Inxi not showing the correct info about clock frequency of the CPU
Great information for sure! Thanks @h2h and welcome to the community! :beers:
Welcome !
Welcome!
And indeed a great first post :upside_down_face:
I actually have a question…
When running:
sudo inxi -v8
In Memory: part, RAM speed is it module’s SPD reported or actual currently running value?
P.S. btw, are there any indication to at least consider that in Kernel lately?
maybe one day the kernel devs will put this data into /sys, and make it real data, taken from the actual system, not dmi data.
I find it pretty sad that on Linux you can’t reliably get stuff like actual currently running RAM speed / basic timings.
You can do that even on Windows, with programs like CPU-Z, which is double-sad :frowning:
  Info: 8-Core model: AMD Ryzen 7 4800U with Radeon Graphics bits: 64
  type: MT MCP L2 cache: 4096 KiB
  Speed: 2666 MHz min/max: 1400/1800 MHz Core speeds (MHz): 1: 1397 2: 1398
  3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397
  12: 1560 13: 1471 14: 1600 15: 1397 16: 1397
  type: MT MCP arch: Zen rev: 1 L2 cache: 4096 KiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 57488
  Speed: 1397 MHz min/max: 1400/1800 MHz boost: enabled Core speeds (MHz):
  1: 1397 2: 1397 3: 1397 4: 1396 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397
  10: 1397 11: 1397 12: 1397 13: 1397 14: 1631 15: 1397 16: 1396
  Info: 8-Core model: AMD Ryzen 7 4800U with Radeon Graphics socket: FP6
  bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 60 (96)
  stepping: 1 microcode: 8600104 L1 cache: 512 KiB L2 cache: 4096 KiB
  L3 cache: 8192 KiB
  bogomips: 57488
  Speed: 1397 MHz min/max: 1400/1800 MHz base/boost: 1800/4300 boost: enabled
  volts: 1.2 V ext-clock: 100 MHz Core speeds (MHz): 1: 1397 2: 1397 3: 1397
  4: 1397 5: 1397 6: 1396 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397 12: 1397
  13: 1397 14: 1603 15: 1397 16: 1397
  Vulnerabilities: Type: itlb_multihit status: Not affected
  Type: spec_store_bypass
  mitigation: Speculative Store Bypass disabled via prctl and seccomp
  Type: spectre_v1
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  STIBP: conditional, RSB filling
That’s more like it! Thanks once again @h2h for shedding light on this matter!
man inxi
INXI(1)        inxi manual        INXI(1)
NAME
       inxi  - Command line system information script for console and IRC
SYNOPSIS
       inxi
       inxi [-AbBCdDfFGhijJIlmMnNopPrRsSuUVwzZ]
       inxi [-c NUMBER] [-t [--sensors-exclude SENSORS] [--sensors-use SENSORS] [c|m|cm|mc][NUMBER]] [-v NUMBER] [-W LOCATION] [--weather-unit {m|i|mi|im}] [-y WIDTH]
       inxi [--memory-modules] [--memory-short] [--recommends]  [--sensors-default] [--slots]
       inxi [-x|-xx|-xxx|-a] -OPTION(s)
       All short form options have long form variants - see below for these and more advanced options.
DESCRIPTION
       inxi  is a command line system information script built for console and IRC. It is also used a debugging tool for forum technical support to quickly ascertain users' system configurations and hardware. inxi shows system hard‐
       ware, CPU, drivers, Xorg, Desktop, Kernel, gcc version(s), Processes, RAM usage, and a wide variety of other useful information.
       inxi output varies depending on whether it is being used on CLI or IRC, with some default filters and color options applied only for IRC use.  Script colors can be turned off if desired with -c 0,  or  changed  using  the  -c
       color options listed in the STANDARD OPTIONS section below.
PRIVACY AND SECURITY
       In order to maintain basic privacy and security, inxi used on IRC automatically filters out your network device MAC address, WAN and LAN IP, your /home username directory in partitions, and a few other items.
       Because  inxi is often used on forums for support, you can also trigger this filtering with the -z option (-Fz, for example). To override the IRC filter, you can use the -Z option. This can be useful in debugging network con‐
       nection issues online in a private chat, for example.
USING OPTIONS
       Options can be combined if they do not conflict. You can either group the letters together or separate them.
       Letters with numbers can have no gap or a gap at your discretion, except when using  -t. Note that if you use an option that requires an additional argument, that must be last in the short form group of options. Otherwise you
       can use those separately as well.
       For example: inxi -AG | inxi -A -G | inxi -b | inxi -c10 | inxi -FxxzJy90 | inxi -bay
       Note that all the short form options have long form equivalents, which are listed below. However, usually the short form is used in examples in order to keep things simple.
STANDARD OPTIONS
       -A, --audio
              Show Audio/sound card(s) information, including card driver.
       -b, --basic
              Show basic output, short form. Same as: inxi -v 2
       -B, --battery
              Show  system  battery (ID-x) data, charge, condition, plus extra information (if battery present). Uses /sys or, for BSDs without systctl battery data, dmidecode. dmidecode does not have very much information, and none
              about current battery state/charge/voltage. Supports multiple batteries when using /sys data.
              Note that for charge, the output shows the current charge, as well as its value as a percentage of the available capacity, which can be less than the original design capacity. In the following example, the actual  cur‐
              rent available capacity of the battery is 22.2 Wh.
              charge: 20.1 Wh 95.4%
              The condition item shows the remaining available capacity / original design capacity, and then this figure as a percentage of original capacity available in the battery.
              condition: 22.2/36.4 Wh (61%)
              With -x shows attached Device-x information (mouse, keyboard, etc.)  if they are battery powered.
       -c, --color [0-42]
              Set color scheme. If no scheme number is supplied, 0 is assumed.
       -c [94-99]
              These color selectors run a color selector option  prior to inxi starting which lets you set the config file value for the selection.
              NOTE:  All  configuration  file  set color values are removed when output is piped or redirected. You must use the explicit runtime -c <color number> option if you want color codes to be present in the piped/redirected
              output.
              Color selectors for each type display (NOTE: IRC and global only show safe color set):
       -c 94  - Console, out of X.
       -c 95  - Terminal, running in X - like xTerm.
       -c 96  - GUI IRC, running in X - like XChat, Quassel, Konversation etc.
       -c 97  - Console IRC running in X - like irssi in xTerm.
       -c 98  - Console IRC not in  X.
       -c 99  - Global - Overrides/removes all settings.
              Setting a specific color type removes the global color selection.
       -C, --cpu
              Show full CPU output, including per CPU clock speed and CPU max speed (if available).  If max speed data present, shows (max) in short output formats (inxi, inxi -b) if actual CPU speed matches max CPU  speed.  If  max
              CPU speed does not match actual CPU speed, shows both actual and max speed information.  See -x for more options.
              For certain CPUs (some ARM, and AMD Zen family) shows CPU die count.
              The details for each CPU include a technical description e.g. type: MT MCP
              * MT - Multi/Hyper Threaded CPU, more than 1 thread per core (previously HT).
              * MCM - Multi Chip Model (more than 1 die per CPU).
              * MCP - Multi Core Processor (more than 1 core per CPU).
              * SMP - Symmetric Multi Processing (more than 1 physical CPU).
              * UP - Uni (single core) Processor.
              Note that min/max: speeds are not necessarily true in cases of overclocked CPUs or CPUs in turbo/boost mode. See -Ca for alternate base/boost: speed data.
       -d, --disk-full,--optical
              Show  optical  drive  data as well as -D hard drive data. With -x, adds a feature line to the output. Also shows floppy disks if present. Note that there is no current way to get any information about the floppy device
              that we are aware of, so it will simply show the floppy ID without any extra data. -xx adds a few more features.
