No go. Stuck on a black screen with flat curser. But I can get to tty. Yay!
Yeah, you messed up. You updated your kernel, didnāt reboot and then installed driversā¦
Okay, now when you get to a TTY, run
sudo pacman -Syu
reboot
Hopefully, you wonāt get a black screen. Then you can worry about optimus-switch and all that other stuff.
If you get a black screen again, then try:
sudo pacman -R nvidia-dkms
sudo nvidia-installer-dkms
and reboot again.
I got there is nothing to do. So I assume just go to the next step without needing to reboot?
Yes. Try removing the drivers and running the installer again, then reboot.
@shockwave before you uninstalled optimus-manager did you run the optimus-manager --cleanup command?
iāll mention a couple things before i go,
check output of
dkms status, if the nvidia drivers show for your current kernel then they are installed. -
make sure there is not another display/monitor/gpu related conf file in
/etc/X11/xorg.conf.d/that could be conflicting with optimus-switch .conf files which are named 99-nvidia.conf or 99-intel.conf depending on which mode your in. -
if that all looks good then do a file search for optimus manager, if you didnt run the cleanup script before uninstalling it then you probably have some of its files/configurations floating around in places like
/usr/share/X11/xorg.conf.d/and whatever else optimus-manager messes with.
if you cant get to a desktop at all, try switching to intel mode from TTY and reboot so you can have a desktop while figuring out whats going on
Hi @dglt. No I didnāt. Should I do that now
you cant if you already uninstalled it
I reinstalled the Nvidia driver.
Dkms status shows
Acpi_call, 1.1.0, 5.8.5-arch1-1, x86_64: installed
Nvidia, 450.66, 5.8.5-arch1-1, x86_64: installed
I used nano to look at the location you recommended I check. There was nothing there. It just said ā⦠Is a directoryā
I tired switching back to Intel, but still get a black screen with a cursor. I can still get to tty.
You canāt use nano to look in a directory. The command for that is ls. So:
ls /etc/X11/xorg.conf.d/
nano is an editor, not a file manager
Okay. There are two video files there.
20-nvidia.conf and. 99-intel.conf
sudo rm 20-nvidia.conf
sudo set-nvidia.sh
systemctl reboot
and see if you get to a desktop now
That did it. I am back on the desktop. Thank you!
Are there other places where I should look for hidden config files for optimus-manager
glad it worked out
your guess is as good as mine, i never had anything but problems with optimus-manager. if itās working you should be good
Thank you very much. Now to install optimus-indicator.
Thank you everyone for all of your help.
BTW, should I be concerned about any of this other stuff?
journalctl -p3 -xb
-- Logs begin at Sun 2020-08-23 13:57:58 PDT, end at Fri 2020-08-28 14:38:02 PDT. --
Aug 28 14:28:51 workstation0asus kernel: DMAR: [Firmware Bug]: No firmware reserved region can cover this RMRR [0x0000000078800000-0x000000007affffff], contact BIOS vendor for fixes
Aug 28 14:28:51 workstation0asus kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 >
Aug 28 14:28:58 workstation0asus bluetoothd[774]: Failed to set mode: Blocked through rfkill (0x12)
Aug 28 14:32:07 workstation0asus gdm-password][1423]: gkr-pam: unable to locate daemon control file
Aug 28 14:32:09 workstation0asus bluetoothd[774]: RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
Aug 28 14:32:09 workstation0asus bluetoothd[774]: RFCOMM server failed for :1.96/Profile/HSPHSProfile/00001108-0000-1000-8000-00805f9b34fb: rfcomm_bind: Address already in use (98)
I just got this setup working myself. Slick! Iāll take it
Thanks to @dglt and to @linesma for the great scripts!
@ThisPoorGuy Glad you like it and got it working.
@shockwave Happy to see that you are up and running. It was 2am where I was and I had to go to sleep. As far as your second question goes, if you are worried, make a new thread about them. Letās keep this thread about one issue, Optimus Manager issues. This will prevent any confusion in the future if another user reads it to try and solve a similar issue.
Thank you. It seems to be working good. Thank you very much for your help. The good thing when things donāt go as planned is you learn a lot.
