No Audio devices at all
ok just did a fresh re-install because of other problems now I seem to have no audio devices at all.
please help?
Screenshot_20201003_223302
https://endeavouros.com/docs/hardware-and-network/audio/getting-information-on-soundproblems/
problem… I can’t hear the audio in the linked video…
but I did try a few commands:
â—Ź pulseaudio.socket - Sound System
     Loaded: loaded (/usr/lib/systemd/user/pulseaudio.socket; enabled; vend>
     Active: failed (Result: service-start-limit-hit) since Sat 2020-10-03 >
   Triggers: â—Ź pulseaudio.service
     Listen: /run/user/1000/pulse/native (Stream)
Oct 03 22:36:37 Kalevala systemd[1148]: Listening on Sound System.
Oct 03 22:36:40 Kalevala systemd[1148]: pulseaudio.socket: Failed with resu>
lines 1-8/8 (END)
and this:
Alsa mixer seems to be showing the proper sound cards,
Screw it, just going to re-install… again
In Linux world reinstall doesn’t help at all, it won’t magically work…
Except that it did, sound is working fine now
could be network issue or mirror problems while the first install…
Well glad it did, but you must have messed something up really hard then, usually if:
  1. Something gone wrong which worked before
  2. You can determine reason of what gone wrong through your actions (let’s say update or configuration change)
It’s very easy to fix / revert on Linux, without reinstalling anything.
fresh re-install
Or i just misunderstood you at first :laughing:
I thought fresh reinstall meant it was working before and you’ve tried to fix it with re-install :slight_smile:
You know as well as anyone else regardless of Linux, Winfows, OSX bad installs happen for what seems like no reason.
Several things can be easily overlooked leading to a bad installation. Badly prepared install media, not checking the checksum of the iso download, and not updating the mirrors on the live usb prior to installation.
Now, we’ll never know what was wrong. :disappointed: But at least your problem is fixed. :smiley:
After the basic install it was working, i installed lot… and I mean a LOT of things, did a reboot and suddenly it wasn’t working,
it was late, I had just finished reinstalling because of a totally different screw-up I made, and I was frustrated. Figured I hadn’t restored my backups or anything yet so…
I have this habit of tinkering with things, and then they break… It’s kind of why I like arch.
It must of happened between installed a LOT of things and screw-up I made, and I was frustrated.
We have all been there trust me! Just try Deepin for a while! :rofl:
Glad you got it fixed!
Greetings friends,
This has happened to me before on my new laptop and sadly remains unresolved.
I run endeavour on my desktop without any problems.
My new laptop, an x360 - 15.6 hybrid, has been a nightmare.
I really like EOS and was sad that I couldn’t make it work. I have tried the online help from arch for similar sound issues to no avail. I have tried the latest EOS installer as well, no sound.
Here is a list of the distros I have tried:
EOS KDE: above results. installs fine, but no sound. Bluetooth worked.
Debian 10.6 nonfree iso: no network card detected, could not install.
Manjaro 20.1: installs fine, no sound, bluetooth worked.
MX KDE: sound is present, but could not install hybrid graphics module.
Fedora 32: no sound, installs fine.
deepin: would not load for some reason (md5sum ok) - i was mostly interested in the reported improvement in fingerprint scanner detection.
Solus: installed fine with sound, but after eopkg upgrade (new 5.7 kernel), sound went away!
KaOS: installed fine, no sound.
POP_OS!: The only distribution that has worked with both sound and hybrid graphics. No bluetooth. No fingerprint. 4K working fine. Battery life great AFTER i did not encrypt whole disk (just user directory - this made a large difference in fan noise and battery life curiously).
It is my observation that pop has the oldest kernel of the bunch. I am concerned that if I upgrade, my sound may go away.
I am a little distraught about this issue, given the amount of time spent on this laptop. Thought about returning it, but I really got a nice machine for the price with 4k, etc… Also, Hp spectre line is pretty high-volume device, one would think? This after years of running debian fine on the prior generation 13 inch.
Anyone having similar issues? Thoughts for the future?
