What should i do now? Maybe @FredBezies knows more about this problem?
Please help ![]()
It is better to copy and paste the output here than post a picture. What did you say when it asked if you wanted to clean build it?
ok, thanks @anon53396576. I take [N]one!
OK try to see if it will clean build. Take [A]ll.
Is the same as before. I haven“t any problem to install pamac-aur.
normally i would translate the error into english but since it is a picture i canāt. Can you copy and paste the error?
Actually it is not just you I can not build it here either. The package may be broken at the moment.
@anon53396576
it have a few issues ⦠i feel for dev/maintainer ATM
pamac -aur work ok i just install ( check for you ) removed just as fast
Looks like manjaro gitlab did not work correctly when you try to build it? I donāt speak german, but deepl.com told me: āYou are not on any branchā.
Try again now, it will work⦠Well, I hope so!
Here is what I get:
error merging pamac-aur-git: fatal: No current branch.
Manually cloning it from gitlab works fine.
I have pamac-aur-git installed on all of my computers. While it continues to function as it always has, it will not update.
I get the message: error merging pamac-aur-git: fatal: No current branch.
Does anyone else get this message too? It is happening on all of my computers.
I can only assume that whatever is wrong is not being corrected right now due to the holidays but I do hope that the problem(s) will be fixed soon.
I do wish everyone a Happy & HEALTHY New Year.
Lawrence
I get this:
[elloquin@elloquin-elloquin i3]$ yay pamac
10 aur/pamac-aur-tuna 9.5.8-1 (+0 0.00) (Out-of-date: 2020-09-05)
fork from pamac-aur and replace aur.archlinux.org by aur.tuna.tsinghua.edu.cn
9 aur/pamac-tray-icon-plasma 0.1.2-2 (+2 1.00)
Pamac tray icon for plasma users
8 aur/pamac-all-git 10.0.1.r0.g6138310-1 (+2 0.23)
A Gtk3 frontend for libalpm (everything in one package - snap, flatpak, appindicator)
7 aur/archlinux-appstream-data-pamac 20201223-1 (+3 2.09)
Arch Linux application database for AppStream-based software centers (Fixed for pamac)
6 aur/pamac-zsh-completions 0.6-1 (+3 0.43)
ZSH completions for pamac
5 aur/pamac-all 10.0.3-2 (+6 3.34)
4 aur/pamac-cli 10.0.3-1 (+7 0.60)
Pamac cli frontend for libalpm
3 aur/pamac-classic 7.2.1-1 (+15 0.00)
A Gtk3 frontend for libalpm - classic version
2 aur/pamac-aur-git 10.0.3.r0.gbfa5409-2 (+20 0.24)
A Gtk3 frontend for libalpm - git version
1 aur/pamac-aur 10.0.3-1 (+314 9.84)
A Gtk3 frontend, Package Manager based on libalpm with AUR and Appstream support
==> Packages to install (eg: 1 2 3, 1-3 or ^4)
==> 2
:: Checking for conflicts...
:: Checking for inner conflicts...
[Repo:2] gcab-1.4-1 appstream-glib-0.7.18-1
[Repo Make:27] docbook-xml-4.5-9 itstool-1:2.0.6-2 docbook-xsl-1.79.2-7 glib2-docs-2.66.4-1 python-lxml-4.6.2-1 python-pygments-2.7.3-1 python-anytree-2.8.0-3 gtk-doc-1.33.1-1 libxaw-1.0.13-3 jbig2dec-0.19-1 libpaper-1.1.28-1 ijs-0.35-3 libidn-1.36-1 ghostscript-9.53.3-2 netpbm-10.73.33-1 gts-0.7.6.121130-2 gsfonts-20200910-1 graphviz-2.44.1-6 vala-0.50.2-1 ninja-1.10.2-1 meson-0.56.0-3 python-markupsafe-1.1.1-6 python-beaker-1.11.0-6 python-mako-1.1.3-3 python-markdown-3.3.3-2 gobject-introspection-1.66.1-3 asciidoc-9.0.4-2
[Aur:2] archlinux-appstream-data-pamac-20201223-1 pamac-aur-git-10.0.3.r0.gbfa5409-2
==> Remove make dependencies after install? [y/N] y
2 archlinux-appstream-data-pamac (Build Files Exist)
1 pamac-aur-git (Build Files Exist)
==> Packages to cleanBuild?