       -D, --disk
              Show Hard Disk info. Shows total disk space and used percentage. The disk used percentage includes space used by swap partition(s), since those are not usable for data storage. Note that with RAID disks, the percentage
              will  be  wrong  since  the  total  is  computed from the disk sizes, but used is computed from mounted partition used percentages. This small defect may get corrected in the future.  Also, unmounted partitions are not
              counted in disk use percentages since inxi has no access to the used amount.
              Also shows per disk information: Disk ID, type (if present), vendor (if detected), model, and size. See Extra Data Options (-x options) and Admin Extra Data Options (--admin options) for many more features.
       --filter, --filter-override - See -z, -Z.
       --filter-label
              Filter partition label names from -j, -o, -p, -P, and -Sa (root=LABEL=...). Generally only useful in very specialized cases.
       --filter-uuid
              Filter partition UUIDs from -j, -o, -p, -P, and -Sa (root=UUID=...). Generally only useful in very specialized cases.
       -f, --flags
              Show all CPU flags used, not just the short list. Not shown with -F in order to avoid spamming. ARM CPUs: show features items.
       -F, --full
              Show Full output for inxi. Includes all Upper Case line letters except -W, plus --swap, -s and -n. Does not show extra verbose options such as -d -f -i -l -m -o -p -r -t -u -x unless you use those arguments in the com‐
              mand, e.g.: inxi -Frmxx
       -G, --graphics
              Show Graphic card(s) information, including details of card and card driver, display protocol (if available), display server (and/or Wayland compositor), vendor and version number, e.g.:
              Display: x11 server: Xorg 1.15.1
              If protocol is not detected, shows:
              Display: server: Xorg 1.15.1
              Also shows screen resolution(s) (per monitor/X screen), OpenGL renderer, OpenGL core profile version/OpenGL version.
              Compositor information will show if detected using -xx option or always if detected and Wayland.
       -h, --help
              The  help  menu.  Features  dynamic  sizing to fit into terminal window. Set script global COLS_MAX_CONSOLE if you want a different default value, or use -y <width> to temporarily override the defaults or actual window
              width.
       -i, --ip
              Show WAN IP address and local interfaces (latter requires ifconfig or ip network tool), as well as network output from -n.  Not shown with -F for user security reasons. You shouldn't paste your local/WAN IP. Shows both
              IPv4 and IPv6 link IP addresses.
       -I, --info
              Show Information: processes, uptime, memory, IRC client (or shell type if run in shell, not IRC), inxi version. See -Ix, -Ixx, and -Ia for extra information (init type/version, runlevel, packages).
              Note: if -m is used or triggered, the memory item will show in the main Memory: report of -m, not in Info:.
              Rasberry Pi only: uses vcgencmd get_mem gpu to get gpu RAM amount, if user is in video group and vcgencmd is installed. Uses this result to increase the Memory: amount and used: amounts.
       -j, --swap
              Shows all active swap types (partition, file, zram). When this option is used, swap partition(s) will not show on the -P line to avoid redundancy.
       -J, --usb
              Show  USB data for attached Hubs and Devices. Hubs also show number of ports.  Be aware that a port is not always external, some may be internal, and either used or unused (for example, a motherboard USB header connec‐
              tor that is not used).
              Hubs and Devices are listed in order of BusID.
              BusID is generally in this format: BusID-port[.port][.port]:DeviceID
              Device ID is a number created by the kernel, and has no necessary ordering or sequence connection, but can be used to match this output to lsusb values, which generally shows BusID / DeviceID  (except  for  tree  view,
              which shows ports).
              Examples: Device-3: 4-3.2.1:2 or Hub: 4-0:1
              The rev: 2.0 item refers to the USB revision number, like 1.0 or 3.1.
       -l, --label
              Show partition labels. Default: main partitions -P. For full -p output, use: -pl.
       -m, --memory
              Memory (RAM) data. Does not display with  -b or  -F unless you use -m explicitly. Ordered by system board physical system memory array(s) (Array-[number]), and individual memory devices (Device-[number]). Physical mem‐
              ory array  data shows array capacity, number of devices supported, and Error Correction information. Devices shows locator data (highly variable in syntax), size, speed, type (eg: type: DDR3).
              Note: -m uses dmidecode, which must be run as root (or start inxi with sudo), unless you figure out how to set up sudo to permit dmidecode to read /dev/mem as user. speed and bus width will not show if  No  Module  In‐
              stalled is found in size.
              Note: If -m is triggered RAM total/used report will appear in this section, not in -I or -tm items.
              Because  dmidecode  data is extremely unreliable, inxi will try to make best guesses.  If you see (check) after the capacity number, you should check it with the specifications. (est) is slightly more reliable, but you
              should still check the real specifications before buying RAM. Unfortunately there is nothing inxi can do to get truly reliable data about the system RAM; maybe one day the kernel devs will put this data into /sys,  and
              make it real data, taken from the actual system, not dmi data. For most people, the data will be right, but a significant percentage of users will have either a wrong max module size, if present, or max capacity.
              See --memory-modules and --memory-short if you want a shorter report.
       --memory-modules
              Memory (RAM) data. Show only RAM arrays and modules in Memory report.  Skip empty slots. See -m.
       --memory-short
              Memory (RAM) data. Show a one line RAM report in Memory. See -m.
              Sample: Report: arrays: 1 slots: 4 modules: 2 type: DDR4
       -M, --machine
              Show  machine  data.  Device,  Motherboard, BIOS, and if present, System Builder (Like Lenovo).  Older systems/kernels without the required /sys data can use dmidecode instead, run as root. If using dmidecode, may also
              show BIOS/UEFI revision as well as version.  --dmidecode forces use of dmidecode data instead of /sys.  Will also attempt to show if the system was booted by BIOS, UEFI, or UEFI [Legacy], the latter being  legacy  BIOS
              boot mode in a system board using UEFI.
              Device information requires either /sys or dmidecode. Note that 'other-vm?'  is a type that means it's usually a VM, but inxi failed to detect which type, or positively confirm which VM it is. Primary VM identification
              is via systemd-detect-virt but fallback tests that should also support some BSDs are used. Less commonly used or harder to detect VMs may not be correctly detected. If you get an incorrect output,  post  an  issue  and
              we'll get it fixed if possible.
              Due to unreliable vendor data, device type will show: desktop, laptop, notebook, server, blade, plus some obscure stuff that inxi is unlikely to ever run on.
       -n, --network-advanced
              Show Advanced Network card information in addition to that produced by -N.  Shows interface, speed, MAC ID, state, etc.
       -N, --network
              Show Network card(s) information, including card driver. With -x, shows PCI BusID, Port number.
       -o, --unmounted
              Show  unmounted partition information (includes UUID and LABEL if available).  Shows file system type if you have lsblk installed (Linux only). For BSD/GNU Linux: shows file system type if file is installed, and if you
              are root or if you have added to /etc/sudoers (sudo v. 1.7 or newer):
              <username> ALL = NOPASSWD: /usr/bin/file (sample)
              Does not show components (partitions that create the md-raid array) of md-raid arrays.
       -p, --partitions-full
              Show full Partition information (-P plus all other detected mounted partitions).
       -P, --partitions
              Show basic Partition information.  Shows, if detected: / /boot /home /opt /tmp /usr /usr/home /var /var/tmp /var/log.  If --swap is not used, shows active swap partitions (never shows file or zram type swap).   Use  -p
              to see all mounted partitions.