There is no sound
lspci output:
00:00.0 Host bridge: Intel Corporation Device 9b61 (rev 0c)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics (rev 02)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 0c)
00:12.0 Signal processing controller: Intel Corporation Comet Lake Thermal Subsytem
00:13.0 Serial controller: Intel Corporation Comet Lake Integrated Sensor Solution
00:14.0 USB controller: Intel Corporation Device 02ed
00:14.2 RAM memory: Intel Corporation Device 02ef
00:14.3 Network controller: Intel Corporation Wireless-AC 9462
00:15.0 Serial bus controller [0c80]: Intel Corporation Serial IO I2C Host Controller
00:15.1 Serial bus controller [0c80]: Intel Corporation Comet Lake Serial IO I2C Host Controller
00:16.0 Communication controller: Intel Corporation Comet Lake Management Engine Interface
00:17.0 RAID bus controller: Intel Corporation 82801 Mobile SATA Controller [RAID mode]
00:1c.0 PCI bridge: Intel Corporation Device 02ba (rev f0)
00:1c.4 PCI bridge: Intel Corporation Device 02bc (rev f0)
00:1d.0 PCI bridge: Intel Corporation Device 02b0 (rev f0)
00:1d.4 PCI bridge: Intel Corporation Device 02b4 (rev f0)
00:1d.6 PCI bridge: Intel Corporation Device 02b6 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Device 0284
00:1f.3 Multimedia audio controller: Intel Corporation Device 02c8
00:1f.4 SMBus: Intel Corporation Device 02a3
00:1f.5 Serial bus controller [0c80]: Intel Corporation Comet Lake SPI (flash) Controller
01:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS525A PCI Express Card Reader (rev 01)
02:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 2C 2018] (rev 06)
03:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 2C 2018] (rev 06)
03:01.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 2C 2018] (rev 06)
03:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 2C 2018] (rev 06)
04:00.0 System peripheral: Intel Corporation JHL7540 Thunderbolt 3 NHI [Titan Ridge 2C 2018] (rev 06)
3a:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge 2C 2018] (rev 06)
3b:00.0 3D controller: NVIDIA Corporation GP108M [GeForce MX250] (rev a1)
3c:00.0 Non-Volatile memory controller: Intel Corporation Device 0975 (rev 03)
3d:00.0 Non-Volatile memory controller: Intel Corporation Device 0975
lsmod
Module                  Size  Used by
msr                    16384  0
ses                    20480  0
enclosure              16384  1 ses
scsi_transport_sas     36864  1 ses
uas                    28672  0
usb_storage            77824  2 uas
ccm                    20480  6
uvcvideo               98304  0
videobuf2_vmalloc      20480  1 uvcvideo
videobuf2_memops       20480  1 videobuf2_vmalloc
videobuf2_v4l2         24576  1 uvcvideo
videobuf2_common       49152  2 videobuf2_v4l2,uvcvideo
videodev              225280  3 videobuf2_v4l2,uvcvideo,videobuf2_common
mc                     53248  4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
nvidia_uvm            966656  0
snd_soc_skl_hda_dsp    24576  10
snd_soc_hdac_hdmi      36864  1 snd_soc_skl_hda_dsp
snd_soc_dmic           16384  1
snd_hda_codec_hdmi     61440  1
joydev                 24576  0
snd_hda_codec_realtek   122880  1
snd_hda_codec_generic    81920  1 snd_hda_codec_realtek
snd_sof_pci            20480  0
snd_sof_intel_hda_common    69632  1 snd_sof_pci
snd_soc_hdac_hda       24576  1 snd_sof_intel_hda_common
snd_sof_intel_hda      20480  1 snd_sof_intel_hda_common
snd_sof_intel_byt      20480  1 snd_sof_pci
snd_sof_intel_ipc      20480  1 snd_sof_intel_byt
snd_sof               106496  4 snd_sof_pci,snd_sof_intel_hda_common,snd_sof_intel_byt,snd_sof_intel_ipc
snd_sof_xtensa_dsp     16384  1 snd_sof_pci
snd_hda_ext_core       28672  4 snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_sof_intel_hda
snd_soc_acpi_intel_match    32768  2 snd_sof_pci,snd_sof_intel_hda_common
snd_soc_acpi           16384  2 snd_sof_pci,snd_soc_acpi_intel_match
ledtrig_audio          16384  3 snd_hda_codec_generic,snd_hda_codec_realtek,snd_sof
nvidia_drm             45056  4
nvidia_modeset       1114112  3 nvidia_drm
snd_soc_core          245760  6 snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_soc_dmic,snd_soc_skl_hda_dsp
snd_compress           24576  1 snd_soc_core
ac97_bus               16384  1 snd_soc_core
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_hda_intel          53248  0
intel_rapl_msr         20480  0
snd_intel_dspcfg       24576  3 snd_hda_intel,snd_sof_pci,snd_sof_intel_hda_common
