Well, you’re not wrong. I reproduced it directly from a TTY (tty, not ptty). I reinstalled all of those packages, but it didn’t make a difference. More directly, ldd obviously reported libicuuc.so.70 as being an unresolved dependency, too. It looks like all of the terminals, quite reasonably, use it.
I saw a reference somewhere to lddtree (pax-utils), which is an awesome tool, by the way. This reports that vte3 is what’s directly depending on it (libicuuc):
libvte-2.91.so.0 => /usr/lib/libvte-2.91.so.0
libgnutls.so.30 => /usr/lib/libgnutls.so.30
libp11-kit.so.0 => /usr/lib/libp11-kit.so.0
libdl.so.2 => /usr/lib/libdl.so.2
libbrotlienc.so.1 => /usr/lib/libbrotlienc.so.1
libidn2.so.0 => /usr/lib/libidn2.so.0
libunistring.so.2 => /usr/lib/libunistring.so.2
libtasn1.so.6 => /usr/lib/libtasn1.so.6
libnettle.so.8 => /usr/lib/libnettle.so.8
libhogweed.so.6 => /usr/lib/libhogweed.so.6
libgmp.so.10 => /usr/lib/libgmp.so.10
libicuuc.so.70 => None
libpcre2-8.so.0 => /usr/lib/libpcre2-8.so.0
Once I saw that, I remembered seeing a mention of it at the end of the original upgrade, and a couple of follow-up upgrades (to see if those prompts were effectively resolved). That vte3 dependency occurred at the end of all of my attempts. However, it stopped appearing, for some reason, shortly afterward, and I’d long forgotten about it.
I then then tried rebuilding that but it was ineffective and I kept getting a non-error erroneous message at the end:
(1/2) Arming ConditionNeedsUpdate...
(2/2) Checking which packages need to be rebuilt
foreign vte3-git
[dustin@dustinxps 18:19:25 ?=(0) ~]$
Note that the exit-code was (0) (see prompt). I wasn’t aware of what “foreign” meant, but I am now. A custom build. Then it occurred to me that I had installed the gnome-terminal transparency-patch (which is a custom build), and that maybe that was the culprit if maybe one or more of the terminals or their dependencies had done a major release. Clearly libicuuc had. So, I uninstalled my gnome-terminal transparency package. Still, I was stuck using vte3-git, and rebuilding that continued to not help.
I did a complete removal of vte3-git and it’s dependencies (it was manageable; I could just reinstall the few important-looking things after I reinstalled the terminal). I then installed “vte3” (the non-Git package), followed by most of the previously-removed dependencies. I then reinstalled xfce4-terminal and gnome-terminal. Then it worked.
Thank you for your suggestions.