       --processes - See -t
       -r, --repos
              Show distro repository data. Currently supported repo types:
              APK (Alpine Linux + derived versions)
              APT (Debian, Ubuntu + derived versions, as well as RPM based APT distros like PCLinuxOS or Alt-Linux)
              CARDS (NuTyX + derived versions)
              EOPKG (Solus)
              PACMAN (Arch Linux, KaOS + derived versions)
              PACMAN-G2 (Frugalware + derived versions)
              PISI (Pardus + derived versions)
              PORTAGE (Gentoo, Sabayon + derived versions)
              PORTS (OpenBSD, FreeBSD, NetBSD + derived OS types)
              SLACKPKG (Slackware + derived versions)
              TCE (TinyCore)
              URPMI (Mandriva, Mageia + derived versions)
              XBPS (Void)
              YUM/ZYPP (Fedora, Red Hat, Suse + derived versions)
              More will be added as distro data is collected. If yours is missing please show us how to get this information and we'll try to add it.
              See -rx, -rxx, and -ra for installed package count information.
       -R, --raid
              Show RAID data. Shows RAID devices, states, levels and components, and extra data with -x / -xx.
              md-raid: If device is resyncing, also shows resync progress line.
              Note: Only md-raid and ZFS are currently supported. Other software RAID types could be added, but only if users supply all data required, and if the software RAID actually can be made to give the required output.
              If hardware RAID is detected, shows basic information. Due to complexity of adding hardware RAID device disk / RAID reports, those will only be added if there is demand, and reasonable reporting tools.
       --recommends
              Checks inxi application dependencies and recommends, as well as directories, then shows what package(s) you need to install to add support for each feature.
       -s, --sensors
              Show  output  from  sensors if sensors installed/configured: Motherboard/CPU/GPU temperatures; detected fan speeds. GPU temperature when available. Nvidia shows screen number for multiple screens. IPMI sensors are also
              used (root required) if present. See Advanced options --sensors-use or --sensors-exclude if you want to use only a subset of all sensors, or exclude one.
       --slots
              Show PCI slots with type, speed, and status information.
       --swap - See -j
       -S, --system
              Show System information: host name, kernel, desktop environment (if in X), distro. With -xx show dm - or startx - (only shows if present and running if out of X), and if in X, with -xxx show  more  desktop  info,  e.g.
              taskbar or panel.
       -t, --processes
              [c|m|cm|mc NUMBER] Show processes. If no arguments, defaults to cm.  If followed by a number, shows that number of processes for each type (default: 5; if in IRC, max: 5)
              Make sure that there is no space between letters and numbers (e.g. write as -t cm10).
       -t c   - CPU only. With -x, also shows memory for that process on same line.
       -t m   - memory only. With -x, also shows CPU for that process on same line.  If the -I line is not triggered, will also show the system RAM used/total information.
       -t cm  - CPU+memory. With -x, shows also CPU or memory for that process on same line.
       -u, --uuid
              Show partition UUIDs. Default: main partitions -P. For full -p output, use: -pu.
       -U, --update
              Note - Maintainer may have disabled this function.
              If inxi -h has no listing for -U then it's disabled.
              Auto-update  script. Note: if you installed as root, you must be root to update, otherwise user is fine. Also installs / updates this man page to: /usr/local/share/man/man1 (if /usr/local/share/man/ exists AND there is
              no inxi man page in /usr/share/man/man1, otherwise it goes to /usr/share/man/man1). This requires that you be root to write to that directory. See --man or --no-man to force or disable man install.
       --usb - See -J
       -V, --version
              inxi version information. Prints information then exits.
       -v, --verbosity
              Script verbosity levels. If no verbosity level number is given, 0 is assumed.  Should not be used with -b or -F.
              Supported levels: 0-8 Examples : inxi -v 4  or  inxi -v4
       -v 0   - Short output, same as: inxi
       -v 1   - Basic verbose, -S + basic CPU (cores, type, clock speed, and min/max speeds, if available) + -G + basic Disk + -I.
       -v 2   - Adds networking card (-N), Machine (-M) data, Battery (-B) (if available). Same as: inxi -b
       -v 3   - Adds advanced CPU (-C) and network (-n) data; triggers -x advanced data option.
       -v 4   - Adds partition size/used data (-P) for (if present): / /home /var/ /boot. Shows full disk data (-D)
       -v 5   - Adds audio card (-A), memory/RAM (-m), sensors (-s), partition label (-l), UUID (-u), full swap data (-j), and short form of optical drives.
       -v 6   - Adds full mounted partition data (-p), unmounted partition data (-o), optical drive data (-d), USB (-J); triggers -xx extra data option.
       -v 7   - Adds network IP data (-i); triggers -xxx
       -v 8   - All system data available. Adds Repos (-r), PCI slots (--slots), processes (-tcm), admin (--admin). Useful for testing output and to see what data you can get from your system.
       -w, --weather
              Adds weather line. To get weather for an alternate location, use -W [location]. See also -x, -xx, -xxx options.  Please note that your distribution's maintainer may chose to disable this feature.
              DO NOT USE THIS FEATURE FOR AUTOMATED WEATHER UPDATES! You will be blocked from any further access. This feature is not meant for widget type weather monitoring, or Conky type use. It is meant to get weather  when  you
              need to see it, for example, on a remote server.
       -W, --weather-location <location_string>
              Get  weather/time for an alternate location. Accepts postal/zip code[, country], city,state pair, or latitude,longitude. Note: city/country/state names must not contain spaces. Replace spaces with '+' sign. Don't place
              spaces around any commas. Postal code is not reliable except for North America and maybe the UK.  Try postal codes with and without country code  added.  Note  that  City,State  applies  only  to  USA,  otherwise  it's
              City,Country. If country name (english) does not work, try 2 character country code (e.g. Spain: es; Great Britain: gb).
              See https://en.wikipedia.org/wiki/ISO_3166-1_alpha-2 for current 2 letter country codes.
              Use only ASCII letters in city/state/country names.
              Examples: -W 95623,us OR -W Boston,MA OR -W 45.5234,-122.6762 OR -W new+york,ny OR -W bodo,norway.
              DO NOT USE THIS FEATURE FOR AUTOMATED WEATHER UPDATES! Use of automated queries, will result in your access being blocked. If you try to work around the ban, you will be permanently banned from this service.
       --weather-source, --ws <unit>
              [1-9] Switches weather data source. Possible values are 1-9. 1-4 will generally be active, and 5-9 may or may not be active, so check.  1 may not support city / country names with spaces (even if you use the + sign in‐
              stead of space). 2 offers pretty good data, but may not have all small city names for -W.
              Please note that the data sources are not static per value, and can change any time, or be removed, so always test to verify which source is being used for each value if that is important to you. Data  sources  may  be
              added or removed on occasions, so try each one and see which you prefer. If you get unsupported source message, it means that number has not been implemented.
       --weather-unit <unit>
              [m|i|mi|im] Sets weather units to metric (m), imperial (i), metric (imperial) (mi, default), imperial (metric) (im). If metric or imperial not found,sets to default value, or N/A.
       -y, --width [integer]
              This  is  an  absolute width override which sets the output line width max.  Overrides COLS_MAX_IRC / COLS_MAX_CONSOLE globals, or the actual widths of the terminal. 80 is the minimum width supported.  -1 removes width
              limits. 1 switches to a single indented key/value pair per line, and removes all long line wrapping (similar to dmidecode output).
              If no integer value is given, sets width to default of 80.
              Examples: inxi -Fxx -y 130 or inxi -Fxxy or inxi -bay1
       -z, --filter
              Adds security filters for IP addresses, serial numbers, MAC, location (-w), and user home directory name. Removes Host:.  On by default for IRC clients.
       -Z, --filter-override
              Absolute override for output filters. Useful for debugging networking issues in IRC for example.
EXTRA DATA OPTIONS
       These options can be triggered by one or more -x.  Alternatively, the -v options trigger them in the following way: -v 3 adds -x; -v 6 adds -xx; -v 7 adds -xxx
       These extra data triggers can be useful for getting more in-depth data on various options. They can be added to any long form option list, e.g.: -bxx or -Sxxx
       There are 3 extra data levels:
       -x, -xx, -xxx
       OR
       --extra 1, --extra 2, --extra 3
       The following details show which lines / items display extra information for each extra data level.
