Hey guys … I have this chuwi laptop that i had manjaro on , working fine. Then something broke . So i tried to install arch first. Everything went fine until i rebooted … and the keyboard and the touchpad were not working.
Then i downloaded Manjaro and the mouse and keyboard were not working (in the live enviroment)
Now i downloaded endeavour and it’s the same. No mouse and keyboard.
i did run evtest on the arch install and the keyboard and touchpad were registering events. So those are not dead.
Do you guys have any idea what could be the cause of this.
Thank you.
I have the aerobook !
It’s nice … fanless , so it’s quiet . It worked great for me … never really tested the battery life but i would say it’s over 8 hrs.
Now back to my problem. I implemented the fix and everything seemed to work fine but now i can’t log in into my install the keyboard and mouse do work though .
But the password worked for root (same pass) and for the user it doesn’t say the passwd is wrong.
So i did reset the password with the passwd command but still wont let me log in
I tried the fix from the Chuwi forum link shared but did not work for me… Although my touchpad is fine, the keyboard isn’t working. Even I ran this spacebar test but it did not detect any key presses.
I am a little too confused with this stuff… as you have already got it working on your side, do you mind sharing what exactly you did? TIA
