No WiFi on Live USB (TP-Link Archer T2U Plus)
Not sure I know what you asking. I mean my WiFi card is plugged in USB port.
Yes… that is what i asked. It’s usb. So it should work with the rtl8821au-dkms-git package from the AUR. You listed a different package.
yay -S rtl8821au-dkms-git
Edit: Need to reboot after
Did both. Don’t see any WiFi’s
Can you post this again.
inxi -Na
[elnath@elnathPC ~]$ inxi -Na
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
           vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel modules: r8168 port: f000
           bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
It’s not listing it there just the Ethernet which is using the r8169 kernel module. Do you know if the ethernet is working?
I am writing from ethernet right now.
Okay so remove the r8168 package since you don’t need it for the Ethernet.
sudo pacman -R r8168
Edit: Reboot again
Nevermind PC has ethernet connection (did unplug cable) :sweat_smile: but still no wifi.
Well that’s not good. I’m surprised at that because it doesn’t show that it’s using the r8168. I guess you have to download the r8168 package and reinstall it somehow. :grimacing:
I edited previous post.
Well there are only a couple of other driver packages for that USB WiFi. They are also in the AUR. I’m not sure why it’s not working. :thinking:
Edit: I know the chip is listed with
lsusb
Maybe post the following.
sudo dmesg | eos-sendlog
I did offline install. So don’t have Plasma right now.
sudo dmesg
[    0.039482] PM: hibernation: Registered nosave memory: [mem 0xcbb5e000-0xcbbfefff]
[    0.039483] PM: hibernation: Registered nosave memory: [mem 0xcd000000-0xcfffffff]
[    0.039483] PM: hibernation: Registered nosave memory: [mem 0xd0000000-0xefffffff]
[    0.039483] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xf7ffffff]
[    0.039484] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfd1fffff]
[    0.039484] PM: hibernation: Registered nosave memory: [mem 0xfd200000-0xfd2fffff]
[    0.039484] PM: hibernation: Registered nosave memory: [mem 0xfd300000-0xfd5fffff]
[    0.039485] PM: hibernation: Registered nosave memory: [mem 0xfd600000-0xfd7fffff]
[    0.039485] PM: hibernation: Registered nosave memory: [mem 0xfd800000-0xfe9fffff]
[    0.039485] PM: hibernation: Registered nosave memory: [mem 0xfea00000-0xfea0ffff]
[    0.039486] PM: hibernation: Registered nosave memory: [mem 0xfea10000-0xfeb7ffff]
[    0.039486] PM: hibernation: Registered nosave memory: [mem 0xfeb80000-0xfec01fff]
[    0.039486] PM: hibernation: Registered nosave memory: [mem 0xfec02000-0xfec0ffff]
[    0.039487] PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[    0.039487] PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfec2ffff]
[    0.039488] PM: hibernation: Registered nosave memory: [mem 0xfec30000-0xfec30fff]
[    0.039488] PM: hibernation: Registered nosave memory: [mem 0xfec31000-0xfecfffff]
[    0.039488] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[    0.039489] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed3ffff]
[    0.039489] PM: hibernation: Registered nosave memory: [mem 0xfed40000-0xfed44fff]
[    0.039489] PM: hibernation: Registered nosave memory: [mem 0xfed45000-0xfed7ffff]
[    0.039490] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
[    0.039490] PM: hibernation: Registered nosave memory: [mem 0xfed90000-0xfedc1fff]
[    0.039490] PM: hibernation: Registered nosave memory: [mem 0xfedc2000-0xfedcffff]
[    0.039491] PM: hibernation: Registered nosave memory: [mem 0xfedd0000-0xfedd3fff]
[    0.039491] PM: hibernation: Registered nosave memory: [mem 0xfedd4000-0xfedd5fff]
[    0.039491] PM: hibernation: Registered nosave memory: [mem 0xfedd6000-0xfeffffff]
[    0.039492] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.039492] [mem 0xd0000000-0xefffffff] available for PCI devices
[    0.039493] Booting paravirtualized kernel on bare hardware
[    0.039495] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.041850] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:32 nr_node_ids:1
[    0.042722] percpu: Embedded 57 pages/cpu s196608 r8192 d28672 u262144
[    0.042727] pcpu-alloc: s196608 r8192 d28672 u262144 alloc=1*2097152
[    0.042728] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[    0.042733] pcpu-alloc: [0] 16 17 18 19 20 21 22 23 [0] 24 25 26 27 28 29 30 31
[    0.042751] Built 1 zonelists, mobility grouping on.  Total pages: 8227266
[    0.042752] Policy zone: Normal
[    0.042753] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=c37e0fe7-7983-498c-95e3-4e6feacce38f rw quiet loglevel=3 nowatchdog
[    0.042788] printk: log_buf_len individual max cpu contribution: 4096 bytes
[    0.042788] printk: log_buf_len total cpu_extra contributions: 126976 bytes
[    0.042789] printk: log_buf_len min size: 131072 bytes
[    0.042916] printk: log_buf_len: 262144 bytes
[    0.042917] printk: early log buf free: 115344(88%)
[    0.044670] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.045549] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.045712] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[    0.088997] Memory: 32679876K/33432084K available (14344K kernel code, 2050K rwdata, 9084K rodata, 1796K init, 4128K bss, 751948K reserved, 0K cma-reserved)
[    0.089002] random: get_random_u64 called from __kmem_cache_create+0x2a/0x580 with crng_init=0
[    0.089069] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=32, Nodes=1
[    0.089076] ftrace: allocating 42292 entries in 166 pages
[    0.099158] ftrace: allocated 166 pages with 4 groups
[    0.099244] rcu: Preemptible hierarchical RCU implementation.
[    0.099245] rcu: 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.099245] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=32.
[    0.099246] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.099247] 	Trampoline variant of Tasks RCU enabled.
[    0.099247] 	Rude variant of Tasks RCU enabled.
[    0.099247] 	Tracing variant of Tasks RCU enabled.
[    0.099248] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.099248] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=32
[    0.101004] NR_IRQS: 20736, nr_irqs: 1224, preallocated irqs: 16
[    0.101225] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.101321] Console: colour dummy device 80x25
[    0.101329] printk: console [tty0] enabled
[    0.101341] ACPI: Core revision 20210331
[    0.101424] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[    0.101439] APIC: Switch to symmetric I/O mode setup
[    0.420993] Switched APIC routing to physical flat.
[    0.421610] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.438086] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6a79000e8e8, max_idle_ns: 881590820720 ns
[    0.438089] Calibrating delay loop (skipped), value calculated using timer frequency.. 7389.31 BogoMIPS (lpj=12310896)
[    0.438091] pid_max: default: 32768 minimum: 301
[    0.439340] LSM: Security Framework initializing
[    0.439347] landlock: Up and running.
[    0.439348] Yama: becoming mindful.
[    0.439351] LSM support for eBPF active
[    0.439388] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.439424] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.439563] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[    0.439606] LVT offset 1 assigned for vector 0xf9
[    0.439756] LVT offset 2 assigned for vector 0xf4
[    0.439797] Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
[    0.439798] Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
[    0.439799] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.439800] Spectre V2 : Mitigation: Full AMD retpoline
[    0.439801] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.439801] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.439802] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.439802] Spectre V2 : User space: Mitigation: STIBP always-on protection
[    0.439803] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.441508] Freeing SMP alternatives memory: 36K
[    0.552695] smpboot: CPU0: AMD Ryzen 5 5600X 6-Core Processor (family: 0x19, model: 0x21, stepping: 0x0)
[    0.552780] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[    0.552783] ... version:                0
[    0.552783] ... bit width:              48
[    0.552784] ... generic registers:      6
[    0.552784] ... value mask:             0000ffffffffffff
[    0.552784] ... max period:             00007fffffffffff
[    0.552785] ... fixed-purpose events:   0
[    0.552785] ... event mask:             000000000000003f
[    0.552817] rcu: Hierarchical SRCU implementation.
[    0.553156] smp: Bringing up secondary CPUs ...