       -x -A  - Adds (if available and/or relevant) vendor: item, which shows specific vendor [product] information.
              - Adds version/port(s)/driver version (if available) for each Audio device.
              - Adds PCI Bus ID/USB ID number of each Audio device.
       -x -B  - Adds vendor/model, battery status (if battery present).
              - Adds attached battery powered peripherals (Device-[number]:) if detected (keyboard, mouse, etc.).
       -x -C  - Adds bogomips on CPU (if available)
              - Adds CPU Flags (short list). Use -f to see full flag/feature list.
              - Adds CPU microarchitecture + revision (e.g. Sandy Bridge, K8, ARMv8, P6, etc.). Only shows data if detected. Newer microarchitectures will have to be added as they appear, and require the CPU family ID and model ID.
              Examples: arch: Sandy Bridge rev: 2, arch: K8 rev.F+ rev: 2
       -x -d  - Adds more items to Features line of optical drive; dds rev version to optical drive.
       -x -D  - Adds HDD temperature with disk data if you have hddtemp installed, if you are root or if you have added to /etc/sudoers (sudo v. 1.7 or newer):
              <username> ALL = NOPASSWD: /usr/sbin/hddtemp (sample)
       -x -G  - Adds (if available and/or relevant) vendor: item, which shows specific vendor [product] information.
              - Adds direct rendering status.
              - Adds (for single GPU, nvidia driver) screen number that GPU is running on.
              - Adds PCI Bus ID/USB ID number of each Graphics card.
       -x -i  - Adds IP v6 additional scope data, like Global, Site, Temporary for each interface.
              Note that there is no way we are aware of to filter out the deprecated IP v6 scope site/global temporary addresses from the output of ifconfig. The ip tool shows that clearly.
              ip-v6-temporary - (ip tool only), scope global temporary.  Scope global temporary deprecated is not shown
              ip-v6-global - scope global (ifconfig will show this for all types, global, global temporary, and global temporary deprecated, ip shows it only for global)
              ip-v6-link - scope link (ip/ifconfig) - default for -i.
              ip-v6-site - scope site (ip/ifconfig). This has been deprecated in IPv6, but still exists. ifconfig may show multiple site values, as with global temporary, and global temporary deprecated.
              ip-v6-unknown - unknown scope
       -x -I  - Adds current init system (and init rc in some cases, like OpenRC).  With -xx, shows init/rc version number, if available.
              - Adds default system gcc. With -xx, also show other installed gcc versions.
              - Adds current runlevel (not available with all init systems).
              - Adds total packages discovered in system. See -xx and -a for per package manager types output. Moves to Repos if -rx.
              If your package manager is not supported, please file an issue and we'll add it.  That requires the full output of the query or method to discover all installed packages on your system, as well of course as the command
              or method used to discover those.
              - If in shell (i.e. not in IRC client), adds shell version number, if available.
       -x -J (--usb)
              - For Devices, adds driver(s).
       -x -m, --memory-modules
              - If present, adds maximum memory module/device size in the Array line.  Only some systems will have this data available. Shows estimate if it can generate one.
              - Adds device type in the Device line.
       -x -N  - Adds (if available and/or relevant) vendor: item, which shows specific vendor [product] information.
              - Adds version/port(s)/driver version (if available) for each Network card;
              - Adds PCI Bus ID/USB ID number of each Network card.
       -x -r  - Adds Package info. See -Ix
       -x -R  - md-raid: Adds second RAID Info line with extra data: blocks, chunk size, bitmap (if present). Resync line, shows blocks synced/total blocks.
              - Hardware RAID: Adds driver version, bus ID.
       -x -s  - Adds basic voltages: 12v, 5v, 3.3v, vbat (ipmi, lm-sensors if present).
       -x -S  - Adds Kernel gcc version.
              -  Adds to Distro: base: if detected. System base will only be seen on a subset of distributions. The distro must be both derived from a parent distro (e.g. Mint from Ubuntu), and explicitly added to the supported dis‐
              tributions for this feature. Due to the complexity of distribution identification, these will only be added as relatively solid methods are found for each distribution system base detection.
       -x -t (--processes)
              - Adds memory use output to CPU (-xt c), and CPU use to memory (-xt m).
       -x -w, -W
              - Adds humidity and barometric pressure.
              - Adds wind speed and direction.
       -xx -A - Adds vendor:product ID for each Audio device.
       -xx -B - Adds serial number, voltage (if available). Note that volts shows the data (if available) as the voltage now / minimum design voltage.
       -xx -C - Adds L1 cache: and L3 cache: if either are available. Requires dmidecode and sudo/root.
       -xx -D - Adds disk serial number.
              - Adds disk speed (if available). This is the theoretical top speed of the device as reported. This speed may be restricted by system board limits, eg.  a SATA 3 drive on a SATA 2 board may report SATA  2  speeds,  but
              this is not completely consistent, sometimes a SATA 3 device on a SATA 2 board reports its design speed.
              NVMe  drives:  adds  lanes,  and (per direction) speed is calculated with lane speed * lanes * PCIe overhead. PCIe 1 and 2 have data rates of GT/s * .8  = Gb/s (10 bits required to transfer 8 bits of data).  PCIe 3 and
              greater transfer data at a rate of GT/s * 128/130 * lanes = Gb/s (130 bits required to transfer 128 bits of data).
              For a PCIe 3 NVMe drive, with speed of 8 GT/s and 4 lanes (8GT/s * 128/130 * 4 = 31.6 Gb/s):
              speed: 31.6 Gb/s lanes: 4
       -xx -G - Adds vendor:product ID of each Graphics card.
              - Adds Xorg compositor, if found (always shows for Wayland systems).
              - For free drivers, adds OpenGL compatibility version number if  available.  For nonfree drivers, the core version and compatibility versions are usually the same. Example:
              v: 3.3 Mesa 11.2.0 compat-v: 3.0
              - If available, shows alternate: Xorg drivers. This means a driver on the default list of drivers Xorg automatically checks for the card, but which is not installed. For example, if  you  have  nouveau  driver,  nvidia
              would  show as alternate if it was not installed. Note that alternate: does NOT mean you should have it, it's just one of the drivers Xorg checks to see if is present and loaded when checking the card. This can let you
              know there are other driver options.  Note that if you have explicitly set the driver in xorg.conf, Xorg will not create this automatic check driver list.
              - If available, shows Xorg dpi (s-dpi:) for the active Xorg Screen (not physical monitor). Note that the physical monitor dpi and the Xorg dpi are not necessarily the same thing, and can vary widely.
       -xx -I - Adds init type version number (and rc if present).
              - Adds other detected installed gcc versions (if present).
              - Adds system default runlevel, if detected. Supports Systemd/Upstart/SysVinit type defaults.
              - Shows Packages: counts by discovered package manager types. In cases where only 1 type had results, does not show total after Packages:. Does not show installed package managers wtih 0 packages. See -a for full  out‐
              put.  Moves to Repos if -rxx.
              - Adds parent program (or tty) that started shell, if not IRC client.
       -xx -j (--swap), -xx -p, -xx -P
              - Adds swap priority to each swap partition (for -P) used, and for all swap types (for -j).
       -xx -J (--usb)
              - Adds vendor:chip id.
       -xx -m, --memory-modules
              - Adds memory device Manufacturer.
              -  Adds  memory device Part Number (part-no:). Useful for ordering new or replacement memory sticks etc. Part numbers are unique, particularly if you use the word memory in the search as well. With -xxx, also shows se‐
              rial number.
