepping: 0x1)
[ 0.305565] Performance Events: Fam15h core perfctr, AMD PMU driver.
[ 0.305568] ... version: 0
[ 0.305569] ... bit width: 48
[ 0.305569] ... generic registers: 6
[ 0.305570] ... value mask: 0000ffffffffffff
[ 0.305570] ... max period: 00007fffffffffff
[ 0.305571] ... fixed-purpose events: 0
[ 0.305571] ... event mask: 000000000000003f
[ 0.305610] rcu: Hierarchical SRCU implementation.
[ 0.305864] smp: Bringing up secondary CPUs ...
[ 0.306001] x86: Booting SMP configuration:
[ 0.306002] .... node #0, CPUs: #1 #2 #3
[ 0.309943] smp: Brought up 1 node, 4 CPUs
[ 0.309943] smpboot: Max logical packages: 1
[ 0.309943] smpboot: Total of 4 processors activated (33551.00 BogoMIPS)
[ 0.311191] devtmpfs: initialized
[ 0.311191] x86/mm: Memory block size: 128MB
[ 0.313365] PM: Registering ACPI NVS region [mem 0xbd0cf000-0xbd189fff] (765952 bytes)
[ 0.313365] PM: Registering ACPI NVS region [mem 0xbd9f7000-0xbdbfcfff] (2121728 bytes)
[ 0.313481] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.313481] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.313481] pinctrl core: initialized pinctrl subsystem
[ 0.313481] PM: RTC time: 18:16:19, date: 2020-11-21
[ 0.313518] NET: Registered protocol family 16
[ 0.313904] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.314300] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.314451] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.314451] audit: initializing netlink subsys (disabled)
[ 0.314451] audit: type=2000 audit(1605982579.136:1): state=initialized audit_enabled=0 res=1
[ 0.314451] thermal_sys: Registered thermal governor 'fair_share'
[ 0.314451] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.314451] thermal_sys: Registered thermal governor 'step_wise'
[ 0.314451] thermal_sys: Registered thermal governor 'user_space'
[ 0.314451] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.314451] cpuidle: using governor ladder
[ 0.314451] cpuidle: using governor menu
[ 0.314451] ACPI: bus type PCI registered
[ 0.314451] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.314451] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.314451] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.314451] PCI: Using configuration type 1 for base access
[ 0.314451] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.314451] mtrr: probably your BIOS does not setup all CPUs.
[ 0.314451] mtrr: corrected configuration.
[ 0.317502] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.317502] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.317502] ACPI: Added _OSI(Module Device)
[ 0.317502] ACPI: Added _OSI(Processor Device)
[ 0.317502] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.317502] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.317502] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.317502] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.317502] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.323577] ACPI: 5 ACPI AML tables successfully acquired and loaded
[ 0.325306] ACPI: Interpreter enabled
[ 0.325330] ACPI: (supports S0 S3 S4 S5)
[ 0.325331] ACPI: Using IOAPIC for interrupt routing
[ 0.325382] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.325678] ACPI: Enabled 8 GPEs in block 00 to 1F
[ 0.332756] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.332762] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.333027] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.333421] PCI host bridge to bus 0000:00
[ 0.333423] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.333424] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.333425] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.333426] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.333427] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.333428] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[ 0.333429] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfed3ffff window]
[ 0.333430] pci_bus 0000:00: root bus resource [mem 0xfed45000-0xffffffff window]
[ 0.333431] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.333442] pci 0000:00:00.0: [1022:1422] type 00 class 0x060000
[ 0.333562] pci 0000:00:02.0: [1022:1424] type 00 class 0x060000
[ 0.333647] pci 0000:00:03.0: [1022:1424] type 00 class 0x060000
[ 0.333729] pci 0000:00:03.1: [1022:1426] type 01 class 0x060400
[ 0.333749] pci 0000:00:03.1: enabling Extended Tags
[ 0.333776] pci 0000:00:03.1: PME# supported from D0 D3hot D3cold
[ 0.333887] pci 0000:00:04.0: [1022:1424] type 00 class 0x060000
[ 0.333995] pci 0000:00:10.0: [1022:7814] type 00 class 0x0c0330
[ 0.334015] pci 0000:00:10.0: reg 0x10: [mem 0xfeb06000-0xfeb07fff 64bit]
[ 0.334108] pci 0000:00:10.0: PME# supported from D0 D3hot D3cold
[ 0.334228] pci 0000:00:10.1: [1022:7814] type 00 class 0x0c0330
[ 0.334247] pci 0000:00:10.1: reg 0x10: [mem 0xfeb04000-0xfeb05fff 64bit]
[ 0.334340] pci 0000:00:10.1: PME# supported from D0 D3hot D3cold
[ 0.334456] pci 0000:00:11.0: [1022:7801] type 00 class 0x010601
[ 0.334468] pci 0000:00:11.0: reg 0x10: [io 0xf090-0xf097]
[ 0.334475] pci 0000:00:11.0: reg 0x14: [io 0xf080-0xf083]
[ 0.334482] pci 0000:00:11.0: reg 0x18: [io 0xf070-0xf077]
[ 0.334488] pci 0000:00:11.0: reg 0x1c: [io 0xf060-0xf063]
[ 0.334495] pci 0000:00:11.0: reg 0x20: [io 0xf050-0xf05f]
[ 0.334502] pci 0000:00:11.0: reg 0x24: [mem 0xfeb0d000-0xfeb0d7ff]
[ 0.334620] pci 0000:00:12.0: [1022:7807] type 00 class 0x0c0310
[ 0.334632] pci 0000:00:12.0: reg 0x10: [mem 0xfeb0c000-0xfeb0cfff]
[ 0.334763] pci 0000:00:12.2: [1022:7808] type 00 class 0x0c0320
[ 0.334775] pci 0000:00:12.2: reg 0x10: [mem 0xfeb0b000-0xfeb0b0ff]
[ 0.334835] pci 0000:00:12.2: supports D1 D2
[ 0.334836] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.334927] pci 0000:00:13.0: [1022:7807] type 00 class 0x0c0310
[ 0.334939] pci 0000:00:13.0: reg 0x10: [mem 0xfeb0a000-0xfeb0afff]
[ 0.335069] pci 0000:00:13.2: [1022:7808] type 00 class 0x0c0320
[ 0.335081] pci 0000:00:13.2: reg 0x10: [mem 0xfeb09000-0xfeb090ff]
[ 0.335142] pci 0000:00:13.2: supports D1 D2
