Hello people.
Here a former user from ANGROS and currently in Arch.
I just installed Endeavouros with plasma KDE, but I do not know if I jumped some step or that it was, but I find the system too swollen for my taste.
Would a more personalized installation be possible, with only what you need?
Thank you very much beforehand and I congratulate you for your enormous job.
Greetings, Juan.
Without some specific examples it is hard to understand what you referring to.
Generally speaking, the installer lets you pick and choose whatever you wish if you drill into each section.
Again, examples of things that were installed that you would prefer to not be there would help.
Hi, thanks for your response.
You’re right, I should be more explicit.
There are things like Cuttlefish, icon explorer, Filelight, Kteatime, Ktimer or Xsane, I do not need at all.
Some can be eliminated manually, but others tell me that they come into conflict with a series of dependencies and that will affect other applications.
Sorry for my English sacked from Google Translator
Most of those come from installing kde-utilities-meta
. This is optional in the installer if you drill in one level deeper on the selection screen.
cuttlefish
can be removed by removing plasma-sdk
. That would be hard to avoid without not installing plasma.
Then I understand that already in the graphical installation itself there is the option to install a simpler system, right?
For some reason that step I jumped it.
Yes. On the screen where you select KDE, you can expand that and decide what parts of KDE you want.
That being said, it is easy to fix after the fact as well. You just need to remove those meta packages, remove orphans and then install what you want.
If you want more instructions on how to do that please let me know.
You can also install just the base system with Calamares, then install the bits you want after initial boot. Pacman has a handy feature of excluding packages within a meta package by using ^ (i.e. ^5).
Thanks!.
What I have to learn well is that packages selected and which do not in the installation of EnOS to have a system at least loaded as possible.
You can literally deselect everything except efibootmgr
if you want the smallest install possible.
Thanks!
Actually, it is not that it wants a reduced installation to the minimum expression.
I understand that between that and a typical installation, like the one you are in most distros by default today, there is a middle term.
More than a minimum installation I would like an installation that had what I really need, since I notice too inflated those other default facilities.
Until now I developed me well with the installation of Arch.
With a good guide, you explain the packages you installed and why, and researching in your wiki, I got a system not very inflated and very much of my taste, and then adding things as needed.
I find that the ENOS installation suffers a bit of lack of information about which it is each package you select.
I just made an installation right now in another partition of my SSD, and I took out several pictures with my smartphone of the things that I installed then gathering information about them and seeing what I really need and what it does not.
Surely the title of this thread in the forum is poorly enunciated, and more than a minimum installation what I need is to simply install what I need, and then add other things as the needs grow.
But, for that, I need more information about what is installed.
If you want an easier to read list of the packages you can choose, you can see them here:
https://github.com/endeavouros-team/install-scripts/blob/master/netinstall.yaml
If you have questions about what any of them do, feel free to ask.
Thanks for the information.
What I would really need at the time of installation would be to have information that they are or make the packages that I can select from that list.
For example in KDe-Desktop I can select “fwupd” but, really, I have no idea what it is or if I need it.
In the Arch wiki I can read that “fwupd is a simple demon that allows you to update the firmware of some devices, including UEFI for several machines.”
Well, that information would be nice to have it on the panel on the right when you click on that package.
Then there are others like “yad” for those who can not find information on the wiki and I have no idea if it is really necessary or not.
yad
is used by some of the EOS tools.
I don’t disagree with your assessment but I also don’t know how hard it would be to implement that. In the meantime, pacman
will give you some info about package.
For example:
pacman -Si yad | grep Description
returns:
Description : A fork of zenity - display graphical dialogs from shell scripts or command line
It shouldn’t be too hard to create a simple script that goes through the list and enriches it with descriptions. I could help with that if you would like.
Of course, now I am talking about that it would be good such or what something, but without being fully aware of the difficulties that would imply.
I guess the information you take from Yad in Pacman is something he does after finishing the installation and not while he is with her, right?
As for the creation of a script as individuals … Bufff! … My knowledge is null there.
Anyway, you get to create scripts to use in the system is something that I have given many laps in the past, what happens is that I do not know where to start either.
In fact, I have several sports betting ideas that I do through Calc in LibreOffice and intended to automate them through a program and I was in doubt if I throw myself to web programming or do it more at home, on my PC.
As you see, there are many things that I have in my head … no longer as when I was younger (I’m about to fulfill the 55) but I still get some things out of my head.