              - Adds single/double bank memory, if data is found. Note, this may not be 100% right all of the time since it depends on the order that data is found in dmidecode output for type 6 and type 17.
       -xx -M - Adds chassis information, if data is available. Also shows BIOS ROM size if using dmidecode.
       -xx -N - Adds vendor:product ID for each Network card.
       -xx -r - Adds Packages info. See -Ixx
       -xx -R - md-raid: Adds superblock (if present) and algorithm. If resync, shows progress bar.
              - Hardware RAID: Adds Chip vendor:product ID.
       -xx -s - Adds DIMM/SOC voltages, if present (ipmi only).
       -xx -S - Adds display manager (dm) type, if present. If none, shows N/A.  Supports most known display managers, including gdm, gdm3, idm, kdm, lightdm, lxdm, mdm, nodm, sddm, slim, tint, wdm, and xdm.
              - Adds, if run in X, window manager type (wm), if available.  Not all window managers are supported. Some desktops support using more than one window manager, so this can be useful to see what window manager  is  actu‐
              ally running.  If none found, shows nothing. Uses a less accurate fallback tool wmctrl if ps tests fail to find data.
              - Adds desktop toolkit (tk), if available (Xfce/KDE/Trinity).
       -xx --slots
              - Adds slot length.
       -xx -w, -W
              - Adds wind chill, heat index, and dew point, if available.
              - Adds cloud cover, rain, snow, or precipitation (amount in previous hour to observation time), if available.
       -xxx -A
              - Adds, if present, serial number.
       -xxx -B
              -  Adds  battery  chemistry (e.g. Li-ion), cycles (NOTE: there appears to be a problem with the Linux kernel obtaining the cycle count, so this almost always shows 0. There's nothing that can be done about this glitch,
              the data is simply not available as of 2018-04-03), location (only available from dmidecode derived output).
              - Adds attached device rechargeable: [yes|no] information.
       -xxx -C
              - Adds boost: [enabled|disabled] if detected, aka turbo. Not all CPUs have this feature.
              - Adds CPU voltage and external clock speed (this is the motherboard speed).  Requires sudo/root and dmidecode.
       -xxx -D
              - Adds disk firmware revision number (if available).
              - Adds disk partition scheme (in most cases), e.g. scheme: GPT. Currently not able to detect all schemes, but handles the most common, e.g. GPT or MBR.
              - Adds disk rotation speed (in some but not all cases), e.g. rotation: 7200 rpm.  Only appears if detected (SSD drives do not have rotation speeds, for example). If none found, nothing shows. Not all disks report  this
              speed, so even if they are spinnning, no data will show.
       -xxx -I
              - For Shell: adds (su|sudo|login) to shell name if present.
              - For Shell: adds default: shell if different from running shell, and default shell v:, if available.
              - For running in: adds (SSH) to parent, if present. SSH detection uses the who am i test.
       -xxx -J (--usb)
              - Adds, if present, serial number for non hub devices.
              - Adds interfaces: for non hub devices.
              - Adds, if available, USB speed in Mbits/s or Gbits/s.
       -xxx -m, --memory-modules
              -  Adds memory bus width: primary bus width, and if present, total width. e.g.  bus width: 64 bit (total: 72 bits). Note that total / data widths are mixed up sometimes in dmidecode output, so inxi will take the larger
              value as the total if present. If no total width data is found, then inxi will not show that item.
              - Adds device Type Detail, e.g. detail: DDR3 (Synchronous).
              - Adds, if present, memory module voltage. Only some systems will have this data available.
              - Adds device serial number.
       -xxx -N
       -xxx -R
              - md-raid: Adds system mdraid support types (kernel support, read ahead, RAID events)
              - zfs-raid: Adds portion allocated (used) by RAID array/device.
              - Hardware RAID: Adds rev, ports, and (if available and/or relevant) vendor: item, which shows specific vendor [product] information.
       -xxx -S
              - Adds, if in X, or with --display, bar/dock/panel/tray items (info). If none found, shows nothing. Supports desktop items like gnome-panel, lxpanel, xfce4-panel, lxqt-panel, tint2, cairo-dock, trayer, and many others.
              - Adds (if present), window manager (wm) version number.
              - Adds (if present), display manager (dm) version number.
       -xxx -w, -W
              - Adds location (city state country), observation altitude (if available), weather observation time (if available), sunset/sunrise (if available).
ADMIN EXTRA DATA OPTIONS
       These options are triggered with --admin or -a. Admin options are advanced output options, and are more technical, and mostly of interest to system administrators or other machine admins.
       The --admin option sets -xxx, and only has to be used once.  It will trigger the following features:
       -a -A  - Adds, if present, possible alternate: kernel modules capable of driving each Device-x (not including the current driver:). If no non-driver modules found, shows nothing. NOTE: just because it lists a module does  NOT
              mean it is available in the system, it's just something the kernel knows could possibly be used instead.
       -a -C  - Adds CPU family, model-id, and stepping (replaces rev of -Cx).  Format is hexadecimal (decimal) if greater than 9, otherwise hexadecimal.
              - Adds CPU microcode. Format is hexadecimal.
              - Adds socket type (for motherboard CPU socket, if available). If results doubtful will list two socket types and note: check. Requires sudo/root and dmidecode.  The item in parentheses may simply be a different syntax
              for the same socket, but in general, check this before trusting it.
              Sample: socket: 775 (478) note: check
              Sample: socket: AM4
              - Adds DMI CPU base and boost/turbo speeds. Requires sudo/root and dmidecode.  In some cases, like with overclocking or 'turbo' or 'boost' modes, voltage and external clock speeds may be increased, or short term limits
              raised on max CPU speeds.  These are often not reflected in /sys based CPU min/max: speed results, but often are using this source.
              Samples:
              CPU not overclocked, with boost, like Ryzen:
              Speed: 2861 MHz min/max: 1550/3400 MHz boost: enabled base/boost: 3400/3900
              Overclocked 2900 MHz CPU, with no boost available:
              Speed: 2900 MHz min/max: 800/2900 MHz base/boost: 3350/3000
              Overclocked 3000 MHz CPU, with boosted max speed:
              Speed: 4190 MHz min/max: 1200/3001 MHz base/boost: 3000/4000
              Note  that  these numbers can be confusing, but basically, the base number is the actual normal top speed the CPU runs at without boost mode, and the boost number is the max speed the CPU reports itself able to run at.
              The actual max speed may be higher than either value, or lower.  The boost number appears to be hard-coded into the CPU DMI data, and does not seem to reflect actual max speeds that overclocking or  other  combinations
              of speed boosters can enable, as you can see from the example where the CPU is running at a speed faster than the min/max or base/boost values.
              Note that the normal min/max: speeds do NOT show actual overclocked OR boost/turbo mode speeds, and appear to be hard-coded values, not dynamic real values. The base/boost: values are sometimes real, and sometimes not.
              base appears in general to be real.
              - Adds CPU Vulnerabilities (bugs) as known by your current kernel. Lists by Type: ... (status|mitigation): .... for systems that support this feature (Linux kernel 4.14 or newer, or patched older kernels).
       -a -d,-a -D
              - Adds logical and physical block size in bytes.
              Using smartctl (requires sudo/root privileges).
              - Adds device model family, like Caviar Black, if available.
              - Adds SATA type (eg 1.0, 2.6, 3.0) if a SATA device.
              - Adds SMART report line: status, enabled/disabled, health, powered on, cycles, and some error cases if out of range values. Note that for Pre-fail items, it will show the VALUE and THRESHOLD numbers. It will also fall
              back  for  unknown  attributes  that are or have been failing and print out the Attribute name, value, threshold, and failing message. This way even for unhandled Attribute names, you should get a solid report for full
              failure cases. Other cases may show if inxi believes that the item may be approaching failure. This is a guess so make sure to check the drive and smartctl full output to verify before taking any further action.
