Dear EOSers,
yesterday I updated my system and that somehow killed my audio system: No more hardware was displayed in the control centre, no output, no input. I could manage to have output again:
Following
https://bbs.archlinux.org/viewtopic.php?id=258594
I created a file /etc/modprobe.d/dsp.conf
and added the line
options snd_intel_dspcfg dsp_driver=1
The hardware iss displayed again, the loudspeaker works.
However, the microphone still does not work.
I commented out the line
#load-module module-alsa-source device=hw:1,0
load-module module-alsa-source device=hw:0,0
and repleaced the ‘1’ by a ‘0’.
in the file
/etc/pulse/default.pa
as advised in
https://wiki.archlinux.org/index.php/PulseAudio/Troubleshooting#Microphone_not_detected_by_PulseAudio
What else can I do?
Paul
Hello @poseidon
Hopefully you put those changes back since they didn’t work. Did you go into /var/log/pacman.log and see what updates were done on that day where the problem started? It would also be a lot more helpful to provide more information such as the desktop you have installed and your hardware info.
You can provide a link to your hardware from the following command.
inxi -Fxxxz --no-host | eos-sendlog
Have a look if there is a .pacnew, see here.
There are pacnew files and I used them minutes ago to replace the original conf-files as suggested in an other thread in this forum. No success.
Of course, ricklinux, sorry!
http://ix.io/2ViN
The log file reads
[2021-04-06T08:16:59+0200] [PACMAN] Running 'pacman -Syu'
[2021-04-06T08:16:59+0200] [PACMAN] synchronizing package lists
[2021-04-06T08:17:00+0200] [PACMAN] starting full system upgrade
[2021-04-06T08:17:28+0200] [ALPM] running '60-mkinitcpio-remove.hook'...
[2021-04-06T08:17:28+0200] [ALPM] running '71-dkms-remove.hook'...
[2021-04-06T08:17:29+0200] [ALPM-SCRIPTLET] ==> dkms remove --no-depmod -m vboxhost -v 6.1.18_OSE -k 5.11.4-arch1-1
[2021-04-06T08:17:29+0200] [ALPM-SCRIPTLET] ==> depmod 5.11.4-arch1-1
[2021-04-06T08:17:37+0200] [ALPM] transaction started
[2021-04-06T08:17:38+0200] [ALPM] removed hunspell-en_GB (2020.12.07-1)
[2021-04-06T08:17:38+0200] [ALPM] removed python-dbus (1.2.16-3)
[2021-04-06T08:17:38+0200] [ALPM] removed python-dbus-common (1.2.16-3)
[2021-04-06T08:17:38+0200] [ALPM] upgraded attr (2.4.48-3 -> 2.5.1-1)
[2021-04-06T08:17:38+0200] [ALPM] upgraded acl (2.2.53-3 -> 2.3.1-1)
[2021-04-06T08:17:38+0200] [ALPM] upgraded glib2 (2.66.7-1 -> 2.68.0-5)
[2021-04-06T08:17:38+0200] [ALPM] upgraded zstd (1.4.8-1 -> 1.4.9-1)
[2021-04-06T08:17:38+0200] [ALPM] upgraded gdk-pixbuf2 (2.42.2-1 -> 2.42.4-1)
[2021-04-06T08:17:38+0200] [ALPM] upgraded harfbuzz (2.7.4-1 -> 2.8.0-1)
[2021-04-06T08:17:38+0200] [ALPM] upgraded fontconfig (2:2.13.91+48+gfcb0420-2 -> 2:2.13.93-4)
[2021-04-06T08:17:38+0200] [ALPM-SCRIPTLET] Creating fontconfig configuration...
[2021-04-06T08:17:38+0200] [ALPM-SCRIPTLET] >>> If you have configured NoExtract to prevent symlinks in /etc/fonts/conf.d/
[2021-04-06T08:17:38+0200] [ALPM-SCRIPTLET] from being restored, these symlinks have been recreated one last time. You
[2021-04-06T08:17:38+0200] [ALPM-SCRIPTLET] can now delete the symlinks and remove the paths from NoExtract and they
[2021-04-06T08:17:38+0200] [ALPM-SCRIPTLET] will not be created again.
[2021-04-06T08:17:38+0200] [ALPM-SCRIPTLET] Rebuilding fontconfig cache...
[2021-04-06T08:17:43+0200] [ALPM] upgraded cairo (1.17.4-3 -> 1.17.4-5)
[2021-04-06T08:17:43+0200] [ALPM] upgraded pango (1:1.48.2-1 -> 1:1.48.4-1)
[2021-04-06T08:17:43+0200] [ALPM] upgraded gtk-update-icon-cache (1:4.0.3-1 -> 1:4.2.0-2)
[2021-04-06T08:17:43+0200] [ALPM] upgraded adwaita-icon-theme (3.38.0-1 -> 40rc-1)
[2021-04-06T08:17:43+0200] [ALPM] upgraded alsa-card-profiles (1:0.3.23-1 -> 1:0.3.24-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded openssl (1.1.1.j-1 -> 1.1.1.k-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded libldap (2.4.57-1 -> 2.4.58-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded krb5 (1.18.3-1 -> 1.19.1-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded nettle (3.7.1-1 -> 3.7.2-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded audit (3.0-1 -> 3.0.1-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded libcap (2.48-1 -> 2.49-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded libgpg-error (1.41-1 -> 1.42-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded systemd-libs (247.3-1 -> 248-3)
[2021-04-06T08:17:44+0200] [ALPM] upgraded gnutls (3.7.0-1 -> 3.7.1-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded gtk2 (2.24.33-1 -> 2.24.33-2)
[2021-04-06T08:17:44+0200] [ALPM] upgraded nspr (4.29-1 -> 4.30-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded sqlite (3.34.1-1 -> 3.35.4-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded nss (3.62-1 -> 3.63-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded arduino (1:1.8.13-2 -> 1:1.8.13-3)
[2021-04-06T08:17:44+0200] [ALPM] upgraded at-spi2-core (2.38.0-1 -> 2.40.0-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded vulkan-icd-loader (1.2.171-1 -> 1.2.172-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded libssh2 (1.9.0-2 -> 1.9.0-3)
[2021-04-06T08:17:44+0200] [ALPM] upgraded libnghttp2 (1.41.0-1 -> 1.43.0-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded ca-certificates-mozilla (3.62-1 -> 3.63-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded curl (7.75.0-1 -> 7.76.0-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded libedit (20191231_3.1-3 -> 20210216_3.1-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded mesa (20.3.4-3 -> 21.0.1-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded libxkbcommon (1.1.0-1 -> 1.2.0-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded libxkbcommon-x11 (1.1.0-1 -> 1.2.0-1)
[2021-04-06T08:17:44+0200] [ALPM] upgraded cryptsetup (2.3.4-2 -> 2.3.5-2)
[2021-04-06T08:17:44+0200] [ALPM] upgraded file (5.39-1 -> 5.40-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded systemd (247.3-1 -> 248-3)
[2021-04-06T08:17:45+0200] [ALPM-SCRIPTLET] Creating group sgx with gid 967.