[    0.553210] x86: Booting SMP configuration:
[    0.553211] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6
[    0.564792] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[    0.564836]   #7  #8  #9 #10 #11
[    0.576905] smp: Brought up 1 node, 12 CPUs
[    0.576905] smpboot: Max logical packages: 3
[    0.576905] smpboot: Total of 12 processors activated (88673.72 BogoMIPS)
[    0.578302] devtmpfs: initialized
[    0.578302] x86/mm: Memory block size: 128MB
[    0.578875] PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20dfff] (57344 bytes)
[    0.578875] PM: Registering ACPI NVS region [mem 0xc8a04000-0xca12ffff] (24297472 bytes)
[    0.578875] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.578875] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[    0.578875] pinctrl core: initialized pinctrl subsystem
[    0.578875] PM: RTC time: 19:24:53, date: 2021-11-19
[    0.578875] NET: Registered protocol family 16
[    0.578875] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.578875] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.579009] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.579013] audit: initializing netlink subsys (disabled)
[    0.579017] audit: type=2000 audit(1637349892.163:1): state=initialized audit_enabled=0 res=1
[    0.579017] thermal_sys: Registered thermal governor 'fair_share'
[    0.579017] thermal_sys: Registered thermal governor 'bang_bang'
[    0.579017] thermal_sys: Registered thermal governor 'step_wise'
[    0.579017] thermal_sys: Registered thermal governor 'user_space'
[    0.579017] thermal_sys: Registered thermal governor 'power_allocator'
[    0.579017] cpuidle: using governor ladder
[    0.579017] cpuidle: using governor menu
[    0.579017] Detected 1 PCC Subspaces
[    0.579017] Registering PCC driver as Mailbox controller
[    0.579017] ACPI: bus type PCI registered
[    0.579017] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.579017] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[    0.579017] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
[    0.579017] PCI: Using configuration type 1 for base access
[    0.579017] Kprobes globally optimized
[    0.579017] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.579017] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.581465] ACPI: Added _OSI(Module Device)
[    0.581465] ACPI: Added _OSI(Processor Device)
[    0.581466] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.581466] ACPI: Added _OSI(Processor Aggregator Device)
[    0.581466] ACPI: Added _OSI(Linux-Dell-Video)
[    0.581467] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.581467] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.590034] ACPI: 9 ACPI AML tables successfully acquired and loaded
[    0.590881] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.592860] ACPI: Interpreter enabled
[    0.592869] ACPI: (supports S0 S3 S4 S5)
[    0.592870] ACPI: Using IOAPIC for interrupt routing
[    0.593068] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.593268] ACPI: Enabled 4 GPEs in block 00 to 1F
[    0.597935] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.597938] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.598069] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME LTR DPC]
[    0.598208] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
[    0.598215] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-7f] only partially covers this bridge
[    0.598433] PCI host bridge to bus 0000:00
[    0.598434] pci_bus 0000:00: root bus resource [io  0x0000-0x03af window]
[    0.598435] pci_bus 0000:00: root bus resource [io  0x03e0-0x0cf7 window]
[    0.598436] pci_bus 0000:00: root bus resource [io  0x03b0-0x03df window]
[    0.598436] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.598437] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.598437] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[    0.598438] pci_bus 0000:00: root bus resource [mem 0xd0000000-0xfec2ffff window]
[    0.598439] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window]
[    0.598439] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.598448] pci 0000:00:00.0: [1022:1480] type 00 class 0x060000
[    0.598534] pci 0000:00:00.2: [1022:1481] type 00 class 0x080600
[    0.598625] pci 0000:00:01.0: [1022:1482] type 00 class 0x060000
[    0.598694] pci 0000:00:01.1: [1022:1483] type 01 class 0x060400
[    0.598723] pci 0000:00:01.1: enabling Extended Tags
[    0.598777] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[    0.598883] pci 0000:00:01.2: [1022:1483] type 01 class 0x060400
[    0.598912] pci 0000:00:01.2: enabling Extended Tags
[    0.598965] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[    0.599066] pci 0000:00:02.0: [1022:1482] type 00 class 0x060000
[    0.599130] pci 0000:00:03.0: [1022:1482] type 00 class 0x060000
[    0.599195] pci 0000:00:03.1: [1022:1483] type 01 class 0x060400
[    0.599276] pci 0000:00:03.1: PME# supported from D0 D3hot D3cold
[    0.599628] pci 0000:00:04.0: [1022:1482] type 00 class 0x060000
[    0.599694] pci 0000:00:05.0: [1022:1482] type 00 class 0x060000
[    0.599759] pci 0000:00:07.0: [1022:1482] type 00 class 0x060000
[    0.599821] pci 0000:00:07.1: [1022:1484] type 01 class 0x060400
[    0.599845] pci 0000:00:07.1: enabling Extended Tags
[    0.599884] pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
[    0.599970] pci 0000:00:08.0: [1022:1482] type 00 class 0x060000
[    0.600033] pci 0000:00:08.1: [1022:1484] type 01 class 0x060400
[    0.600058] pci 0000:00:08.1: enabling Extended Tags
[    0.600100] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[    0.600203] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[    0.600311] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[    0.600428] pci 0000:00:18.0: [1022:1440] type 00 class 0x060000
[    0.600464] pci 0000:00:18.1: [1022:1441] type 00 class 0x060000
[    0.600499] pci 0000:00:18.2: [1022:1442] type 00 class 0x060000
[    0.600536] pci 0000:00:18.3: [1022:1443] type 00 class 0x060000
[    0.600571] pci 0000:00:18.4: [1022:1444] type 00 class 0x060000
[    0.600607] pci 0000:00:18.5: [1022:1445] type 00 class 0x060000
[    0.600642] pci 0000:00:18.6: [1022:1446] type 00 class 0x060000
[    0.600677] pci 0000:00:18.7: [1022:1447] type 00 class 0x060000
[    0.600770] pci 0000:01:00.0: [2646:500f] type 00 class 0x010802
[    0.600792] pci 0000:01:00.0: reg 0x10: [mem 0xfc700000-0xfc703fff 64bit]
[    0.600993] pci 0000:00:01.1: PCI bridge to [bus 01]
[    0.600998] pci 0000:00:01.1:   bridge window [mem 0xfc700000-0xfc7fffff]
[    0.601055] pci 0000:02:00.0: [1022:43ee] type 00 class 0x0c0330
[    0.601074] pci 0000:02:00.0: reg 0x10: [mem 0xfc6a0000-0xfc6a7fff 64bit]
[    0.601119] pci 0000:02:00.0: enabling Extended Tags
[    0.601177] pci 0000:02:00.0: PME# supported from D3hot D3cold
[    0.601264] pci 0000:02:00.1: [1022:43eb] type 00 class 0x010601
[    0.601317] pci 0000:02:00.1: reg 0x24: [mem 0xfc680000-0xfc69ffff]
[    0.601325] pci 0000:02:00.1: reg 0x30: [mem 0xfc600000-0xfc67ffff pref]
[    0.601332] pci 0000:02:00.1: enabling Extended Tags
[    0.601376] pci 0000:02:00.1: PME# supported from D3hot D3cold
[    0.601444] pci 0000:02:00.2: [1022:43e9] type 01 class 0x060400
[    0.601493] pci 0000:02:00.2: enabling Extended Tags
[    0.601543] pci 0000:02:00.2: PME# supported from D3hot D3cold
[    0.601621] pci 0000:00:01.2: PCI bridge to [bus 02-06]
[    0.601624] pci 0000:00:01.2:   bridge window [io  0xf000-0xffff]
[    0.601626] pci 0000:00:01.2:   bridge window [mem 0xfc500000-0xfc6fffff]
[    0.601712] pci 0000:03:00.0: [1022:43ea] type 01 class 0x060400
[    0.601764] pci 0000:03:00.0: enabling Extended Tags
[    0.601821] pci 0000:03:00.0: PME# supported from D3hot D3cold
[    0.601911] pci 0000:03:08.0: [1022:43ea] type 01 class 0x060400
[    0.601963] pci 0000:03:08.0: enabling Extended Tags
[    0.602020] pci 0000:03:08.0: PME# supported from D3hot D3cold
[    0.602104] pci 0000:03:09.0: [1022:43ea] type 01 class 0x060400
[    0.602156] pci 0000:03:09.0: enabling Extended Tags
[    0.602213] pci 0000:03:09.0: PME# supported from D3hot D3cold
[    0.602302] pci 0000:02:00.2: PCI bridge to [bus 03-06]
[    0.602307] pci 0000:02:00.2:   bridge window [io  0xf000-0xffff]
[    0.602310] pci 0000:02:00.2:   bridge window [mem 0xfc500000-0xfc5fffff]
[    0.602349] pci 0000:03:00.0: PCI bridge to [bus 04]
[    0.602396] pci 0000:03:08.0: PCI bridge to [bus 05]
[    0.602481] pci 0000:06:00.0: [10ec:8168] type 00 class 0x020000
[    0.602510] pci 0000:06:00.0: reg 0x10: [io  0xf000-0xf0ff]
[    0.602549] pci 0000:06:00.0: reg 0x18: [mem 0xfc504000-0xfc504fff 64bit]
[    0.602573] pci 0000:06:00.0: reg 0x20: [mem 0xfc500000-0xfc503fff 64bit]
[    0.602730] pci 0000:06:00.0: supports D1 D2
[    0.602731] pci 0000:06:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.602899] pci 0000:03:09.0: PCI bridge to [bus 06]
