i might be mistaken then
When you installed eos you have to choose grub in order to install with grub bootloader. The default is systemd-boot.
Edit: Iβll let @ringo help you from here.
show output of efibootmgr
does the fstab mount to /efi or /boot/efi ?
thanks for the help
not sure i did that, i kept most things on default
there is or was Grub also systemd-boot the uefi os is linked to grub first boot is grub as thirth is systemd-boot
if you go intoo your disk partition /mnt , to etc, check fstab
if you see /mnt we can rearange boot selection
its possible to check that to go into bios and select linux boot manager
i do have a directory called fstab, not sure what you mean with check fstab
in efibootmgr you see boot order right ?
is basicly how it works at 2. point
you can let it start at 0005
fstab is a disk information file there is stored everything in it
your current BootOrder: 0000,0005,0004,0006,0007
sudo efibootmgr -o 0004,0000,0005,0006,0007
wil rearange the order. best is to confirm in /mnt/etc/fstab file if its to /efi
this case change the bootorder
it should be back after boot
and in efibootmgr is there also a grub probably not used ? so in that tutorial at 4. you can remove an entry also
just to be clear that would be 0000 that iβd need to remove right?
yes maar make first the os bootable this case
alright, i changed the order, ill reboot now
seems like it isnβt solved
you see the bootloader now or not ?