[ 0.335142] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.335234] pci 0000:00:14.0: [1022:780b] type 00 class 0x0c0500
[ 0.335348] pci 0000:00:14.1: [1022:780c] type 00 class 0x01018a
[ 0.335360] pci 0000:00:14.1: reg 0x10: [io 0xf040-0xf047]
[ 0.335367] pci 0000:00:14.1: reg 0x14: [io 0xf030-0xf033]
[ 0.335373] pci 0000:00:14.1: reg 0x18: [io 0xf020-0xf027]
[ 0.335380] pci 0000:00:14.1: reg 0x1c: [io 0xf010-0xf013]
[ 0.335387] pci 0000:00:14.1: reg 0x20: [io 0xf000-0xf00f]
[ 0.335402] pci 0000:00:14.1: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ 0.335403] pci 0000:00:14.1: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ 0.335404] pci 0000:00:14.1: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ 0.335405] pci 0000:00:14.1: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ 0.335492] pci 0000:00:14.2: [1022:780d] type 00 class 0x040300
[ 0.335507] pci 0000:00:14.2: reg 0x10: [mem 0xfeb00000-0xfeb03fff 64bit]
[ 0.335558] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[ 0.335645] pci 0000:00:14.3: [1022:780e] type 00 class 0x060100
[ 0.335782] pci 0000:00:14.4: [1022:780f] type 01 class 0x060401
[ 0.335893] pci 0000:00:14.5: [1022:7809] type 00 class 0x0c0310
[ 0.335906] pci 0000:00:14.5: reg 0x10: [mem 0xfeb08000-0xfeb08fff]
[ 0.336035] pci 0000:00:15.0: [1022:43a0] type 01 class 0x060400
[ 0.336066] pci 0000:00:15.0: enabling Extended Tags
[ 0.336102] pci 0000:00:15.0: supports D1 D2
[ 0.336102] pci 0000:00:15.0: PME# supported from D0 D3hot D3cold
[ 0.336216] pci 0000:00:15.1: [1022:43a1] type 01 class 0x060400
[ 0.336246] pci 0000:00:15.1: enabling Extended Tags
[ 0.336282] pci 0000:00:15.1: supports D1 D2
[ 0.336283] pci 0000:00:15.1: PME# supported from D0 D3hot D3cold
[ 0.336391] pci 0000:00:18.0: [1022:141a] type 00 class 0x060000
[ 0.336464] pci 0000:00:18.1: [1022:141b] type 00 class 0x060000
[ 0.336533] pci 0000:00:18.2: [1022:141c] type 00 class 0x060000
[ 0.336606] pci 0000:00:18.3: [1022:141d] type 00 class 0x060000
[ 0.336686] pci 0000:00:18.4: [1022:141e] type 00 class 0x060000
[ 0.336755] pci 0000:00:18.5: [1022:141f] type 00 class 0x060000
[ 0.336875] pci 0000:01:00.0: [1002:67ef] type 00 class 0x030000
[ 0.336890] pci 0000:01:00.0: reg 0x10: [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.336900] pci 0000:01:00.0: reg 0x18: [mem 0xd0000000-0xd01fffff 64bit pref]
[ 0.336907] pci 0000:01:00.0: reg 0x20: [io 0xe000-0xe0ff]
[ 0.336913] pci 0000:01:00.0: reg 0x24: [mem 0xfea00000-0xfea3ffff]
[ 0.336920] pci 0000:01:00.0: reg 0x30: [mem 0xfea40000-0xfea5ffff pref]
[ 0.336925] pci 0000:01:00.0: enabling Extended Tags
[ 0.336991] pci 0000:01:00.0: supports D1 D2
[ 0.336992] pci 0000:01:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.337052] pci 0000:01:00.0: 16.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x4 link at 0000:00:03.1 (capable of 63.008 Gb/s with 8.0 GT/s PCIe x8 link)
[ 0.337098] pci 0000:01:00.1: [1002:aae0] type 00 class 0x040300
[ 0.337113] pci 0000:01:00.1: reg 0x10: [mem 0xfea60000-0xfea63fff 64bit]
[ 0.337146] pci 0000:01:00.1: enabling Extended Tags
[ 0.337192] pci 0000:01:00.1: supports D1 D2
[ 0.337285] pci 0000:00:03.1: PCI bridge to [bus 01]
[ 0.337288] pci 0000:00:03.1: bridge window [io 0xe000-0xefff]
[ 0.337289] pci 0000:00:03.1: bridge window [mem 0xfea00000-0xfeafffff]
[ 0.337292] pci 0000:00:03.1: bridge window [mem 0xc0000000-0xd01fffff 64bit pref]
[ 0.337301] pci_bus 0000:02: extended config space not accessible
[ 0.337351] pci 0000:00:14.4: PCI bridge to [bus 02] (subtractive decode)
[ 0.337357] pci 0000:00:14.4: bridge window [io 0x0000-0x03af window] (subtractive decode)
[ 0.337358] pci 0000:00:14.4: bridge window [io 0x03e0-0x0cf7 window] (subtractive decode)
[ 0.337359] pci 0000:00:14.4: bridge window [io 0x03b0-0x03df window] (subtractive decode)
[ 0.337360] pci 0000:00:14.4: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.337361] pci 0000:00:14.4: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.337362] pci 0000:00:14.4: bridge window [mem 0x000c0000-0x000dffff window] (subtractive decode)
[ 0.337363] pci 0000:00:14.4: bridge window [mem 0xc0000000-0xfed3ffff window] (subtractive decode)
[ 0.337364] pci 0000:00:14.4: bridge window [mem 0xfed45000-0xffffffff window] (subtractive decode)
[ 0.337419] pci 0000:03:00.0: [168c:002e] type 00 class 0x028000
[ 0.337443] pci 0000:03:00.0: reg 0x10: [mem 0xfe900000-0xfe90ffff 64bit]
[ 0.337567] pci 0000:03:00.0: supports D1
[ 0.337568] pci 0000:03:00.0: PME# supported from D0 D1 D3hot
[ 0.337689] pci 0000:00:15.0: PCI bridge to [bus 03]
[ 0.337694] pci 0000:00:15.0: bridge window [mem 0xfe900000-0xfe9fffff]
[ 0.337749] pci 0000:04:00.0: [1969:10a1] type 00 class 0x020000
[ 0.337774] pci 0000:04:00.0: reg 0x10: [mem 0xfe800000-0xfe83ffff 64bit]
[ 0.337785] pci 0000:04:00.0: reg 0x18: [io 0xd000-0xd07f]
[ 0.337894] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.337996] pci 0000:00:15.1: PCI bridge to [bus 04]
[ 0.338000] pci 0000:00:15.1: bridge window [io 0xd000-0xdfff]
[ 0.338002] pci 0000:00:15.1: bridge window [mem 0xfe800000-0xfe8fffff]
[ 0.338720] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 5 7 *10 11 14 15)
[ 0.338791] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 5 7 10 *11 14 15)
[ 0.338865] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 5 7 10 *11 14 15)
[ 0.338939] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 5 7 *10 11 14 15)
[ 0.338998] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 5 7 10 11 14 15) *0
[ 0.339044] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 5 7 10 11 14 15) *0
[ 0.339090] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 5 7 10 11 14 15) *0
[ 0.339136] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 5 7 10 11 14 15) *0
[ 0.339925] iommu: Default domain type: Translated
[ 0.339937] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.339937] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.339937] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.339937] vgaarb: loaded
[ 0.340101] SCSI subsystem initialized
[ 0.340144] libata version 3.00 loaded.
