I’m relatively new to endevouros and linux in general.
Today I updated using yay to try install the new nvidia drivers.
My audio is now completely messed up.
my pc is connected to my tv via hdmi. I use kodi to watch tv. Up until now it has been fine.
Now, when I load kodi and try to watch a video there is no sound.
If I go back to the system, I can’t get sound at all, unless I have the volume mixer open. If I don’t have it focused the sound goes away, distorts or repeats etc.
Does anyone have a suggestion of how to troubleshoot?
After this, reboot your computer and test your audio again.
Why do this? You should have also received an audio package update for “wireplumber/pipewire”. This may be the cause of the issue. Renaming this folder and rebooting causes your system to automatically recreate the folder with the updated default settings.
Yay had some new nvidia drivers. Possibly a patch. Problem is still here.
If I start system, use firefox, navigate to youtube etc. Audio seems to work.
If I open Kodi, try to play a video, all system audio stops.
Only way to get system audio back is to toggle output from digital stereo to digital surround and back again.
Messing with these settings occasionally leads to apps only making a noise if the audio panel is open, and when loosing focus there is distortion, repeating etc.
Do you have no audio at all or only when you open for example a browser and play a video ? because i had that issue. for some strange reason my sinks did switch all the time.
If I boot into the system and use browser, games or freetube there is audio.
When I open Kodi, initially, I hear menu sounds, however when I try to play videos, there is no audio and this kills all audio for other apps.
After this, if I have the volume mixer up - I can hear audio, if I unfocus it, the audio goes away, or distorts, or repeats.
The only fix is to change the device to something else, then change it back. however, if I do, and try to use Kodi again, it breaks the system in a similar fashion.
open your browser play a video give these two commands and do the same if you close the browser and try to ply something with kodi i think then you will also see some kind of weird switch for example your default audio sink stays in SUSPEND mode. i had that problem to.
I can hear the audio only if the “volume control app” is open, or I’ve clicked on audio volume in the task bar
Audio works for a little while if the volume control app is open, but goes away after say, a minute. It’s not as you would expect, there is still distortion etc, so it’s not a fix to simply leave it open all the time
what happens when you are in kodi and switch in the kde settings to a different audio setting , because it looks like you have same sort of issue i have. if kodi crashes all meaning connection between pipewire and piwire-pulse get lost you can check that with by opening pavucontrol for example.
Jun 16 19:51:23 HTPC systemd[768]: Started Multimedia Service Session Manager.
Jun 16 19:51:24 HTPC wireplumber[872]: spa.bluez5: BlueZ system service is not available
Jun 16 19:51:24 HTPC wireplumber[872]: [0:00:12.450007160] [872] ERROR IPAModule ipa_module.cpp:172 Symbol ipaModuleInfo not found
Jun 16 19:51:24 HTPC wireplumber[872]: [0:00:12.450025067] [872] ERROR IPAModule ipa_module.cpp:292 v4l2-compat.so: IPA module has no valid info
Jun 16 19:51:24 HTPC wireplumber[872]: [0:00:12.450055531] [872] INFO Camera camera_manager.cpp:313 libcamera v0.3.0
Jun 16 20:56:05 HTPC wireplumber[872]: wireplumber: stopped by signal: Terminated
Jun 16 20:56:05 HTPC systemd[768]: Stopping Multimedia Service Session Manager...
Jun 16 20:56:05 HTPC wireplumber[872]: wireplumber: disconnected from pipewire
Jun 16 20:56:05 HTPC wireplumber[872]: pw.core: 0x60fa451afd70: leaked proxy 0x60fa4525a7c0 id:4
Jun 16 20:56:05 HTPC wireplumber[872]: pw.core: 0x60fa451afd70: leaked proxy 0x60fa45284410 id:5
Jun 16 20:56:05 HTPC systemd[768]: Stopped Multimedia Service Session Manager.
-- Boot ae226ba6cf1d4bab85e0a054078c17be --
Jun 16 20:56:44 HTPC systemd[890]: Started Multimedia Service Session Manager.