[2021-04-06T08:17:45+0200] [ALPM-SCRIPTLET] Creating group systemd-oom with gid 966.
[2021-04-06T08:17:45+0200] [ALPM-SCRIPTLET] Creating user systemd-oom (systemd Userspace OOM Killer) with uid 966 and gid 966.
[2021-04-06T08:17:45+0200] [ALPM] upgraded libgudev (234-1 -> 236-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded libinput (1.17.0-1 -> 1.17.1-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded attica (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded ki18n (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded karchive (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded kconfig (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded kcoreaddons (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded poppler (21.03.0-1 -> 21.04.0-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded poppler-qt5 (21.03.0-1 -> 21.04.0-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded libpulse (14.2-2 -> 14.2-3)
[2021-04-06T08:17:45+0200] [ALPM] upgraded libva (2.10.0-1 -> 2.11.0-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded libvpx (1.9.0-1 -> 1.10.0-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded x264 (3:0.160.r3011.cde9a93-1 -> 3:0.161.r3039.544c61f-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded x265 (3.4-1 -> 3.5-1)
[2021-04-06T08:17:45+0200] [ALPM] installed zimg (3.0.1-2)
[2021-04-06T08:17:45+0200] [ALPM] upgraded ffmpeg (2:4.3.2-1 -> 2:4.3.2-5)
[2021-04-06T08:17:45+0200] [ALPM] upgraded kfilemetadata (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded kidletime (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded js78 (78.8.0-1 -> 78.9.0-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded btrfs-progs (5.10.1-3 -> 5.11.1-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded gptfdisk (1.0.6-1 -> 1.0.7-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded libinih (52-2 -> 53-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded xfsprogs (5.10.0-2 -> 5.11.0-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded libassuan (2.5.4-2 -> 2.5.5-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded pinentry (1.1.0-5 -> 1.1.1-1)
[2021-04-06T08:17:45+0200] [ALPM] upgraded solid (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kwidgetsaddons (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kjobwidgets (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kdbusaddons (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kwindowsystem (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kcrash (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kglobalaccel (5.79.0-1 -> 5.80.0-2)
[2021-04-06T08:17:46+0200] [ALPM] upgraded qt5-svg (5.15.2-1 -> 5.15.2-2)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kauth (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kcodecs (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kguiaddons (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kconfigwidgets (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kitemviews (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kiconthemes (5.79.0-1 -> 5.80.0-2)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kxmlgui (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kbookmarks (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded iso-codes (4.5.0-1 -> 4.6.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded gstreamer (1.18.3-1 -> 1.18.4-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded gst-plugins-base-libs (1.18.3-1 -> 1.18.4-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded gst-plugins-base (1.18.3-1 -> 1.18.4-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded knotifications (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kservice (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kwallet (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kcompletion (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded sonnet (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded ktextwidgets (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kded (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded kio (5.79.0-1 -> 5.80.1-2)
[2021-04-06T08:17:46+0200] [ALPM] upgraded lmdb (0.9.28-1 -> 0.9.29-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded baloo (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded dconf (0.38.0-1 -> 0.40.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded libgusb (0.3.5-1 -> 0.3.6-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded gsettings-desktop-schemas (3.38.0-1 -> 40.0-2)
[2021-04-06T08:17:46+0200] [ALPM] upgraded glib-networking (2.66.0-1 -> 1:2.68.0-1)
[2021-04-06T08:17:46+0200] [ALPM] upgraded libsoup (2.72.0+5+g0b094bff-3 -> 2.72.0+10+gfe1e295d-1)
[2021-04-06T08:17:47+0200] [ALPM] upgraded gtk3 (1:3.24.26-1 -> 1:3.24.28-1)
[2021-04-06T08:17:47+0200] [ALPM] upgraded libhandy (1.0.3-1 -> 1.2.0-2)
[2021-04-06T08:17:47+0200] [ALPM] upgraded baobab (3.38.0-1 -> 40.0-1)
[2021-04-06T08:17:47+0200] [ALPM] upgraded bind (9.16.12-1 -> 9.16.13-1)
[2021-04-06T08:17:47+0200] [ALPM] upgraded bison (3.7.3-1 -> 3.7.6-1)
[2021-04-06T08:17:48+0200] [ALPM] upgraded bluez (5.56-1 -> 5.58-1)
[2021-04-06T08:17:48+0200] [ALPM] upgraded pulseaudio (14.2-2 -> 14.2-3)
[2021-04-06T08:17:48+0200] [ALPM] upgraded bluez-libs (5.56-1 -> 5.58-1)
[2021-04-06T08:17:48+0200] [ALPM] upgraded pulseaudio-bluetooth (14.2-2 -> 14.2-3)
[2021-04-06T08:17:48+0200] [ALPM] upgraded gnome-bluetooth (3.34.3-1 -> 3.34.5-1)
[2021-04-06T08:17:48+0200] [ALPM] installed dbus-python (1.2.16-4)