[    0.602904] pci 0000:03:09.0:   bridge window [io  0xf000-0xffff]
[    0.602907] pci 0000:03:09.0:   bridge window [mem 0xfc500000-0xfc5fffff]
[    0.602989] pci 0000:07:00.0: [10de:21c4] type 00 class 0x030000
[    0.603004] pci 0000:07:00.0: reg 0x10: [mem 0xfb000000-0xfbffffff]
[    0.603016] pci 0000:07:00.0: reg 0x14: [mem 0xd0000000-0xdfffffff 64bit pref]
[    0.603028] pci 0000:07:00.0: reg 0x1c: [mem 0xe0000000-0xe1ffffff 64bit pref]
[    0.603036] pci 0000:07:00.0: reg 0x24: [io  0xe000-0xe07f]
[    0.603044] pci 0000:07:00.0: reg 0x30: [mem 0xfc000000-0xfc07ffff pref]
[    0.603062] pci 0000:07:00.0: BAR 1: assigned to efifb
[    0.603113] pci 0000:07:00.0: PME# supported from D0 D3hot D3cold
[    0.603191] pci 0000:07:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:03.1 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[    0.603230] pci 0000:07:00.1: [10de:1aeb] type 00 class 0x040300
[    0.603242] pci 0000:07:00.1: reg 0x10: [mem 0xfc080000-0xfc083fff]
[    0.603375] pci 0000:07:00.2: [10de:1aec] type 00 class 0x0c0330
[    0.603393] pci 0000:07:00.2: reg 0x10: [mem 0xe2000000-0xe203ffff 64bit pref]
[    0.603412] pci 0000:07:00.2: reg 0x1c: [mem 0xe2040000-0xe204ffff 64bit pref]
[    0.603473] pci 0000:07:00.2: PME# supported from D0 D3hot D3cold
[    0.603526] pci 0000:07:00.3: [10de:1aed] type 00 class 0x0c8000
[    0.603538] pci 0000:07:00.3: reg 0x10: [mem 0xfc084000-0xfc084fff]
[    0.603616] pci 0000:07:00.3: PME# supported from D0 D3hot D3cold
[    0.603691] pci 0000:00:03.1: PCI bridge to [bus 07]
[    0.603695] pci 0000:00:03.1:   bridge window [io  0xe000-0xefff]
[    0.603696] pci 0000:00:03.1:   bridge window [mem 0xfb000000-0xfc0fffff]
[    0.603700] pci 0000:00:03.1:   bridge window [mem 0xd0000000-0xe20fffff 64bit pref]
[    0.603736] pci 0000:08:00.0: [1022:148a] type 00 class 0x130000
[    0.603764] pci 0000:08:00.0: enabling Extended Tags
[    0.603861] pci 0000:00:07.1: PCI bridge to [bus 08]
[    0.603911] pci 0000:09:00.0: [1022:1485] type 00 class 0x130000
[    0.603944] pci 0000:09:00.0: enabling Extended Tags
[    0.604053] pci 0000:09:00.1: [1022:1486] type 00 class 0x108000
[    0.604069] pci 0000:09:00.1: reg 0x18: [mem 0xfc300000-0xfc3fffff]
[    0.604080] pci 0000:09:00.1: reg 0x24: [mem 0xfc408000-0xfc409fff]
[    0.604088] pci 0000:09:00.1: enabling Extended Tags
[    0.604183] pci 0000:09:00.3: [1022:149c] type 00 class 0x0c0330
[    0.604196] pci 0000:09:00.3: reg 0x10: [mem 0xfc200000-0xfc2fffff 64bit]
[    0.604226] pci 0000:09:00.3: enabling Extended Tags
[    0.604271] pci 0000:09:00.3: PME# supported from D0 D3hot D3cold
[    0.604337] pci 0000:09:00.4: [1022:1487] type 00 class 0x040300
[    0.604346] pci 0000:09:00.4: reg 0x10: [mem 0xfc400000-0xfc407fff]
[    0.604372] pci 0000:09:00.4: enabling Extended Tags
[    0.604414] pci 0000:09:00.4: PME# supported from D0 D3hot D3cold
[    0.604484] pci 0000:00:08.1: PCI bridge to [bus 09]
[    0.604488] pci 0000:00:08.1:   bridge window [mem 0xfc200000-0xfc4fffff]
[    0.604775] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[    0.604809] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[    0.604838] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    0.604874] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[    0.604906] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    0.604933] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    0.604960] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    0.604987] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    0.605437] iommu: Default domain type: Translated
[    0.605455] pci 0000:07:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    0.605455] pci 0000:07:00.0: vgaarb: bridge control possible
[    0.605455] pci 0000:07:00.0: vgaarb: setting as boot device
[    0.605455] vgaarb: loaded
[    0.605455] SCSI subsystem initialized
[    0.605455] libata version 3.00 loaded.
[    0.605455] ACPI: bus type USB registered
[    0.605455] usbcore: registered new interface driver usbfs
[    0.605455] usbcore: registered new interface driver hub
[    0.605455] usbcore: registered new device driver usb
[    0.605455] pps_core: LinuxPPS API ver. 1 registered
[    0.605455] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.605455] PTP clock support registered
[    0.605455] EDAC MC: Ver: 3.0.0
[    0.605455] Registered efivars operations
[    0.605455] NetLabel: Initializing
[    0.605455] NetLabel:  domain hash size = 128
[    0.605455] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.605455] NetLabel:  unlabeled traffic allowed by default
[    0.605455] PCI: Using ACPI for IRQ routing
[    0.609700] PCI: pci_cache_line_size set to 64 bytes
[    0.609765] e820: reserve RAM buffer [mem 0x09d1f000-0x0bffffff]
[    0.609766] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[    0.609767] e820: reserve RAM buffer [mem 0x0b000000-0x0bffffff]
[    0.609767] e820: reserve RAM buffer [mem 0xc43f5000-0xc7ffffff]
[    0.609768] e820: reserve RAM buffer [mem 0xc4cf2000-0xc7ffffff]
[    0.609768] e820: reserve RAM buffer [mem 0xc50e2000-0xc7ffffff]
[    0.609769] e820: reserve RAM buffer [mem 0xc8475000-0xcbffffff]
[    0.609769] e820: reserve RAM buffer [mem 0xcd000000-0xcfffffff]
[    0.609770] e820: reserve RAM buffer [mem 0x82f380000-0x82fffffff]
[    0.609773] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.609773] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[    0.611456] clocksource: Switched to clocksource tsc-early
[    0.615595] VFS: Disk quotas dquot_6.6.0
[    0.615604] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.615641] pnp: PnP ACPI init
[    0.615691] system 00:00: [mem 0xf0000000-0xf7ffffff] has been reserved
[    0.615695] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.615728] system 00:01: [mem 0xfd200000-0xfd2fffff] has been reserved
[    0.615730] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.615751] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.615835] system 00:03: [io  0x0290-0x029f] has been reserved
[    0.615836] system 00:03: [io  0x0200-0x021f] has been reserved
[    0.615837] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.616005] pnp 00:04: [dma 0 disabled]
[    0.616020] pnp 00:04: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.616172] system 00:05: [io  0x04d0-0x04d1] has been reserved
[    0.616174] system 00:05: [io  0x040b] has been reserved
[    0.616174] system 00:05: [io  0x04d6] has been reserved
[    0.616175] system 00:05: [io  0x0c00-0x0c01] has been reserved
[    0.616176] system 00:05: [io  0x0c14] has been reserved
[    0.616176] system 00:05: [io  0x0c50-0x0c51] has been reserved
[    0.616177] system 00:05: [io  0x0c52] has been reserved
[    0.616177] system 00:05: [io  0x0c6c] has been reserved
[    0.616178] system 00:05: [io  0x0c6f] has been reserved
[    0.616178] system 00:05: [io  0x0cd8-0x0cdf] has been reserved
[    0.616179] system 00:05: [io  0x0800-0x089f] has been reserved
[    0.616179] system 00:05: [io  0x0b00-0x0b0f] has been reserved
[    0.616180] system 00:05: [io  0x0b20-0x0b3f] has been reserved
[    0.616181] system 00:05: [io  0x0900-0x090f] has been reserved
[    0.616181] system 00:05: [io  0x0910-0x091f] has been reserved
[    0.616182] system 00:05: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.616183] system 00:05: [mem 0xfec01000-0xfec01fff] could not be reserved
[    0.616184] system 00:05: [mem 0xfedc0000-0xfedc0fff] has been reserved
[    0.616185] system 00:05: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.616186] system 00:05: [mem 0xfed80000-0xfed8ffff] could not be reserved
[    0.616187] system 00:05: [mem 0xfec10000-0xfec10fff] has been reserved
[    0.616188] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[    0.616190] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.616545] pnp: PnP ACPI: found 6 devices
[    0.621691] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.621724] NET: Registered protocol family 2
[    0.621858] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.622792] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.622946] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.623137] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.623184] TCP: Hash tables configured (established 262144 bind 65536)
[    0.623281] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
[    0.623334] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.623391] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.623449] NET: Registered protocol family 1
[    0.623451] NET: Registered protocol family 44
[    0.623458] pci 0000:00:01.1: PCI bridge to [bus 01]
[    0.623461] pci 0000:00:01.1:   bridge window [mem 0xfc700000-0xfc7fffff]
[    0.623466] pci 0000:03:00.0: PCI bridge to [bus 04]
[    0.623477] pci 0000:03:08.0: PCI bridge to [bus 05]