snd_hda_codec         131072  6 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek,snd_soc_hdac_hda,snd_soc_skl_hda_dsp
snd_hda_core           90112  11 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_sof_intel_hda,snd_soc_skl_hda_dsp
snd_hwdep              20480  1 snd_hda_codec
mei_hdcp               24576  0
snd_pcm               106496  9 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_core,snd_hda_core,snd_pcm_dmaengine
iwlmvm                380928  0
snd_seq_midi           20480  0
x86_pkg_temp_thermal    20480  0
intel_powerclamp       20480  0
nvidia              20680704  135 nvidia_uvm,nvidia_modeset
mac80211              843776  1 iwlmvm
coretemp               20480  0
snd_seq_midi_event     16384  1 snd_seq_midi
snd_rawmidi            36864  1 snd_seq_midi
kvm_intel             282624  0
libarc4                16384  1 mac80211
snd_seq                69632  2 snd_seq_midi,snd_seq_midi_event
snd_seq_device         16384  3 snd_seq,snd_seq_midi,snd_rawmidi
snd_timer              36864  2 snd_seq,snd_pcm
kvm                   663552  1 kvm_intel
nls_iso8859_1          16384  1
snd                    90112  34 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,snd_soc_core,snd_pcm,snd_soc_skl_hda_dsp,snd_rawmidi
input_leds             16384  0
iwlwifi               331776  1 iwlmvm
serio_raw              20480  0
intel_cstate           20480  0
intel_rapl_perf        20480  0
hp_wmi                 16384  0
wmi_bmof               16384  0
intel_wmi_thunderbolt    20480  0
mxm_wmi                16384  0
soundcore              16384  1 snd
ipmi_devintf           20480  0
ipmi_msghandler       106496  2 ipmi_devintf,nvidia
rtsx_pci_ms            24576  0
memstick               20480  1 rtsx_pci_ms
cfg80211              704512  3 iwlmvm,iwlwifi,mac80211
hid_sensor_accel_3d    20480  1
hid_sensor_rotation    20480  0
hid_sensor_incl_3d     20480  0
hid_sensor_magn_3d     20480  1
hid_sensor_gyro_3d     20480  0
hid_sensor_trigger     20480  11 hid_sensor_gyro_3d,hid_sensor_incl_3d,hid_sensor_accel_3d,hid_sensor_magn_3d,hid_sensor_rotation
industrialio_triggered_buffer    16384  5 hid_sensor_gyro_3d,hid_sensor_incl_3d,hid_sensor_accel_3d,hid_sensor_magn_3d,hid_sensor_rotation
kfifo_buf              16384  1 industrialio_triggered_buffer
hid_sensor_iio_common    20480  6 hid_sensor_gyro_3d,hid_sensor_trigger,hid_sensor_incl_3d,hid_sensor_accel_3d,hid_sensor_magn_3d,hid_sensor_rotation
mei_me                 40960  1
industrialio           73728  10 industrialio_triggered_buffer,hid_sensor_gyro_3d,hid_sensor_trigger,hid_sensor_incl_3d,kfifo_buf,hid_sensor_accel_3d,hid_sensor_magn_3d,hid_sensor_rotation
ucsi_acpi              16384  0
hid_multitouch         28672  0
mei                   106496  3 mei_hdcp,mei_me
typec_ucsi             40960  1 ucsi_acpi
processor_thermal_device    24576  0
intel_rapl_common      24576  2 intel_rapl_msr,processor_thermal_device
cros_ec_ishtp          20480  0
cros_ec                20480  1 cros_ec_ishtp
intel_soc_dts_iosf     20480  1 processor_thermal_device
typec                  45056  1 typec_ucsi
mac_hid                16384  0
int3403_thermal        16384  0
int3400_thermal        20480  0
acpi_pad              184320  0
int340x_thermal_zone    16384  2 int3403_thermal,processor_thermal_device
acpi_thermal_rel       16384  1 int3400_thermal
intel_hid              20480  0
hp_wireless            16384  0
sparse_keymap          16384  2 hp_wmi,intel_hid
sch_fq_codel           20480  1
parport_pc             40960  0
ppdev                  24576  0
lp                     20480  0
parport                53248  3 parport_pc,lp,ppdev
ip_tables              32768  0
x_tables               40960  1 ip_tables
autofs4                45056  2
dm_crypt               40960  2
raid10                 57344  0
raid456               155648  0
async_raid6_recov      24576  1 raid456
async_memcpy           20480  2 raid456,async_raid6_recov
async_pq               24576  2 raid456,async_raid6_recov
async_xor              20480  3 async_pq,raid456,async_raid6_recov
async_tx               20480  5 async_pq,async_memcpy,async_xor,raid456,async_raid6_recov
xor                    24576  1 async_xor
raid6_pq              114688  3 async_pq,raid456,async_raid6_recov
libcrc32c              16384  1 raid456
raid1                  45056  0
raid0                  24576  0
multipath              20480  0