[2021-04-06T08:17:48+0200] [ALPM] upgraded gobject-introspection-runtime (1.66.1-3 -> 1.68.0-1)
[2021-04-06T08:17:48+0200] [ALPM] upgraded python-gobject (3.38.0-3 -> 3.40.1-1)
[2021-04-06T08:17:48+0200] [ALPM] upgraded blueberry (1.3.9-1 -> 1.4.2-1)
[2021-04-06T08:17:48+0200] [ALPM] upgraded kpackage (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:48+0200] [ALPM] upgraded knewstuff (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:48+0200] [ALPM] upgraded frameworkintegration (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:48+0200] [ALPM] upgraded kdecoration (5.21.2-1 -> 5.21.3-1)
[2021-04-06T08:17:49+0200] [ALPM] upgraded breeze-icons (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:49+0200] [ALPM] upgraded kwayland (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:49+0200] [ALPM] upgraded breeze (5.21.2-1 -> 5.21.3-1)
[2021-04-06T08:17:49+0200] [ALPM] upgraded breeze-gtk (5.21.2-1 -> 5.21.3-1)
[2021-04-06T08:17:49+0200] [ALPM] upgraded libcaca (0.99.beta19-3 -> 0.99.beta19-4)
[2021-04-06T08:17:49+0200] [ALPM] upgraded openmpi (4.0.5-2 -> 4.0.5-3)
[2021-04-06T08:17:49+0200] [ALPM] upgraded rubberband (1.9-1 -> 1.9.1-1)
[2021-04-06T08:17:49+0200] [ALPM] upgraded glslang (11.2.0-1 -> 11.2.0-3)
[2021-04-06T08:17:49+0200] [ALPM] upgraded spirv-tools (2020.6-1 -> 2020.7-1)
[2021-04-06T08:17:49+0200] [ALPM] upgraded shaderc (2020.3-2 -> 2020.5-1)
[2021-04-06T08:17:49+0200] [ALPM] upgraded mpv (1:0.33.0-4 -> 1:0.33.1-1)
[2021-04-06T08:17:49+0200] [ALPM] upgraded celluloid (0.20-1 -> 0.21-1)
[2021-04-06T08:17:49+0200] [ALPM] upgraded cmake (3.19.6-1 -> 3.20.0-1)
[2021-04-06T08:17:49+0200] [ALPM] upgraded qpdf (10.3.0-1 -> 10.3.1-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded imagemagick (7.0.11.3-1 -> 7.0.11.6-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded liblouis (3.16.0-1 -> 3.17.0-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded cups-filters (1.28.7-1 -> 1.28.8-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded dconf-editor (3.38.2-1 -> 3.38.3-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded python-monotonic (1.5-6 -> 1.5-7)
[2021-04-06T08:17:50+0200] [ALPM] upgraded python-cryptography (3.4.6-1 -> 3.4.7-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded duplicity (0.8.16-2 -> 0.8.18-2)
[2021-04-06T08:17:50+0200] [ALPM] upgraded gcr (3.38.1-1 -> 3.40.0-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded gvfs (1.46.2-1 -> 1.48.0-2)
[2021-04-06T08:17:50+0200] [ALPM] upgraded gnome-keyring (1:3.36.0-3 -> 1:40.0-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded python-yaml (5.3.1-4 -> 5.4.1.1-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded python-setuptools (1:53.1.0-1 -> 1:54.2.0-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded python-pyasn1-modules (0.2.8-3 -> 0.2.8-4)
[2021-04-06T08:17:50+0200] [ALPM] upgraded python-google-auth (1.27.1-1 -> 1.28.0-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded protobuf (3.12.4-3 -> 3.15.7-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded python-protobuf (3.12.4-3 -> 3.15.7-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded python-chardet (3.0.4-7 -> 4.0.0-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded python-idna (2.10-3 -> 3.1-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded python-urllib3 (1.26.3-1 -> 1.26.4-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded python-google-api-core (1.26.0-1 -> 1.26.1-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded python-httplib2 (0.19.0-1 -> 0.19.1-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded python-google-auth-httplib2 (0.0.4-3 -> 0.1.0-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded deja-dup (42.5-1 -> 42.7-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded dialog (1:1.3_20210117-1 -> 1:1.3_20210324-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded ell (0.38-1 -> 0.39-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded endeavouros-mirrorlist (3.3-1 -> 3.4-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded harfbuzz-icu (2.7.4-1 -> 2.8.0-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded libwpe (1.8.0-1 -> 1.10.0-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded wpebackend-fdo (1.8.0-1 -> 1.8.2-1)
[2021-04-06T08:17:50+0200] [ALPM] installed libmanette (0.2.6-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded webkit2gtk (2.30.5-1 -> 2.32.0-1)
[2021-04-06T08:17:50+0200] [ALPM] upgraded yad (8.0-1 -> 9.2-1)
[2021-04-06T08:17:51+0200] [ALPM] upgraded eos-translations (1.1.13-1 -> 1.1.14-1)
[2021-04-06T08:17:51+0200] [ALPM] upgraded eos-bash-shared (1.5.28-1 -> 1.6.15-1)
[2021-04-06T08:17:51+0200] [ALPM] upgraded eos-hooks (1.4.6-1 -> 1.4.7-1)
[2021-04-06T08:17:51+0200] [ALPM] warning: /etc/pacman.d/mirrorlist installed as /etc/pacman.d/mirrorlist.pacnew
[2021-04-06T08:17:51+0200] [ALPM] upgraded pacman-mirrorlist (20210302-1 -> 20210405-1)
[2021-04-06T08:17:51+0200] [ALPM] upgraded eos-update-notifier (1.13.2-1 -> 1.13.3-1)
[2021-04-06T08:17:51+0200] [ALPM] upgraded extra-cmake-modules (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:51+0200] [ALPM] upgraded noto-fonts (20201226-1 -> 20201226-2)
[2021-04-06T08:17:51+0200] [ALPM] upgraded ttf-croscore (20201226-1 -> 20201226-2)
[2021-04-06T08:17:51+0200] [ALPM] upgraded ttf-dejavu (2.37+18+g9b5d1b2f-2 -> 2.37+18+g9b5d1b2f-3)
[2021-04-06T08:17:52+0200] [ALPM] upgraded firefox (86.0-2 -> 87.0-1)
[2021-04-06T08:17:52+0200] [ALPM] upgraded fluidsynth (2.1.7-1 -> 2.1.8-1)
[2021-04-06T08:17:52+0200] [ALPM] upgraded libavif (0.8.4-2 -> 0.9.0-1)
