https://clbin.com/eSypY
After updating mirrors and system and doing my thing on the laptop as normal today the system has no internet connectivity.
systemctl enable NetworkManager.service doesn’t do anything.
There is no problem when I am using the EOS LTS kernel
This is a really good reason to carry both the latest and lts kernel.
It’s not uncommon to lose WiFi or Bluetooth on occasion on latest as it’s always in the building process. I usually don’t dig too deep into this unless it’s also broken in lts. It will very likely get fixed soon and then your original fix may no longer be necessary or even cause other issues.
Sometimes the best fix on this is to wait a week and let the kernel devs do what they do best.
In all honesty unless you know you need the latest, or you want something zen or hardened offer, I think most users would be best suited on lts anyways. I am, and it’s served me very well over the years.
wise words
I do stay on the edge… but mainly to check on issues… normal Desktop users should at least have LTS installed to fall back on something that is working if latest is going nuts
When you perform a system update, all the currently installed packages for which there are new versions will be updated. Even the kernels that you are at the moment not using but have installed.
Edit. seeing the replies above and below, perhaps I misunderstood your question
LTS (long time support) Kernel is not updating to the main kernel it will only update to the next LTS Kernel and got updates internal but not in version…
It is installed side by side with main kernel and you can choose eon boot menu to boot the one or the other… where the last installed will be the one it uses to boot on if you do not interrupt to choose another one.
