Optimus Manager issues
sudo pacman -S linux-headers
Arch package search is a great friend.
https://www.archlinux.org/packages/
To be fair @Kresimir, I missed that in the readme for Optimus-Switch.
I guess I don’t understand the difference between headers and kernel. I was following the wiki…which was originally made for Manjaro.
I gave you the exact command to put in to install Linux-Headers. I even admitted that I missed that in my initial read through.
Linux-headers is a way of adding functionality to the kernel. It is seperate from the kernel. Manjaro uses their own kernels and has their own way of managing packages for it. Because I am so used to doing things “the non-Manjaro way”, I missed that in the instructions.
You probably already have linux-headers installed, so skip this. If unsure, check with
pacman -Q | grep headers
(this is how you should always check if you have something installed or not, regardless whether it is from the repos or the AUR)
Thank you.
@Kresimir
Thanks for that. Very helpful. I installed them before I saw your message. It seemed to install with no problems. Does the below mean I have two different sets of headers or are they used for different things?
linux-api-headers 5.7-1
linux-headers 5.8.5.arch1-1
If you are unsure what a package does, a good starting point is to look it up on:
Alternatively, you can:
pacman -Qi linux-headers
pacman -Qi linux-api-headers
To display info about those packages. In this case, linux-api-headers and linux-headers are entirely different things, you should keep both.
Thank you. I am saving all these in a file so I have them for later.
I just went through the installation, but realized that I skipped the line
sudo modprobe acpi_call
When I run it now, I get
modprobe: FATAL: Module acpi_call not found in directory /lib/modules/5.8.4-arch1-1
Do I need to uninstall and start over?
No, just make sure you have acpi_call-dkms installed. Remember how to check?
pacman -Q | grep acpi
If you don’t see it, install it:
sudo pacman -S acpi_call-dkms
And then run
Yes, I saved that in a file so I can remember. Thank you. (BTW, what happens if you install a package that you already have? Can it cause issues? I thought it just reinstalls it or lets you know it is already installed.)
After running it, it wasn’t installed, so I installed it. But still got the same error
Packages (1) acpi_call-dkms-1.1.0-287
Total Download Size:   0.01 MiB
Total Installed Size:  0.03 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 acpi_call-dkms-1.1.0-...    11.7 KiB   510 KiB/s 00:00 [-----------------------------] 100%
(1/1) checking keys in keyring                          [-----------------------------] 100%
(1/1) checking package integrity                        [-----------------------------] 100%
(1/1) loading package files                             [-----------------------------] 100%
(1/1) checking for file conflicts                       [-----------------------------] 100%
:: Processing package changes...
(1/1) installing acpi_call-dkms                         [-----------------------------] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Install DKMS modules
==> dkms install --no-depmod -m acpi_call -v 1.1.0 -k 5.8.5-arch1-1
==> depmod 5.8.5-arch1-1
Did you update your kernel without rebooting? It seems you are running 5.8.4, but have 5.8.5 installed.
You should always reboot after updating your kernel. Especially before installing graphics drivers. :man_facepalming:
Now I worry that if you reboot, you’ll get a black screen…
Yes. I haven’t rebooted.
Yes, this is a real concern for me as well as it happened many times when I first installed Manjaro.
If I do get a black screen I can boot using systemd.unit=rescue.target to get to a terminal. What will I need to do from there to make sure I can get the computer back?
If you can’t boot, you’ll probably have to uninstall Nvidia drivers and start all over :roll_eyes:
Well, just YOLO it… :man_shrugging:
okay. Hopefully I can manage that. So
sudo pacman -R nvidia-installer-dkms
sudo pacman -S nvidia-installer-dkms
No, just reboot. Don’t do anything else.
I mean if boot fails. Should I try that?
No, you already have nvidia-installer-dkms installed. You’ll have to remove the drivers (not the installer) and run the installer again. Hopefully you have another computer or a phone you can use to read this forum.
Okay, here goes nothing. lol
