Obs crashing when I press start recording
[parasetu@pasec ~]$ obs
debug: Found portal inhibitor
debug: Attempted path: share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: share/obs/obs-studio/locale.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale.ini
debug: Attempted path: share/obs/obs-studio/locale/en-GB.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/en-GB.ini
info: Using preferred locale 'en-GB'
debug: Attempted path: share/obs/obs-studio/themes/Yami.qss
debug: Attempted path: /usr/share/obs/obs-studio/themes/Yami.qss
info: Using EGL/X11
info: CPU Name: Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
info: CPU Speed: 4690.514MHz
info: Physical Cores: 8, Logical Cores: 16
info: Physical Memory: 15707MB Total, 12185MB Free
info: Kernel Version: Linux 6.2.12-arch1-1
info: Distribution: EndeavourOS Unknown
info: Session Type: x11
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.21.1
info: Qt Version: 6.5.0 (runtime), 6.4.2 (compiled)
info: Portable mode: false
qt.core.qmetaobject.connectslotsbyname: QMetaObject::connectSlotsByName: No matching signal for on_tbar_position_valueChanged(int)
info: OBS 29.0.2-2 (linux)
info: ---------------------------------
info: audio settings reset:
	samples per sec: 48000
	speakers:        2
	max buffering:   960 milliseconds
	buffering type:  dynamically increasing
info: Initializing OpenGL...
info: Loading up OpenGL on adapter Intel Mesa Intel(R) UHD Graphics 630 (CML GT2)
info: OpenGL loaded successfully, version 4.6 (Core Profile) Mesa 23.0.2, shading language 4.60
info: video settings reset:
	base resolution:   1920x1080
	output resolution: 1920x1080
	downscale filter:  Bicubic
	fps:               60/1
	format:            NV12
	YUV mode:          Rec. 709/Partial
info: NV12 texture support not available
info: P010 texture support not available
info: Audio monitoring device:
warning: Failed to load 'en-US' text for module: 'decklink-captions.so'
warning: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
warning: A DeckLink iterator could not be created.  The DeckLink drivers may not be installed
warning: Failed to initialize module 'decklink.so'
warning: Failed to load 'en-GB' text for module: 'frontend-tools.so'
warning: Failed to load 'en-GB' text for module: 'linux-alsa.so'
warning: Failed to load 'en-GB' text for module: 'linux-capture.so'
warning: Failed to load 'en-GB' text for module: 'linux-jack.so'
warning: Failed to load 'en-GB' text for module: 'linux-pipewire.so'
info: [pipewire] Available captures:
info: [pipewire]     - Desktop capture
info: [pipewire]     - Window capture
warning: Failed to load 'en-GB' text for module: 'linux-pulseaudio.so'
warning: v4l2loopback not installed, virtual camera disabled
info: NVENC supported
error: VAAPI: Failed to initialize display in vaapi_device_h264_supported
info: FFmpeg VAAPI H264 encoding not supported
warning: Failed to load 'en-GB' text for module: 'obs-libfdk.so'
warning: Failed to load 'en-GB' text for module: 'obs-vst.so'
warning: Failed to load 'en-GB' text for module: 'obs-x264.so'
warning: Failed to load 'en-GB' text for module: 'rtmp-services.so'
info:   Loaded Modules:
info:     text-freetype2.so
info:     rtmp-services.so
info:     obs-x264.so
info:     obs-vst.so
info:     obs-transitions.so
info:     obs-outputs.so
info:     obs-libfdk.so
info:     obs-filters.so
info:     obs-ffmpeg.so
info:     linux-v4l2.so
info:     linux-pulseaudio.so
info:     linux-pipewire.so
info:     linux-jack.so
info:     linux-capture.so
info:     linux-alsa.so
info:     image-source.so
info:     frontend-tools.so
info:     decklink-output-ui.so
info:     decklink-captions.so
info: ==== Startup complete ===============================================
QVariant: Provided metatype for 'QColor' does not support destruction and copy construction
info: All scene data cleared
info: ------------------------------------------------
info: pulse-input: Server name: 'PulseAudio (on PipeWire 0.3.69) 15.0.0'
info: pulse-input: Audio format: s32le, 48000 Hz, 2 channels
info: pulse-input: Started recording from 'alsa_output.pci-0000_00_1f.3.analog-stereo.monitor' (default)
info: [Loaded global audio device]: 'Desktop Audio'
info: [window-capture: 'Window Capture (Xcomposite)'] update settings:
	title: Desktop @ QRect(0,0 1920x1080)  — Plasma
	class: plasmashell
info: Switched to scene 'Scene'
info: Loaded scenes:
info: - scene 'Scene':
info:     - source: 'Window Capture (Xcomposite)' (xcomposite_input)
info: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds (source: Desktop Audio)
info: [FFmpeg NVENC encoder: 'simple_video_recording'] settings:
	encoder:      NVIDIA NVENC H.264 (FFmpeg)
	rate_control: CQP
	bitrate:      0
	cqp:          23
	keyint:       250
	preset:       p5
	tuning:       hq
	multipass:    qres
	profile:      high
	width:        1920
	height:       1080
	b-frames:     2
	psycho-aq:    1
	GPU:          0
[h264_nvenc @ 0x55d6e97c6a40] dl_fn->cuda_dl->cuInit(0) failed -> CUDA_ERROR_NO_DEVICE: no CUDA-capable device is detected
Segmentation fault (core dumped)
This Arch Linux BBS thread might give you some idea, where and how to begin trouble-shooting, I hope.