[2021-04-06T08:17:52+0200] [ALPM] upgraded libheif (1.11.0-1 -> 1.11.0-2)
[2021-04-06T08:17:52+0200] [ALPM] upgraded gd (2.3.2-1 -> 2.3.2-2)
[2021-04-06T08:17:52+0200] [ALPM] upgraded gtksourceview4 (4.8.0-1 -> 4.8.1-1)
[2021-04-06T08:17:52+0200] [ALPM] upgraded libpeas (1.28.0-3 -> 1.30.0-1)
[2021-04-06T08:17:52+0200] [ALPM] upgraded tepl (5.0.1-2 -> 6.00.0-1)
[2021-04-06T08:17:52+0200] [ALPM] upgraded gedit (3.38.1-1 -> 40.0-1)
[2021-04-06T08:17:52+0200] [ALPM] upgraded gedit-plugins (3.38.1-1 -> 40.0-1)
[2021-04-06T08:17:52+0200] [ALPM] upgraded geoip-database (20210223-1 -> 20210323-1)
[2021-04-06T08:17:52+0200] [ALPM] upgraded run-parts (4.8.6.1-2 -> 4.11.2-1)
[2021-04-06T08:17:53+0200] [ALPM] upgraded ghostscript (9.53.3-3 -> 9.54.0-2)
[2021-04-06T08:17:53+0200] [ALPM] upgraded git (2.30.1-1 -> 2.31.1-1)
[2021-04-06T08:17:53+0200] [ALPM] upgraded glib2-docs (2.66.7-1 -> 2.68.0-5)
[2021-04-06T08:17:53+0200] [ALPM] upgraded gnome-autoar (0.2.4-2 -> 0.3.1-1)
[2021-04-06T08:17:53+0200] [ALPM] upgraded gnome-backgrounds (3.38.0-1 -> 40rc-1)
[2021-04-06T08:17:53+0200] [ALPM] upgraded libgee (0.20.3-2 -> 0.20.4-1)
[2021-04-06T08:17:53+0200] [ALPM] upgraded gnome-calculator (3.38.2-1 -> 40.0-1)
[2021-04-06T08:17:53+0200] [ALPM] upgraded gnome-desktop (1:3.38.4-1 -> 1:40.0-1)
[2021-04-06T08:17:53+0200] [ALPM] upgraded gnome-online-accounts (3.38.0-1 -> 3.39.92-1)
[2021-04-06T08:17:53+0200] [ALPM] upgraded gnome-screenshot (3.38.0-1 -> 40.0-2)
[2021-04-06T08:17:53+0200] [ALPM] upgraded gnome-system-monitor (3.38.0-1 -> 40.0-2)
[2021-04-06T08:17:53+0200] [ALPM] upgraded vte-common (0.62.3-1 -> 0.64.0-1)
[2021-04-06T08:17:53+0200] [ALPM] upgraded vte3 (0.62.3-1 -> 0.64.0-1)
[2021-04-06T08:17:53+0200] [ALPM] upgraded gnome-terminal (3.38.3-1 -> 3.40.0-1)
[2021-04-06T08:17:53+0200] [ALPM] upgraded python-markdown (3.3.3-3 -> 3.3.4-1)
[2021-04-06T08:17:53+0200] [ALPM] upgraded gobject-introspection (1.66.1-3 -> 1.68.0-1)
[2021-04-06T08:17:53+0200] [ALPM] upgraded groff (1.22.4-4 -> 1.22.4-5)
[2021-04-06T08:17:53+0200] [ALPM] upgraded re2 (1:20210202-1 -> 1:20210401-1)
[2021-04-06T08:17:53+0200] [ALPM] upgraded grpc (1.36.2-1 -> 1.36.4-1)
[2021-04-06T08:17:53+0200] [ALPM] upgraded grub-tools (1.6.4-1 -> 1.6.5-1)
[2021-04-06T08:17:53+0200] [ALPM] upgraded gsfonts (20200910-1 -> 20200910-2)
[2021-04-06T08:17:53+0200] [ALPM] upgraded gst-libav (1.18.3-1 -> 1.18.4-1)
[2021-04-06T08:17:53+0200] [ALPM] upgraded pipewire (1:0.3.23-1 -> 1:0.3.24-1)
[2021-04-06T08:17:54+0200] [ALPM] warning: /etc/pipewire/media-session.d/media-session.conf installed as /etc/pipewire/media-session.d/media-session.conf.pacnew
[2021-04-06T08:17:54+0200] [ALPM] upgraded pipewire-media-session (1:0.3.23-1 -> 1:0.3.24-1)
[2021-04-06T08:17:54+0200] [ALPM] upgraded gst-plugin-pipewire (1:0.3.23-1 -> 1:0.3.24-1)
[2021-04-06T08:17:54+0200] [ALPM] upgraded gst-plugins-bad-libs (1.18.3-2 -> 1.18.4-3)
[2021-04-06T08:17:54+0200] [ALPM] upgraded mpg123 (1.26.3-2 -> 1.26.5-1)
[2021-04-06T08:17:54+0200] [ALPM] upgraded gst-plugins-good (1.18.3-1 -> 1.18.4-2)
[2021-04-06T08:17:54+0200] [ALPM] upgraded gst-plugins-bad (1.18.3-2 -> 1.18.4-3)
[2021-04-06T08:17:54+0200] [ALPM] upgraded gst-plugins-ugly (1.18.3-1 -> 1.18.4-2)
[2021-04-06T08:17:54+0200] [ALPM] upgraded gvfs-afc (1.46.2-1 -> 1.48.0-2)
[2021-04-06T08:17:54+0200] [ALPM] upgraded gvfs-goa (1.46.2-1 -> 1.48.0-2)
[2021-04-06T08:17:54+0200] [ALPM] upgraded gvfs-google (1.46.2-1 -> 1.48.0-2)
[2021-04-06T08:17:54+0200] [ALPM] upgraded gvfs-gphoto2 (1.46.2-1 -> 1.48.0-2)
[2021-04-06T08:17:54+0200] [ALPM] upgraded gvfs-mtp (1.46.2-1 -> 1.48.0-2)
[2021-04-06T08:17:54+0200] [ALPM] upgraded gvfs-nfs (1.46.2-1 -> 1.48.0-2)
[2021-04-06T08:17:54+0200] [ALPM] upgraded ldb (1:2.2.0-3 -> 1:2.3.0-1)
[2021-04-06T08:17:54+0200] [ALPM] installed python-dnspython (1:1.16.0-3)
[2021-04-06T08:17:54+0200] [ALPM] upgraded smbclient (4.13.4-1 -> 4.14.2-1)
[2021-04-06T08:17:54+0200] [ALPM] upgraded gvfs-smb (1.46.2-1 -> 1.48.0-2)
[2021-04-06T08:17:54+0200] [ALPM] installed hunspell-en_gb (2020.12.07-2)
[2021-04-06T08:17:54+0200] [ALPM] upgraded libcdr (0.1.6-3 -> 0.1.7-1)
[2021-04-06T08:17:54+0200] [ALPM] upgraded poppler-glib (21.03.0-1 -> 21.04.0-1)
[2021-04-06T08:17:54+0200] [ALPM] upgraded inkscape (1.0.2-4 -> 1.0.2-5)
[2021-04-06T08:17:54+0200] [ALPM] upgraded inxi (3.3.01.1-1 -> 3.3.03.1-1)
[2021-04-06T08:17:54+0200] [ALPM] upgraded iwd (1.12-1 -> 1.13-1)
[2021-04-06T08:17:54+0200] [ALPM] upgraded jasper (2.0.25-1 -> 2.0.27-1)
[2021-04-06T08:17:54+0200] [ALPM] upgraded kactivities (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:54+0200] [ALPM] upgraded kdeclarative (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:54+0200] [ALPM] upgraded kcmutils (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:54+0200] [ALPM] upgraded kde-gtk-config (5.21.2-1 -> 5.21.3-1)
[2021-04-06T08:17:54+0200] [ALPM] upgraded kdnssd (5.79.1-1 -> 5.80.0-1)
[2021-04-06T08:17:54+0200] [ALPM] upgraded kdoctools (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:54+0200] [ALPM] upgraded kinit (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:54+0200] [ALPM] upgraded kirigami2 (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:54+0200] [ALPM] upgraded kitemmodels (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:55+0200] [ALPM] upgraded kjs (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:55+0200] [ALPM] upgraded knotifyconfig (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:55+0200] [ALPM] upgraded kparts (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:55+0200] [ALPM] upgraded kpty (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:55+0200] [ALPM] upgraded syntax-highlighting (5.79.1-1 -> 5.80.0-1)
