Hello there, friendly EOS community. After having used EOS for over 3 months without bigger issues, I’ve finally ran into a problem that I can’t wrap my head around. I’m also generally still quite new to the Linux environment, so please assume that I have big knowledge gaps all over the place - also when it comes to basic things.
I’m running EOS on a desktop PC with KDE Plasma on Wayland. I have an Nvidia RTX 3060, using the native Nvidia drivers. I have 2 monitors attached: 1 TV via HDMI 2.1 and one monitor via DP 1.2. Until recently, the screens ran according to their specs (both at 60Hz) and I don’t recall noticing anything odd in the display settings. Now, after a recent yay, the display config only lists up to 30Hz for the TV. I went through the TV’s settings to see if there’s anything limiting from that side, but no such thing, I also tried different HDMI cables, including nominal 8K HDMI 2.1 ones. I’ve tried nvidia-dkms (alongside nvidia, I suppose. This one might need some clarification.) Finally, I’ve tried setting a profile manually, according to https://wiki.archlinux.org/title/Xrandr#Permanently_adding_undetected_resolutions, all to no avail.
Here are some hopefully relevant parameters:
ohdeer@eos-pc ~> inxi -G
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] driver: nvidia
v: 570.124.04
Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
Device-3: EVGA XR1 Pro Capture Box Video
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB
Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_wayland driver: X: loaded: nvidia unloaded: modesetting
gpu: nvidia,nvidia-nvswitch resolution: 1: 1920x1080~60Hz
2: 3840x2160~30Hz
API: EGL v: 1.5 drivers: nvidia
platforms: gbm,wayland,x11,surfaceless,device
API: OpenGL v: 4.6.0 vendor: nvidia v: 570.124.04 renderer: NVIDIA
GeForce RTX 3060/PCIe/SSE2
API: Vulkan v: 1.4.304 drivers: N/A surfaces: xcb,xlib,wayland
de: kscreen-console,kscreen-doctor gpu: corectrl, nvidia-settings,
nvidia-smi wl: wayland-info x11: xdpyinfo, xprop, xrandr
ohdeer@eos-pc ~> xrandr
Screen 0: minimum 16 x 16, current 4920 x 2160, maximum 32767 x 32767
DP-1 connected 1080x1920+3840+117 right (normal left inverted right x axis y axis) 531mm x 299mm
1920x1080 59.96*+
1440x1080 59.99
1400x1050 59.98
1280x1024 59.89
1280x960 59.94
1152x864 59.96
1024x768 59.92
800x600 59.86
640x480 59.38
320x240 59.29
1680x1050 59.95
1440x900 59.89
1280x800 59.81
1152x720 59.97
960x600 59.63
928x580 59.88
800x500 59.50
768x480 59.90
720x480 59.71
640x400 59.95
320x200 58.14
1600x900 59.95
1368x768 59.88
1280x720 59.86
1024x576 59.90
864x486 59.92
720x400 59.27
640x350 59.28
HDMI-A-1 connected primary 3840x2160+0+0 (normal left inverted right x axis y axis) 1872mm x 1053mm
3840x2160 29.98*+
2048x1536 29.95
1920x1440 29.95
1600x1200 29.95
1440x1080 29.86
1400x1050 29.98
1280x1024 29.90
1280x960 29.82
1152x864 29.92
1024x768 29.89
800x600 29.55
640x480 29.79
320x240 27.17
2560x1600 29.99
1920x1200 29.95
1680x1050 29.95
1440x900 29.91
1280x800 29.83
1152x720 29.96
960x600 29.81
928x580 29.54
800x500 29.36
768x480 29.46
720x480 29.08
640x400 29.37
320x200 26.16
3200x1800 29.96
2880x1620 29.96
2560x1440 29.94
2048x1152 29.94
1920x1080 29.95
1600x900 29.92
1368x768 29.83
1280x720 29.93
1024x576 29.79
864x486 29.38
720x400 29.30
640x350 28.79
3840x2160_60.00 (0x3b0) 712.750MHz -HSync +VSync
h: width 3840 start 4152 end 4576 total 5312 skew 0 clock 134.18KHz
v: height 2160 start 2163 end 2168 total 2237 clock 59.98Hz
ohdeer@eos-pc ~> xrandr --output HDMI-A-1 --mode 3840x2160_60.00
xrandr: cannot find mode 3840x2160_60.00
Apologies if I’m missing something obvious and thanks in advance!
Edit: It just occurred to me that xrandr is probably specific for X sessions, right?
So here’s this while I dive deeper into the matter:
ohdeer@eos-pc ~> kscreen-doctor -o
Output: 1 DP-1
enabled
connected
priority 2
DisplayPort
Modes: 1:1920x1080@60*! 2:1920x1080@144 3:1920x1080@120 4:1920x1080@100 5:1920x1080@85 6:1920x1080@60 7:1920x1080@50 8:1680x1050@60 9:1280x1024@75 10:1280x1024@60 11:1440x900@60 12:1280x960@60 13:1280x800@60 14:1152x864@75 15:1280x720@60 16:1280x720@60 17:1280x720@50 18:1024x768@75 19:1024x768@70 20:1024x768@60 21:800x600@75 22:800x600@72 23:800x600@60 24:800x600@56 25:720x576@50 26:720x480@60 27:640x480@75 28:640x480@60 29:640x480@60
Geometry: 3072,94 864x1536
Scale: 1.25
Rotation: 8
Overscan: 0
Vrr: incapable
RgbRange: unknown
HDR: incapable
Wide Color Gamut: incapable
ICC profile: none
Color profile source: sRGB
Color power preference: prefer efficiency and performance
Brightness control: supported, set to 60% and dimming to 100%
Output: 2 HDMI-A-1
enabled
connected
priority 1
HDMI
Modes: 30:3840x2160@30*! 31:4096x2160@30 32:4096x2160@24 33:4096x2160@24 34:3840x2160@30 35:3840x2160@25 36:3840x2160@24 37:2560x1440@60 38:1920x1080@60 39:1920x1080@60 40:1920x1080@50 41:1920x1080@30 42:1920x1080@25 43:1920x1080@24 44:1680x1050@60 45:1600x900@60 46:1280x1024@75 47:1280x1024@60 48:1440x900@60 49:1280x800@60 50:1152x864@75 51:1280x720@60 52:1280x720@60 53:1280x720@50 54:1024x768@75 55:1024x768@70 56:1024x768@60 57:800x600@75 58:800x600@72 59:800x600@60 60:720x576@50 61:720x480@60 62:640x480@75 63:640x480@73 64:640x480@60
Geometry: 0,0 3072x1728
Scale: 1.25
Rotation: 1
Overscan: 0
Vrr: incapable
RgbRange: unknown
HDR: disabled
ICC profile: none
Color power preference: prefer accuracy
Brightness control: supported, set to 100% and dimming to 100%