linear                 20480  0
system76_io            16384  0
system76_acpi          16384  0
hid_sensor_custom      24576  0
hid_sensor_hub         24576  8 hid_sensor_gyro_3d,hid_sensor_trigger,hid_sensor_iio_common,hid_sensor_incl_3d,hid_sensor_accel_3d,hid_sensor_magn_3d,hid_sensor_rotation,hid_sensor_custom
intel_ishtp_loader     24576  0
intel_ishtp_hid        24576  0
hid_generic            16384  0
crct10dif_pclmul       16384  1
crc32_pclmul           16384  0
ghash_clmulni_intel    16384  0
i915                 1986560  27
aesni_intel           372736  4291
i2c_algo_bit           16384  1 i915
drm_kms_helper        184320  2 nvidia_drm,i915
crypto_simd            16384  1 aesni_intel
syscopyarea            16384  1 drm_kms_helper
cryptd                 24576  2145 crypto_simd,ghash_clmulni_intel
sysfillrect            16384  1 drm_kms_helper
rtsx_pci_sdmmc         28672  0
glue_helper            16384  1 aesni_intel
nvme                   49152  3
sysimgblt              16384  1 drm_kms_helper
fb_sys_fops            16384  1 drm_kms_helper
drm                   491520  16 drm_kms_helper,nvidia_drm,i915
i2c_i801               32768  0
ahci                   40960  0
nvme_core             102400  6 nvme
intel_lpss_pci         20480  0
thunderbolt           167936  0
intel_lpss             16384  1 intel_lpss_pci
libahci                32768  1 ahci
intel_ish_ipc          24576  0
idma64                 20480  0
rtsx_pci               73728  2 rtsx_pci_sdmmc,rtsx_pci_ms
intel_ishtp            49152  4 cros_ec_ishtp,intel_ishtp_hid,intel_ish_ipc,intel_ishtp_loader
virt_dma               20480  1 idma64
i2c_hid                28672  0
hid                   131072  5 i2c_hid,hid_multitouch,hid_sensor_hub,intel_ishtp_hid,hid_generic
wmi                    32768  4 hp_wmi,intel_wmi_thunderbolt,wmi_bmof,mxm_wmi
pinctrl_cannonlake     36864  1
video                  49152  1 i915
pinctrl_intel          28672  1 pinctrl_cannonlake
neofetch:
             /////////////                anblanco@pop-os
      ///////*767////////////////         OS: Pop!_OS 20.04 LTS x86_64
    //////7676767676*//////////////       Host: HP Spectre x360 Convertible 15-
   /////76767//7676767//////////////      Kernel: 5.4.0-7642-generic
  /////767676///*76767///////////////     Uptime: 14 hours, 27 mins
 ///////767676///76767.///7676*///////    Packages: 2129 (dpkg)
/////////767676//76767///767676////////   Shell: bash 5.0.17
//////////76767676767////76767/////////   Resolution: 3840x2160
///////////76767676//////7676//////////   DE: GNOME
////////////,7676,///////767///////////   WM: Mutter
/////////////*7676///////76////////////   WM Theme: Pop
///////////////7676////////////////////   Theme: Arc-BLACK-3.36 [GTK2/3]
 ///////////////7676///767////////////    Icons: Humanity-Dark [GTK2/3]
  //////////////////////'////////////     Terminal: gnome-terminal
   //////.7676767676767676767,//////      CPU: Intel i7-10510U (8) @ 4.900GHz
    /////767676767676767676767/////       GPU: Intel UHD Graphics
      ///////////////////////////         GPU: NVIDIA GeForce MX250
         /////////////////////            Memory: 5195MiB / 15644MiB
You have to install: sof-firmware
It is in Extra as shown here with a search.
[ricklinux@eos-plasma ~]$ yay -Ss sof-firmware
extra/sof-firmware 1.6-1 (602.4 KiB 7.3 MiB)
    Sound Open Firmware
Edit: Looks like it’s installed on PopOS but not on the others?
thank you once again ricklinux,
as always, you are prompt and most helpful.
i installed this module previously to no avail.
perhaps i can try again with your new disc.
how can i try this on the livecd before committing to a complete installation?
thanks again!
Does the audio not work on the live usb?
no
I’m not sure if you boot on the live usb and try installing it.
sudo pacman -S sof-firmware
Edit: I’m surprised that it didn’t work if you installed it before?
Edit2: Maybe you can also give me the output for this.
inxi -Fxxxa --no-host
It should work on EndeavourOS if you install the sof-firmware which is required for that particular Intel Audio chip. Not sure why it didn’t if as you say you installed it other than looking to see that the correct audio device is selected for output. So it may have been there but on the wrong device. You should be able to check that by right click on volume icon and configure audio device to see if the correct one is selected.
Edit: Hope this helps.
