Get a room you two.
For aur i only browe with pkgbrowser and yup as a ncurses aur helper
For AUR, I browse with https://aur.archlinux.org/ and yay.
I have pamac and no issues that i know of. It would be nice to know what you are trying to install? It works for me on 3 different computers so i donât know what the issue is but i have no idea what you have installed on your systems, what the hardware is, how itâs set up or what could be causing it because it doesnât make sense to me.
There is a reason we set this distro as terminal centric distribution, there is a lot distro thats user friendly and Distrowatch is not a good source. We have to rely on ranking thats never good. ARch based distro is not necesarry user friendly even Manjaro has its quirks.
Most importand you learn how to manage a os and keep it running does not mather what you use, linux in the core can be a pain.
Free to choose
Sorry but Endeavour is terminal-centric, so therefore not beginner friendly.
What you said were bugs, donât seem like bugs to me, they are things you have to work out because this is not a beginner OS.
Manjaro is my backup OS for computers that donât play well with Endeavour, maybe you should give that a try again.
Iâd recommend you file a bug on the upstream issue tracker and work with the developer to fix the software.
If noone else has the same problem, but you can reliably replicate an issue, then youâre the one best placed to help make the software better.
How about Garuda Linux ??
Ask @SGS if you wanna know better !
Manjaro has dropped support for proprietary nvidia drivers though so itâs no longer a viable option to me
What???
Where do you get this?
I have a similar problem:
yesterday Pacman worked fine
today I did a reinstall following the copy & paste BTRFS with Encryption tutorial
worked like a charm
installed Pacman, some stuff installs fine, other stuff, usually Larger apps it hands on âsynchronizing packagesâ
installing the same packages through terminal seems to work just fine
Not sure what the problem is, just going to use terminal for now. But if someone figures out why this is happening Iâd love to know.
I found Pacman to have a nice GUI, and it was convenient to have flatpack, Aur, snap, and everything all in one place. Honestly for me at least, itâs not a deal breaker though
No it hasnât, thatâs poppycock. But even if it has, you can get them from the AUR. You shouldnât though, just install them using MHWD.
I just checked pkgbrowser out and installed yup and I can get by with using that.
Thanks for the recommendation.
Question with ncurses though, is it supposed to support mouse clicking in the terminal (Konsole)?
Because it ainât registering my mouse clicks
Yes it has. They made a twitter post about the 5.9 kernel not supporting it or something like that.
Do a search of Manjaro dropping proprietary NVIDIA support before calling me a liar and accusing me of information YOU are misinformed about
Yes that article says Linux but a Manjaro twitter post which has now been deleted also said that Manjaro would only be using open source NVIDIA drivers.
Maybe you should keep up with the very latest Linux news before accusing me of being a liar
Yeah thatâs where mine hangs too. Even on ArcoLinux which I just tried it does the same thing
Excuse me sir, but you might want to re-read it again ![]()
I just had a rather big update in Arcolinux through Pamac. No issue to be reported on my end.
ps. posting from Arco
I literally just installed Arco, went to install 4 packages and it froze.
Left it running while frozen and 30 minutes later itâs still frozen while Iâm browsing the web on it!
