Well i disagree with that philosophy as those updates are important. The ones after your current version are for Windows 11 support and also updates for AMD AGESA which is the firmware that runs everything for your Ryzen processor. So it has a lot of adjustments to power settings and such for performance and also stability.
Edit: You could try another package for the WiFi? There are a couple of others.
Yes i would try the rtl88xxau-aircrack-dkms-git but lets see what @manuel says too. I know this package conflicts with that one so I’m not sure whether it removes it automatically on install?
This chip is rtl8821au so there are only 3 packages in the AUR?
Edit: Had enough trouble getting this install to pick up Windows /efi but I’m quite confident it was because of secure boot keys needed to cleared in order for secure boot to be off.
Okay awesome! So if i were you and no rush. Please spend some time on the Asus site and read up on how to update your UEFI Bios for your particular motherboard. Usually you download the updated Bios file and extract the contents and then put them on a usb to boot from and run the flash update from the UEFI settings screen. You have to do it properly or you can ruin the board. Power has to not interrupted and flashing process either until it is complete. If you have any questions before you decide when you want to update it then ask .
There is nothing that say’s you have to update the UEFI Bios if you don’t have any issues. It’s entirely up to you. It’s your hardware. If i can help just ask.
I will now go reinstall to Plasma EOS. Everyone is sleeping I can utilize my network now. Let’s hope something wont break once again (it really shouldn’t)
Yeah I will read about BIOS update stuff when have time for it. I am mostly scared of this:
Thats big danger if doing this can damage MB without going back. Wouldn’t be amazing if after few days I got totally new PC, I damage its MB…