[ 0.340144] ACPI: bus type USB registered
[ 0.340144] usbcore: registered new interface driver usbfs
[ 0.340144] usbcore: registered new interface driver hub
[ 0.340144] usbcore: registered new device driver usb
[ 0.340144] pps_core: LinuxPPS API ver. 1 registered
[ 0.340144] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.340144] PTP clock support registered
[ 0.340144] EDAC MC: Ver: 3.0.0
[ 0.340144] NetLabel: Initializing
[ 0.340144] NetLabel: domain hash size = 128
[ 0.340144] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.340144] NetLabel: unlabeled traffic allowed by default
[ 0.340144] PCI: Using ACPI for IRQ routing
[ 0.348467] PCI: pci_cache_line_size set to 64 bytes
[ 0.348527] e820: reserve RAM buffer [mem 0x0009e800-0x0009ffff]
[ 0.348529] e820: reserve RAM buffer [mem 0xbd06c000-0xbfffffff]
[ 0.348530] e820: reserve RAM buffer [mem 0xbd0cf000-0xbfffffff]
[ 0.348531] e820: reserve RAM buffer [mem 0xbd9f7000-0xbfffffff]
[ 0.348532] e820: reserve RAM buffer [mem 0xbdd54000-0xbfffffff]
[ 0.348532] e820: reserve RAM buffer [mem 0xbe980000-0xbfffffff]
[ 0.348533] e820: reserve RAM buffer [mem 0xbf000000-0xbfffffff]
[ 0.348534] e820: reserve RAM buffer [mem 0x43f000000-0x43fffffff]
[ 0.348542] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.348542] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.350006] clocksource: Switched to clocksource tsc-early
[ 0.362414] VFS: Disk quotas dquot_6.6.0
[ 0.362426] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.362505] pnp: PnP ACPI init
[ 0.362659] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.362666] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.362736] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.362797] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.362926] system 00:03: [io 0x0290-0x029f] has been reserved
[ 0.362929] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.363268] pnp 00:04: [dma 3]
[ 0.363366] pnp 00:04: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.363503] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.363552] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.363680] system 00:07: [io 0x04d0-0x04d1] has been reserved
[ 0.363683] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.363915] pnp 00:08: [dma 0 disabled]
[ 0.363948] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.364197] system 00:09: [io 0x04d0-0x04d1] has been reserved
[ 0.364199] system 00:09: [io 0x040b] has been reserved
[ 0.364200] system 00:09: [io 0x04d6] has been reserved
[ 0.364201] system 00:09: [io 0x0c00-0x0c01] has been reserved
[ 0.364202] system 00:09: [io 0x0c14] has been reserved
[ 0.364203] system 00:09: [io 0x0c50-0x0c51] has been reserved
[ 0.364204] system 00:09: [io 0x0c52] has been reserved
[ 0.364205] system 00:09: [io 0x0c6c] has been reserved
[ 0.364205] system 00:09: [io 0x0c6f] has been reserved
[ 0.364206] system 00:09: [io 0x0cd0-0x0cd1] has been reserved
[ 0.364207] system 00:09: [io 0x0cd2-0x0cd3] has been reserved
[ 0.364208] system 00:09: [io 0x0cd4-0x0cd5] has been reserved
[ 0.364209] system 00:09: [io 0x0cd6-0x0cd7] has been reserved
[ 0.364210] system 00:09: [io 0x0cd8-0x0cdf] has been reserved
[ 0.364211] system 00:09: [io 0x0800-0x089f] has been reserved
[ 0.364212] system 00:09: [io 0x0b20-0x0b3f] has been reserved
[ 0.364213] system 00:09: [io 0x0900-0x090f] has been reserved
[ 0.364214] system 00:09: [io 0x0910-0x091f] has been reserved
[ 0.364215] system 00:09: [io 0xfe00-0xfefe] has been reserved
[ 0.364217] system 00:09: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.364218] system 00:09: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.364219] system 00:09: [mem 0xfed80000-0xfed8ffff] has been reserved
[ 0.364222] system 00:09: [mem 0xfed61000-0xfed70fff] has been reserved
[ 0.364223] system 00:09: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.364224] system 00:09: [mem 0xff000000-0xffffffff] has been reserved
[ 0.364228] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.364433] pnp: PnP ACPI: found 10 devices
[ 0.370550] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.370599] NET: Registered protocol family 2
[ 0.370777] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.370961] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.371267] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.371329] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.371551] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.371635] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.371701] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.371793] NET: Registered protocol family 1
[ 0.371799] NET: Registered protocol family 44
[ 0.371827] pci 0000:00:03.1: PCI bridge to [bus 01]
[ 0.371832] pci 0000:00:03.1: bridge window [io 0xe000-0xefff]
[ 0.371835] pci 0000:00:03.1: bridge window [mem 0xfea00000-0xfeafffff]
[ 0.371838] pci 0000:00:03.1: bridge window [mem 0xc0000000-0xd01fffff 64bit pref]
[ 0.371841] pci 0000:00:14.4: PCI bridge to [bus 02]
[ 0.371850] pci 0000:00:15.0: PCI bridge to [bus 03]
[ 0.371853] pci 0000:00:15.0: bridge window [mem 0xfe900000-0xfe9fffff]
[ 0.371858] pci 0000:00:15.1: PCI bridge to [bus 04]
[ 0.371860] pci 0000:00:15.1: bridge window [io 0xd000-0xdfff]
[ 0.371863] pci 0000:00:15.1: bridge window [mem 0xfe800000-0xfe8fffff]
[ 0.371870] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.371871] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.371872] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.371873] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.371874] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.371875] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.371876] pci_bus 0000:00: resource 10 [mem 0xc0000000-0xfed3ffff window]
[ 0.371877] pci_bus 0000:00: resource 11 [mem 0xfed45000-0xffffffff window]
[ 0.371878] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.371879] pci_bus 0000:01: resource 1 [mem 0xfea00000-0xfeafffff]
[ 0.371880] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd01fffff 64bit pref]
[ 0.371882] pci_bus 0000:02: resource 4 [io 0x0000-0x03af window]
[ 0.371883] pci_bus 0000:02: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.371884] pci_bus 0000:02: resource 6 [io 0x03b0-0x03df window]
[ 0.371885] pci_bus 0000:02: resource 7 [io 0x0d00-0xffff window]
[ 0.371886] pci_bus 0000:02: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.371887] pci_bus 0000:02: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.371888] pci_bus 0000:02: resource 10 [mem 0xc0000000-0xfed3ffff window]
[ 0.371888] pci_bus 0000:02: resource 11 [mem 0xfed45000-0xffffffff window]
[ 0.371889] pci_bus 0000:03: resource 1 [mem 0xfe900000-0xfe9fffff]
[ 0.371890] pci_bus 0000:04: resource 0 [io 0xd000-0xdfff]
[ 0.371891] pci_bus 0000:04: resource 1 [mem 0xfe800000-0xfe8fffff]
[ 0.450180] pci 0000:00:12.0: quirk_usb_early_handoff+0x0/0x6e0 took 76024 usecs
[ 0.466863] pci 0000:00:12.2: quirk_usb_early_handoff+0x0/0x6e0 took 16277 usecs
[ 0.466865] pci 0000:00:12.2: PME# does not work under D3, disabling it
[ 0.490208] pci 0000:00:13.0: quirk_usb_early_handoff+0x0/0x6e0 took 22781 usecs
[ 0.506837] pci 0000:00:13.2: quirk_usb_early_handoff+0x0/0x6e0 took 16224 usecs
[ 0.506840] pci 0000:00:13.2: PME# does not work under D3, disabling it
[ 0.533521] pci 0000:00:14.5: quirk_usb_early_handoff+0x0/0x6e0 took 26032 usecs
[ 0.533545] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.533580] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.533633] pci 0000:04:00.0: set MSI_INTX_DISABLE_BUG flag
[ 0.533635] PCI: CLS 64 bytes, default 64
[ 0.533704] Trying to unpack rootfs image as initramfs...
