cmd like adb version works well but other cmds of adb are not working
All of them gets stucked and doesn’t provide any response…
Well all the things that are needed are already installed like android-udev android-tools
but still there is no response in the cmd adb devices, adb kill-server or start-server.
Tried all of them
Don’t know what might be the reason but only adb version is working and other cmds anre not responding
I have tried it with other devices also, but the issue persists
Yes, it is on file manager the cable is working fine.
Sir, does the path of the adb can give issue ?
I think the adb is installed in /usr/bin or it should be inside android SDK ?
[diyash@diyash-nitroan51555 ~]$ adb version
Android Debug Bridge version 1.0.41
Version 34.0.4-android-tools
Installed as /usr/bin/adb
Running on Linux 6.6.10-zen1-1-zen (x86_64)
I never install android-sdk only android-tools which i belive has been renamed to android-utils anyway the only tool i use is adb for weekly backups of my phone.
however even adb devices with nothing plugged in should give some output
I just realized your on the zen kernel i’m not sure if that would make a difference or not. However since I’m on the regular kernel and it works i would suspect its something to do with the zen kernel
