Check comparison table
Pretty much yes, but GE is…even MORE patched
For good or for worse - your choice
Well Proton-5.9-GE-4ST was the trick to get Borderlands 3 running here…
Before that I would get random game-breaking bugs.
Strangely enough the newer Proton-5.9-GE-6ST doesn’t play nice with Borderlands 3 anymore
Might give it a go with TKG, and see how it goes
You will see that. Each release changes for different reasons. I have 3, 4, 5, and 6 installed depending on the game I am trying to launch.
That’s why i recommend in this guide to use non-system Wine / Proton versions and keep the one that works for games that have some trouble
Usually all games work like charm with wine-staging, in rare cases you need GE / TKG until it’s patched in wine-staging / dxvk / vkd3d.
So think of GE / TKG as experimental bleeding edge stuff, which may help you run newest games, fix some bugs etc
Well…And for Steam it’s obviously way ahead of normal Porton, which have some longer cycle of release
I should probably take a closer look at your guide, instead of doing stuff first, and troubleshooting later
Highly recommended - a lot of current best practices summarized in there…
Hopefully i’ll get back to add / edit this guide again soon!
Nvidia are adding Vulkan support to their new cards which is good news (if you can get a card )
GloriousEggroll Proton-5.9-GE-7-ST got updated!
This release just has a butt ton of game fixes. Some full, some partial. Some important notes are that a workaround has been found for multiplayer desync in some games (SUCH AS MK11 AND AGE OF EMPIRES II:DE !!!).Yes, that’s right, MK11 multiplayer finally works, -and- renders correctly as far as I could tell. If you know of other games that have desyncing with multiplayer, they will likely need the custom vcrun2019_ge winetricks verb I’ve added to protonfixes. Also it’s highly recommended to update your graphics drivers for games such as HZD, Death Stranding, Serious Sam 4. AMD users mesa-git, Nvidia users 455.23.04 beta.
So let’s get down to the fixes:
What’s new in this release (see below for details):
Bugs fixed in 5.19 (total 27):
15437 Multiple programs using madCodeHook crash (in-memory PE image of Wine builtins vs. ELF image on disk)
29926 Multiple games need IDirectDrawStreamSample::Update() (Beach Life, The Sims Complete Collection, Risk II, Earth 2150, Need for Russia)
31342 Multiple applications need msvcirt.dll.??0ofstream@@QAE@XZ (Trespasser, Max Payne 1, 3Dmark1999 MAX, 3Dmark2000, 3Dmark2001 SE, GraphCalc, Charon)
39123 Fairy Fencer F depends on NtQuerySystemInformation(SYSTEM_INTERRUPT_INFORMATION) volatility for random number generation
45090 (nearly) every test shows a leak in kernel32/{console,term}.c
45331 Exile: Escape From the Pit crashes after splash screen
45400 eden* (VN) some font characters display with the wrong glyph (capitals/spaces)
45489 World of Warcraft needs GetRawInputBuffer
46588 Cegid Business Line installer fails in custom script action installing “BLJNR.MSI” component.
48529 Avencast: Rise of the Mage fails to launch
49172 Always true condition code > 0xffff
in vbscript/global.c
49367 1971 Project Helios shows a black screen
49470 Silent Hill 4 crashes when a person is suppose to scream.
49549 winetricks -q dotnet45 leaves dozens of mscorsvw.exe processes
49586 valgrind shows a leak in dlls/ntdll/env.c:set_wow64_environment()