Here you go. The missing packages are groups.
yay Yet another yogurt. Pacman wrapper and AUR helper written in go.
linux-headers Headers and scripts for building modules for the Linux kernel
linux-firmware Firmware files for Linux
pacman-contrib Contributed scripts and tools for pacman systems
xf86-video-vesa X.org vesa video driver
xorg-server Xorg X server
xorg-xinit X.Org initialisation program
xf86-input-libinput Generic input driver for the X.Org server based on libinput
xf86-video-amdgpu X.org amdgpu video driver
xf86-video-ati X.org ati video driver
xf86-video-fbdev X.org framebuffer video driver
xf86-video-intel X.org Intel i810/i830/i915/945G/G965+ video drivers
xorg-xkill Kill a client by its X resource
xorg-xrandr Primitive command line interface to RandR extension
xorg-xinput Small commandline tool to configure devices
xdg-utils Command line tools that assist applications with a variety of desktop integration tasks
xdg-user-dirs Manage user directories like ~/Desktop and ~/Music
accountsservice D-Bus interface for user account query and manipulation
smartmontools Control and monitor S.M.A.R.T. enabled ATA and SCSI Hard Drives
libwnck3 Library to manage X windows and workspaces (via pagers, tasklists, etc.)
b43-fwcutter firmware extractor for the b43 kernel module
broadcom-wl-dkms Broadcom 802.11 Linux STA wireless driver
r8168 A kernel module for Realtek 8168 network cards
ipw2100-fw Intel Centrino Drivers firmware for IPW2100
ipw2200-fw Firmware for the Intel PRO/Wireless 2200BG
modemmanager Mobile broadband modem management service
netctl Profile based systemd network management
net-tools Configuration tools for Linux networking
ntfs-3g NTFS filesystem driver and utilities
networkmanager Network connection manager and user applications
networkmanager-openvpn NetworkManager VPN plugin for OpenVPN
nss-mdns glibc plugin providing host name resolution via mDNS
usb_modeswitch Activating switchable USB devices on Linux.
whois Intelligent WHOIS client
dhclient A standalone DHCP client from the dhcp package
ethtool Utility for controlling network drivers and hardware
openconnect Open client for Cisco AnyConnect VPN
openvpn An easy-to-use, robust and highly configurable VPN (Virtual Private Network)
rp-pppoe Roaring Penguin's Point-to-Point Protocol over Ethernet client
wireless-regdb Central Regulatory Domain Database
wireless_tools Tools allowing to manipulate the Wireless Extensions
wpa_supplicant A utility providing key negotiation for WPA wireless networks
wvdial A dialer program to connect to the Internet
gnu-netcat GNU rewrite of netcat, the network piping application
iwd Internet Wireless Daemon
linux-atm Drivers and tools to support ATM networking under Linux.
ndisc6 Collection of IPv6 networking utilities
ppp A daemon which implements the Point-to-Point Protocol for dial-up networking
pptpclient Client for the proprietary Microsoft Point-to-Point Tunneling Protocol, PPTP.
vpnc VPN client for cisco3000 VPN Concentrators
xl2tpd an open source implementation of the L2TP maintained by Xelerance Corporation
dialog A tool to display dialog boxes from shell scripts
dnsmasq Lightweight, easy to configure DNS forwarder and DHCP server
upower Abstraction for enumerating power devices, listening to device events and querying history and statistics
hwinfo Hardware detection tool from openSUSE
gtop System monitoring dashboard for terminal
python Next generation of the python high-level scripting language
solid Hardware integration and detection
mlocate Merging locate/updatedb implementation
ttf-dejavu Font family based on the Bitstream Vera Fonts with a wider range of characters
ttf-liberation Font family which aims at metric compatibility with Arial, Times New Roman, and Courier New
ttf-bitstream-vera Bitstream Vera fonts.
cantarell-fonts Humanist sans serif font
noto-fonts Google Noto TTF fonts
adobe-source-han-sans-jp-fonts Adobe Source Han Sans Subset OTF - Japanese OpenType/CFF fonts
adobe-source-han-sans-kr-fonts Adobe Source Han Sans Subset OTF - Korean OpenType/CFF fonts
adobe-source-han-sans-cn-fonts Adobe Source Han Sans Subset OTF - Simplified Chinese OpenType/CFF fonts
opendesktop-fonts Chinese TrueType Fonts
ttf-opensans Sans-serif typeface commissioned by Google
firefox Standalone web browser from mozilla.org
alsa-utils Advanced Linux Sound Architecture - Utilities
alsa-plugins Additional ALSA plugins
alsa-firmware Firmware binaries for loader programs in alsa-tools and hotplug firmware loader
hardinfo A system information and benchmark tool.