[2021-04-06T08:17:55+0200] [ALPM] upgraded ktexteditor (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:17:55+0200] [ALPM] upgraded less (563-1 -> 1:563-1)
[2021-04-06T08:17:55+0200] [ALPM] upgraded libebml (1.4.1-1 -> 1.4.2-1)
[2021-04-06T08:17:55+0200] [ALPM] upgraded libftdi (1.5-1 -> 1.5-2)
[2021-04-06T08:17:55+0200] [ALPM] upgraded libgweather (3.36.1-1 -> 3.36.1-2)
[2021-04-06T08:17:55+0200] [ALPM] upgraded libkscreen (5.21.2-1 -> 5.21.3-1)
[2021-04-06T08:17:55+0200] [ALPM] upgraded libmatroska (1.6.2-1 -> 1.6.3-1)
[2021-04-06T08:17:55+0200] [ALPM] upgraded libnm (1.30.0-2 -> 1.30.2-1)
[2021-04-06T08:17:55+0200] [ALPM] upgraded libphonenumber (8.12.14-3 -> 8.12.20-1)
[2021-04-06T08:17:57+0200] [ALPM] upgraded libreoffice-fresh (7.1.1-1 -> 7.1.2-2)
[2021-04-06T08:17:57+0200] [ALPM] upgraded libreoffice-fresh-de (7.1.1-1 -> 7.1.2-1)
[2021-04-06T08:17:57+0200] [ALPM] upgraded libsynctex (2020.54586-11 -> 2020.54586-12)
[2021-04-06T08:17:57+0200] [ALPM] upgraded libupnp (1.14.2-1 -> 1.14.4-1)
[2021-04-06T08:17:57+0200] [ALPM] upgraded liburing (0.7-2 -> 2.0-1)
[2021-04-06T08:17:57+0200] [ALPM] upgraded libxaw (1.0.13-3 -> 1.0.14-1)
[2021-04-06T08:17:57+0200] [ALPM] upgraded libxnvctrl (460.56-1 -> 460.67-1)
[2021-04-06T08:17:57+0200] [ALPM] upgraded libxres (1.2.0-2 -> 1.2.1-1)
[2021-04-06T08:17:57+0200] [ALPM] upgraded libytnef (1.9.3+7+g24fe30e-2 -> 1:1.9.3-1)
[2021-04-06T08:17:57+0200] [ALPM] upgraded mkinitcpio-busybox (1.32.1-2 -> 1.32.1-3)
[2021-04-06T08:17:58+0200] [ALPM] upgraded linux (5.11.4.arch1-1 -> 5.11.11.arch1-1)
[2021-04-06T08:17:59+0200] [ALPM] upgraded linux-firmware (20210208.b79d239-1 -> 20210315.3568f96-1)
[2021-04-06T08:17:59+0200] [ALPM] upgraded pahole (1.20-1 -> 1.20-2)
[2021-04-06T08:18:02+0200] [ALPM] upgraded linux-headers (5.11.4.arch1-1 -> 5.11.11.arch1-1)
[2021-04-06T08:18:03+0200] [ALPM] upgraded man-pages (5.10-1 -> 5.11-1)
[2021-04-06T08:18:03+0200] [ALPM] upgraded mercurial (5.7-1 -> 5.7.1-1)
[2021-04-06T08:18:03+0200] [ALPM] upgraded mlocate (0.26.git.20170220-5 -> 0.26.git.20170220-6)
[2021-04-06T08:18:03+0200] [ALPM] upgraded mplayer (38157-3 -> 38157-4)
[2021-04-06T08:18:03+0200] [ALPM] upgraded zeromq (4.3.3-2 -> 4.3.4-1)
[2021-04-06T08:18:03+0200] [ALPM] upgraded networkmanager (1.30.0-2 -> 1.30.2-1)
[2021-04-06T08:18:03+0200] [ALPM] upgraded networkmanager-openvpn (1.8.12-1 -> 1.8.14-1)
[2021-04-06T08:18:03+0200] [ALPM] upgraded nodejs (15.11.0-1 -> 15.13.0-1)
[2021-04-06T08:18:04+0200] [ALPM] upgraded noto-fonts-extra (20201226-1 -> 20201226-2)
[2021-04-06T08:18:04+0200] [ALPM] upgraded os-prober (1.77-2 -> 1.78-1)
[2021-04-06T08:18:04+0200] [ALPM] upgraded p7zip (17.03-2 -> 1:17.04-1)
[2021-04-06T08:18:08+0200] [ALPM] upgraded paper-icon-theme (1.5.0-2 -> 1.5.0.832.aa3e8af-1)
[2021-04-06T08:18:08+0200] [ALPM] upgraded pcsclite (1.9.0-1 -> 1.9.1-1)
[2021-04-06T08:18:08+0200] [ALPM] upgraded perl-file-which (1.23-4 -> 1.24-1)
[2021-04-06T08:18:08+0200] [ALPM] upgraded perl-html-parser (3.75-1 -> 3.76-1)
[2021-04-06T08:18:08+0200] [ALPM] upgraded perl-net-http (6.20-1 -> 6.21-1)
[2021-04-06T08:18:11+0200] [ALPM] upgraded qt5-webengine (5.15.3-2 -> 5.15.3-3)
[2021-04-06T08:18:11+0200] [ALPM] upgraded purpose (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:18:11+0200] [ALPM] upgraded python-atspi (2.38.0-3 -> 2.38.1-1)
[2021-04-06T08:18:11+0200] [ALPM] upgraded python-soupsieve (2.2-1 -> 2.2.1-1)
[2021-04-06T08:18:11+0200] [ALPM] upgraded python-beautifulsoup4 (4.9.3-3 -> 4.9.3-4)
[2021-04-06T08:18:11+0200] [ALPM] upgraded python-grpcio (1.36.2-1 -> 1.36.4-1)
[2021-04-06T08:18:11+0200] [ALPM] upgraded python-html5lib (1.1-5 -> 1.1-6)
[2021-04-06T08:18:11+0200] [ALPM] upgraded python-parso (1:0.7.1-3 -> 1:0.8.1-1)
[2021-04-06T08:18:11+0200] [ALPM] upgraded python-jedi (0.17.2-3 -> 0.18.0-1)
[2021-04-06T08:18:11+0200] [ALPM] upgraded python-lxml (4.6.2-1 -> 4.6.3-1)
[2021-04-06T08:18:11+0200] [ALPM] upgraded python-pep517 (0.9.1-3 -> 0.10.0-1)
[2021-04-06T08:18:11+0200] [ALPM] upgraded python-pillow (8.1.0-1 -> 8.1.2-1)
[2021-04-06T08:18:11+0200] [ALPM] upgraded python-pyserial (3.5-1 -> 3.5-2)
[2021-04-06T08:18:11+0200] [ALPM] upgraded python-pyzmq (20.0.0-1 -> 22.0.3-1)
[2021-04-06T08:18:12+0200] [ALPM] upgraded python-ruamel-yaml (0.16.13-1 -> 0.17.2-1)
[2021-04-06T08:18:12+0200] [ALPM] upgraded python2 (2.7.18-2 -> 2.7.18-3)
[2021-04-06T08:18:17+0200] [ALPM] upgraded qtcreator (4.14.1-1 -> 4.14.2-1)
[2021-04-06T08:18:17+0200] [ALPM] upgraded r8168 (8.048.03-73 -> 8.048.03-80)
[2021-04-06T08:18:17+0200] [ALPM] upgraded whois (5.5.8-1 -> 5.5.9-1)
[2021-04-06T08:18:17+0200] [ALPM] upgraded reflector-simple (1.14-1 -> 1.15-1)
[2021-04-06T08:18:17+0200] [ALPM] upgraded s-nail (14.9.21-1 -> 14.9.22-1)
[2021-04-06T08:18:17+0200] [ALPM] upgraded s-tui (1.0.2-2 -> 1.1.1-1)
[2021-04-06T08:18:17+0200] [ALPM] upgraded samba (4.13.4-1 -> 4.14.2-1)
[2021-04-06T08:18:17+0200] [ALPM] upgraded xorg-xkbcomp (1.4.4-1 -> 1.4.5-1)
[2021-04-06T08:18:17+0200] [ALPM] upgraded sddm (0.19.0-3 -> 0.19.0-4)
[2021-04-06T08:18:17+0200] [ALPM] upgraded shotcut (21.02.15-1 -> 21.03.21-1)
[2021-04-06T08:18:17+0200] [ALPM] upgraded simple-scan (3.38.5-1 -> 40.0-1)
[2021-04-06T08:18:17+0200] [ALPM] upgraded sudo (1.9.5.p2-1 -> 1.9.6.p1-1)
[2021-04-06T08:18:17+0200] [ALPM] upgraded systemd-sysvcompat (247.3-1 -> 248-3)