==> a
:: Deleting (1/2): /home/elloquin/.cache/yay/archlinux-appstream-data-pamac
:: Deleting (2/2): /home/elloquin/.cache/yay/pamac-aur-git
:: Downloaded PKGBUILD (1/2): archlinux-appstream-data-pamac
:: Downloaded PKGBUILD (2/2): pamac-aur-git
==> Diffs to show?
==> n
error: target not found: docbook-xml
error: target not found: itstool
error: target not found: docbook-xsl
error: target not found: glib2-docs
error: target not found: python-lxml
error: target not found: python-pygments
error: target not found: python-anytree
error: target not found: gtk-doc
error: target not found: libxaw
error: target not found: jbig2dec
error: target not found: libpaper
error: target not found: ijs
error: target not found: libidn
error: target not found: ghostscript
error: target not found: netpbm
error: target not found: gts
error: target not found: gsfonts
error: target not found: graphviz
error: target not found: vala
error: target not found: ninja
error: target not found: meson
error: target not found: python-markupsafe
error: target not found: python-beaker
error: target not found: python-mako
error: target not found: python-markdown
error: target not found: gobject-introspection
error: target not found: asciidoc
Are you trying to install from a system which isnāt updated?
Try yay -Syu pamac-aur-git
Updated immediately prior:
core is up to date
extra is up to date
community 5.3 MiB 2.53 MiB/s 00:02 [----------------------------------------------------------------------------------------] 100%
multilib is up to date
endeavouros is up to date
resolving dependencies...
Packages (27) cantarell-fonts-1:0.301-1 eos-bash-shared-1.5.2-1 exo-4.16.0-1 geoip-database-20201222-1 harfbuzz-2.7.4-1 harfbuzz-icu-2.7.4-1 iproute2-5.10.0-1 libepoxy-1.5.5-1 libevdev-1.10.0-2 libgpg-error-1.41-1
libgtop-2.40.0+2+g31db82ef-2 libibus-1.5.23+3+gaa558de8-2 libxfce4ui-4.16.0-1 libxfce4util-4.16.0-1 man-pages-5.10-1 mobile-broadband-provider-info-20201225-1 ndctl-71.1-1 python-packaging-20.8-2
reflector-simple-1.12.3-1 rsync-3.2.3-2 terminus-font-4.49-2 thunar-4.16.0-1 thunar-volman-4.16.0-1 tumbler-4.16.0-1 tzdata-2020e-1 xfce4-terminal-0.8.10-1 xfconf-4.16.0-1
Total Download Size: 24.97 MiB
Total Installed Size: 132.62 MiB
Net Upgrade Size: 1.35 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
tzdata-2020e-1-x86_64 386.6 KiB 4.72 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
libgpg-error-1.41-1-x86_64 233.0 KiB 5.69 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
iproute2-5.10.0-1-x86_64 976.8 KiB 3.97 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
man-pages-5.10-1-any 5.8 MiB 3.99 MiB/s 00:01 [----------------------------------------------------------------------------------------] 100%
cantarell-fonts-1:0.301-1-any 355.5 KiB 4.51 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
libepoxy-1.5.5-1-x86_64 447.5 KiB 5.46 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
harfbuzz-2.7.4-1-x86_64 842.7 KiB 5.14 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
harfbuzz-icu-2.7.4-1-x86_64 7.5 KiB 0.00 B/s 00:00 [----------------------------------------------------------------------------------------] 100%
libxfce4util-4.16.0-1-x86_64 125.2 KiB 0.00 B/s 00:00 [----------------------------------------------------------------------------------------] 100%
xfconf-4.16.0-1-x86_64 185.9 KiB 4.91 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
libgtop-2.40.0+2+g31db82ef-2-x86_64 196.2 KiB 4.79 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
libxfce4ui-4.16.0-1-x86_64 349.8 KiB 8.54 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
exo-4.16.0-1-x86_64 370.8 KiB 4.53 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
geoip-database-20201222-1-any 1566.8 KiB 4.78 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
libevdev-1.10.0-2-x86_64 63.7 KiB 0.00 B/s 00:00 [----------------------------------------------------------------------------------------] 100%
libibus-1.5.23+3+gaa558de8-2-x86_64 9.5 MiB 5.05 MiB/s 00:02 [----------------------------------------------------------------------------------------] 100%
mobile-broadband-provider-info-20201225-1-any 60.9 KiB 0.00 B/s 00:00 [----------------------------------------------------------------------------------------] 100%
ndctl-71.1-1-x86_64 258.2 KiB 7.00 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
python-packaging-20.8-2-any 52.0 KiB 0.00 B/s 00:00 [----------------------------------------------------------------------------------------] 100%
rsync-3.2.3-2-x86_64 310.7 KiB 7.59 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
thunar-4.16.0-1-x86_64 1285.2 KiB 6.18 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
thunar-volman-4.16.0-1-x86_64 130.7 KiB 0.00 B/s 00:00 [----------------------------------------------------------------------------------------] 100%
tumbler-4.16.0-1-x86_64 171.9 KiB 0.00 B/s 00:00 [----------------------------------------------------------------------------------------] 100%
xfce4-terminal-0.8.10-1-x86_64 422.4 KiB 10.3 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