Jun 16 20:56:45 HTPC wireplumber[995]: spa.bluez5: BlueZ system service is not available
Jun 16 20:56:45 HTPC wireplumber[995]: [0:00:12.217750924] [995] ERROR IPAModule ipa_module.cpp:172 Symbol ipaModuleInfo not found
Jun 16 20:56:45 HTPC wireplumber[995]: [0:00:12.217764921] [995] ERROR IPAModule ipa_module.cpp:292 v4l2-compat.so: IPA module has no valid info
Jun 16 20:56:45 HTPC wireplumber[995]: [0:00:12.217819323] [995] INFO Camera camera_manager.cpp:313 libcamera v0.3.0
Jun 16 20:56:57 HTPC systemd[890]: Stopping Multimedia Service Session Manager...
Jun 16 20:56:57 HTPC wireplumber[995]: wireplumber: stopped by signal: Terminated
Jun 16 20:56:57 HTPC wireplumber[995]: wireplumber: disconnected from pipewire
Jun 16 20:56:57 HTPC systemd[890]: Stopped Multimedia Service Session Manager.
-- Boot 17331f86e0e54d0b846ad411fa4905bf --
Jun 16 22:16:36 HTPC systemd[763]: Started Multimedia Service Session Manager.
Jun 16 22:16:37 HTPC wireplumber[867]: spa.bluez5: BlueZ system service is not available
Jun 16 22:16:37 HTPC wireplumber[867]: [0:00:12.445876186] [867] ERROR IPAModule ipa_module.cpp:172 Symbol ipaModuleInfo not found
Jun 16 22:16:37 HTPC wireplumber[867]: [0:00:12.445892345] [867] ERROR IPAModule ipa_module.cpp:292 v4l2-compat.so: IPA module has no valid info
Jun 16 22:16:37 HTPC wireplumber[867]: [0:00:12.445919306] [867] INFO Camera camera_manager.cpp:313 libcamera v0.3.0
Jun 16 21:43:48 HTPC systemd[763]: Stopping Multimedia Service Session Manager...
Jun 16 21:43:48 HTPC wireplumber[867]: wireplumber: stopped by signal: Terminated
Jun 16 21:43:48 HTPC wireplumber[867]: wireplumber: disconnected from pipewire
Jun 16 21:43:48 HTPC wireplumber[867]: pw.core: 0x61109ca50c70: leaked proxy 0x61109ca94d00 id:3
Jun 16 21:43:48 HTPC wireplumber[867]: pw.core: 0x61109ca50c70: leaked proxy 0x61109cbdecc0 id:4
Jun 16 21:43:48 HTPC systemd[763]: Stopped Multimedia Service Session Manager.
-- Boot d3605f4b84b8497d874553f81f2e1609 --
Jun 16 21:44:31 HTPC systemd[768]: Started Multimedia Service Session Manager.
Jun 16 21:44:32 HTPC wireplumber[872]: spa.bluez5: BlueZ system service is not available
Jun 16 21:44:32 HTPC wireplumber[872]: [0:00:12.403628687] [872] ERROR IPAModule ipa_module.cpp:172 Symbol ipaModuleInfo not found
Jun 16 21:44:32 HTPC wireplumber[872]: [0:00:12.403646597] [872] ERROR IPAModule ipa_module.cpp:292 v4l2-compat.so: IPA module has no valid info
Jun 16 21:44:32 HTPC wireplumber[872]: [0:00:12.403686483] [872] INFO Camera camera_manager.cpp:313 libcamera v0.3.0
Jun 16 23:58:45 HTPC wireplumber[872]: wp-event-dispatcher: <WpAsyncEventHook:0x55b3bb8f6a10> failed: failed to activate item: Object activation aborted: PipeWire proxy destroyed
Jun 16 23:58:46 HTPC wireplumber[872]: wp-event-dispatcher: <WpAsyncEventHook:0x55b3bb8fdfa0> failed: <WpSiStandardLink:0x55b3bb9a3a20> link failed: 1 of 1 PipeWire links failed to activate