[2021-04-06T08:18:17+0200] [ALPM] upgraded threadweaver (5.79.0-1 -> 5.80.0-1)
[2021-04-06T08:18:17+0200] [ALPM] upgraded tracker3 (3.0.3-1 -> 3.1.1-1)
[2021-04-06T08:18:17+0200] [ALPM] upgraded ttf-caladea (20200113-2 -> 20200113-3)
[2021-04-06T08:18:18+0200] [ALPM] upgraded ttf-carlito (20130920-5 -> 20130920-6)
[2021-04-06T08:18:18+0200] [ALPM] upgraded ttf-ubuntu-font-family (0.83-6 -> 0.83-7)
[2021-04-06T08:18:18+0200] [ALPM] upgraded unp (2.0~pre7+nmu1-4 -> 2.0.pre9-2)
[2021-04-06T08:18:20+0200] [ALPM] upgraded vlc (3.0.12-1 -> 3.0.12-3)
[2021-04-06T08:18:20+0200] [ALPM] upgraded welcome (3.9.9-1 -> 3.11.4-1)
[2021-04-06T08:18:20+0200] [ALPM] upgraded xterm (366-1 -> 367-1)
[2021-04-06T08:18:20+0200] [ALPM] upgraded yay (10.1.2-2 -> 10.2.0-1)
[2021-04-06T08:18:20+0200] [ALPM] upgraded yelp-xsl (3.38.3-1 -> 40.0-1)
[2021-04-06T08:18:21+0200] [ALPM] upgraded yelp (3.38.3-1 -> 40.0-1)
[2021-04-06T08:18:21+0200] [ALPM] upgraded yelp-tools (3.38.0-1 -> 40.0-1)
[2021-04-06T08:18:22+0200] [ALPM] transaction completed
[2021-04-06T08:18:24+0200] [ALPM] running '20-systemd-sysusers.hook'...
[2021-04-06T08:18:24+0200] [ALPM] running '30-systemd-catalog.hook'...
[2021-04-06T08:18:24+0200] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-04-06T08:18:25+0200] [ALPM] running '30-systemd-hwdb.hook'...
[2021-04-06T08:18:25+0200] [ALPM] running '30-systemd-sysctl.hook'...
[2021-04-06T08:18:25+0200] [ALPM] running '30-systemd-tmpfiles.hook'...
[2021-04-06T08:18:25+0200] [ALPM] running '30-systemd-udev-reload.hook'...
[2021-04-06T08:18:25+0200] [ALPM] running '30-systemd-update.hook'...
[2021-04-06T08:18:25+0200] [ALPM] running '40-fontconfig-config.hook'...
[2021-04-06T08:18:25+0200] [ALPM] running '40-update-ca-trust.hook'...
[2021-04-06T08:18:26+0200] [ALPM] running '60-depmod.hook'...
[2021-04-06T08:18:33+0200] [ALPM] running '70-dkms-install.hook'...
[2021-04-06T08:18:33+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod -m vboxhost -v 6.1.18_OSE -k 5.11.11-arch1-1
[2021-04-06T08:18:51+0200] [ALPM-SCRIPTLET] ==> depmod 5.11.11-arch1-1
[2021-04-06T08:18:58+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2021-04-06T08:18:58+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'default'
[2021-04-06T08:18:58+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-linux -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
[2021-04-06T08:18:58+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.11.11-arch1-1
[2021-04-06T08:18:58+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-04-06T08:18:58+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-04-06T08:18:59+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-04-06T08:18:59+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-04-06T08:18:59+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-04-06T08:18:59+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2021-04-06T08:18:59+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-04-06T08:19:00+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-04-06T08:19:00+0200] [ALPM-SCRIPTLET] -> Running build hook: [encrypt]
[2021-04-06T08:19:00+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qat_4xxx
[2021-04-06T08:19:01+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-04-06T08:19:01+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-04-06T08:19:01+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-04-06T08:19:01+0200] [ALPM-SCRIPTLET] ==> Creating xz-compressed initcpio image: /boot/initramfs-linux.img
[2021-04-06T08:19:16+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-04-06T08:19:16+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'fallback'
[2021-04-06T08:19:16+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-linux -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-fallback.img -S autodetect
[2021-04-06T08:19:16+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.11.11-arch1-1
[2021-04-06T08:19:16+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-04-06T08:19:16+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-04-06T08:19:16+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-04-06T08:19:16+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-04-06T08:19:17+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: aic94xx
[2021-04-06T08:19:17+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: wd719x
[2021-04-06T08:19:18+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2021-04-06T08:19:19+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-04-06T08:19:19+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-04-06T08:19:19+0200] [ALPM-SCRIPTLET] -> Running build hook: [encrypt]
[2021-04-06T08:19:20+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qat_4xxx
[2021-04-06T08:19:20+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-04-06T08:19:21+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-04-06T08:19:23+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-04-06T08:19:23+0200] [ALPM-SCRIPTLET] ==> Creating xz-compressed initcpio image: /boot/initramfs-linux-fallback.img
[2021-04-06T08:20:14+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-04-06T08:20:14+0200] [ALPM] running 'dbus-reload.hook'...
[2021-04-06T08:20:14+0200] [ALPM] running 'detect-old-perl-modules.hook'...
[2021-04-06T08:20:14+0200] [ALPM] running 'eos-grub-fix-initrd-generation.hook'...
[2021-04-06T08:20:14+0200] [ALPM-SCRIPTLET] ===> INFO: grub-tools / grub-fix-initrd-generation:
[2021-04-06T08:20:14+0200] [ALPM-SCRIPTLET] ===> INFO: /etc/grub.d/30_os-prober changed. See file /var/log/grub-fix-initrd-generation.log.