[ 1.118125] Freeing initrd memory: 7180K
[ 1.118133] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.118135] software IO TLB: mapped [mem 0xb906c000-0xbd06c000] (64MB)
[ 1.118179] amd_uncore: AMD NB counters detected
[ 1.118430] LVT offset 0 assigned for vector 0x400
[ 1.118464] perf: AMD IBS detected (0x000001ff)
[ 1.118522] check: Scanning for low memory corruption every 60 seconds
[ 1.118855] Initialise system trusted keyrings
[ 1.118865] Key type blacklist registered
[ 1.118944] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 1.120082] zbud: loaded
[ 1.128115] Key type asymmetric registered
[ 1.128116] Asymmetric key parser 'x509' registered
[ 1.128125] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 1.128174] io scheduler mq-deadline registered
[ 1.128175] io scheduler kyber registered
[ 1.128194] io scheduler bfq registered
[ 1.128546] pcieport 0000:00:03.1: PME: Signaling with IRQ 24
[ 1.128696] pcieport 0000:00:15.0: PME: Signaling with IRQ 25
[ 1.128826] pcieport 0000:00:15.1: PME: Signaling with IRQ 26
[ 1.128907] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.128974] vesafb: mode is 1920x1080x32, linelength=7680, pages=0
[ 1.128974] vesafb: scrolling: redraw
[ 1.128975] vesafb: Truecolor: size=0:8:8:8, shift=0:16:8:0
[ 1.129066] vesafb: framebuffer at 0xc0000000, mapped to 0x(____ptrval____), using 8128k, total 8128k
[ 1.129133] fbcon: Deferring console take-over
[ 1.129133] fb0: VESA VGA frame buffer device
[ 1.129200] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 1.129224] ACPI: Power Button [PWRB]
[ 1.129254] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 1.133307] ACPI: Power Button [PWRF]
[ 1.133466] ACPI: \_PR_.P000: Found 2 idle states
[ 1.133566] ACPI: \_PR_.P001: Found 2 idle states
[ 1.133685] ACPI: \_PR_.P002: Found 2 idle states
[ 1.133763] ACPI: \_PR_.P003: Found 2 idle states
[ 1.134032] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.134164] 00:08: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.135009] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 1.135010] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[ 1.135516] ahci 0000:00:11.0: version 3.0
[ 1.135736] ahci 0000:00:11.0: AHCI 0001.0300 32 slots 4 ports 6 Gbps 0xf impl SATA mode
[ 1.135738] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck led clo pmp pio slum part
[ 1.136150] scsi host0: ahci
[ 1.136271] scsi host1: ahci
[ 1.136382] scsi host2: ahci
[ 1.136495] scsi host3: ahci
[ 1.136551] ata1: SATA max UDMA/133 abar m2048@0xfeb0d000 port 0xfeb0d100 irq 27
[ 1.136553] ata2: SATA max UDMA/133 abar m2048@0xfeb0d000 port 0xfeb0d180 irq 27
[ 1.136555] ata3: SATA max UDMA/133 abar m2048@0xfeb0d000 port 0xfeb0d200 irq 27
[ 1.136556] ata4: SATA max UDMA/133 abar m2048@0xfeb0d000 port 0xfeb0d280 irq 27
[ 1.136620] usbcore: registered new interface driver usbserial_generic
[ 1.136623] usbserial: USB Serial support registered for generic
[ 1.136643] rtc_cmos 00:06: RTC can wake from S4
[ 1.136808] rtc_cmos 00:06: registered as rtc0
[ 1.136829] rtc_cmos 00:06: setting system clock to 2020-11-21T18:16:20 UTC (1605982580)
[ 1.136842] rtc_cmos 00:06: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.136918] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.136984] drop_monitor: Initializing network drop monitor service
[ 1.137130] NET: Registered protocol family 10
[ 1.141762] Segment Routing with IPv6
[ 1.141764] RPL Segment Routing with IPv6
[ 1.141790] NET: Registered protocol family 17
[ 1.141845] x86/pm: family 0x15 cpu detected, MSR saving is needed during suspending.
[ 1.142132] microcode: CPU0: patch_level=0x06003106
[ 1.142137] microcode: CPU1: patch_level=0x06003106
[ 1.142140] microcode: CPU2: patch_level=0x06003106
[ 1.142147] microcode: CPU3: patch_level=0x06003106
[ 1.142196] microcode: Microcode Update Driver: v2.2.
[ 1.142201] IPI shorthand broadcast: enabled
[ 1.142208] sched_clock: Marking stable (1142011098, 180707)->(1148595203, -6403398)
[ 1.142280] registered taskstats version 1
[ 1.142292] Loading compiled-in X.509 certificates
[ 1.145198] Loaded X.509 cert 'Build time autogenerated kernel key: 00e32af39d4a2635c8d60f93bbd3e041fd36fd45'
[ 1.145372] zswap: loaded using pool lz4/z3fold
[ 1.145552] Key type ._fscrypt registered
[ 1.145553] Key type .fscrypt registered
[ 1.145554] Key type fscrypt-provisioning registered
[ 1.145917] PM: Magic number: 12:239:292
[ 1.145942] tty tty25: hash matches
[ 1.146092] RAS: Correctable Errors collector initialized.