terminus-font-4.49-2-any 1095.7 KiB 6.56 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
eos-bash-shared-1.5.2-1-any 27.5 KiB 0.00 B/s 00:00 [----------------------------------------------------------------------------------------] 100%
reflector-simple-1.12.3-1-any 17.6 KiB 0.00 B/s 00:00 [----------------------------------------------------------------------------------------] 100%
(27/27) checking keys in keyring [----------------------------------------------------------------------------------------] 100%
(27/27) checking package integrity [----------------------------------------------------------------------------------------] 100%
(27/27) loading package files [----------------------------------------------------------------------------------------] 100%
(27/27) checking for file conflicts [----------------------------------------------------------------------------------------] 100%
:: Processing package changes...
( 1/27) upgrading cantarell-fonts [----------------------------------------------------------------------------------------] 100%
( 2/27) upgrading tzdata [----------------------------------------------------------------------------------------] 100%
( 3/27) upgrading libgpg-error [----------------------------------------------------------------------------------------] 100%
( 4/27) upgrading libepoxy [----------------------------------------------------------------------------------------] 100%
( 5/27) upgrading harfbuzz [----------------------------------------------------------------------------------------] 100%
( 6/27) upgrading harfbuzz-icu [----------------------------------------------------------------------------------------] 100%
( 7/27) upgrading eos-bash-shared [----------------------------------------------------------------------------------------] 100%
( 8/27) upgrading libxfce4util [----------------------------------------------------------------------------------------] 100%
( 9/27) upgrading xfconf [----------------------------------------------------------------------------------------] 100%
(10/27) installing libgtop [----------------------------------------------------------------------------------------] 100%
(11/27) upgrading libxfce4ui [----------------------------------------------------------------------------------------] 100%
(12/27) upgrading exo [----------------------------------------------------------------------------------------] 100%
(13/27) upgrading geoip-database [----------------------------------------------------------------------------------------] 100%
(14/27) upgrading iproute2 [----------------------------------------------------------------------------------------] 100%
New optional dependencies for iproute2
db: userspace arp daemon [installed]
(15/27) upgrading libevdev [----------------------------------------------------------------------------------------] 100%
(16/27) upgrading libibus [----------------------------------------------------------------------------------------] 100%
(17/27) upgrading man-pages [----------------------------------------------------------------------------------------] 100%
(18/27) upgrading mobile-broadband-provider-info [----------------------------------------------------------------------------------------] 100%
(19/27) upgrading ndctl [----------------------------------------------------------------------------------------] 100%
(20/27) upgrading python-packaging [----------------------------------------------------------------------------------------] 100%
(21/27) upgrading reflector-simple [----------------------------------------------------------------------------------------] 100%
New optional dependencies for reflector-simple
reflector-bash-completion: useful for plain reflector usage
(22/27) upgrading rsync [----------------------------------------------------------------------------------------] 100%
(23/27) upgrading terminus-font [----------------------------------------------------------------------------------------] 100%
(24/27) upgrading thunar [----------------------------------------------------------------------------------------] 100%
New optional dependencies for thunar
gvfs: trash support, mounting with udisk and remote filesystems [installed]
thunar-archive-plugin: archive creation and extraction [installed]
thunar-media-tags-plugin: view/edit ID3/OGG tags [installed]
thunar-volman: removable device management [installed]
tumbler: thumbnail previews [installed]
(25/27) upgrading thunar-volman [----------------------------------------------------------------------------------------] 100%
(26/27) upgrading tumbler [----------------------------------------------------------------------------------------] 100%
New optional dependencies for tumbler
ffmpegthumbnailer: video thumbnails [installed]
freetype2: font thumbnails [installed]
libgepub: EPUB thumbnails
libgsf: ODF thumbnails [installed]
libopenraw: RAW thumbnails [installed]
poppler-glib: PDF thumbnails [installed]
(27/27) upgrading xfce4-terminal [----------------------------------------------------------------------------------------] 100%
(1/7) Reloading system manager configuration...
