Kwin and plasma crashing
Hi guys I have been having severe crashing with kde plasma and kwin:
KDE versions:
KDE Plasma Version: 5.22.3
KDE Frameworks Version: 5.83.0
Qt Version: 5.15.2
Kernel Version: 5.12.14-arch1-1
OS Type 64-bit
Graphics Platform: X11
Hardware:
Intel Core i7-4790
GPU GTX 970 (proprietary drivers)
Smaller previous issue:
would be gratefull for any help
It could be proprietary drivers. BUT I was having some screen tearing a while ago, and I didn’t have transparency. These are my settings if you want to give it a go.
Screenshot_20210708_161509
xrender does definitly fix the problem but it does unfortunatly break transperancy (and hence kinda spoiling themes like antdark):
Also when I used breeze-dark I lacked these issues presumably since the theme didn’t use the transperancy effect.
I now have antdark up working fine. . . so it’s not that.
Have you tried the LTS kernel? I’m having no issue on 5.10.48.
Also - it could be nvidia. I HATE nvidia. I’ll never spend a dollar on a computer with it, or anything they make.
I haven’t tried the LTS Kernal but I have had similar issues when older versions of Manjaro a year ago (before switching to Endevour) and debian buster with kde plasma.
The reason I’m more keen on nvidia being the issue is odley reinstalling the proprietary drivers with nvidia-dkms fixes the issues but the trade off is kwin_x11 starts to use 50-60% of my cpu and animations become choppy until the blur effects are disabled.
Are you running a intel iGPU or AMD based system?
Lenovo T480s
Screenshot_20210708_170015
Yeah its looks like a nvidia bug after all :slightly_frowning_face:
I guess filing an upstream bug report may be one option. That said do you know where the source code for nvidia-installer-dkms is? I tried looking on endevour OS’s github but the repo looks archived/deleted
https://github.com/endeavouros-team/nvidia-installer-dkms
The high cpu usage and issue fix is the only part that bothers me and that I haven’t seen on manjaro (more cause this wasn’t even an option).
Edit found the new source code:
source code? Nvidia is not an open source project. So in the words of Linus Torvalds - F*** Nvidia.
Although - I did find this in the AUR - maybe worth giving a shot for you, and it looks like it was just updated.
https://aur.archlinux.org/packages/nvidia-dkms-performance
You’ve maxed my Nvidia knowledge though. I know very little, and that’s already more than I care to know about that right trash product.