[2021-04-06T08:20:14+0200] [ALPM-SCRIPTLET] ===> INFO: /usr/lib/linux-boot-probes/mounted/40grub2 changed. See file /var/log/grub-fix-initrd-generation.log.
[2021-04-06T08:20:15+0200] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2021-04-06T08:20:15+0200] [ALPM-SCRIPTLET] Found theme: /boot/grub/themes/EndeavourOS/theme.txt
[2021-04-06T08:20:16+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-linux
[2021-04-06T08:20:16+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux.img
[2021-04-06T08:20:16+0200] [ALPM-SCRIPTLET] Found fallback initrd image(s) in /boot: initramfs-linux-fallback.img
[2021-04-06T08:20:16+0200] [ALPM-SCRIPTLET] done
[2021-04-06T08:20:16+0200] [ALPM] running 'eos-hooks.hook'...
[2021-04-06T08:20:17+0200] [ALPM] running 'eos-reboot-required.hook'...
[2021-04-06T08:20:17+0200] [ALPM-SCRIPTLET] Reboot is recommended because of recent core system package upgrades.
[2021-04-06T08:20:17+0200] [ALPM] running 'fontconfig.hook'...
[2021-04-06T08:20:17+0200] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2021-04-06T08:20:17+0200] [ALPM] running 'gio-querymodules.hook'...
[2021-04-06T08:20:17+0200] [ALPM] running 'glib-compile-schemas.hook'...
[2021-04-06T08:20:17+0200] [ALPM] running 'gtk-query-immodules-2.0.hook'...
[2021-04-06T08:20:17+0200] [ALPM] running 'gtk-query-immodules-3.0.hook'...
[2021-04-06T08:20:17+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-04-06T08:20:18+0200] [ALPM] running 'gvfsd.hook'...
[2021-04-06T08:20:18+0200] [ALPM] running 'texinfo-install.hook'...
[2021-04-06T08:20:18+0200] [ALPM] running 'update-desktop-database.hook'...
[2021-04-06T08:20:18+0200] [ALPM] running 'update-mime-database.hook'...
[2021-04-06T08:20:18+0200] [ALPM] running 'update-vlc-plugin-cache.hook'...
[2021-04-06T09:43:18+0200] [PACMAN] Running 'pacman -U --noconfirm --config /etc/pacman.conf -- /home/fgeiger/.cache/yay/yed/yed-1:3.21.1-1-any.pkg.tar.zst'
[2021-04-06T09:43:18+0200] [ALPM] transaction started
[2021-04-06T09:43:19+0200] [ALPM] upgraded yed (1:3.20.1-2 -> 1:3.21.1-1)
[2021-04-06T09:43:19+0200] [ALPM-SCRIPTLET] >>> You have to read and accept the license agreement under
[2021-04-06T09:43:19+0200] [ALPM-SCRIPTLET] >>> /usr/share/licenses/yed/license.html before using yEd.
[2021-04-06T09:43:19+0200] [ALPM] transaction completed
[2021-04-06T09:43:19+0200] [ALPM] running '30-systemd-update.hook'...
[2021-04-06T09:43:19+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-04-06T09:43:19+0200] [ALPM] running 'update-desktop-database.hook'...
[2021-04-06T09:43:19+0200] [ALPM] running 'update-mime-database.hook'...
[2021-04-06T10:53:39+0200] [PACMAN] Running 'pacman -S community/ttf-linux-libertine community/ttf-opensans'
[2021-04-06T10:53:43+0200] [ALPM] transaction started
[2021-04-06T10:53:43+0200] [ALPM] installed ttf-linux-libertine (5.3.0-6)
[2021-04-06T10:53:43+0200] [ALPM] installed ttf-opensans (1.101-2)
[2021-04-06T10:53:43+0200] [ALPM] transaction completed
[2021-04-06T10:53:43+0200] [ALPM] running '30-systemd-update.hook'...
[2021-04-06T10:53:43+0200] [ALPM] running 'fontconfig.hook'...
[2021-04-06T21:04:35+0200] [PACMAN] Running 'pacman -Syuw'
[2021-04-06T21:04:35+0200] [PACMAN] synchronizing package lists
[2021-04-06T21:04:46+0200] [PACMAN] starting full system upgrade
[2021-04-06T22:50:02+0200] [PACMAN] Running 'pacman -Syu'
[2021-04-06T22:50:02+0200] [PACMAN] synchronizing package lists
[2021-04-06T22:50:13+0200] [PACMAN] starting full system upgrade
[2021-04-06T23:01:39+0200] [PACMAN] Running 'pacman -Syuw'
[2021-04-06T23:01:39+0200] [PACMAN] synchronizing package lists
[2021-04-06T23:01:50+0200] [PACMAN] starting full system upgrade
[2021-04-06T23:12:10+0200] [PACMAN] Running 'pacman -Su'
[2021-04-06T23:12:10+0200] [PACMAN] starting full system upgrade
[2021-04-06T23:12:15+0200] [ALPM] transaction started
[2021-04-06T23:12:15+0200] [ALPM] upgraded alsa-card-profiles (1:0.3.24-1 -> 1:0.3.25-1)
[2021-04-06T23:12:15+0200] [ALPM] upgraded kdecoration (5.21.3-1 -> 5.21.4-1)
[2021-04-06T23:12:15+0200] [ALPM] upgraded graphene (1.10.4-1 -> 1.10.6-1)
[2021-04-06T23:12:15+0200] [ALPM] upgraded breeze (5.21.3-1 -> 5.21.4-1)
[2021-04-06T23:12:15+0200] [ALPM] upgraded breeze-gtk (5.21.3-1 -> 5.21.4-1)
[2021-04-06T23:12:15+0200] [ALPM] upgraded ceph-libs (15.2.8-2 -> 15.2.10-1)
[2021-04-06T23:12:15+0200] [ALPM] upgraded poppler (21.04.0-1 -> 21.04.0-2)
[2021-04-06T23:12:15+0200] [ALPM] upgraded cups-pdf (3.0.1-5 -> 3.0.1-6)
[2021-04-06T23:12:15+0200] [ALPM] upgraded pipewire (1:0.3.24-1 -> 1:0.3.25-1)
[2021-04-06T23:12:15+0200] [ALPM] warning: /etc/pipewire/media-session.d/alsa-monitor.conf installed as /etc/pipewire/media-session.d/alsa-monitor.conf.pacnew
[2021-04-06T23:12:15+0200] [ALPM] warning: /etc/pipewire/media-session.d/media-session.conf installed as /etc/pipewire/media-session.d/media-session.conf.pacnew
[2021-04-06T23:12:15+0200] [ALPM] upgraded pipewire-media-session (1:0.3.24-1 -> 1:0.3.25-1)
[2021-04-06T23:12:15+0200] [ALPM] upgraded gst-plugin-pipewire (1:0.3.24-1 -> 1:0.3.25-1)
[2021-04-06T23:12:15+0200] [ALPM] upgraded kde-gtk-config (5.21.3-1 -> 5.21.4-1)
[2021-04-06T23:12:16+0200] [ALPM] upgraded libbluray (1.2.1-1 -> 1.3.0-1)
[2021-04-06T23:12:16+0200] [ALPM] upgraded libkscreen (5.21.3-1 -> 5.21.4-1)
[2021-04-06T23:12:16+0200] [ALPM] upgraded poppler-glib (21.04.0-1 -> 21.04.0-2)
[2021-04-06T23:12:16+0200] [ALPM] upgraded poppler-qt5 (21.04.0-1 -> 21.04.0-2)
[2021-04-06T23:12:16+0200] [ALPM] upgraded rav1e (0.4.0-1 -> 0.4.1-1)
[2021-04-06T23:12:17+0200] [ALPM] upgraded sof-firmware (1.6.1-1 -> 1.7-1)
[2021-04-06T23:12:17+0200] [ALPM] upgraded xf86-input-libinput (0.30.0-1 -> 1.0.0-1)
[2021-04-06T23:12:17+0200] [ALPM] transaction completed
[2021-04-06T23:12:17+0200] [ALPM] running '30-systemd-udev-reload.hook'...