(2/7) Arming ConditionNeedsUpdate...
(3/7) Updating fontconfig cache...
(4/7) Updating GIO module cache...
(5/7) Updating icon theme caches...
(6/7) Updating the info directory file...
(7/7) Updating the desktop file MIME type cache...
:: Searching databases for updates...
:: Searching AUR for updates...
there is nothing to do
I find my installed versions working fine and have updated. Wont install from scratch as a new installation. I switched to pamac-aur for now on a new install.
Try forcing a db update:
yay -Syy pamac-aur-git
Same:
[elloquin@elloquin-elloquin i3]$ yay -Syy pamac-aur-git
core 133.7 KiB 1078 KiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
extra 1638.3 KiB 2.86 MiB/s 00:01 [----------------------------------------------------------------------------------------] 100%
community 5.3 MiB 3.26 MiB/s 00:02 [----------------------------------------------------------------------------------------] 100%
multilib 152.3 KiB 4.13 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
endeavouros 15.2 KiB 0.00 B/s 00:00 [----------------------------------------------------------------------------------------] 100%
:: There are 2 providers available for pamac-aur-git:
:: Repository AUR
1) pamac-aur-git 2) pamac-all
Enter a number (default=1): 1
==> a
==> Diffs to show?
==> n
I just built and installed timeshift with no issues.
The pamac-aur-git repo is broken with commit 1ce1c41 - maintainer has somehow added a commit which is not on a named branch, and so makepkg wonāt find it.
This is up to @FredBezies to fix.
(Aside: Itās also completely unnecessary to bump the pkgver of a -git package for each upstream release. The whole point of a VCS package with a pkgver() function is to do that automatically when the package is rebuilt.)
These are all repo packages. It is concerning that pacman canāt find them.
They are there and can be found just not via this pamac-aur-git package.
[elloquin@elloquin-elloquin i3]$ yay docbook-xml
3 extra/docbook5-xml 5.1-2 (140.8 KiB 6.4 MiB)
a complete rewrite of the well-known DocBook 4 XML schema (DTD, Relax NG, W3C schema) for Docbook 5.X
2 extra/docbook-xsl 1.79.2-7 (887.2 KiB 26.3 MiB)
XML stylesheets for Docbook-xml transformations
1 extra/docbook-xml 4.5-9 (89.0 KiB 2.0 MiB)
A widely used XML scheme for writing documentation and help
==> 1
[sudo] password for elloquin:
Packages (1) docbook-xml-4.5-9
Total Installed Size: 1.96 MiB
(1/1) checking keys in keyring [----------------------------------------------------------------------------------------] 100%
(1/1) checking package integrity [----------------------------------------------------------------------------------------] 100%
(1/1) loading package files [----------------------------------------------------------------------------------------] 100%
(1/1) checking for file conflicts [----------------------------------------------------------------------------------------] 100%
(1/1) installing docbook-xml [----------------------------------------------------------------------------------------] 100%
(1/1) Arming ConditionNeedsUpdate...