glances CLI curses-based monitoring tool
htop Interactive process viewer
neofetch A CLI system information tool written in BASH that supports displaying images.
pulseaudio A featureful, general-purpose sound server
pavucontrol PulseAudio Volume Control
paprefs Configuration dialog for PulseAudio
sof-firmware Sound Open Firmware
ffmpegthumbnailer Lightweight video thumbnailer that can be used by file managers.
poppler-glib Poppler glib bindings
libgsf An extensible I/O abstraction library for dealing with structured file formats
libopenraw Library for decoding RAW files
freetype2 Font rasterization library
gst-libav Multimedia graph framework - libav plugin
gst-plugins-bad Multimedia graph framework - bad plugins
gst-plugins-ugly Multimedia graph framework - ugly plugins
gst-plugin-pipewire Multimedia graph framework - pipewire plugin
mplayer Media player for Linux
libdvdcss Portable abstraction library for DVD decryption
efibootmgr Linux user-space application to modify the EFI Boot Manager
dosfstools DOS filesystem utilities
mtools A collection of utilities to access MS-DOS disks
openssh Premier connectivity tool for remote login with the SSH protocol
intel-ucode Microcode update files for Intel CPUs
amd-ucode Microcode update image for AMD CPUs
os-prober Utility to detect other OSes on a set of drives
grub-tools Fixes, additions and enhancements to grub and os-prober.
wget Network utility to retrieve files from the Web
bash-completion Programmable completion for the bash shell
lsb-release LSB version query program
s-tui Terminal UI stress test and monitoring tool
tlp Linux Advanced Power Management
yad A fork of zenity - display graphical dialogs from shell scripts or command line
reflector A Python 3 module and script to retrieve and filter the latest Pacman mirror list.
endeavouros-theming Default EndeavourOS background images and icons for all different DE
reflector-simple Simple GUI wrapper for 'reflector'.
welcome Welcome greeter for new EndeavourOS users.
eos-update-notifier Software update notifier and 'news for you' for EndeavourOS users.
eos-hooks EndeavourOS pacman hooks
nvidia-installer-dkms Script to setup nvidia drivers (dkms version) in EndeavourOS
mkinitcpio-openswap mkinitcpio hook to open swap at boot time
pcurses A curses package management tool using libalpm
eos-log-tool Gathers selected system logs and sends them to the internet.
keyserver-rank Ranks some keyservers.
inxi Full featured CLI system information tool
tldr Command line client for tldr, a collection of simplified and community-driven man pages.
mousepad Simple text editor for Xfce
parole Modern media player based on the GStreamer framework
ristretto Fast and lightweight picture-viewer for Xfce4
thunar-archive-plugin Create and extract archives in Thunar
thunar-media-tags-plugin Adds special features for media files to the Thunar File Manager
xfce4-battery-plugin A battery monitor plugin for the Xfce panel
xfce4-datetime-plugin A date and time display plugin for the Xfce panel
xfce4-mount-plugin Mount/umount utility for the Xfce4 panel
xfce4-netload-plugin A netload plugin for the Xfce panel
xfce4-notifyd Notification daemon for the Xfce desktop
xfce4-pulseaudio-plugin Pulseaudio plugin for Xfce4 panel
xfce4-screensaver Xfce Screensaver
xfce4-screenshooter Plugin that makes screenshots for the Xfce panel
xfce4-taskmanager Easy to use task manager
xfce4-wavelan-plugin Plugin to monitor wifi connectivity for the Xfce4 panel
xfce4-weather-plugin A weather plugin for the Xfce4 panel
xfce4-whiskermenu-plugin Menu for Xfce4
xfce4-xkb-plugin Plugin to switch keyboard layouts for the Xfce4 panel
file-roller Create and modify archives
gvfs Virtual filesystem implementation for GIO
gvfs-mtp Virtual filesystem implementation for GIO (MTP backend; Android, media player)
gvfs-afc Virtual filesystem implementation for GIO (AFC backend; Apple mobile devices)
gvfs-goa Virtual filesystem implementation for GIO (Gnome Online Accounts backend; cloud storage)
gvfs-google Virtual filesystem implementation for GIO (Google Drive backend)
gvfs-gphoto2 Virtual filesystem implementation for GIO (gphoto2 backend; PTP camera, MTP media player)
gvfs-nfs Virtual filesystem implementation for GIO (NFS backend)
gvfs-smb Virtual filesystem implementation for GIO (SMB/CIFS backend; Windows client)
network-manager-applet Applet for managing network connections
xed A small and lightweight text editor. X-Apps Project.
