Well -n shows more than N
[ricklinux@eos-kde ~]$ inxi -n
Network: Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: wl
IF: wlan0 state: down mac: 8a:73:15:a2:f8:7f
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8168
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: 00:d8:61:9d:ac:6f
[ricklinux@eos-kde ~]$ inxi -N
Jonathon, the total output from inxi -NA was only Audio and Network so I put an abbreviated mention about Audio.
@Bobcapp
Well itās entirely your decision as i say you could install xfce offline and see if there is Ethernet after the install and reboot.
Edit: https://discovery.endeavouros.com/desktop-environments/how-to-install-desktop-environments-next-to-your-existing-ones/2021/03/
Iām going for it and install without the internet.
After all, youāve been good enough to spend all afternoon and then some to help me. You too Jonathon.
Iāll let you know how it goes. Thanks again.
Okay i put up the link to the wiki for installing another desktop and also tells you how to remove a desktop if the Ethernet does end up working.
Bobcapp, I asked for inxi -Na. Note the lower case a. -A will provide audio output which is obviously irrelevant here.
You the man. So far, so good. It is unpacking.
derek@t480s ~> inxi -Na
Network: Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel port: efa0 bus-ID: 00:1f.6
chip-ID: 8086:15d8 class-ID: 0200
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: efa0 bus-ID: 3d:00.0 chip-ID: 8086:24fd
class-ID: 0280
Device-3: Intel Bluetooth wireless interface type: USB driver: btusb bus-ID: 1-7:2 chip-ID: 8087:0a2b
class-ID: e001
derek@t480s ~>
Works here!
Sorry, my typing just sucks on a laptop. Just a typo. Thanks for all your help, time and patience. I really am grateful.
Thanks Derek, All of you are great in helping out a newbie.
Take your time - typos in terminal will cause massive problems for you. Everything matters.
Okay⦠I agree your inxi -Na gives even more info.
It does, though I think -n provides enough for the basics. I wonder why they implemented both -N and -n as that seems confusingā¦
I donāt know but i assume -Na means all?
-a is (AFAIK) relatively new and is equivalent to -xxx (e.g. my fairly typical -Fxxxz can now be shortened to -Faz).
I use -Fxxxz because it colors the output. Not sure about -Faz
Edit: Yes it does. Bonus!
@Bobcapp
Welll ⦠how did you make out installing the offline version?
Dev0ut
June 25, 2021, 3:35am
60
You can try to disable the Power Management (saving) feature from windows and Bios (like PCIe power management, power on by pci, intel pxe, wakeonlan), then reboot and try again
