Hi, after updating somwhere this week i am no longer able to boot into endeavour. after looking for a solution i saw, that my grub might need to be repaired or reinstalled.
after mounting my endeavour and EFI partitions and chrooting into it, i ran the grub-installer command, and rebooted. this seems to not have helped.
if my problem is not grub, how do i figure out what my issue is and solve it?
so i went trough all the steps again
mounting to /mnt and /mnt/efi
arch-chroot ing into it and using the grub-install and then running your suggested command wicht resulted in no errors.
and then rebooting i still only got the boot into eufi firmware interface option, i tried booting into the partition but is just trew me back there with that, only option.
i did see i can enter a terminal in the menu should i be doing something in there?