              - Adds, for USB or other external drives, actual model name/serial if available, and different from enclosure model/serial, and corrects block sizes if necessary. Adds in drive temperature for some drives as well,  and
              other useful data.
       -a -G  Triggers a much more complete Screen/Monitor output on the Display: line of -G. Note that the basic feature requires xdpyinfo, and the advanced per monitor feature requires xrandr.
              No  support  currently  exists for Wayland since we so far can find no documentation or easy methods to extract this information from Wayland compositors. This unfortunate situation may change in the future, hopefully.
              However, most Wayland systems also come with xwayland, which should supply the tools necessary for the time being.
              Further note that all references to Displays, Screens, and Monitors are referring to the X technical terms, not normal consumer usage. 1 Display runs 1 or more Screens, and a Screen runs 1 or more Monitors.
              - Adds Display ID, for the Display running the Screen that runs the Monitors.
              - Adds total number of Screens listed for the current Display.
              - Adds default Screen ID if Screen (not monitor!) total is greater than 1.
              - Adds Screen line, which includes the ID (Screen: 0) then s-res (Screen resolution), s-dpi, s-size and s-diag. Remember, this is an Xorg Screen, NOT a monitor screen, and the  information  listed  is  about  the  Xorg
              Screen! It may at times be the same as a single monitor system, but usually it's different in some ways.
              -  Adds  Monitor ID(s). Monitors are a subset of a Screen, each of which can have one or more monitors. Normally a dual monitor setup is 2 monitors run by one Xorg Screen. Each monitor has the following data, if avail‐
              able:
              - res: resolution in pixels. This is the individual monitor's reported pixel dimensions.
              - hz: frequency in Herz, as reported to Xorg. Note that there have been and may continue to be bugs with how Xorg treats > 1 monitor frequencies.
              - dpi: dpi (dots per inch), aka, ppi (pixels per inch). This is the physical screen dpi, which is calculated using the screen dimensions and its resolution.
              - size: size in mm (inches). Note that this is the real monitor size, not the Xorg Screen size, which can be quite different (1 Xorg Screen can for instance contain two or more monitors).
              - diag: monitor screen diagonal in mm (inches). Note that this is the real monitor size, not the Xorg full Screen diagonal size, which can be quite different.
              Sample (with both xdpyinfo and xrandr data available):
              inxi -aG
              Display: x11 server: X.Org 1.20.6 driver: modesetting
              display ID: :0.0 screens: 1
              Screen-1: 0 s-res: 2560x1024 s-dpi: 96 s-size: 677x271mm (26.7x10.7")
              s-diag: 729mm (28.7")
              Monitor-1: DVI-I-0 res: 1280x1024 hz: 60 dpi: 96
              size: 338x270mm (13.3x10.6") diag: 433mm (17")
              Monitor-2: VGA-0 res: 1280x1024 hz: 60 dpi: 86
              size: 376x301mm (14.8x11.9") diag: 482mm (19")
       -a -I  Adds Packages, totals, per package manager totals, and number of lib packages detected per package manager. Also adds detected package managers with 0 packages listed. Moves to Repos if -ra.
              inxi -aI
               Init: systemd v: 245 runlevel: 5 Compilers: gcc: 9.3.0 alt: 5/6/7/8/9
               Packages: apt: 3681 lib: 2096 rpm: 0 Shell: ksh v: A_2020.0.0 default: Bash
               v: 5.0.16 running in: kate inxi: 3.1.04
       -a -j, -a -P , -a -P
              - Adds swappiness and vfs cache pressure, and a message to indicate if the value is the default value or not (Linux only, and only if available).  If not the default value, shows default value as well, e.g.
              For -P per swap physical partition:
              swappiness: 60 (default) cache pressure: 90 (default 100)
              For -j row 1 output:
              Kernel: swappiness: 60 (default) cache pressure: 90 (default 100)
       -a -n, -a -N, -a -i
       -a -p,-a -P
              - Adds raw partition size, including file system overhead, partition table, e.g.
              raw size: 60.00 GiB.
              - Adds percent of raw size available to size: item, e.g.
              size: 58.81 GiB (98.01%).
              Note that used: 16.44 GiB (34.3%) percent refers to the available size, not the raw size.
              - Adds partition filesystem block size if found (requires root and blockdev).
       -a -r  - Adds Packages. See -Ia
       -a -S  - Adds kernel boot parameters to Kernel section (if detected). Support varies by OS type.
ADVANCED OPTIONS
       --alt 40
              Bypass Perl as a downloader option. Priority is: Perl (HTTP::Tiny), Curl, Wget, Fetch, (OpenBSD only) ftp.
       --alt 41
              Bypass Curl as a downloader option. Priority is: Perl (HTTP::Tiny), Curl, Wget, Fetch, (OpenBSD only) ftp.
       --alt 42
              Bypass Fetch as a downloader option. Priority is: Perl (HTTP::Tiny), Curl, Wget, Fetch, (OpenBSD only) ftp.
       --alt 43
              Bypass Wget as a downloader option. Priority is: Perl (HTTP::Tiny), Curl, Wget, Fetch, OpenBSD only: ftp
       --alt 44
              Bypass Curl, Fetch, and Wget as downloader options. This basically forces the downloader selection to use Perl 5.x HTTP::Tiny, which is generally slower than Curl or Wget but it may help bypass issues with downloading.
       --dig  Temporary override of NO_DIG configuration item. Only use to test w/wo dig.  Restores default behavior for WAN IP, which is use dig if present.
       --display [:<integer>]
              Will try to get display data out of X (does not usually work as root user).  Default gets display info from display :0. If you use the format --display :1 then it would get it from display 1 instead, or any display you
              specify.
              Note  that  in some cases, --display will cause inxi to hang endlessly when running the option in console with Intel graphics. The situation regarding other free drivers such as nouveau/ATI is currently unknown. It may
              be that this is a bug with the Intel graphics driver - more information is required.
              You can test this easily by running the following command out of X/display server: glxinfo -display :0
              If it hangs, --display will not work.
       --dmidecode
              Force use of dmidecode. This will override /sys data in some lines, e.g. -M or -B.
       --downloader [curl|fetch|perl|wget]
              Force inxi to use Curl, Fetch, Perl, or Wget for downloads.
       --host Turns on hostname in System line. Overrides inxi config file value (if set):
              SHOW_HOST='false' - Same as: SHOW_HOST='true'
              This is an absolute override, the host will always show no matter what other switches you use.
       --html-wan
              Temporary override of NO_HTML_WAN configuration item. Only use to test w/wo HTML downloaders for WAN IP. Restores default behavior for WAN IP, which is use HTML downloader if present and if dig failed.
       --indent-min [integer]
              Overrides default indent minimum value. This is the value that makes inxi change from wrapped line starters [like Info] to non wrapped. If less than 80, no wrapping will occur. Overrides internal default value and user
              configuration value:
              INDENT_MIN=85
       --limit [-1 - x]
              Raise or lower max output limit of IP addresses for -i. -1 removes limit.
       --man  Updates / installs man page with -U if pinxi or using -U 3 dev branch.  (Only active if -U is is not disabled by maintainers).
       --no-dig
              Overrides default use of dig to get WAN IP address. Allows use of normal downloader tool to get IP addresses. Only use if dig is failing, since dig is much faster and more reliable in general than other methods.
       --no-host
              Turns off hostname in System line. This is default when using -z, for anonymizing inxi output for posting on forums or IRC. Overrides configuration value (if set):
              SHOW_HOST='true' - Same as: SHOW_HOST='false'
              This is an absolute override, the host will not show no matter what other switches you use.