[ 1.393900] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.395983] ata3: SATA link down (SStatus 0 SControl 300)
[ 1.553415] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.553473] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.553821] ata1.00: supports DRM functions and may not be fully accessible
[ 1.554586] ata4.00: ATAPI: HL-DT-ST DVDRAM GH24NSD1, LB00, max UDMA/133
[ 1.554616] ata1.00: ATA-10: Crucial_CT275MX300SSD1, M0CR070, max UDMA/133
[ 1.554617] ata1.00: 537234768 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.556077] ata4.00: configured for UDMA/133
[ 1.556684] ata1.00: supports DRM functions and may not be fully accessible
[ 1.559263] ata1.00: configured for UDMA/133
[ 1.559474] scsi 0:0:0:0: Direct-Access ATA Crucial_CT275MX3 R070 PQ: 0 ANSI: 5
[ 1.559643] ata1.00: Enabling discard_zeroes_data
[ 1.559696] sd 0:0:0:0: [sda] 537234768 512-byte logical blocks: (275 GB/256 GiB)
[ 1.559706] sd 0:0:0:0: [sda] Write Protect is off
[ 1.559708] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.559720] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.559890] ata1.00: Enabling discard_zeroes_data
[ 1.560304] sda: sda1 sda2 sda3 sda4
[ 1.560397] scsi 3:0:0:0: CD-ROM HL-DT-ST DVDRAM GH24NSD1 LB00 PQ: 0 ANSI: 5
[ 1.560565] ata1.00: Enabling discard_zeroes_data
[ 1.560782] sd 0:0:0:0: [sda] supports TCG Opal
[ 1.560783] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.606237] Freeing unused decrypted memory: 2040K
[ 1.606704] Freeing unused kernel image (initmem) memory: 1660K
[ 1.606707] Write protecting the kernel read-only data: 24576k
[ 1.607373] Freeing unused kernel image (text/rodata gap) memory: 2044K
[ 1.607466] Freeing unused kernel image (rodata/data gap) memory: 244K
[ 1.639378] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.639385] Run /init as init process
[ 1.639386] with arguments:
[ 1.639387] /init
[ 1.639387] with environment:
[ 1.639388] HOME=/
[ 1.639388] TERM=linux
[ 1.639388] BOOT_IMAGE=/boot/vmlinuz-linux
[ 1.655758] fbcon: Taking over console
[ 1.655843] Console: switching to colour frame buffer device 240x67
[ 1.735562] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.735949] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.735950] Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
[ 1.736783] ehci-pci: EHCI PCI platform driver
[ 1.736938] QUIRK: Enable AMD PLL fix
[ 1.736965] ehci-pci 0000:00:12.2: EHCI Host Controller
[ 1.736971] ehci-pci 0000:00:12.2: new USB bus registered, assigned bus number 1
[ 1.736975] ehci-pci 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 1.736983] ehci-pci 0000:00:12.2: debug port 1
[ 1.737025] ehci-pci 0000:00:12.2: irq 17, io mem 0xfeb0b000
[ 1.743941] scsi host4: pata_atiixp
[ 1.746554] scsi host5: pata_atiixp
[ 1.746726] ata5: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xf000 irq 14
[ 1.746727] ata6: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xf008 irq 15
[ 1.749970] ehci-pci 0000:00:12.2: USB 2.0 started, EHCI 1.00
[ 1.750036] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[ 1.750038] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.750040] usb usb1: Product: EHCI Host Controller
[ 1.750041] usb usb1: Manufacturer: Linux 5.9.9-arch1-1 ehci_hcd
[ 1.750042] usb usb1: SerialNumber: 0000:00:12.2
[ 1.750195] hub 1-0:1.0: USB hub found
[ 1.750202] hub 1-0:1.0: 5 ports detected
[ 1.750406] xhci_hcd 0000:00:10.0: xHCI Host Controller
[ 1.750416] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2
[ 1.750591] xhci_hcd 0000:00:10.0: hcc params 0x014040c3 hci version 0x100 quirks 0x0000000000000418
[ 1.750841] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[ 1.750842] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.750844] usb usb2: Product: xHCI Host Controller
[ 1.750845] usb usb2: Manufacturer: Linux 5.9.9-arch1-1 xhci-hcd
[ 1.750846] usb usb2: SerialNumber: 0000:00:10.0
[ 1.750973] hub 2-0:1.0: USB hub found
[ 1.750982] hub 2-0:1.0: 2 ports detected
[ 1.751126] ehci-pci 0000:00:13.2: EHCI Host Controller
[ 1.751133] ehci-pci 0000:00:13.2: new USB bus registered, assigned bus number 3
[ 1.751138] ehci-pci 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 1.751150] ehci-pci 0000:00:13.2: debug port 1
[ 1.751169] xhci_hcd 0000:00:10.0: xHCI Host Controller
[ 1.751173] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 4
[ 1.751177] xhci_hcd 0000:00:10.0: Host supports USB 3.0 SuperSpeed
[ 1.751189] ehci-pci 0000:00:13.2: irq 17, io mem 0xfeb09000
[ 1.754020] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.754047] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
[ 1.754049] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.754050] usb usb4: Product: xHCI Host Controller
[ 1.754051] usb usb4: Manufacturer: Linux 5.9.9-arch1-1 xhci-hcd
[ 1.754052] usb usb4: SerialNumber: 0000:00:10.0
[ 1.754194] hub 4-0:1.0: USB hub found
[ 1.754203] hub 4-0:1.0: 2 ports detected
[ 1.763177] sr 3:0:0:0: [sr0] scsi3-mmc drive: 48x/12x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.763180] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.763261] ehci-pci 0000:00:13.2: USB 2.0 started, EHCI 1.00
[ 1.763323] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[ 1.763324] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.763325] usb usb3: Product: EHCI Host Controller
[ 1.763326] usb usb3: Manufacturer: Linux 5.9.9-arch1-1 ehci_hcd
[ 1.763327] usb usb3: SerialNumber: 0000:00:13.2
[ 1.763444] hub 3-0:1.0: USB hub found
[ 1.763451] hub 3-0:1.0: 5 ports detected
[ 1.763601] xhci_hcd 0000:00:10.1: xHCI Host Controller
[ 1.763612] xhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 5
[ 1.764628] ohci-pci: OHCI PCI platform driver
[ 1.764805] ohci-pci 0000:00:12.0: OHCI PCI host controller
[ 1.764810] ohci-pci 0000:00:12.0: new USB bus registered, assigned bus number 6
[ 1.764854] ohci-pci 0000:00:12.0: irq 18, io mem 0xfeb0c000
[ 1.765091] xhci_hcd 0000:00:10.1: hcc params 0x014040c3 hci version 0x100 quirks 0x0000000000000418
[ 1.765411] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[ 1.765413] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.765414] usb usb5: Product: xHCI Host Controller
[ 1.765415] usb usb5: Manufacturer: Linux 5.9.9-arch1-1 xhci-hcd
[ 1.765416] usb usb5: SerialNumber: 0000:00:10.1
[ 1.765766] hub 5-0:1.0: USB hub found
[ 1.765778] hub 5-0:1.0: 2 ports detected
[ 1.765971] xhci_hcd 0000:00:10.1: xHCI Host Controller
[ 1.765976] xhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 7
[ 1.765981] xhci_hcd 0000:00:10.1: Host supports USB 3.0 SuperSpeed
[ 1.767209] usb usb7: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.767232] usb usb7: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
[ 1.767234] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.767235] usb usb7: Product: xHCI Host Controller
[ 1.767236] usb usb7: Manufacturer: Linux 5.9.9-arch1-1 xhci-hcd
[ 1.767237] usb usb7: SerialNumber: 0000:00:10.1
[ 1.767339] hub 7-0:1.0: USB hub found
[ 1.767346] hub 7-0:1.0: 2 ports detected
[ 1.773629] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 1.824101] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.09
[ 1.824103] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.824104] usb usb6: Product: OHCI PCI host controller
[ 1.824105] usb usb6: Manufacturer: Linux 5.9.9-arch1-1 ohci_hcd
[ 1.824106] usb usb6: SerialNumber: 0000:00:12.0
[ 1.824264] hub 6-0:1.0: USB hub found
[ 1.824275] hub 6-0:1.0: 5 ports detected
[ 1.824606] ohci-pci 0000:00:13.0: OHCI PCI host controller
[ 1.824613] ohci-pci 0000:00:13.0: new USB bus registered, assigned bus number 8
[ 1.824643] ohci-pci 0000:00:13.0: irq 18, io mem 0xfeb0a000
[ 1.884126] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.09
[ 1.884128] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.884129] usb usb8: Product: OHCI PCI host controller
[ 1.884130] usb usb8: Manufacturer: Linux 5.9.9-arch1-1 ohci_hcd
[ 1.884131] usb usb8: SerialNumber: 0000:00:13.0
[ 1.884285] hub 8-0:1.0: USB hub found
[ 1.884295] hub 8-0:1.0: 5 ports detected
[ 1.884614] ohci-pci 0000:00:14.5: OHCI PCI host controller
[ 1.884621] ohci-pci 0000:00:14.5: new USB bus registered, assigned bus number 9
[ 1.884655] ohci-pci 0000:00:14.5: irq 18, io mem 0xfeb08000
[ 1.944288] usb usb9: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.09
[ 1.944290] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.944291] usb usb9: Product: OHCI PCI host controller
[ 1.944292] usb usb9: Manufacturer: Linux 5.9.9-arch1-1 ohci_hcd
[ 1.944293] usb usb9: SerialNumber: 0000:00:14.5
[ 1.944446] hub 9-0:1.0: USB hub found
[ 1.944458] hub 9-0:1.0: 2 ports detected
[ 2.070274] tsc: Refined TSC clocksource calibration: 4192.375 MHz
[ 2.070280] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x3c6e3ea513b, max_idle_ns: 440795291324 ns
[ 2.070301] clocksource: Switched to clocksource tsc
[ 2.080070] usb 2-2: new full-speed USB device number 2 using xhci_hcd
[ 2.127147] random: fast init done
[ 2.163675] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[ 2.247046] usb 2-2: New USB device found, idVendor=24ae, idProduct=1813, bcdDevice= 1.10
[ 2.247048] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.247050] usb 2-2: Product: Rapoo 2.4G Wireless Device
[ 2.247051] usb 2-2: Manufacturer: RAPOO
[ 2.313302] systemd[1]: systemd 246.6-1-arch running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 2.330212] systemd[1]: Detected architecture x86-64.
