I have a Dell xps 17 running Atlantis gnome. The speakers do show up both in sound settings and in pulseaudio volume. The microphone does not show up at all.
I can say I have had EOS before, with the August ISO. Everything worked out of the box that time, and updating to pipewire later did not cause problems either. https://clbin.com/9kMPo
I was on the April .iso, but manually changed PulseAudio to Pipewire since that’s now the default and I don’t want to be left in the dust! I had one or two quirks with Pipewire output configuration, but between laptop speakers, bluetooth UE Boom speaker, and Samsung Galaxy bluetooth earbuds, everything does work on my end. Here’s my current sound setup, perhaps you might need to select a different ‘configuration’ ?
I remember that it looked like that before! how did you get the “volumes levels” tab? Bluetooth, headphones, usb c headset etc works. Only thing that does not work is the internal speakers and microphone.
The volume levels tab shows up whenever you have anything open that uses sound, for me that’s currently Vivaldi (displayed as chromium), gnome podcasts app, and Rhythmbox open which is currently playing music. System Sounds should always be there by default, if you don’t at least see that, then you might be missing a crucial package. As for the microphone, that should also be displayed by default. Your Dell XPS 17 was released back in May 2021, so the hardware “should” be support by the kernel by now, but it’s possible you might want to test the LTS and ZEN kernels via EndeavourOS akm app just to see if this is more a kernel issue than anything else. What kernel are you on now?
Edit: nevermind I forgot to check it: Kernel: 5.15.8-arch1-1 x86_64
