it shows the device is working on EndeavourOS and it does not show any issues on other Linux Distros too what means it should work fine… so it is most likely that it will work again on one of the next main kernel updates…
Sory i post in the wrong spot!
Appologies for being thick.
How is this connected with my Wi-Fi kernel issue?
ok - so the LTS kernel next’s update is only when the particular package LTS kernel is udpated. and presumably it will be safe to use…
Thank you.
I know it should work because I’ve been using it for a long time now.