[ 2.351579] systemd[1]: Set hostname to <mak-pc>.
[ 2.360003] usb 6-4: new full-speed USB device number 2 using ohci-pci
[ 2.513210] systemd[1]: Queued start job for default target Graphical Interface.
[ 2.513481] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.514378] systemd[1]: Created slice system-getty.slice.
[ 2.514435] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.514625] systemd[1]: Created slice system-modprobe.slice.
[ 2.514636] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.514778] systemd[1]: Created slice User and Session Slice.
[ 2.514829] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.514866] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.515019] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.515054] systemd[1]: Reached target Local Encrypted Volumes.
[ 2.515068] systemd[1]: Reached target Login Prompts.
[ 2.515093] systemd[1]: Reached target Paths.
[ 2.515110] systemd[1]: Reached target Remote File Systems.
[ 2.515124] systemd[1]: Reached target Slices.
[ 2.515142] systemd[1]: Reached target Swap.
[ 2.515207] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 2.515487] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 2.515695] systemd[1]: Listening on LVM2 poll daemon socket.
[ 2.517682] systemd[1]: Listening on Process Core Dump Socket.
[ 2.517790] systemd[1]: Listening on Journal Audit Socket.
[ 2.517858] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.517934] systemd[1]: Listening on Journal Socket.
[ 2.518023] systemd[1]: Listening on udev Control Socket.
[ 2.518080] systemd[1]: Listening on udev Kernel Socket.
[ 2.518982] systemd[1]: Mounting Huge Pages File System...
[ 2.519898] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.521043] systemd[1]: Mounting Kernel Debug File System...
[ 2.522276] systemd[1]: Mounting Kernel Trace File System...
[ 2.523457] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 2.524594] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 2.525789] systemd[1]: Starting Load Kernel Module drm...
[ 2.526274] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 2.526326] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 2.528023] systemd[1]: Starting Journal Service...
[ 2.530637] systemd[1]: Starting Load Kernel Modules...
[ 2.531584] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 2.531653] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 2.532685] systemd[1]: Starting Coldplug All udev Devices...
[ 2.534184] systemd[1]: Mounted Huge Pages File System.
[ 2.534303] Linux agpgart interface v0.103
[ 2.534315] systemd[1]: Mounted POSIX Message Queue File System.
[ 2.534416] systemd[1]: Mounted Kernel Debug File System.
[ 2.534507] systemd[1]: Mounted Kernel Trace File System.
[ 2.534988] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 2.543699] usb 6-4: New USB device found, idVendor=3938, idProduct=1031, bcdDevice= 1.08
[ 2.543701] usb 6-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.543703] usb 6-4: Product: 2.4G Wireless Mouse
[ 2.543704] usb 6-4: Manufacturer: MOSART Semi.
[ 2.547074] EXT4-fs (sda3): re-mounted. Opts: (null)
[ 2.548719] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.548759] sr 3:0:0:0: Attached scsi generic sg1 type 5
[ 2.550160] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 2.550360] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 2.551722] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 2.552682] systemd[1]: Starting Load/Save Random Seed...
[ 2.553843] systemd[1]: Starting Create System Users...
[ 2.566661] systemd[1]: modprobe@drm.service: Succeeded.
[ 2.567177] systemd[1]: Finished Load Kernel Module drm.
[ 2.570952] Asymmetric key parser 'pkcs8' registered
[ 2.572153] systemd[1]: Finished Load Kernel Modules.
[ 2.572354] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 2.573384] systemd[1]: Mounting Kernel Configuration File System...
[ 2.574499] systemd[1]: Starting Apply Kernel Variables...
[ 2.576726] systemd[1]: Mounted Kernel Configuration File System.
[ 2.584046] systemd[1]: Finished Create System Users.
[ 2.585134] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 2.586884] systemd[1]: Finished Apply Kernel Variables.
[ 2.600592] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 2.602025] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 2.610878] systemd[1]: Finished Coldplug All udev Devices.
[ 2.985309] systemd[1]: Started Journal Service.
[ 2.985429] audit: type=1130 audit(1605982582.343:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.110363] audit: type=1130 audit(1605982582.470:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.125180] audit: type=1130 audit(1605982582.483:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.126373] audit: type=1130 audit(1605982582.483:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.202527] acpi_cpufreq: overriding BIOS provided _PSD data
[ 3.260759] parport_pc 00:04: reported by Plug and Play ACPI
[ 3.260806] parport0: PC-style at 0x378, irq 5 [PCSPP,EPP]
[ 3.262335] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 3.262337] piix4_smbus 0000:00:14.0: Using register 0x2e for SMBus port selection
[ 3.262468] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 3.286393] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 3.286511] sp5100-tco sp5100-tco: Using 0xfed80b00 for watchdog MMIO address
[ 3.288307] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 3.398720] input: PC Speaker as /devices/platform/pcspkr/input/input2
[ 3.401774] audit: type=1130 audit(1605982582.760:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.403516] alx 0000:04:00.0 eth0: Qualcomm Atheros AR816x/AR817x Ethernet [d0:50:99:07:f7:37]
[ 3.432513] cryptd: max_cpu_qlen set to 1000
[ 3.453506] fuse: init (API version 7.31)
[ 3.466966] audit: type=1130 audit(1605982582.823:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.478940] audit: type=1127 audit(1605982582.836:8): pid=376 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 3.484953] audit: type=1130 audit(1605982582.843:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.491171] audit: type=1130 audit(1605982582.850:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.515673] AVX version of gcm_enc/dec engaged.