Jun 16 23:59:58 HTPC wireplumber[872]: wp-event-dispatcher: <WpAsyncEventHook:0x55b3bb8fdfa0> failed: <WpSiStandardLink:0x55b3bba5ca10> link failed: some node was destroyed before the link was created
Jun 17 00:12:21 HTPC wireplumber[872]: wp-event-dispatcher: <WpAsyncEventHook:0x55b3bb8fdfa0> failed: <WpSiStandardLink:0x55b3bb96bdf0> link failed: 1 of 1 PipeWire links failed to activate
Jun 17 00:16:23 HTPC wireplumber[872]: wp-event-dispatcher: <WpAsyncEventHook:0x55b3bb8f6a10> failed: failed to activate item: Object activation aborted: proxy destroyed
Jun 17 00:23:14 HTPC wireplumber[872]: wp-event-dispatcher: <WpAsyncEventHook:0x55b3bb8fdfa0> failed: <WpSiStandardLink:0x55b3bba5c640> link failed: 1 of 1 PipeWire links failed to activate
Jun 17 00:30:27 HTPC wireplumber[872]: wp-event-dispatcher: <WpAsyncEventHook:0x55b3bb8f6a10> failed: failed to activate item: Object activation aborted: proxy destroyed
Jun 17 00:30:56 HTPC wireplumber[872]: wp-event-dispatcher: <WpAsyncEventHook:0x55b3bb8fdfa0> failed: <WpSiStandardLink:0x55b3bba54060> link failed: some node was destroyed before the link was created
Jun 17 00:35:33 HTPC wireplumber[872]: wp-event-dispatcher: <WpAsyncEventHook:0x55b3bb8f6a10> failed: failed to activate item: Object activation aborted: proxy destroyed
Jun 17 00:41:01 HTPC wireplumber[872]: wp-event-dispatcher: <WpAsyncEventHook:0x55b3bb8fdfa0> failed: <WpSiStandardLink:0x55b3bba5d600> link failed: 1 of 1 PipeWire links failed to activate
Jun 17 00:41:29 HTPC wireplumber[872]: wp-event-dispatcher: <WpAsyncEventHook:0x55b3bb8fdfa0> failed: <WpSiStandardLink:0x55b3bb9722f0> link failed: 1 of 1 PipeWire links failed to activate
Jun 17 00:41:43 HTPC wireplumber[872]: wp-event-dispatcher: <WpAsyncEventHook:0x55b3bb8f6a10> failed: failed to activate item: Object activation aborted: proxy destroyed
Jun 17 00:47:55 HTPC wireplumber[872]: wp-event-dispatcher: <WpAsyncEventHook:0x55b3bb8fdfa0> failed: <WpSiStandardLink:0x55b3bba5c630> link failed: some node was destroyed before the link was created
Jun 17 01:35:27 HTPC systemd[768]: Stopping Multimedia Service Session Manager...
Jun 17 01:35:27 HTPC wireplumber[872]: wireplumber: stopped by signal: Terminated
Jun 17 01:35:27 HTPC wireplumber[872]: wireplumber: disconnected from pipewire
Jun 17 01:35:27 HTPC wireplumber[872]: pw.core: 0x55b3bb90f880: leaked proxy 0x55b3bb955020 id:3
Jun 17 01:35:27 HTPC wireplumber[872]: pw.core: 0x55b3bb90f880: leaked proxy 0x55b3bb9afe10 id:4
Jun 17 01:35:27 HTPC systemd[768]: Stopped Multimedia Service Session Manager.
Jun 17 01:35:27 HTPC systemd[768]: wireplumber.service: Consumed 3.181s CPU time.
-- Boot 178f65db62bf463aa6efe86a9e0565af --
Jun 17 01:36:12 HTPC systemd[773]: Started Multimedia Service Session Manager.
Jun 17 01:36:13 HTPC wireplumber[877]: spa.bluez5: BlueZ system service is not available
Jun 17 01:36:13 HTPC wireplumber[877]: [0:00:13.129620430] [877] ERROR IPAModule ipa_module.cpp:172 Symbol ipaModuleInfo not found