[2021-04-06T23:12:17+0200] [ALPM] running '30-systemd-update.hook'...
[2021-04-06T23:12:17+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-04-06T23:15:19+0200] [PACMAN] Running 'pacman -S -u -w -y --config /etc/pacman.conf --'
[2021-04-06T23:15:19+0200] [PACMAN] synchronizing package lists
[2021-04-06T23:15:20+0200] [PACMAN] starting full system upgrade
[2021-04-06T23:18:08+0200] [PACMAN] Running 'pacman -U --noconfirm --config /etc/pacman.conf -- /home/fgeiger/.cache/yay/zoom/zoom-5.6.1-1-x86_64.pkg.tar.zst'
[2021-04-06T23:18:08+0200] [ALPM] transaction started
[2021-04-06T23:18:09+0200] [ALPM] upgraded zoom (5.5.4-1 -> 5.6.1-1)
[2021-04-06T23:18:09+0200] [ALPM] transaction completed
[2021-04-06T23:18:09+0200] [ALPM] running '30-systemd-update.hook'...
[2021-04-06T23:18:09+0200] [ALPM] running 'update-desktop-database.hook'...
[2021-04-06T23:18:09+0200] [ALPM] running 'update-mime-database.hook'...
Any other infos I can provide?
Paul
Did you revert the original changes you made before replacing the pacnew files?
Did you restart the service
systemctl restart --user pipewire pipewire-pulse pipewire-media-session.service
I reverted only the change that had no effect: Commented out the line
in
So, this file is in its original state again. I did not revert the creation of
with its entry
as this made the speaker work again.
…and, alas, I did it after the copying of the files. Doesn’t matter, I guess, or does it?
Did you try restarting the service as above?
Yes, I did and then rebooted.
No success. In the Control Center → Sound → Input the only entry I see is “Monitor of Built-in Audio Analog Stereo”. The Control Center → Sound → Hardware shows
Built-in Audio
1 Output / 1 Input
Analog Stereo Output
BTW, ricklinux asked about my DE. It’s Mate.
Check.
systemctl --user status pipewire.service
$ systemctl --user status pipewire.service
● pipewire.service - Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; vendor preset: enabled)
Active: active (running) since Wed 2021-04-07 18:24:57 CEST; 1min 34s ago
TriggeredBy: ● pipewire.socket
Main PID: 3420 (pipewire)
Tasks: 2 (limit: 18954)
Memory: 5.5M
CPU: 190ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─3420 /usr/bin/pipewire
Apr 07 18:24:57 aquarius systemd[1135]: Started Multimedia Service.
I’m assuming you want Analog Stereo Output.
Replacing “restart” by “status” yields:
$ systemctl status --user pipewire pipewire-pulse pipewire-media-session.service
Active: active (running) since Wed 2021-04-07 18:24:57 CEST; 2min 36s ago
Memory: 5.5M
CPU: 190ms
● pipewire-pulse.service - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; disabled; vendor preset: enabled)
TriggeredBy: ● pipewire-pulse.socket
Main PID: 3422 (pipewire-pulse)
Memory: 2.3M
CPU: 109ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
└─3422 /usr/bin/pipewire-pulse
Apr 07 18:24:57 aquarius systemd[1135]: Started PipeWire PulseAudio.
Apr 07 18:24:57 aquarius pipewire-pulse[3422]: D-Bus name org.pulseaudio.Server already taken.
Apr 07 18:25:01 aquarius pipewire-pulse[3422]: pulse-server 0x555fc60daf90: [PulseAudio Volume Control] ERROR command:87 (EXTENSION) tag:12 error:19 (Operation not supported)
Apr 07 18:25:01 aquarius pipewire-pulse[3422]: pulse-server 0x555fc60daf90: [PulseAudio Volume Control] ERROR command:87 (EXTENSION) tag:13 error:19 (Operation not supported)
Apr 07 18:25:01 aquarius pipewire-pulse[3422]: pulse-server 0x555fc60daf90: [PulseAudio Volume Control] ERROR command:87 (EXTENSION) tag:14 error:19 (Operation not supported)
Apr 07 18:25:01 aquarius pipewire-pulse[3422]: pulse-server 0x555fc60daf90: [PulseAudio Volume Control] ERROR command:87 (EXTENSION) tag:15 error:19 (Operation not supported)
Apr 07 18:25:01 aquarius pipewire-pulse[3422]: pulse-server 0x555fc60daf90: [PulseAudio Volume Control] ERROR command:87 (EXTENSION) tag:17 error:19 (Operation not supported)
● pipewire-media-session.service - Multimedia Service Session Manager
Loaded: loaded (/usr/lib/systemd/user/pipewire-media-session.service; enabled; vendor preset: enabled)
Main PID: 3423 (pipewire-media-)
Memory: 4.3M
CPU: 133ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-media-session.service
└─3423 /usr/bin/pipewire-media-session
Apr 07 18:24:57 aquarius systemd[1135]: Started Multimedia Service Session Manager.
systemctl --user restart pipewire-media-session
Did it. Doesn’t show errors.
$ systemctl --user status pipewire-media-session
Active: active (running) since Wed 2021-04-07 18:41:47 CEST; 1min 26s ago
Main PID: 3949 (pipewire-media-)
Memory: 3.3M
CPU: 125ms
└─3949 /usr/bin/pipewire-media-session
Apr 07 18:41:47 aquarius systemd[1135]: Started Multimedia Service Session Manager.
pavucontrol still doesn’t show an input device.
Despite the fact that the speaker works: Does the file
with
have a bad influence, preventing pipewire to “see” the input device? I mean, this file doesn’t seem to have existed before as nano said it’s new when I edited it.
Ok, so I’ll keep it. Strange that sound worked before as it is newly created.
Have you replaced any old conf files in /etc/pipewire/media-session.d with the new ones that ended in pacnew?