49659 Multiple games crash on launch (Mahjong Titans, Resident Evil HD Remaster, Resident Evil 0 HD Remaster)
49857 NCLauncher2: Crypto error on a successful login
49873 Warzone 2100 crashes on unimplemented function api-ms-win-crt-convert-l1-1-0.dll.strtold
49894 Regression in “kernelbase: Use conhost to handle Unix consoles.”
49895
[Regression] Steam fails to load pages
49899 Multiple games need IDirectDrawMediaStream::NewSegment() implementation (The Sims Complete Collection, Earth 2150, Beach Life, Risk II, Need for Russia)
49906 Fallout New Vegas: broken gog installation
49909 Win Toolkit v.1.4.37.20 (.NET 3.5 app) crashes with wine-mono
49911 Sebastien Loeb Rally EVO 64-bit version crashes with builtin xactengine3_7
49924 IP address control does not focus its fields on focus change
49929 Game for Windows Live installer fails with ‘winetricks -q gfw’
49946 Themida-packed application crashing on multi-hop import forward
wine-tkg and proton-tkg 5.19.r1.gb49e8743
GloriousEggroll Proton-5.9-GE-8-ST got updated!
Ok, so I found yet a few more important fixes… so I went ahead and just said screw it and took yesterdays update and added it on to today’s release to make people more aware. This build should be used as its basically a bunch of hotfixes on top of GE-7-ST.
winetricks is now fully integrated into the build, which means no more relying on the winetricks package of whatever system it’s running on, and no more failing without any notice if it’s not installed on the system
Death Stranding working again (found the issue that broke it in GE-5-ST, it was a woopsie on my part).
Death Stranding Red Halo and issue fixed
Baldur’s Gate 3 DX11 crash fixed
Baldur’s Gate 3 will now ask you if you want to use Vulkan (No=DX11)
Baldur’s Gate 3 still requires AMDVLK on AMD if you want to use Vulkan, DX11 works fine.
Serious Sam 4 will now ask you if you want to use Vulkan (No=DX11)
Serious Sam 4 Nvidia still crashes in-game with Vulkan. DX11 works fine.
Serious Sam 4 flicker workaround found and applied.
Halo: MCC – vcrun2019 fix applied – should fix coop campaign multiplayer desync
Just Cause 4 patches backported – game works now
Watch Dogs 2 eac launcher and nosplash options added to protonfix
Soul Calibur VI – I found out the game actually works but you need to ‘press any button’ before the ‘press any button’ audio finishes, or it will freeze.
vkd3d has been updated – Horizon Zero Dawn fullscreen mode should be fixed now.
dxvk was updated with the latest release which fixes some previous major crash issues.
I’ve heard results vary a lot on Wayland depending on DE / compositor too
I wonder what that means say i3 xorg versus sway wayland. All things being equal looks like xorg is on top.
git submodule update --init --recursive
when updating.Welp that pretty much makes every game in my library playable
There’s a script here for checking if your Glorious Egg roll is up to date and installing as necessary:
Bugs fixed in 5.20 (total 36):
14640 Multiple OpenGL applications and games fail at ChoosePixelFormat/SetPixelFormat (Lazarus, Counterclockwise, USI T3 emulator)
30364 X3 Reunion hangs at start
33392 .NET Framework 4.0 installer misreports disk space if not enough disk space available ‘Drive C: Required - 64u MB, Available - 64u MB’ (‘FormatMessageA/W’ needs to support I64)
34558 Multiple applications and games wrapped with ASProtect 1.x-2.x protection scheme fail to start after registration (Farm Frenzy 2, Alawar, FL Studio 11.x VSTi ‘Slayer2’ plugin, FORScan)
35694 Serena hits deadlock on exit
35744 LabChart Reader 8 installer ends prematurely (VBScript support for class default sub missing)
36873 Multiple games have non-functional mouse input, invisible mouse cursor (Chronology, Mount & Blade II: Bannerlord)
39297 kernel32.IsValidCodePage and friends don’t support code page 708.