epdfview Lightweight PDF document viewer
galculator GTK+ based scientific calculator
blueberry Bluetooth configuration tool
lightdm A lightweight display manager
lightdm-gtk-greeter GTK+ greeter for LightDM
lightdm-gtk-greeter-settings Settings editor for the LightDM GTK+ Greeter
arc-x-icons-theme Modern free desktop icon theme whose design is based around the use of bold colours and simple geometric shapes to compose icons with pixel perfect rendering.
capitaine-cursors An x-cursor theme inspired by macOS and based on KDE Breeze
arc-gtk-theme A flat theme with transparent elements for GTK 3, GTK 2 and Gnome-Shell
endeavouros-xfce4-terminal-colors EndeavourOS colorscheme for xfce4-terminal
xdg-user-dirs-gtk Creates user dirs and asks to relocalize them
seahorse GNOME application for managing PGP keys.
celluloid Simple GTK+ frontend for mpv
kdeconnect Adds communication between KDE and your smartphone
fwupd Simple daemon to allow session software to update firmware
python-dbus Python bindings for DBUS
kde-system-meta Meta package for KDE system applications
kde-utilities-meta Meta package for KDE utilities applications
kio-fuse FUSE interface for KIO
kio-gdrive KIO Slave to access Google Drive
audiocd-kio Kioslave for accessing audio CDs
gwenview A fast and easy to use image viewer
ark Archiving Tool
okular Document Viewer
spectacle KDE screenshot capture utility
dragon A multimedia player where the focus is on simplicity, instead of features
elisa A simple music player aiming to provide a nice experience for its users
print-manager A tool for managing print jobs and printers
gnome-tweaks Graphical interface for advanced GNOME 3 settings (Tweak Tool)
nautilus-sendto Easily send files via mail
gnome-nettool Graphical interface for various networking tools
gnome-usage GNOME application to view information about use of system resources
gnome-multi-writer Write an ISO file to multiple USB devices at once
adwaita-icon-theme GNOME standard icons
chrome-gnome-shell Native browser connector for integration with extensions.gnome.org
cinnamon Linux desktop which provides advanced innovative features and a traditional user experience
cinnamon-translations Translations for Cinnamon and Nemo
gnome-terminal The GNOME Terminal Emulator
gnome-system-monitor View current processes and monitor system state
gpicview-gtk3 Lightweight image viewer (GTK+ 3 version)
x-apps file-roller Create and modify archives
nemo-fileroller File archiver extension for Nemo
nemo-image-converter Nemo extension to rotate/resize image files
nemo-preview Quick file previewer for Nemo
nemo-seahorse PGP encryption and signing extension for Nemo
nemo-share Samba extension for Nemo
gnome-screenshot Take pictures of your screen
gnome-calculator GNOME Scientific calculator
budgie-desktop Modern desktop environment from the Solus Project
gnome gnome-screensaver Legacy GNOME screensaver
deepin-album A fashion photo manager for viewing and organizing pictures
deepin-boot-maker Tool to create a bootable usb stick quick and easy
deepin-calculator An easy to use calculator for ordinary users
deepin-clipboard DDE clipboard manager component
deepin-clone Disk and partition backup/restore tool
deepin-community-wallpapers Community wallpapers for DDE
deepin-compressor A fast and lightweight application for creating and extracting archives
deepin-draw A lightweight drawing tool for Linux Deepin
deepin-editor Simple editor for Deepin
deepin-movie Movie player based on QtAV
deepin-music Awesome music player with brilliant and tweakful UI Deepin-UI based.