[    0.623488] pci 0000:03:09.0: PCI bridge to [bus 06]
[    0.623490] pci 0000:03:09.0:   bridge window [io  0xf000-0xffff]
[    0.623494] pci 0000:03:09.0:   bridge window [mem 0xfc500000-0xfc5fffff]
[    0.623501] pci 0000:02:00.2: PCI bridge to [bus 03-06]
[    0.623502] pci 0000:02:00.2:   bridge window [io  0xf000-0xffff]
[    0.623506] pci 0000:02:00.2:   bridge window [mem 0xfc500000-0xfc5fffff]
[    0.623513] pci 0000:00:01.2: PCI bridge to [bus 02-06]
[    0.623514] pci 0000:00:01.2:   bridge window [io  0xf000-0xffff]
[    0.623517] pci 0000:00:01.2:   bridge window [mem 0xfc500000-0xfc6fffff]
[    0.623521] pci 0000:00:03.1: PCI bridge to [bus 07]
[    0.623523] pci 0000:00:03.1:   bridge window [io  0xe000-0xefff]
[    0.623525] pci 0000:00:03.1:   bridge window [mem 0xfb000000-0xfc0fffff]
[    0.623527] pci 0000:00:03.1:   bridge window [mem 0xd0000000-0xe20fffff 64bit pref]
[    0.623530] pci 0000:00:07.1: PCI bridge to [bus 08]
[    0.623536] pci 0000:00:08.1: PCI bridge to [bus 09]
[    0.623538] pci 0000:00:08.1:   bridge window [mem 0xfc200000-0xfc4fffff]
[    0.623542] pci_bus 0000:00: resource 4 [io  0x0000-0x03af window]
[    0.623543] pci_bus 0000:00: resource 5 [io  0x03e0-0x0cf7 window]
[    0.623544] pci_bus 0000:00: resource 6 [io  0x03b0-0x03df window]
[    0.623544] pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
[    0.623545] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[    0.623545] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[    0.623546] pci_bus 0000:00: resource 10 [mem 0xd0000000-0xfec2ffff window]
[    0.623546] pci_bus 0000:00: resource 11 [mem 0xfee00000-0xffffffff window]
[    0.623547] pci_bus 0000:01: resource 1 [mem 0xfc700000-0xfc7fffff]
[    0.623548] pci_bus 0000:02: resource 0 [io  0xf000-0xffff]
[    0.623548] pci_bus 0000:02: resource 1 [mem 0xfc500000-0xfc6fffff]
[    0.623549] pci_bus 0000:03: resource 0 [io  0xf000-0xffff]
[    0.623549] pci_bus 0000:03: resource 1 [mem 0xfc500000-0xfc5fffff]
[    0.623550] pci_bus 0000:06: resource 0 [io  0xf000-0xffff]
[    0.623550] pci_bus 0000:06: resource 1 [mem 0xfc500000-0xfc5fffff]
[    0.623551] pci_bus 0000:07: resource 0 [io  0xe000-0xefff]
[    0.623551] pci_bus 0000:07: resource 1 [mem 0xfb000000-0xfc0fffff]
[    0.623552] pci_bus 0000:07: resource 2 [mem 0xd0000000-0xe20fffff 64bit pref]
[    0.623553] pci_bus 0000:09: resource 1 [mem 0xfc200000-0xfc4fffff]
[    0.623704] pci 0000:07:00.1: D0 power state depends on 0000:07:00.0
[    0.623755] pci 0000:07:00.2: D0 power state depends on 0000:07:00.0
[    0.623862] pci 0000:07:00.3: D0 power state depends on 0000:07:00.0
[    0.623970] PCI: CLS 64 bytes, default 64
[    0.623976] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[    0.623983] AMD-Vi: Lazy IO/TLB flushing enabled
[    0.623995] pci 0000:00:01.0: Adding to iommu group 0
[    0.623999] Trying to unpack rootfs image as initramfs...
[    0.624000] pci 0000:00:01.1: Adding to iommu group 1
[    0.624006] pci 0000:00:01.2: Adding to iommu group 2
[    0.624011] pci 0000:00:02.0: Adding to iommu group 3
[    0.624017] pci 0000:00:03.0: Adding to iommu group 4
[    0.624022] pci 0000:00:03.1: Adding to iommu group 5
[    0.624027] pci 0000:00:04.0: Adding to iommu group 6
[    0.624031] pci 0000:00:05.0: Adding to iommu group 7
[    0.624038] pci 0000:00:07.0: Adding to iommu group 8
[    0.624042] pci 0000:00:07.1: Adding to iommu group 9
[    0.624048] pci 0000:00:08.0: Adding to iommu group 10
[    0.624053] pci 0000:00:08.1: Adding to iommu group 11
[    0.624060] pci 0000:00:14.0: Adding to iommu group 12
[    0.624063] pci 0000:00:14.3: Adding to iommu group 12
[    0.624077] pci 0000:00:18.0: Adding to iommu group 13
[    0.624081] pci 0000:00:18.1: Adding to iommu group 13
[    0.624084] pci 0000:00:18.2: Adding to iommu group 13
[    0.624088] pci 0000:00:18.3: Adding to iommu group 13
[    0.624091] pci 0000:00:18.4: Adding to iommu group 13
[    0.624097] pci 0000:00:18.5: Adding to iommu group 13
[    0.624101] pci 0000:00:18.6: Adding to iommu group 13
[    0.624104] pci 0000:00:18.7: Adding to iommu group 13
[    0.624110] pci 0000:01:00.0: Adding to iommu group 14
[    0.624119] pci 0000:02:00.0: Adding to iommu group 15
[    0.624124] pci 0000:02:00.1: Adding to iommu group 15
[    0.624129] pci 0000:02:00.2: Adding to iommu group 15
[    0.624132] pci 0000:03:00.0: Adding to iommu group 15
[    0.624134] pci 0000:03:08.0: Adding to iommu group 15
[    0.624135] pci 0000:03:09.0: Adding to iommu group 15
[    0.624137] pci 0000:06:00.0: Adding to iommu group 15
[    0.624148] pci 0000:07:00.0: Adding to iommu group 16
[    0.624153] pci 0000:07:00.1: Adding to iommu group 16
[    0.624158] pci 0000:07:00.2: Adding to iommu group 16
[    0.624163] pci 0000:07:00.3: Adding to iommu group 16
[    0.624168] pci 0000:08:00.0: Adding to iommu group 17
[    0.624175] pci 0000:09:00.0: Adding to iommu group 18
[    0.624181] pci 0000:09:00.1: Adding to iommu group 19
[    0.624186] pci 0000:09:00.3: Adding to iommu group 20
[    0.624193] pci 0000:09:00.4: Adding to iommu group 21
[    0.627045] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[    0.627047] AMD-Vi: Extended features (0x58f77ef22294a5a): PPR NX GT IA PC GA_vAPIC
[    0.627050] AMD-Vi: Interrupt remapping enabled
[    0.627135] amd_uncore: 4  amd_df counters detected
[    0.627139] amd_uncore: 6  amd_l3 counters detected
[    0.627237] LVT offset 0 assigned for vector 0x400
[    0.627284] perf: AMD IBS detected (0x000003ff)
[    0.627287] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[    0.628003] Initialise system trusted keyrings
[    0.628009] Key type blacklist registered
[    0.628027] workingset: timestamp_bits=41 max_order=23 bucket_order=0
[    0.628461] zbud: loaded
[    0.630835] Key type asymmetric registered
[    0.630836] Asymmetric key parser 'x509' registered
[    0.630839] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.630861] io scheduler mq-deadline registered
[    0.630862] io scheduler kyber registered
[    0.630877] io scheduler bfq registered
[    0.631061] pcieport 0000:00:01.1: AER: enabled with IRQ 26
[    0.631193] pcieport 0000:00:01.2: AER: enabled with IRQ 27
[    0.631310] pcieport 0000:00:03.1: AER: enabled with IRQ 28
[    0.631468] pcieport 0000:00:07.1: AER: enabled with IRQ 30
[    0.631564] pcieport 0000:00:08.1: AER: enabled with IRQ 31
[    0.632075] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.632087] efifb: probing for efifb
[    0.632093] efifb: framebuffer at 0xd0000000, using 3072k, total 3072k
[    0.632094] efifb: mode is 1024x768x32, linelength=4096, pages=1
[    0.632095] efifb: scrolling: redraw
[    0.632095] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.632112] fbcon: Deferring console take-over
[    0.632113] fb0: EFI VGA frame buffer device
[    0.632173] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    0.632186] ACPI: button: Power Button [PWRB]
[    0.632200] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.632614] ACPI: button: Power Button [PWRF]
[    0.635948] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1155
[    0.635959] Monitor-Mwait will be used to enter C-1 state
[    0.635963] ACPI: \_SB_.PLTF.C000: Found 2 idle states
[    0.638175] ACPI: \_SB_.PLTF.C002: Found 2 idle states
[    0.638246] ACPI: \_SB_.PLTF.C004: Found 2 idle states
[    0.638294] ACPI: \_SB_.PLTF.C006: Found 2 idle states
[    0.638341] ACPI: \_SB_.PLTF.C008: Found 2 idle states
[    0.638402] ACPI: \_SB_.PLTF.C00A: Found 2 idle states
[    0.638470] ACPI: \_SB_.PLTF.C001: Found 2 idle states
[    0.638539] ACPI: \_SB_.PLTF.C003: Found 2 idle states
[    0.638603] ACPI: \_SB_.PLTF.C005: Found 2 idle states
[    0.638665] ACPI: \_SB_.PLTF.C007: Found 2 idle states
[    0.638724] ACPI: \_SB_.PLTF.C009: Found 2 idle states
[    0.638787] ACPI: \_SB_.PLTF.C00B: Found 2 idle states
[    0.638920] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.639053] 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    0.639914] Non-volatile memory driver v1.3
[    0.639915] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    0.640316] nvme nvme0: pci function 0000:01:00.0
[    0.640340] ahci 0000:02:00.1: version 3.0
[    0.640453] ahci 0000:02:00.1: SSS flag set, parallel bus scan disabled
[    0.640513] ahci 0000:02:00.1: AHCI 0001.0301 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[    0.640514] ahci 0000:02:00.1: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
[    0.640761] scsi host0: ahci
[    0.640817] scsi host1: ahci
[    0.640859] scsi host2: ahci
[    0.640894] scsi host3: ahci
[    0.640930] scsi host4: ahci
[    0.640964] scsi host5: ahci
[    0.640979] ata1: SATA max UDMA/133 abar m131072@0xfc680000 port 0xfc680100 irq 41
[    0.640981] ata2: SATA max UDMA/133 abar m131072@0xfc680000 port 0xfc680180 irq 41