46950 UFOHD2 crashes when trying to open camera preview
47771 Multiple games have broken mouse movement (Alan Wake, Hard Reset, Battlefield 3, Watch Dogs, Sniper Elite V2 Remastered)
47906 Alice Madness Return crashes
48336 Applications using MS ADO require Recordset Connect to be implemented (Enterprise Architect, Brickcom CMS client)
48717 Saints Row 2 needs xactengine3_2.dll
49012 Application build with .NET CoreRT crashes due to FLS callbacks not being called
49044 CPU-Z 1.92 crashing on startup
49450 Adobe Shockwave Player 11.x plugin installer fails with jscript:cc_parser_parse ‘&&’ expression not implemented
49529 5.12 regression: Wine segfaults if the +heap debug channel is enabled
49661 Red Evil:black screen in game.
49673 Backpacker 3:Americana:unhandled exception
49679 Visual Studio 98 and Visual Basic 6 installers hang
49808 Stellaris loads very slowly
49814 FreeBSD 12.1 undebuggable crash on startup (regression)
49821 Seismobuild crashes at start
49860 Dungeons & Dragons Online 64bit client fails to start in wine-5.16, 5.17, 5.18
49904 all wine processes show a definite leak in load_libwine()
49950 d3d10:reflection tests crash
49960 The Sims Complete Collection is stuck on playing intro
49966 powershell_ise.exe fails with Unhandled Exception: System.NotImplementedException: The method or operation is not implemented. at System.Runtime.InteropServices.Marshal.ThrowEx
49982 A ‘(call )’ line does not reset %ERRORLEVEL% to 0
49997 Capella no yakusoku: Game doesn’t start (black screen)
50000 Wineconsole crashes on F8
50004 Python script hangs when pipe IPC is used
50008 Metro Exodus fails to launch since commit fde5967f725624c5ee4995dcbe22f262979c5c9c
50016 PS Remote Play can’t install: “To use PS Remote Play, update your PC’s OS to the latest version, and then install the Media Feature Pack from Microsoft.”
50020 mf:mf tests crash on Windows 7
50025 Cannot run Line (chat app) on Wine
Bugs fixed in 5.21 (total 24):
22797 ‘Sample1_DLLEmbedding’ example from BoxedApp SDK v3.3.x (native API application virtualization scheme) crashes (needs hookable NtXXXSection API entries / NT syscalls)
25834 Adobe Reader X and XI cannot open in Protected Mode due to advapi32.dll CreateRestrictedToken being a stub
33072 dxdiag: can’t retrieve network info
33162 Acrobat Reader 11 crashes on start (native API application virtualization, NtProtectVirtualMemory removes execute page protection on its own code)
45349 Multiple applications and games crash due to missing support for 64-bit syscall thunks (StreetFighter V, World of Warcraft)
45550 League of Legends 8.15+ anticheat fails due to incorrect implementation of NtQuerySystemInformation(SystemModuleInformation)
45666 Multiple Riot Games’ anti-cheat / protection schemes need implementation of NtQuerySystemInformation ‘SystemModuleInformationEx’ info class (League of Legends 8.15+, Valorant/Vanguard)
46373 Unknown game crashes in unimplemented function msvcr80.dll._strnset_s in 1.6.2
46870 League of Legends 8.12+ fails to start a game in Vista+ mode (anticheat engine, SystemExtendedProcessInformation)
46967 GOG Galaxy doesn’t run in virtual desktop
48203 Far Manager 3 broken appearance
48204 Wineconsole running Far File Manager 3 crashes as soon as you try to resize its window
48715 A Wolf RPG game freezes on map transition
49298 Path of Exile crashes when switching to Vulkan Renderer on RADV. Switching works in proton.
49449 Terraria Mobile Server (.NET 4.x) crashes with System.NotImplementedException NATUPNPLib.IUPnPNAT.get_StaticPortMappingCollection()
49610 mu online crashes after login
49739 Microsoft Flight Simulator needs netutils.dll and srvcli.dll
49785 Linking of some objects sometimes fails with undefined reference to windowscodecs GUIDs
49813 Implement debugging feedback extensions (VK_EXT_debug_utils/VK_EXT_debug_report) to forward data to Linux impl
50038 IWbemClassObject::Get method with wszName = NULL crashes inside wbemprox
50039 Wine 5.18+ fails build on Ubuntu 18.04 with libwine.so Makefile symbolic link
50049 Fallout 76 opens black screen then crashes on start
50050 Wine 5.20 build fails on Ubuntu 16.04
50077 .NET 3.5SP1 installer depends on PEB->Reserved[1] / AtlThunkSListPtr32 being 0 or 1
GloriousEggroll Proton-5.21-GE-1 got updated!