       --no-html-wan
              Overrides  use  of HTML downloaders to get WAN IP address. Use either only dig, or do not get wan IP. Only use if dig is failing, and the HTML downloaders are taking too long, or are hanging or failing.  Make permanent
              with NO_HTML_WAN='true'
       --no-man
              Disables man page install with -U for master and active development branches.  (Only active if -U is is not disabled by maintainers).
       --no-sensor-force
              Overrides user set SENSOR_FORCE configuration value. Restores default behavior.
       --no-ssl
              Skip SSL certificate checks for all downloader actions (-U, -w, -W, -i). Use if your system does not have current SSL certificate lists, or if you have problems making a connection for  any  reason.  Works  with  Wget,
              Curl, Perl HTTP::Tinyand Fetch.
       --no-sudo
              Skips  the use of sudo to run certain internal features (like hddtemp, file) with sudo. Not related to running inxi itself with sudo or super user. Some systems will register errors which will then trigger admin emails
              in such cases, so if you want to disable regular user use of sudo (which requires configuration to setup anyway for these options) just use this option, or NO_SUDO configuration item.
       --output [json|screen|xml]
              Change data output type. Requires --output-file if not screen.
       --output-file [full path to output file|print]
              The given directory path must exist. The directory path given must exist, The print options prints to stdout.  Required for non-screen --output formats (json|xml).
       --partition-sort [dev-base|fs|id|label|percent-used|size|uuid|used]
              Change default sort order of partition output. Corresponds to PARTITION_SORT configuration item. These are the available sort options:
              dev-base - /dev partition identifier, like /dev/sda1.  Note that it's an alphabetic sort, so sda12 is before sda2.
              fs - Partition filesystem. Note that sorts will be somewhat random if all filesystems are the same.
              id - Mount point of partition (default).
              label - Label of partition. If partitions have no labels, sort will be random.
              percent-used - Percentage of partition size used.
              size - KiB size of partition.
              uuid - UUID of the partition.
              used - KiB used of partition.
       --pm-type [package manager name]
              For distro package maintainers only, and only for non apt, rpm, or pacman based systems.  To be used to test replacement package lists for recommends for that package manager.
       --sensors-default
              Overrides configuration values SENSORS_USE or SENSORS_EXCLUDE on a one time basis.
       --sensors-exclude
              Similar to --sensors-use except removes listed sensors from sensor data.  Make permanent with SENSORS_EXCLUDE configuration item. Note that gpu, network, disk, and other specific device monitor chips  are  excluded  by
              default.
              Example: inxi -sxx --sensors-exclude k10temp-pci-00c3
       --sensors-use
              Use only the  (comma separated) sensor arrays for -s output. Make permanent with SENSORS_USE configuration item. Sensor array ID value must be the exact value shown in lm-sensors sensors output (Linux/lm-sensors only).
              If you only want to exclude one (or more) sensors from the output, use --sensors-exlude.
              Can be useful if the default sensor data used by inxi is not from the right sensor array. Note that all other sensor data will be removed, which may lead to undesired consequences. Please be aware that this can lead to
              many  undesirable side-effects, since default behavior is to use all the sensors arrays and select which values to use from them following a set sequence of rules. So if you force one to be used, you may lose data that
              was used from another one.
              Most likely best use is when one (or two) of the sensor arrays has all the sensor data you want, and you just want to make sure inxi doesn't use data from another array that has inacurate or misleading data.
              Note that gpu, network, disk, and other specific device monitor chips are excluded by default, and should not be added since they do not provide cpu, board, system, etc, sensor data.
              Example: inxi -sxx --sensors-use nct6791-isa-0290,k10temp-pci-00c3
       --sleep [0-x.x]
              Usually in decimals. Change CPU sleep time for -C (current:  .35).  Sleep is used to let the system catch up and show a more accurate CPU use. Example:
              inxi -Cxxx --sleep 0.15
              Overrides default internal value and user configuration value:
              CPU_SLEEP=0.25
       --tty  Forces internal IRC flag to off. Used in unhandled cases where the program running inxi may not be seen as a shell/tty, but it is not an IRC client. Put --tty first in option list to avoid  unexpected  errors.  If  you
              want a specific output width, use the --width option. If you want normal color codes in the output, use the  -c [color ID] flag.
              The  sign you need to use this is extra numbers before the key/value pairs of the output of your program. These are IRC, not TTY, color codes. Please post a github issue if you find you need to use --tty (including the
              full -Ixxx line) so we can figure out how to add your program to the list of whitelisted programs.
              You can see what inxi believed started it in the -Ixxx line, Shell: or Client: item. Please let us know what that result was so we can add it to the parent start program whitelist.
       --usb-sys
              Forces the USB data generator to use /sys as data source instead of lsusb.
       --usb-tool
              Forces the USB data generator to use lsusb as data source. Overrides USB_SYS in user configuration file(s).
       --wan-ip-url [URL]
              Force -i to use supplied URL as WAN IP source. Overrides dig or default IP source urls. URL must start with http[s] or ftp.
              The IP address from the URL must be the last item on the last (non-empty) line of the page content source code.
              Same as configuration value (example):
              WAN_IP_URL='https://mysite.com/ip.php'
       --wm   Force System item wm to use wmctrl as data source, override default ps source.
DEBUGGING OPTIONS
       --dbg 1
              - Debug downloader failures. Turns off silent/quiet mode for curl, wget, and fetch. Shows more downloader action information. Shows some more information for Perl downloader.
       --dbg [2-xx]
              - See github inxi-perl/docs/inxi-values.txt for specific specialized debugging options. These can vary but tend to not change much, though they are added as needed.
       --debug [1-3]
              - On screen debugger output. Output varies depending on current needs Usually nothing changes.
       --debug 10
              - Basic logging. Check $XDG_DATA_HOME/inxi/inxi.log or $HOME/.local/share/inxi/inxi.log or $HOME/.inxi/inxi.log.
       --debug 11
              - Full file/system info logging.
       --debug 20
              Creates a tar.gz file of system data and collects the inxi output in a file.
              * tree traversal data file(s) read from /proc and /sys, and other system data.
              * xorg conf and log data, xrandr, xprop, xdpyinfo, glxinfo etc.
              * data from dev, disks, partitions, etc.
       --debug 21
              Automatically uploads debugger data tar.gz file to ftp.smxi.org, then removes the debug data directory, but leaves the debug tar.gz file.  See --ftp for uploading to alternate locations.
       --debug 22
              Automatically uploads debugger data tar.gz file to ftp.smxi.org, then removes the debug data directory and the tar.gz file.  See --ftp for uploading to alternate locations.
       --ftp [ftp.yoursite.com/incoming]
              For alternate ftp upload locations: Example:
              inxi --ftp ftp.yourserver.com/incoming --debug 21
DEBUGGING OPTIONS TO DEBUG DEBUGGER FAILURES
       Only used the following in conjunction with --debug 2[012], and only use if you experienced a failure or hang, or were instructed to do so.
       --debug-proc
              Force debugger to parse /proc directory data when run as root. Normally this is disabled due to unpredictable data in /proc tree.
       --debug-proc-print
              Use this to locate file that /proc debugger hangs on.
       --debug-no-exit
              Skip exit on error when running debugger.
       --debug-no-proc
              Skip /proc debugging in case of a hang.
       --debug-no-sys
              Skip /sys debugging in case of a hang.
       --debug-sys
              Force PowerPC debugger parsing of /sys as sudo/root.
       --debug-sys-print
              Use this to locate file that /sys debugger hangs on.
SUPPORTED IRC CLIENTS
       BitchX, Gaim/Pidgin, ircII, Irssi, Konversation, Kopete, KSirc, KVIrc, Weechat, and Xchat. Plus any others that are capable of displaying either built-in or external script output.