[    0.640983] ata3: SATA max UDMA/133 abar m131072@0xfc680000 port 0xfc680200 irq 41
[    0.640984] ata4: SATA max UDMA/133 abar m131072@0xfc680000 port 0xfc680280 irq 41
[    0.640985] ata5: SATA max UDMA/133 abar m131072@0xfc680000 port 0xfc680300 irq 41
[    0.640987] ata6: SATA max UDMA/133 abar m131072@0xfc680000 port 0xfc680380 irq 41
[    0.641014] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.641016] ehci-pci: EHCI PCI platform driver
[    0.641022] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.641024] ohci-pci: OHCI PCI platform driver
[    0.641029] uhci_hcd: USB Universal Host Controller Interface driver
[    0.641049] usbcore: registered new interface driver usbserial_generic
[    0.641052] usbserial: USB Serial support registered for generic
[    0.641090] rtc_cmos 00:02: RTC can wake from S4
[    0.641245] rtc_cmos 00:02: registered as rtc0
[    0.641285] rtc_cmos 00:02: setting system clock to 2021-11-19T19:24:53 UTC (1637349893)
[    0.641291] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    0.641355] ledtrig-cpu: registered to indicate activity on CPUs
[    0.641444] hid: raw HID events driver (C) Jiri Kosina
[    0.641474] drop_monitor: Initializing network drop monitor service
[    0.641505] Initializing XFRM netlink socket
[    0.641546] NET: Registered protocol family 10
[    0.645226] Freeing initrd memory: 8036K
[    0.647147] Segment Routing with IPv6
[    0.647148] RPL Segment Routing with IPv6
[    0.647161] NET: Registered protocol family 17
[    0.647569] microcode: CPU0: patch_level=0x0a201009
[    0.647573] microcode: CPU1: patch_level=0x0a201009
[    0.647578] microcode: CPU2: patch_level=0x0a201009
[    0.647583] microcode: CPU3: patch_level=0x0a201009
[    0.647588] microcode: CPU4: patch_level=0x0a201009
[    0.647593] microcode: CPU5: patch_level=0x0a201009
[    0.647599] microcode: CPU6: patch_level=0x0a201009
[    0.647603] microcode: CPU7: patch_level=0x0a201009
[    0.647607] microcode: CPU8: patch_level=0x0a201009
[    0.647612] microcode: CPU9: patch_level=0x0a201009
[    0.647616] microcode: CPU10: patch_level=0x0a201009
[    0.647621] microcode: CPU11: patch_level=0x0a201009
[    0.647623] microcode: Microcode Update Driver: v2.2.
[    0.647698] resctrl: L3 allocation detected
[    0.647699] resctrl: L3DATA allocation detected
[    0.647699] resctrl: L3CODE allocation detected
[    0.647699] resctrl: MB allocation detected
[    0.647700] resctrl: L3 monitoring detected
[    0.647701] IPI shorthand broadcast: enabled
[    0.647708] sched_clock: Marking stable (334121429, 313571410)->(752706475, -105013636)
[    0.647902] registered taskstats version 1
[    0.647907] Loading compiled-in X.509 certificates
[    0.649161] Loaded X.509 cert 'Build time autogenerated kernel key: 45d205d420df703c18a4eaa0abbba708488711c9'
[    0.649852] zswap: loaded using pool lz4/z3fold
[    0.649957] Key type ._fscrypt registered
[    0.649958] Key type .fscrypt registered
[    0.649958] Key type fscrypt-provisioning registered
[    0.650115] PM:   Magic number: 13:848:445
[    0.650227] RAS: Correctable Errors collector initialized.
[    0.661585] nvme nvme0: allocated 64 MiB host memory buffer.
[    0.679745] nvme nvme0: 8/0/0 default/read/poll queues
[    0.686166]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8
[    0.956094] ata1: SATA link down (SStatus 0 SControl 330)
[    1.271374] ata2: SATA link down (SStatus 0 SControl 330)
[    1.584598] ata3: SATA link down (SStatus 0 SControl 330)
[    1.638372] tsc: Refined TSC clocksource calibration: 3693.060 MHz
[    1.638381] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6a77744cfd5, max_idle_ns: 881590969987 ns
[    1.638419] clocksource: Switched to clocksource tsc
[    1.898556] ata4: SATA link down (SStatus 0 SControl 330)
[    2.211787] ata5: SATA link down (SStatus 0 SControl 330)
[    2.525052] ata6: SATA link down (SStatus 0 SControl 330)
[    2.525818] Freeing unused decrypted memory: 2036K
[    2.525967] Freeing unused kernel image (initmem) memory: 1796K
[    2.525969] Write protecting the kernel read-only data: 26624k
[    2.526243] Freeing unused kernel image (text/rodata gap) memory: 2036K
[    2.526381] Freeing unused kernel image (rodata/data gap) memory: 1156K
[    2.547189] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    2.547193] rodata_test: all tests were successful
[    2.547196] Run /init as init process
[    2.547196]   with arguments:
[    2.547197]     /init
[    2.547198]   with environment:
[    2.547198]     HOME=/
[    2.547198]     TERM=linux
[    2.547199]     BOOT_IMAGE=/boot/vmlinuz-linux
[    2.555716] fbcon: Taking over console
[    2.555760] Console: switching to colour frame buffer device 128x48
[    2.596830] xhci_hcd 0000:02:00.0: xHCI Host Controller
[    2.596836] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 1
[    2.652124] xhci_hcd 0000:02:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000000000410
[    2.652419] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.13
[    2.652421] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.652422] usb usb1: Product: xHCI Host Controller
[    2.652423] usb usb1: Manufacturer: Linux 5.13.12-arch1-1 xhci-hcd
[    2.652423] usb usb1: SerialNumber: 0000:02:00.0
[    2.652495] hub 1-0:1.0: USB hub found
[    2.652508] hub 1-0:1.0: 10 ports detected
[    2.655274] xhci_hcd 0000:02:00.0: xHCI Host Controller
[    2.655276] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 2
[    2.655277] xhci_hcd 0000:02:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[    2.655319] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.655328] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.13
[    2.655329] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.655329] usb usb2: Product: xHCI Host Controller
[    2.655330] usb usb2: Manufacturer: Linux 5.13.12-arch1-1 xhci-hcd
[    2.655330] usb usb2: SerialNumber: 0000:02:00.0
[    2.655374] hub 2-0:1.0: USB hub found
[    2.655381] hub 2-0:1.0: 4 ports detected
[    2.656705] xhci_hcd 0000:07:00.2: xHCI Host Controller
[    2.656707] xhci_hcd 0000:07:00.2: new USB bus registered, assigned bus number 3
[    2.657307] xhci_hcd 0000:07:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
[    2.657404] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.13
[    2.657405] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.657406] usb usb3: Product: xHCI Host Controller
[    2.657407] usb usb3: Manufacturer: Linux 5.13.12-arch1-1 xhci-hcd
[    2.657407] usb usb3: SerialNumber: 0000:07:00.2
[    2.657446] hub 3-0:1.0: USB hub found
[    2.657451] hub 3-0:1.0: 2 ports detected
[    2.657517] xhci_hcd 0000:07:00.2: xHCI Host Controller
[    2.657518] xhci_hcd 0000:07:00.2: new USB bus registered, assigned bus number 4
[    2.657519] xhci_hcd 0000:07:00.2: Host supports USB 3.1 Enhanced SuperSpeed
[    2.657535] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.657543] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.13
[    2.657543] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.657544] usb usb4: Product: xHCI Host Controller
[    2.657544] usb usb4: Manufacturer: Linux 5.13.12-arch1-1 xhci-hcd
[    2.657545] usb usb4: SerialNumber: 0000:07:00.2
[    2.657578] hub 4-0:1.0: USB hub found
[    2.657585] hub 4-0:1.0: 4 ports detected
[    2.657699] xhci_hcd 0000:09:00.3: xHCI Host Controller
[    2.657702] xhci_hcd 0000:09:00.3: new USB bus registered, assigned bus number 5
[    2.657805] xhci_hcd 0000:09:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[    2.658043] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.13
[    2.658044] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.658044] usb usb5: Product: xHCI Host Controller
[    2.658045] usb usb5: Manufacturer: Linux 5.13.12-arch1-1 xhci-hcd
[    2.658045] usb usb5: SerialNumber: 0000:09:00.3
[    2.658087] hub 5-0:1.0: USB hub found
[    2.658096] hub 5-0:1.0: 4 ports detected
[    2.658222] xhci_hcd 0000:09:00.3: xHCI Host Controller
[    2.658223] xhci_hcd 0000:09:00.3: new USB bus registered, assigned bus number 6
[    2.658224] xhci_hcd 0000:09:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[    2.658231] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.658238] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.13
[    2.658239] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.658240] usb usb6: Product: xHCI Host Controller
[    2.658240] usb usb6: Manufacturer: Linux 5.13.12-arch1-1 xhci-hcd
[    2.658241] usb usb6: SerialNumber: 0000:09:00.3
[    2.658277] hub 6-0:1.0: USB hub found
[    2.658282] hub 6-0:1.0: 4 ports detected
[    2.715598] EXT4-fs (nvme0n1p6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    2.728932] random: fast init done
[    2.783418] systemd[1]: systemd 249.3-1-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[    2.798124] systemd[1]: Detected architecture x86-64.
