I installed EnOS-Gnome last evening on another laptop (I have already Cinnamon and Plasma setup on another machine) and I am facing an odd issue with smooth scrolling on certain web browsers.
As it is now, it works fine on Firefox and Epiphany but not on Chromium or Vivaldi. I don’t know what causes this so I would appreciate your help and suggestion to solve it if possible. Please let me know if you need some more info.
Thanks for taking your time and read this thread! Though I am not sure how to interpret your reply and your emojis. If you think you could help me out, which I would appreciate greatly, please be more specific about what it is you want to know and I try my best to provide the information.
Sorry , my fault . I didn’t get it at first . I only have firefox installed .
Maybe this link can help . Well , it’s old . I will install chromium to see if I have the same problem if this doesn’t help .
This is a new one and it seems chromium does have problems with smooth scrolling . This is written for edge (based on chroium) but may work for you
The relevant part of it
i think one thing people will notice that how smooth scrolling was on old Edge. it was smooth.
chromium still has issues with smooth scrolling animation but these experimental flags may help you with it :
Also running GNOME with Firefox and Vivaldi I can’t spot a difference in the scrolling behaviour.
Did you already play with these switches (Smooth Scrolling / Hardware Acceleration)?
I changed the first one from default to enabled,
The second and third flags are not available.
I enabled also the fourth.
Unfortunately after restarting the browser the problem with scrolling is still present.
To use VA-API on XWayland, use the --use-gl=egl flag. Currently exhibits choppiness FS#67035.
To use VA-API on Xorg, use the --use-gl=desktop flag.
Starting in Chromium 86, there will be support for VA-API when using the ANGLE gl renderer. Use the --enable-accelerated-video-decode to enable it on an intel GPU.
You may try running GNOME under “Xorg” instead of the default “Wayland”
Wow, that’s quite a piece of information! Thank you so much @Tinymeat! I will surely have a look and hopefully find a way to resolve this issue. Most probably I have to wait until next weekend to do it.
Messing around with my disk, I happened, sort of, to nuke the partition with EOS-GNOME.
You know, I have a reputation to live up to
I’ll be reinstalling it later on and I have bookmarked your post to see if I can resolve the issue i was having.
Thanks again for the help!
I nuked Ubuntu along with Windows on the third day I got a computer and many more distros when dual booting and other stuff afterwards . Stopped on EnOS though .
The article in the Arch-WiKi says that Blink-based browser like Chromium doesn’t function well with Wayland. But that isn’t quite correct since I’ve no problems running Vivaldi with Wayland. So let’s see what happens when you will have finished your fresh installation
I Had to reinstall the system after my little misfortune mentioned above. Now I’ve got the issue with all the browser including Firefox, both with Wayland and Xorg.