:crossed_fingers:
Nvidia encoder can’t work with Intel GPU, you need to force use of nvidia GPU while launching OBS
how do i do that? I have already virtualised my Nvidia graphic card , so for endeavour os its just intel integrated gpu
unable to connect with it, says connection has timed out
here is my system configuration
  Kernel: 6.2.12-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 dm: GDM
  Type: Desktop System: Dell product: OptiPlex 5080 v: N/A
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: Dell model: 032W55 v: A00 serial: <superuser required> UEFI: Dell
    v: 1.17.1 date: 12/18/2022
  Info: 8-core model: Intel Core i7-10700 bits: 64 type: MT MCP
    arch: Comet Lake rev: 5 cache: L1: 512 KiB L2: 2 MiB L3: 16 MiB
  Speed (MHz): avg: 3125 high: 4700 min/max: 800/4800 cores: 1: 4700 2: 2900
    3: 2900 4: 4700 5: 2900 6: 2900 7: 2900 8: 2900 9: 2900 10: 2900 11: 2900
    12: 2900 13: 2900 14: 2900 15: 2900 16: 2900 bogomips: 92838
  Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: Dell driver: i915
    v: kernel arch: Gen-9.5 ports: active: DP-2 empty: DP-1, DP-3, HDMI-A-1,
    HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:9bc5
  Device-2: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Dell
    driver: vfio-pci v: N/A arch: Turing pcie: speed: 2.5 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:21c4
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
    compositor: kwin_x11 driver: X: loaded: intel unloaded: modesetting
    alternate: fbdev,vesa dri: i965 gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96
  Monitor-1: DP-2 mapped: DP2 model: Dell E2420H res: 1920x1080 dpi: 92
    diag: 604mm (23.8")
  API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel UHD Graphics 630 (CML
    GT2) direct-render: Yes
  Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: snd_hda_intel
    v: kernel bus-ID: 00:1f.3 chip-ID: 8086:06c8
  Device-2: NVIDIA TU116 High Definition Audio vendor: Dell driver: vfio-pci
    pcie: speed: Unknown lanes: 63 bus-ID: 01:00.1 chip-ID: 10de:1aeb
  API: ALSA v: k6.2.12-arch1-1 status: kernel-api
  Server-1: PipeWire v: 0.3.69 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin 4: pw-jack type: plugin
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:06f0
  Device-2: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4c
  IF: eno2 state: down mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth:
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 1-14:5 chip-ID: 8087:0026
  Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
  Local Storage: total: 8.42 TiB used: 557.63 GiB (6.5%)
  ID-1: /dev/nvme0n1 vendor: SK Hynix model: PC611 NVMe 256GB
    size: 238.47 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 26.9 C
  ID-2: /dev/sda vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
    speed: 6.0 Gb/s serial: <filter>
  ID-3: /dev/sdb type: USB vendor: Western Digital model: WD20SDRW-11VUUS0
    size: 1.82 TiB serial: <filter>
  ID-4: /dev/sdc type: USB vendor: Western Digital model: WD50NDZW-11A8JS1
    size: 4.55 TiB serial: <filter>
  ID-1: / size: 784.07 GiB used: 544.4 GiB (69.4%) fs: ext4 dev: /dev/sdb13
  ID-2: /boot/efi size: 1022 MiB used: 34.5 MiB (3.4%) fs: vfat
    dev: /dev/sdb12
  ID-3: /home size: 97.37 GiB used: 13.2 GiB (13.6%) fs: ext4 dev: /dev/sdb5
  ID-1: swap-1 type: partition size: 12 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sdb11
  System Temperatures: cpu: 65.0 C pch: 43.0 C mobo: N/A
  Fan Speeds (RPM): N/A
  Processes: 335 Uptime: 29m Memory: 15.34 GiB used: 3.29 GiB (21.5%)
  Init: systemd v: 253 default: graphical Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1344 Shell: Bash v: 5.1.16
  running-in: gnome-terminal inxi: 3.3.26
No idea what you mean by vitrtualized, but i assume you’re using Optimus laptop (i hate that crap) so you should research how to switch GPU that’s pretty complicated topic and depends on your setup…
https://wiki.archlinux.org/title/NVIDIA_Optimus
@petsam LOVES that kind of crap, he might want to help…or not :rofl:
It comes up within a second, here.
Where is your Karuṇā for someone living in the same world as you, but in a “remote” place as viewed from your habitat?
Is it working??
Yes!
not for me , but if its for you , you should probably help me
What does it have to do with anything?
I hate that crazy “technology” because it brings suffering to millions of people, it has nothing to do with laptop price, if that’s what you imply - today it’s nearly impossible to find laptop with single GPU.
Here’s the PDF I just saved from that site:
[SOLVED] CUDA not working on linux-ck kernel _ Kernel & Hardware _ Arch Linux Forums.pdf (294.3 KB)
Not implying anything, just asking you for a little bit more mercy on others, who may be in a dire situation. - This may even be me, over-interpreting some things here. :wink:
I don’t know if this will help, but I would try changing it.
I was able to fix this on Ubuntu 22.04 with the following steps:
grep ^ /etc/apt/sources.list /etc/apt/sources.list.d/*
sudo add-apt-repository ppa:obsproject/obs-studio
sudo apt-get update
sudo apt-get upgrade obs-studio
If OBS crashes as soon as you hit “Start Recording,” it could be due to a codec issue, GPU driver conflict, or corrupted settings. First, update your graphics drivers and make sure your recording settings match supported formats (like MP4 or MKV with NVENC or x264). If it’s been saving broken or incomplete files, try using https://repаir.cleverfiles.com/ to fix any corrupted recordings. You can also try resetting OBS settings or running it as admin to see if that helps.
This thread is years old. Best to start a new one and post additional information: Which obs version, which hardware, are there any specific error messages, can you provide a log etc.