[    2.798394] systemd[1]: Hostname set to <elnathPC>.
[    2.830504] random: lvmconfig: uninitialized urandom read (4 bytes read)
[    2.861197] systemd[1]: Queued start job for default target Graphical Interface.
[    2.861677] systemd[1]: Created slice Slice /system/getty.
[    2.861799] systemd[1]: Created slice Slice /system/modprobe.
[    2.861957] systemd[1]: Created slice Slice /system/systemd-fsck.
[    2.862038] systemd[1]: Created slice User and Session Slice.
[    2.862068] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    2.862087] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.862149] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    2.862166] systemd[1]: Reached target Local Encrypted Volumes.
[    2.862174] systemd[1]: Reached target Login Prompts.
[    2.862186] systemd[1]: Reached target Path Units.
[    2.862194] systemd[1]: Reached target Remote File Systems.
[    2.862200] systemd[1]: Reached target Slice Units.
[    2.862211] systemd[1]: Reached target Swaps.
[    2.862219] systemd[1]: Reached target Local Verity Integrity Protected Volumes.
[    2.862249] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    2.862283] systemd[1]: Listening on LVM2 poll daemon socket.
[    2.862754] systemd[1]: Listening on Process Core Dump Socket.
[    2.862810] systemd[1]: Listening on Journal Audit Socket.
[    2.862846] systemd[1]: Listening on Journal Socket (/dev/log).
[    2.862884] systemd[1]: Listening on Journal Socket.
[    2.863647] systemd[1]: Listening on udev Control Socket.
[    2.863681] systemd[1]: Listening on udev Kernel Socket.
[    2.863973] systemd[1]: Mounting Huge Pages File System...
[    2.864275] systemd[1]: Mounting POSIX Message Queue File System...
[    2.864562] systemd[1]: Mounting Kernel Debug File System...
[    2.864846] systemd[1]: Mounting Kernel Trace File System...
[    2.865284] systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
[    2.865555] systemd[1]: Mounting Temporary Directory /tmp...
[    2.865865] systemd[1]: Starting Create List of Static Device Nodes...
[    2.866147] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    2.866443] systemd[1]: Starting Load Kernel Module configfs...
[    2.866767] systemd[1]: Starting Load Kernel Module drm...
[    2.867053] systemd[1]: Starting Load Kernel Module fuse...
[    2.867311] random: lvm: uninitialized urandom read (4 bytes read)
[    2.867358] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    2.867373] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    2.868134] systemd[1]: Starting Journal Service...
[    2.868716] systemd[1]: Starting Load Kernel Modules...
[    2.869102] Linux agpgart interface v0.103
[    2.869115] systemd[1]: Starting Remount Root and Kernel File Systems...
[    2.869157] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[    2.869501] systemd[1]: Starting Coldplug All udev Devices...
[    2.870098] systemd[1]: Mounted Huge Pages File System.
[    2.870139] systemd[1]: Mounted POSIX Message Queue File System.
[    2.870170] systemd[1]: Mounted Kernel Debug File System.
[    2.870200] systemd[1]: Mounted Kernel Trace File System.
[    2.870233] systemd[1]: Mounted Temporary Directory /tmp.
[    2.870338] systemd[1]: Finished Create List of Static Device Nodes.
[    2.870445] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    2.870518] systemd[1]: Finished Load Kernel Module configfs.
[    2.870843] systemd[1]: Mounting Kernel Configuration File System...
[    2.871820] EXT4-fs (nvme0n1p6): re-mounted. Opts: (null). Quota mode: none.
[    2.871881] fuse: init (API version 7.34)
[    2.872130] systemd[1]: Finished Remount Root and Kernel File Systems.
[    2.872222] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    2.872299] systemd[1]: Finished Load Kernel Module fuse.
[    2.872629] systemd[1]: Mounting FUSE Control File System...
[    2.872660] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[    2.873531] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    2.873966] systemd[1]: Starting Load/Save Random Seed...
[    2.874287] systemd[1]: Starting Create System Users...
[    2.874805] systemd[1]: Mounted Kernel Configuration File System.
[    2.874876] systemd[1]: Mounted FUSE Control File System.
[    2.875613] Asymmetric key parser 'pkcs8' registered
[    2.875967] systemd[1]: Finished Load Kernel Modules.
[    2.875997] audit: type=1130 audit(1637349895.730:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.876375] systemd[1]: Starting Apply Kernel Variables...
[    2.879463] systemd[1]: Finished Apply Kernel Variables.
[    2.879484] audit: type=1130 audit(1637349895.733:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.881354] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    2.881459] systemd[1]: Finished Load Kernel Module drm.
[    2.881478] audit: type=1130 audit(1637349895.737:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@drm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.881485] audit: type=1131 audit(1637349895.737:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@drm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.882815] systemd[1]: Finished Create System Users.
[    2.882830] audit: type=1130 audit(1637349895.737:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysusers comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.883135] systemd[1]: Starting Create Static Device Nodes in /dev...
[    2.891744] systemd[1]: Finished Create Static Device Nodes in /dev.
[    2.891760] audit: type=1130 audit(1637349895.747:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.892126] audit: type=1334 audit(1637349895.747:8): prog-id=14 op=LOAD
[    2.892187] audit: type=1334 audit(1637349895.747:9): prog-id=15 op=LOAD
[    2.892229] audit: type=1334 audit(1637349895.747:10): prog-id=16 op=LOAD
[    2.892388] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    2.894704] systemd[1]: Started Journal Service.
[    2.896741] systemd-journald[300]: Received client request to flush runtime journal.
[    2.904764] usb 1-3: new full-speed USB device number 2 using xhci_hcd
[    2.968267] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[    2.968306] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[    2.968330] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[    2.968381] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[    2.973058] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[    2.973060] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[    2.973101] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[    2.974497] nvidia-gpu 0000:07:00.3: enabling device (0000 -> 0002)
[    2.989694] random: mktemp: uninitialized urandom read (6 bytes read)
[    3.025081] input: PC Speaker as /devices/platform/pcspkr/input/input2
[    3.025102] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[    3.025166] sp5100-tco sp5100-tco: Using 0xfed80b00 for watchdog MMIO address
[    3.025172] sp5100-tco sp5100-tco: Watchdog hardware is disabled
[    3.027430] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[    3.027431] RAPL PMU: hw unit of domain package 2^-16 Joules
[    3.028866] cryptd: max_cpu_qlen set to 1000
[    3.028883] ccp 0000:09:00.1: enabling device (0000 -> 0002)
[    3.029022] ccp 0000:09:00.1: ccp: unable to access the device: you might be running a broken BIOS.
