I just did an update, and now I can’t seem to allocate any pseudoterminals. I can open everything else (read: everything graphical). I’ve tried multiple window managers, and my fallback kernel. Any ideas?
My post in Superuser:
Can you post system logs:
Must not have been a proper update? Partial?
Can you still drop to a tty?
Are you use bash? fish? zsh?
The solution will most likely involve entering terminal commands. You might be able to get a fullscreen terminal by holding the keys CTRL
+ ALT
+ F2
. To switch back to the desktop hold down CTRL
+ ALT
+ F1
edit:
Xfce: ALT
+ F2
Unfortunately I don’t know the solution to this problem.
Superuser link shows Cinnamon and Xfce installed? Not a very clear picture of the problem.
Have you tried to login from TTY as mentioned above by @mrvictory.
If you can, then you could run the commands from there.
Edit: sorry @mrvictory
and @Melways
I saw the M and …
The SU link (which I should’ve also mentioned here) says that all of my WMs experience the problem, including both XFCE and Cinnamon. Cinnamon, though, specifically shows a spinning mouse icon when I click on my Terminal link (the rest of the WMs just seem to ignore my invoking the terminal completely).
It’s OK - I don’t mind being known as Mister Victory
My thinking was that if you can get a terminal in Xfce via ALT
+ F2
then after logging in there you could:
sudo pacman -S xfce4-terminal
Maybe you had 1 terminal emulator across desktops that somehow where uninstalled.
What is ALL of your WMs? What’s installed? Multiple desktops?
Done via an SSH session, but no difference.
A TTY (teletype) terminal, not a ptty/pseudoterminal.
Yes, BASH.
My point is that it’s window-manager agnostic. It’s happening everywhere. XFCE and Cinnamon (mentioned in that same comment), and Gnome.
Thanks for all of the responses.
It’s not an application problem, it’s presumably a pseudoterminal problem in that I can’t open a terminal window in any sense, though I can open an SSH session to myself, which seems like a paradox. Normal terminals work fine.
I’ve replaced the original Superuser post with this one, which is specific to it being a pseudoterminal anomaly:
As requested directly/indirectly above, this is my journalctl output:
I didn’t see any present/useful Xorg/X11 logging even though this is also, arguably, an X11 problem.
is selfdestroyed already …
May 22 15:46:25 dustinxps /usr/lib/gdm-x-session[5863]: /usr/bin/xfce4-terminal: error while loading shared libraries: libicuuc.so.70: cannot open shared object file: No such file or directory
Try reinstalling:
1 core/icu 71.1-1 [installed]
2 extra/harfbuzz-icu 4.3.0-1 [installed]
9 multilib/lib32-icu 71.1-1 [installed]
:edit: it is looking for 70, 71 is the current, looks like a partial upgrade, either ssh or chroot in and try and update.
