Hello!
I installed EndeavourOS on my Macbook Pro 2015 and I cannot see my home wifi network to connect. I did not have this issue on my Macbook Air and am wondering if I can get some help here.
For starters, I went through this post:
After distro hopping for a while, I decided to focus on one distro, EndeavourOS, and learn as much as I can. The BIG ISSUE that I’m having trouble figuring out after a new install is WIFI. I have a 2014 MacBook Pro 13", I haven’t figured out what I need to do yet to get the WIFI working. This MBP does not have an Ethernet port so it adds to the challenge. I installed EndearourOS on a USB flash drive, I’m not sure if that has any impact to my issue or not. Any advice and direction would be great! …
I first installed the following packages :
pacman -S linux-headers
pacman -S broadcom-wl-dkms
pacman -S dkms
Still couldn’t detect wifi networks after a reboot.
Next I tried to install and reboot but to no avail :
Some additional details from the terminal:
pacman -Qs broadcom
local/broadcom-wl 6.30.223.271-362
Broadcom 802.11 Linux STA wireless driver
lsmod | grep wl
wl 6524928 0
cfg80211 1064960 1 wl
rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp0s20u1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN mode DEFAULT group default qlen 1000
link/ether 1a:5e:5e:6f:d2:bb brd ff:ff:ff:ff:ff:ff
inxi -Nx
Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
driver: N/A bus-ID: 03:00.0
Please let me know if there are other commands I’ll need to run and paste the output for.
Thanks for any help provided by kind strangers!
It should work on the broadcom-wl or broadcom-wl-dkms. Are you using the current kernel or lts?
Try reinstalling
broadcom-wl-dkms
Reboot
Thanks for the response. But I already tried that and it didn’t work. I will post what worked for me and close this. Thanks again!
Edit: I am using the kernel that comes with fresh install.
This solution worked for me!
Have exact same WiFi module.
Decided to throw EOS on my old Macbook I use 2-3 times a year for travelling abroad. Probably a bad idea as you can imagine the backlog of updates everytime I take it out of storage and abroad.
Model: A1502 (EMC 2835)
Year: Early 2015
Wifi: Broadcom BCM43602
Wired: Broadcom BCM57762
Fresh EOS online install - To get the Wifi working from Arch wiki I made a /etc/modprobe.d/no_bmca.conf file and added line blacklist bmca. Then removed broadcom-w…
Okay … looks like this chip is using the kernel module. Glad you got it working.
Edit: I have the BCM4360 802.11 AC and it does use the broadcom-wl-dkms
system
closed
February 12, 2022, 1:30am
#6