[    3.033426] AVX2 version of gcm_enc/dec engaged.
[    3.033448] AES CTR mode by8 optimization enabled
[    3.038316] EXT4-fs (nvme0n1p7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    3.049046] libphy: r8169: probed
[    3.049171] r8169 0000:06:00.0 eth0: RTL8168h/8111h, 7c:10:c9:21:1a:71, XID 541, IRQ 74
[    3.049173] r8169 0000:06:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[    3.109322] nvidia: loading out-of-tree module taints kernel.
[    3.109327] nvidia: module license 'NVIDIA' taints kernel.
[    3.109328] Disabling lock debugging due to kernel taint
[    3.120299] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[    3.127903] asus_wmi: ASUS WMI generic driver loaded
[    3.132144] nvidia-nvlink: Nvlink Core is being initialized, major device number 235
[    3.132704] nvidia 0000:07:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[    3.154596] r8169 0000:06:00.0 enp6s0: renamed from eth0
[    3.179850] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  470.63.01  Tue Aug  3 20:44:16 UTC 2021
[    3.186972] asus_wmi: Initialization: 0x0
[    3.187012] asus_wmi: BIOS WMI version: 0.9
[    3.187183] asus_wmi: SFUN value: 0x0
[    3.187185] eeepc-wmi eeepc-wmi: Detected ASUSWMI, use DCTS
[    3.187746] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input3
[    3.191812] kvm: disabled by bios
[    3.192672] snd_hda_intel 0000:07:00.1: enabling device (0000 -> 0002)
[    3.192740] snd_hda_intel 0000:07:00.1: Disabling MSI
[    3.192750] snd_hda_intel 0000:07:00.1: Handle vga_switcheroo audio client
[    3.192863] snd_hda_intel 0000:09:00.4: enabling device (0000 -> 0002)
[    3.193882] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  470.63.01  Tue Aug  3 20:30:55 UTC 2021
[    3.195748] [drm] [nvidia-drm] [GPU ID 0x00000700] Loading driver
[    3.195750] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:07:00.0 on minor 0
[    3.228635] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:07:00.1/sound/card0/input4
[    3.228661] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:07:00.1/sound/card0/input5
[    3.228682] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:07:00.1/sound/card0/input6
[    3.228701] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:07:00.1/sound/card0/input7
[    3.228718] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.1/0000:07:00.1/sound/card0/input8
[    3.228736] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:03.1/0000:07:00.1/sound/card0/input9
[    3.244900] usb 1-3: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.11
[    3.244904] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.244905] usb 1-3: Product: USB Receiver
[    3.244906] usb 1-3: Manufacturer: Logitech
[    3.248107] Generic FE-GE Realtek PHY r8169-0-600:00: attached PHY driver (mii_bus:phy_addr=r8169-0-600:00, irq=MAC)
[    3.318480] MCE: In-kernel MCE decoding enabled.
[    3.319938] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC897: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[    3.319941] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    3.319944] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    3.319945] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
[    3.319946] snd_hda_codec_realtek hdaudioC1D0:    dig-out=0x1e/0x0
[    3.319947] snd_hda_codec_realtek hdaudioC1D0:    inputs:
[    3.319947] snd_hda_codec_realtek hdaudioC1D0:      Front Mic=0x19
[    3.319948] snd_hda_codec_realtek hdaudioC1D0:      Rear Mic=0x18
[    3.319949] snd_hda_codec_realtek hdaudioC1D0:      Line=0x1a
[    3.321407] kvm: disabled by bios
[    3.333880] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card1/input10
[    3.333904] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card1/input11
[    3.333922] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card1/input12
[    3.333942] input: HD-Audio Generic Line Out Front as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card1/input13
[    3.333960] input: HD-Audio Generic Line Out Surround as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card1/input14
[    3.333977] input: HD-Audio Generic Line Out CLFE as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card1/input15
[    3.333995] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card1/input16
[    3.384762] usb 1-4: new full-speed USB device number 3 using xhci_hcd
[    3.408253] r8169 0000:06:00.0 enp6s0: Link is Down
[    3.470931] kvm: disabled by bios
[    3.652226] intel_rapl_common: Found RAPL domain package
[    3.652228] intel_rapl_common: Found RAPL domain core
[    3.655436] kvm: disabled by bios
[    3.711601] usb 1-4: New USB device found, idVendor=046d, idProduct=c332, bcdDevice= 3.02
[    3.711603] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.711605] usb 1-4: Product: Gaming Mouse G502
[    3.711605] usb 1-4: Manufacturer: Logitech
[    3.711606] usb 1-4: SerialNumber: 096A38663435
[    3.788633] kvm: disabled by bios
[    3.844773] usb 1-6: new full-speed USB device number 4 using xhci_hcd
[    3.949832] kvm: disabled by bios
[    4.082496] kvm: disabled by bios
[    4.152602] usb 1-6: config 1 has an invalid interface number: 2 but max is 1
[    4.152604] usb 1-6: config 1 has no interface number 1
[    4.164602] usb 1-6: New USB device found, idVendor=0b05, idProduct=1939, bcdDevice= 1.00
[    4.164604] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.164605] usb 1-6: Product: AURA LED Controller
[    4.164606] usb 1-6: Manufacturer: AsusTek Computer Inc.
[    4.164607] usb 1-6: SerialNumber: 9876543210
[    4.195769] nvidia-gpu 0000:07:00.3: i2c timeout error e0000000
[    4.195772] ucsi_ccg 3-0008: i2c_transfer failed -110
[    4.195773] ucsi_ccg 3-0008: ucsi_ccg_init failed - -110
[    4.195778] ucsi_ccg: probe of 3-0008 failed with error -110
[    4.235933] kvm: disabled by bios
[    4.291428] usb 1-7: new high-speed USB device number 5 using xhci_hcd
[    4.391191] kvm: disabled by bios
[    4.454105] usb 1-7: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.90
[    4.454107] usb 1-7: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    4.454109] usb 1-7: Product: USB2.0 Hub
[    4.463105] hub 1-7:1.0: USB hub found
[    4.467082] hub 1-7:1.0: 4 ports detected
[    4.508025] kvm: disabled by bios
[    4.608095] usb 1-9: new high-speed USB device number 6 using xhci_hcd
[    4.631437] random: crng init done
[    4.631438] random: 7 urandom warning(s) missed due to ratelimiting
[    4.774085] usb 1-9: New USB device found, idVendor=2357, idProduct=0120, bcdDevice= 2.00
[    4.774088] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.774089] usb 1-9: Product: 802.11ac WLAN Adapter
[    4.774090] usb 1-9: Manufacturer: Realtek
[    4.774091] usb 1-9: SerialNumber: 00e04c000001
[    5.869746] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-3/1-3:1.0/0003:046D:C52B.0001/input/input17
[    5.925378] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:02:00.0-3/input0
[    5.947185] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-3/1-3:1.1/0003:046D:C52B.0002/input/input18
[    5.947262] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-3/1-3:1.1/0003:046D:C52B.0002/input/input19
[    5.996422] kauditd_printk_skb: 34 callbacks suppressed
[    5.996424] audit: type=1103 audit(1637349898.850:45): pid=951 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[    6.003587] audit: type=1130 audit(1637349898.857:46): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@974 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.004832] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-3/1-3:1.1/0003:046D:C52B.0002/input/input20
[    6.004901] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:02:00.0-3/input1
[    6.008576] audit: type=1101 audit(1637349898.863:47): pid=955 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.008592] audit: type=1103 audit(1637349898.863:48): pid=955 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[    6.008618] audit: type=1006 audit(1637349898.863:49): pid=955 uid=0 old-auid=4294967295 auid=974 tty=(none) old-ses=4294967295 ses=1 res=1
[    6.008623] audit: type=1300 audit(1637349898.863:49): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7ffd4ae98550 a2=3 a3=3ce items=0 ppid=1 pid=955 auid=974 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" key=(null)
[    6.008624] audit: type=1327 audit(1637349898.863:49): proctitle="(systemd)"
[    6.009775] audit: type=1105 audit(1637349898.863:50): pid=955 uid=0 auid=974 ses=1 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.011967] audit: type=1334 audit(1637349898.867:51): prog-id=24 op=LOAD
[    6.011969] audit: type=1300 audit(1637349898.867:51): arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7fff88381810 a2=78 a3=7fff88381810 items=0 ppid=1 pid=955 auid=974 uid=974 gid=974 euid=974 suid=974 fsuid=974 egid=974 sgid=974 fsgid=974 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
[    6.019743] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:02:00.0-3/input2
[    6.028676] input: Logitech Gaming Mouse G502 as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-4/1-4:1.0/0003:046D:C332.0004/input/input22
[    6.028714] hid-generic 0003:046D:C332.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech Gaming Mouse G502] on usb-0000:02:00.0-4/input0
[    6.038754] input: Logitech Gaming Mouse G502 Keyboard as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-4/1-4:1.1/0003:046D:C332.0005/input/input23
[    6.094867] hid-generic 0003:046D:C332.0005: input,hiddev98,hidraw4: USB HID v1.11 Keyboard [Logitech Gaming Mouse G502] on usb-0000:02:00.0-4/input1
[    6.101825] hid-generic 0003:0B05:1939.0006: hiddev99,hidraw5: USB HID v1.11 Device [AsusTek Computer Inc. AURA LED Controller] on usb-0000:02:00.0-6/input2
[    6.101850] usbcore: registered new interface driver usbhid
[    6.101851] usbhid: USB HID core driver
[    6.224868] mousedev: PS/2 mouse device common for all mice
[    6.452161] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:02:00.0-3/input2
[    6.567855] input: Logitech Wireless Device PID:406e Keyboard as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-3/1-3:1.2/0003:046D:C52B.0003/0003:046D:406E.0007/input/input26
[    6.567959] hid-generic 0003:046D:406E.0007: input,hidraw1: USB HID v1.11 Keyboard [Logitech Wireless Device PID:406e] on usb-0000:02:00.0-3/input2:2
[    6.729769] input: Logitech K800 as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-3/1-3:1.2/0003:046D:C52B.0003/0003:046D:406E.0007/input/input30
[    6.729910] logitech-hidpp-device 0003:046D:406E.0007: input,hidraw1: USB HID v1.11 Keyboard [Logitech K800] on usb-0000:02:00.0-3/input2:2
[   10.731976] logitech-hidpp-device 0003:046D:406E.0007: HID++ 4.5 device connected.