[ 3.515675] AES CTR mode by8 optimization enabled
[ 3.639824] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.647689] snd_hda_intel 0000:01:00.1: Force to non-snoop mode
[ 3.660450] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 3.677839] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:01:00.1/sound/card1/input3
[ 3.677900] input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:01:00.1/sound/card1/input4
[ 3.677953] input: HDA ATI HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:01:00.1/sound/card1/input5
[ 3.678014] input: HDA ATI HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:01:00.1/sound/card1/input6
[ 3.678076] input: HDA ATI HDMI HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.1/0000:01:00.1/sound/card1/input7
[ 3.704075] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC892: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[ 3.704077] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 3.704079] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 3.704080] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 3.704081] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x1e/0x0
[ 3.704082] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 3.704083] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 3.704084] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 3.704085] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 3.725827] ppdev: user-space parallel port driver
[ 3.725938] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:14.2/sound/card0/input8
[ 3.725989] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input9
[ 3.726033] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input10
[ 3.726071] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:14.2/sound/card0/input11
[ 3.726112] input: HD-Audio Generic Line Out Front as /devices/pci0000:00/0000:00:14.2/sound/card0/input12
[ 3.726152] input: HD-Audio Generic Line Out Surround as /devices/pci0000:00/0000:00:14.2/sound/card0/input13
[ 3.726191] input: HD-Audio Generic Line Out CLFE as /devices/pci0000:00/0000:00:14.2/sound/card0/input14
[ 3.726233] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:14.2/sound/card0/input15
[ 3.866477] alx 0000:04:00.0 enp4s0: renamed from eth0
[ 3.984929] [drm] amdgpu kernel modesetting enabled.
[ 3.986499] amdgpu: Ignoring ACPI CRAT on non-APU system
[ 3.987782] Virtual CRAT table created for CPU
[ 3.987806] amdgpu: Topology: Add CPU node
[ 3.988857] checking generic (c0000000 7f0000) vs hw (c0000000 10000000)
[ 3.988858] fb0: switching to amdgpudrmfb from VESA VGA
[ 3.988932] Console: switching to colour dummy device 80x25
[ 3.988971] amdgpu 0000:01:00.0: vgaarb: deactivate vga console
[ 3.989104] [drm] initializing kernel modesetting (POLARIS11 0x1002:0x67EF 0x1787:0xA460 0xCF).
[ 3.989107] amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
[ 3.989118] [drm] register mmio base: 0xFEA00000
[ 3.989119] [drm] register mmio size: 262144
[ 3.989121] [drm] PCIE atomic ops is not supported
[ 3.989126] [drm] add ip block number 0 <vi_common>
[ 3.989127] [drm] add ip block number 1 <gmc_v8_0>
[ 3.989128] [drm] add ip block number 2 <tonga_ih>
[ 3.989129] [drm] add ip block number 3 <gfx_v8_0>
[ 3.989130] [drm] add ip block number 4 <sdma_v3_0>
[ 3.989131] [drm] add ip block number 5 <powerplay>
[ 3.989132] [drm] add ip block number 6 <dm>
[ 3.989133] [drm] add ip block number 7 <uvd_v6_0>
[ 3.989134] [drm] add ip block number 8 <vce_v3_0>
[ 3.989137] kfd kfd: skipped device 1002:67ef, PCI rejects atomics
[ 3.989382] amdgpu 0000:01:00.0: No more image in the PCI ROM
[ 3.989434] amdgpu: ATOM BIOS: 113-BAFFIN_PRO_160513_D5_2G_MH_SF_H_W82
[ 3.989451] [drm] UVD is enabled in VM mode
[ 3.989451] [drm] UVD ENC is enabled in VM mode
[ 3.989454] [drm] VCE enabled in VM mode
[ 3.989479] [drm] vm size is 64 GB, 2 levels, block size is 10-bit, fragment size is 9-bit
[ 3.992044] amdgpu 0000:01:00.0: amdgpu: VRAM: 2048M 0x000000F400000000 - 0x000000F47FFFFFFF (2048M used)
[ 3.992046] amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
[ 3.992055] [drm] Detected VRAM RAM=2048M, BAR=256M
[ 3.992057] [drm] RAM width 128bits GDDR5
[ 3.992122] [TTM] Zone kernel: Available graphics memory: 8165516 KiB
[ 3.992123] [TTM] Zone dma32: Available graphics memory: 2097152 KiB
[ 3.992124] [TTM] Initializing pool allocator
[ 3.992128] [TTM] Initializing DMA pool allocator
[ 3.992164] [drm] amdgpu: 2048M of VRAM memory ready
[ 3.992167] [drm] amdgpu: 3072M of GTT memory ready.
[ 3.992170] [drm] GART: num cpu pages 65536, num gpu pages 65536
[ 3.995658] [drm] PCIE GART of 256M enabled (table at 0x000000F4007E9000).
[ 4.002154] [drm] Chained IB support enabled!
[ 4.098245] amdgpu: hwmgr_sw_init smu backed is polaris10_smu
[ 4.114454] [drm] Found UVD firmware Version: 1.130 Family ID: 16
[ 4.128670] kvm: Nested Virtualization enabled
[ 4.128676] SVM: kvm: Nested Paging enabled
[ 4.135783] MCE: In-kernel MCE decoding enabled.
[ 4.148428] [drm] Found VCE firmware Version: 53.26 Binary ID: 3
[ 4.150199] EDAC amd64: F15h detected (node 0).
[ 4.150207] EDAC amd64: Error: F1 not found: device 0x1601 (broken BIOS?)
[ 4.201372] EDAC amd64: F15h detected (node 0).
[ 4.201382] EDAC amd64: Error: F1 not found: device 0x1601 (broken BIOS?)
[ 4.204516] hid: raw HID events driver (C) Jiri Kosina
[ 4.231962] usbcore: registered new interface driver usbhid
[ 4.231964] usbhid: USB HID core driver
[ 4.259784] [drm] DM_PPLIB: values for Engine clock
[ 4.259786] [drm] DM_PPLIB: 214000
[ 4.259786] [drm] DM_PPLIB: 481000
[ 4.259787] [drm] DM_PPLIB: 760000
[ 4.259788] [drm] DM_PPLIB: 1020000
[ 4.259789] [drm] DM_PPLIB: 1102000
[ 4.259789] [drm] DM_PPLIB: 1138000
[ 4.259790] [drm] DM_PPLIB: 1180000
[ 4.259791] [drm] DM_PPLIB: 1220000
[ 4.259792] [drm] DM_PPLIB: Validation clocks:
[ 4.259792] [drm] DM_PPLIB: engine_max_clock: 122000
[ 4.259793] [drm] DM_PPLIB: memory_max_clock: 175000
[ 4.259794] [drm] DM_PPLIB: level : 8
[ 4.259795] [drm] DM_PPLIB: values for Memory clock
[ 4.259796] [drm] DM_PPLIB: 300000
[ 4.259797] [drm] DM_PPLIB: 1750000
[ 4.259797] [drm] DM_PPLIB: Validation clocks:
[ 4.259798] [drm] DM_PPLIB: engine_max_clock: 122000
[ 4.259799] [drm] DM_PPLIB: memory_max_clock: 175000
[ 4.259799] [drm] DM_PPLIB: level : 8
[ 4.259864] [drm] dce110_link_encoder_construct: Failed to get encoder_cap_info from VBIOS with error code 4!