deepin-picker Color picker tool for deepin
deepin-printer Printer configuration project for DDE
deepin-reader A simple PDF reader, supporting bookmarks, highlights and annotations
deepin-screen-recorder Deepin Screen Recorder
deepin-screensaver-pp Optional PP screensaver resource for deepin screensaver
deepin-terminal Default terminal emulation application for Deepin
deepin-voice-note A lightweight memo tool to make text notes and voice recordings
deepin-kwin KWin configures on DDE
i3-gaps A fork of i3wm tiling window manager with more features, including gaps
i3blocks Define blocks for your i3bar status line
i3lock Improved screenlocker based upon XCB and PAM
i3status Generates status bar to use with i3bar, dzen2 or xmobar
arandr Provide a simple visual front end for XRandR 1.2.
archlinux-xdg-menu automatic generate WM menu from xdg files
lxappearance-gtk3 Feature-rich GTK+ theme switcher of the LXDE Desktop (GTK+ 3 version)
otf-font-awesome Iconic font designed for Bootstrap
dmenu Generic menu for X
polkit-gnome Legacy polkit authentication agent for GNOME
thunar Modern file manager for Xfce
thunar-volman Automatic management of removeable devices in Thunar
tumbler D-Bus service for applications to request thumbnails
xfce4-terminal A modern terminal emulator primarily for the Xfce desktop environment
acpi Client for battery, power, and thermal readings
sysstat a collection of performance monitoring tools (iostat,isag,mpstat,pidstat,sadf,sar)
nitrogen Background browser and setter for X windows
bluez-utils Development and debugging utilities for the bluetooth protocol stack
rofi A window switcher, application launcher and dmenu replacement
xcursor-neutral A smoothed and shadowed X cursors theme
xbindkeys Launch shell commands with your keyboard or your mouse under X
scrot Simple command-line screenshot utility for X
xorg-xdpyinfo Display information utility for X
dex Program to generate and execute DesktopEntry files of type Application
picom X compositor that may fix tearing issues
jq Command-line JSON processor
feh Fast and light imlib2-based image viewer
dunst Customizable and lightweight notification-daemon
gtk-engine-murrine GTK2 engine to make your desktop look like a 'murrina', an italian word meaning the art glass works done by Venicians glass blowers.
numlockx Turns on the numlock key in X11.
sddm QML based X11 and Wayland display manager
libpulse A featureful, general-purpose sound server (client library)
libstatgrab A library that provides cross platform access to statistics about the system on which it's run
libsysstat Library to query system statistics (net, resource usage, ...)
lm_sensors Collection of user space tools for general SMBus access and hardware monitoring
oxygen-icons The Oxygen Icon Theme
breeze Artwork, styles and assets for the Breeze visual style for the Plasma Desktop
breeze-gtk Breeze widget theme for GTK 2 and 3
featherpad Lightweight Qt plain text editor
smplayer Media player with built-in codecs that can play virtually all video and audio formats
pavucontrol-qt A Pulseaudio mixer in Qt (port of pavucontrol)
xscreensaver Screen saver and locker for the X Window System
cups The CUPS Printing System - daemon package
cups-filters OpenPrinting CUPS Filters
cups-pdf PDF printer for cups
ghostscript An interpreter for the PostScript language
gsfonts (URW)++ Core Font Set [Level 2]
foomatic-db-engine Foomatic - Foomatic's database engine generates PPD files from the data in Foomatic's XML database. It also contains scripts to directly generate print queues and handle jobs.
foomatic-db Foomatic - The collected knowledge about printers, drivers, and driver options in XML files, used by foomatic-db-engine to generate PPD files.
foomatic-db-ppds Foomatic - PPDs from printer manufacturers
foomatic-db-nonfree Foomatic - database extension consisting of manufacturer-supplied PPD files released under non-free licenses
foomatic-db-nonfree-ppds Foomatic - non-free PPDs from printer manufacturers
gutenprint Top quality printer drivers for POSIX systems
foomatic-db-gutenprint-ppds simplified prebuilt ppd files
splix CUPS drivers for SPL (Samsung Printer Language) printers
system-config-printer A CUPS printer configuration tool and status applet
hplip Drivers for HP DeskJet, OfficeJet, Photosmart, Business Inkjet and some LaserJet
python-pyqt5 A set of Python bindings for the Qt5 toolkit
python-reportlab A proven industry-strength PDF generating solution
xsane A GTK-based X11 frontend for SANE and plugin for Gimp.
orca Screen reader for individuals who are blind or visually impaired
mousetweaks Mouse accessibility enhancements
Mil gracias!
Thank you!