[   11.705884] kauditd_printk_skb: 4 callbacks suppressed
[   11.705886] audit: type=1100 audit(1637349904.560:55): pid=1014 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="elnath" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[   11.706633] audit: type=1101 audit(1637349904.560:56): pid=1014 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="elnath" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[   11.726186] audit: type=1106 audit(1637349904.580:57): pid=951 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[   11.726206] audit: type=1104 audit(1637349904.580:58): pid=951 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[   11.727856] audit: type=1103 audit(1637349904.580:59): pid=1014 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="elnath" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[   11.727903] audit: type=1006 audit(1637349904.580:60): pid=1014 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[   11.727911] audit: type=1300 audit(1637349904.580:60): arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7ffc593e5900 a2=4 a3=3e8 items=0 ppid=514 pid=1014 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="lightdm" exe="/usr/bin/lightdm" key=(null)
[   11.727912] audit: type=1327 audit(1637349904.580:60): proctitle=6C69676874646D002D2D73657373696F6E2D6368696C64003132003139
[   11.735429] audit: type=1130 audit(1637349904.590:61): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   11.738029] audit: type=1101 audit(1637349904.590:62): pid=1049 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="elnath" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   21.987110] kauditd_printk_skb: 18 callbacks suppressed
[   21.987113] audit: type=1131 audit(1637349914.840:77): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@974 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   21.990594] audit: type=1131 audit(1637349914.843:78): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@974 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   33.223936] audit: type=1131 audit(1637349926.080:79): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   33.318150] audit: type=1334 audit(1637349926.173:80): prog-id=23 op=UNLOAD
[   33.318154] audit: type=1334 audit(1637349926.173:81): prog-id=22 op=UNLOAD
[   33.318156] audit: type=1334 audit(1637349926.173:82): prog-id=21 op=UNLOAD
[   41.975617] audit: type=1111 audit(1637349934.830:83): pid=496 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-activate uuid=a25289ae-fa8d-32c7-a1ff-94199c57cd68 name=576972656420636F6E6E656374696F6E2031 pid=1759 uid=1000 result=fail exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=failed'
[   65.757257] usb 1-4: USB disconnect, device number 3
[   73.611983] usb 1-3: USB disconnect, device number 2
[  302.254713] Generic FE-GE Realtek PHY r8169-0-600:00: Downshift occurred from negotiated speed 1Gbps to actual speed 100Mbps, check cabling!
[  302.254724] r8169 0000:06:00.0 enp6s0: Link is Up - 100Mbps/Full (downshifted) - flow control rx/tx
[  302.254736] IPv6: ADDRCONF(NETDEV_CHANGE): enp6s0: link becomes ready
[  304.266146] audit: type=1130 audit(1637350197.120:84): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  307.621627] usb 1-4: new full-speed USB device number 7 using xhci_hcd
[  307.945090] usb 1-4: New USB device found, idVendor=046d, idProduct=c332, bcdDevice= 3.02
[  307.945095] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  307.945097] usb 1-4: Product: Gaming Mouse G502
[  307.945098] usb 1-4: Manufacturer: Logitech
[  307.945099] usb 1-4: SerialNumber: 096A38663435
[  307.968161] input: Logitech Gaming Mouse G502 as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-4/1-4:1.0/0003:046D:C332.0008/input/input31
[  307.968247] hid-generic 0003:046D:C332.0008: input,hidraw0: USB HID v1.11 Mouse [Logitech Gaming Mouse G502] on usb-0000:02:00.0-4/input0
[  307.978227] input: Logitech Gaming Mouse G502 Keyboard as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-4/1-4:1.1/0003:046D:C332.0009/input/input32
[  308.035115] hid-generic 0003:046D:C332.0009: input,hiddev96,hidraw1: USB HID v1.11 Keyboard [Logitech Gaming Mouse G502] on usb-0000:02:00.0-4/input1
[  314.325078] audit: type=1131 audit(1637350206.633:85): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  362.370622] usb 1-3: new full-speed USB device number 8 using xhci_hcd
[  362.706344] usb 1-3: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.11
[  362.706348] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  362.706349] usb 1-3: Product: USB Receiver
[  362.706351] usb 1-3: Manufacturer: Logitech
[  362.780465] logitech-djreceiver 0003:046D:C52B.000C: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:02:00.0-3/input2
[  362.905423] input: Logitech K800 as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-3/1-3:1.2/0003:046D:C52B.000C/0003:046D:406E.000D/input/input35
[  362.905683] logitech-hidpp-device 0003:046D:406E.000D: input,hidraw3: USB HID v1.11 Keyboard [Logitech K800] on usb-0000:02:00.0-3/input2:2
[  364.527372] logitech-hidpp-device 0003:046D:406E.000D: HID++ 4.5 device connected.
[  574.985549] usb 1-9: USB disconnect, device number 6
[  590.044108] usb 5-1: new high-speed USB device number 2 using xhci_hcd
[  590.190638] usb 5-1: New USB device found, idVendor=2357, idProduct=0120, bcdDevice= 2.00
[  590.190641] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  590.190643] usb 5-1: Product: 802.11ac WLAN Adapter
[  590.190644] usb 5-1: Manufacturer: Realtek
[  590.190645] usb 5-1: SerialNumber: 00e04c000001
[  650.506424] audit: type=1100 audit(1637350542.814:86): pid=2918 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="elnath" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  650.507231] audit: type=1101 audit(1637350542.817:87): pid=2918 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="elnath" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  650.507569] audit: type=1110 audit(1637350542.817:88): pid=2918 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  650.508596] audit: type=1105 audit(1637350542.817:89): pid=2918 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  650.519942] audit: type=1106 audit(1637350542.827:90): pid=2918 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  650.519976] audit: type=1104 audit(1637350542.827:91): pid=2918 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  738.085241] audit: type=1101 audit(1637350630.394:92): pid=2929 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="elnath" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  738.085532] audit: type=1110 audit(1637350630.394:93): pid=2929 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  738.086549] audit: type=1105 audit(1637350630.398:94): pid=2929 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[elnath@elnathPC ~]$
This is hard to read this way. You need to run it in full screen terminal and post the link.
I am not on Plasma, I’m on XFCE.
[elnath@elnathPC ~]$ sudo dmesg | eso-sendlog
bash: eso-sendlog: command not found
not sure how to post that whole thing easier to read format.
Sorry i have a typo I’ll correct it.
Edit:
Done! Use a full terminal and post the link.
https://clbin.com/pEM0t
That’s much better! First of all your UEFI Bios is version 2006 dated 03/19/2021
There are three newer updates for that board so you should think about updating to the latest which is version 2423 at some point.
Also i see you haven’t updated as the kernel is 5.13.12 So i would do a full update
sudo pacman -Syu
It looks like it’s seeing the usb WiFi.
So after updating and rebooting. Click on the network icon and see if it sees your SSID and if you can connect to it.
That still is pretty new. Is there a big reason to upgrade BIOS if all hardware is recognized? As I know people usually upgrade to newer BIOS version if the hardware is not recognized / not working properly.
“Don’t fix it, if its working” ?
Just updated whole system and restart. Still no wifi.