[ 4.259885] [drm] dce110_link_encoder_construct: Failed to get encoder_cap_info from VBIOS with error code 4!
[ 4.259898] [drm] Display Core initialized with v3.2.95!
[ 4.263873] EDAC amd64: F15h detected (node 0).
[ 4.263883] EDAC amd64: Error: F1 not found: device 0x1601 (broken BIOS?)
[ 4.293591] snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 4.320851] EDAC amd64: F15h detected (node 0).
[ 4.320861] EDAC amd64: Error: F1 not found: device 0x1601 (broken BIOS?)
[ 4.343885] ath: EEPROM regdomain: 0x809c
[ 4.343887] ath: EEPROM indicates we should expect a country code
[ 4.343888] ath: doing EEPROM country->regdmn map search
[ 4.343889] ath: country maps to regdmn code: 0x52
[ 4.343890] ath: Country alpha2 being used: CN
[ 4.343890] ath: Regpair used: 0x52
[ 4.345418] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 4.353726] ieee80211 phy0: Atheros AR9287 Rev:2 mem=0xffff9b67808b0000, irq=16
[ 4.431492] [drm] UVD and UVD ENC initialized successfully.
[ 4.543444] [drm] VCE initialized successfully.
[ 4.543451] amdgpu 0000:01:00.0: amdgpu: SE 2, SH per SE 1, CU per SH 8, active_cu_number 14
[ 4.545684] [drm] fb mappable at 0xC0D19000
[ 4.545685] [drm] vram apper at 0xC0000000
[ 4.545686] [drm] size 8294400
[ 4.545687] [drm] fb depth is 24
[ 4.545688] [drm] pitch is 7680
[ 4.545784] fbcon: amdgpudrmfb (fb0) is primary device
[ 4.593251] random: crng init done
[ 4.593253] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.601982] Console: switching to colour frame buffer device 240x67
[ 4.624389] amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 4.642735] [drm] Initialized amdgpu 3.39.0 20150101 for 0000:01:00.0 on minor 0
[ 5.019182] input: RAPOO Rapoo 2.4G Wireless Device as /devices/pci0000:00/0000:00:10.0/usb2/2-2/2-2:1.0/0003:24AE:1813.0001/input/input16
[ 5.073954] hid-generic 0003:24AE:1813.0001: input,hidraw0: USB HID v1.01 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-0000:00:10.0-2/input0
[ 5.074601] input: RAPOO Rapoo 2.4G Wireless Device Mouse as /devices/pci0000:00/0000:00:10.0/usb2/2-2/2-2:1.1/0003:24AE:1813.0002/input/input17
[ 5.074780] input: RAPOO Rapoo 2.4G Wireless Device Consumer Control as /devices/pci0000:00/0000:00:10.0/usb2/2-2/2-2:1.1/0003:24AE:1813.0002/input/input18
[ 5.130705] hid-generic 0003:24AE:1813.0002: input,hiddev0,hidraw1: USB HID v1.01 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-0000:00:10.0-2/input1
[ 5.130922] input: MOSART Semi. 2.4G Wireless Mouse as /devices/pci0000:00/0000:00:12.0/usb6/6-4/6-4:1.0/0003:3938:1031.0003/input/input20
[ 5.131027] input: MOSART Semi. 2.4G Wireless Mouse as /devices/pci0000:00/0000:00:12.0/usb6/6-4/6-4:1.0/0003:3938:1031.0003/input/input21
[ 5.131134] hid-generic 0003:3938:1031.0003: input,hiddev1,hidraw2: USB HID v1.10 Mouse [MOSART Semi. 2.4G Wireless Mouse] on usb-0000:00:12.0-4/input0
[ 5.140607] mousedev: PS/2 mouse device common for all mice
[ 5.317348] kauditd_printk_skb: 25 callbacks suppressed
[ 5.317350] audit: type=1101 audit(1605982584.676:36): pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="mak" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.317407] audit: type=1103 audit(1605982584.676:37): pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="mak" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 5.317430] audit: type=1006 audit(1605982584.676:38): pid=769 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 5.319670] audit: type=1105 audit(1605982584.676:39): pid=769 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="mak" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.327236] audit: type=1334 audit(1605982584.686:40): prog-id=11 op=LOAD
[ 5.327240] audit: type=1334 audit(1605982584.686:41): prog-id=11 op=UNLOAD
[ 5.404133] audit: type=1130 audit(1605982584.763:42): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.435655] audit: type=1130 audit(1605982584.793:43): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.463584] audit: type=1105 audit(1605982584.823:44): pid=680 uid=0 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="mak" exe="/usr/lib/gdm-session-worker" hostname=mak-pc addr=? terminal=/dev/tty2 res=success'
[ 6.691164] wlan0: authenticate with 04:bf:6d:53:88:3e
[ 6.714655] wlan0: send auth to 04:bf:6d:53:88:3e (try 1/3)
[ 6.716518] wlan0: authenticated
[ 6.719943] wlan0: associate with 04:bf:6d:53:88:3e (try 1/3)
[ 6.725950] wlan0: RX AssocResp from 04:bf:6d:53:88:3e (capab=0x411 status=0 aid=2)
[ 6.726153] wlan0: associated
[ 7.938449] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 8.601171] audit: type=1334 audit(1605982587.960:45): prog-id=12 op=LOAD
[ 9.747294] rfkill: input handler disabled
[ 10.814761] kauditd_printk_skb: 9 callbacks suppressed
[ 10.814763] audit: type=1130 audit(1605982590.173:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 15.011294] audit: type=1131 audit(1605982594.370:56): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 34.288504] audit: type=1334 audit(1605982613.646:57): prog-id=16 op=LOAD
[ 34.288685] audit: type=1334 audit(1605982613.646:58): prog-id=17 op=LOAD
[ 34.773594] audit: type=1130 audit(1605982614.126:59): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.544113] audit: type=1131 audit(1605982619.683:60): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.651225] audit: type=1334 audit(1605982619.787:61): prog-id=10 op=UNLOAD
[ 40.651230] audit: type=1334 audit(1605982619.787:62): prog-id=9 op=UNLOAD
[ 41.083431] audit: type=1131 audit(1605982620.210:63): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 41.198486] audit: type=1334 audit(1605982620.321:64): prog-id=15 op=UNLOAD
[ 41.198494] audit: type=1334 audit(1605982620.321:65): prog-id=14 op=UNLOAD
[ 65.208608] audit: type=1131 audit(1605982644.168:66): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 65.228636] audit: type=1334 audit(1605982644.188:67): prog-id=17 op=UNLOAD
[ 65.228642] audit: type=1334 audit(1605982644.188:68): prog-id=16 op=UNLOAD
[ 69.411123] audit: type=1131 audit(1605982648.367:69): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
journalclt of a boot I know it did not power off.
