Recently I decided to install EndeavourOS on my Samsung Galaxy Chromebook Go (the board it’s SASUKE), I flashed a custom firmware from MrChromebox.tech and the system works fine. I have just two problems: one it’s realated to kvm (maybe I’ll keep it for another question) and the most important it’s that I have no audio output from wired headphones.
What I read/found:
- A list of Jasperlake devices (just scroll down)
- Someone who did it (not for SASUKE tho) and, on the same website, a list of Google devices (no Jasperlake devices here…)
- Some problems: https://forum.endeavouros.com/t/audio-on-skylake-chromebook/5469
- Probably many others…
What I tried:
- Changing “profiles” in volume control: Pro Audio and Stereo Output
- Playing with aplay and speaker-test:
http://alsa-project.org/db/?f=d5b3ff61d4e0d745fbb9b4873f9358dbb62fabb4
$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sofda7219max983 [sof-da7219max98360a], device 0: Speakers (*) []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: sofda7219max983 [sof-da7219max98360a], device 1: Headset (*) []
Subdevices: 1/1
card 0: sofda7219max983 [sof-da7219max98360a], device 2: HDMI1 (*) []
Subdevices: 1/1
card 0: sofda7219max983 [sof-da7219max98360a], device 3: HDMI2 (*) []
Subdevices: 1/1
card 0: sofda7219max983 [sof-da7219max98360a], device 4: HDMI3 (*) []
Subdevices: 1/1
$ aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PipeWire Media Server)
sysdefault:CARD=sofda7219max983
sof-da7219max98360a,
Default Audio Device
usbstream:CARD=sofda7219max983
sof-da7219max98360a
USB Stream Output
$ speaker-test -D Headset
speaker-test 1.2.6
Playback device is Headset
Stream parameters are 48000Hz, S16_LE, 1 channels
Using 16 octaves of pink noise
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM Headset
Playback open error: -2,No such file or directory
I tried also other commands like speaker-test -D jack
but I had no luck and it was pretty random.
What I noticed:
- Pro Audio seems to perform better then Stereo Audio for “laptop audio” (using Stereo Audio it’s too loud)
Any idea is much appreciated