HOTFIX 11/17/2020:
Game Fixes:
Proton Fixes:
Known Issues:
AGAIN, PLEASE BE AWARE THIS BUILD USES THE SAME RUNTIME AND CONTAINER AS PROTON 5.13, THEREFORE IT HAS THE SAME ISSUES LISTED HERE:
ValveSoftware#4289
Red Dead Redemption 2 still does not work. Unfortunately the syscall patches in current proton do not work with upstream wine.
Fullscreen hack is still currently disabled.
Known mfplat+quartz issues:
Persona 4 is not working
Catherine Classic is not working
Black Ops III is not working
Injustice 2 cutscenes broken currently
Darksiders Warmastered Edition intro+cutscenes broken currently
Probably more stuff I forgot. There were a lot of updates and it took way longer than usual ;_;
Oh coooome on!!
Bugs fixed in 5.22 (total 36):
16991 Cobra 11 Nitro: No video and music at game startup
28210 Rome Total War crash at start
30668 Motocross Madness 2 needs IAMMultiMediaStream::GetState() implementation
32613 Tom Clancy’s Rainbow Six: Lockdown crashes after the intro videos (needs DxDiag_SoundDevices device child nodes present)
37396 Multiple applications need “sRGB Color Space Profile.icm” (Asperite, Word 2007, Word 2010)
38014 CCCP Insurgent v2007-01-01 crashes when querying system information via DxDiag
41081 Foldit puzzle 1266 crashes at start up
42731 stack overflow when .bat script variable has more than 256 characters
43513 Ys VI: The Ark of Napishtim - videos are not playing
44884 Call of Duty Modern Warfare Remastered: Crash after splash with error about Memory/Disk space
45421 Need for Russia does not play msvideo movies
45650 chromium 32-bit sandbox expects different syscall thunks depending on Windows version
46429 Multiple games need IV50 codec to play videos (Thief Gold, Thief II: The Metal Age, Commandos 2: Men of Courage)
46478 Wordpad is slow to start with large enough number of fonts in the system
47320 Black Ops 4 Unhandled Exception When Loading gdi32.dll
47374 Thronebreaker: The Witcher Tales rendering is messed up
47846 Age Of Empires III Crash after Intro
48171 Call of Duty: Modern Warfare (2019) exception
48212 Ys: The Oath in Felghana - movies don’t play
48505 WinRAR x64 4.x/5.x installer crashes on unimplemented function GDI32.dll.ScriptGetCMap
49238 Oblivion: No sound/music
49376 Light of Altair demo has no text in options menu
49490 Overwatch installer fails with new wine prefix
49526 Anno 1800: Crashes on startup
49546 Titan Quest Anniversary Edition has no text with builtin d3dx9_42
49665 Wine 5.14 won’t start, but 5.12 - do!
49844 Cannot create a new file on a mounted fat volume
49907 Fallout New Vegas crashes when leaving Doc Mitchell’s house
50046 wineserver persistence after setup of a WINEPREFIX
50084 Wargaming.net Game Center can’t install updates since wine 5.19
50101 Ghostrunner has no sound after intro movies when prefix is set to Win10
50110 Elite Dangerous Launcher (wine-5.21): AccessViolationException Protected Memory
50116 ODBC applications fail to create/configure system DSNs with builtin ‘odbccp32’ (SQLConfigDataSource must remap ODBC_xxx_SYS_DSN values for ConfigDSN)
50135 explorer.exe crashes when UseXRandR and UseXVidMode are specified to be disabled in registry
50140 “Guild Wars 2 Launcher” over time consumes all available memory
50149 Chromium/MS WebView2 depends on TEB->ReservedForOle ‘apt_mask’ value