RUNNING IN IRC CLIENT
       To trigger inxi output in your IRC client, pick the appropriate method from the list below:
       Hexchat, XChat, Irssi
              (and many other IRC clients) /exec -o inxi [options] If you don't include the -o, only you will see the output on your local IRC client.
       Konversation
              /cmd inxi [options]
              To run inxi in Konversation as a native script if your distribution or inxi package hasn't already done this for you, create this symbolic link:
              KDE 4: ln -s /usr/local/bin/inxi /usr/share/kde4/apps/konversation/scripts/inxi
              KDE 5: ln -s /usr/local/bin/inxi /usr/share/konversation/scripts/inxi
              If inxi is somewhere else, change the path /usr/local/bin to wherever it is located.
              If you are using KDE/QT 5, then you may also need to add the following to get the Konversation /inxi command to work:
              ln -s /usr/share/konversation /usr/share/apps/
              Then you can start inxi directly, like this:
              /inxi [options]
       WeeChat
              NEW: /exec -o inxi [options]
              OLD: /shell -o inxi [options]
              Newer (2014 and later) WeeChats work pretty much the same now as other console IRC clients, with /exec -o inxi [options]. Newer WeeChats have dropped the -curses part of their program name,  i.e.:  weechat  instead  of
              weechat-curses.
CONFIGURATION FILE
       inxi will read its configuration/initialization files in the following order:
       /etc/inxi.conf  contains  the default configurations. These can be overridden by user configurations found in one of the following locations (inxi will store its config file using the following precedence: if $XDG_CONFIG_HOME
       is not empty, it will go there, else if $HOME/.conf/inxi.conf exists, it will go there, and as a last default, the legacy location is used), i.e.:
       $XDG_CONFIG_HOME/inxi.conf > $HOME/.conf/inxi.conf > $HOME/.inxi/inxi.conf
CONFIGURATION OPTIONS
       See the documentation page for more complete information on how to set these up, and for a complete list of options:
       https://smxi.org/docs/inxi-configuration.htm
       Basic Options
              Here's a brief overview of the basic options you are likely to want to use:
              COLS_MAX_CONSOLE The max display column width on terminal.
              COLS_MAX_IRC The max display column width on IRC clients.
              COLS_MAX_NO_DISPLAY The max display column width in console, out of GUI desktop.
              CPU_SLEEP Decimal value 0 or more. Default is usually around 0.35 seconds. Time that inxi will 'sleep' before getting CPU speed data, so that it reflects actual system state.
              DOWNLOADER Sets default inxi downloader: curl, fetch, ftp, perl, wget.  See --recommends output for more information on downloaders and Perl downloaders.
              FILTER_STRING Default <filter>. Any string you prefer to see instead for filtered values.
              INDENT_MIN The point where the line starter wrapping to its own line happens.  Overrides default. See --indent-min. If 80 or less, wrap will never happen.
              LIMIT Overrides default of 10 IP addresses per IF. This is only of interest to sys admins running servers with many IP addresses.
              NO_DIG Set to 1 or true to disable WAN IP use of dig and force use of alternate downloaders.
              NO_HTML_WAN Set to 1 or true to disable WAN IP use of HTML Downloaders and force use of dig only, or nothing if dig disabled as well. Same as --no-html-wan. Only use if dig is failing, and HTML downloaders are hanging.
              NO_SUDO Set to 1 or true to disable internal use of sudo.
              PARTITION_SORT Overrides default partition output sort. See --partition-sort for options.
              PS_COUNT The default number of items showing per -t type, m or c. Default is 5.
              SENSORS_CPU_NO In cases of ambiguous temp1/temp2 (inxi can't figure out which is the CPU), forces sensors to use  either value 1 or 2 as CPU temperature. See the above configuration page on smxi.org for full info.
              SENSORS_EXCLUDE Exclude supplied sensor array[s] from sensor output. Override with --sensors-default. See --sensors-exclude.
              SENSORS_USE Use only supplied sensor array[s]. Override with --sensors-default. See --sensors-use.
              SEP2_CONSOLE Replaces default key / value separator of ':'.
              USB_SYS Forces all USB data to use /sys instead of lsusb.
              WAN_IP_URL Forces -i to use supplied URL, and to not use dig (dig is generally much faster). URL must begin with http or ftp. Note that if you use this, the downloader set tests  will  run  each  time  you  start  inxi
              whether a downloader feature is going to be used or not.
              The IP address from the URL must be the last item on the last (non-empty) line of the URL's page content source code.
              Same as --wan-ip-url [URL]
              WEATHER_SOURCE Values: [0-9]. Same as --weather-source. Values 4-9 are not currently supported, but this can change at any time.
              WEATHER_UNIT Values: [m|i|mi|im]. Same as --weather-unit.
       Color Options
              It's  best to use the -c [94-99] color selector tool to set the following values because it will correctly update the configuration file and remove any invalid or conflicting items, but if you prefer to create your own
              configuration files, here are the options. All take the integer value from the options available in -c 94-99.
              NOTE: All default and configuration file set color values are removed when output is piped or redirected. You must use the explicit -c <color number> option if you want colors to be present in the piped/redirected out‐
              put (creating a PDF for example).
              CONSOLE_COLOR_SCHEME The color scheme for console output (not in X/Wayland).
              GLOBAL_COLOR_SCHEME Overrides all other color schemes.
              IRC_COLOR_SCHEME Desktop X/Wayland IRC CLI color scheme.
              IRC_CONS_COLOR_SCHEME Out of X/Wayland, IRC CLI color scheme.
              IRC_X_TERM_COLOR_SCHEME In X/Wayland IRC client terminal color scheme.
              VIRT_TERM_COLOR_SCHEME Color scheme for virtual terminal output (in X/Wayland).
BUGS
       Please report bugs using the following resources.
       You  may  be asked to run the inxi debugger tool (see --debug 21/22), which will upload a data dump of system files for use in debugging inxi. These data dumps are very important since they provide us with all the real system
       data inxi uses to parse out its report.
       Issue Report
              File an issue report: https://github.com/smxi/inxi/issues
       Forums Post on inxi forums: https://techpatterns.com/forums/forum-33.html
       IRC irc.oftc.net#smxi
              You can also visit irc.oftc.net channel: #smxi to post issues.
HOMEPAGE
       https://smxi.org/docs/inxi.htm
AUTHOR AND CONTRIBUTORS TO CODE
       inxi is a fork of locsmif's very clever infobash script.
       Original infobash author and copyright holder: Copyright (C) 2005-2007  Michiel de Boer aka locsmif
       inxi version: Copyright (C) 2008-20 Harald Hope
       This man page was originally created by Gordon Spencer (aka aus9) and is maintained by Harald Hope (aka h2 or TechAdmin).
       Initial CPU logic, konversation version logic, occasional maintenance fixes, and the initial xiin.py tool for /sys parsing (obsolete, but still very much appreciated for all the valuable debugger  data  it  helped  generate):
       Scott Rogers
       Further fixes (listed as known):
       Horst Tritremmel <hjt at sidux.com>
       Steven Barrett (aka: damentz) - USB audio patch; swap percent used patch.
       Jarett.Stevens - dmidecode -M patch for older systems with no /sys.
SPECIAL THANKS TO THE FOLLOWING
       The nice people at irc.oftc.net channels #linux-smokers-club and #smxi, who  all really have to be considered to be co-developers because of their non-stop enthusiasm and willingness to provide real-time testing and debugging
       of inxi development.
       Siduction forum members, who have helped get some features working by providing a large number of datasets that have revealed possible variations, particularly for the RAM -m option.
       AntiX users and admins, who have helped greatly with testing and debugging, particularly for the 3.0.0 release.
       ArcherSeven (Max), Brett Bohnenkamper (aka KittyKatt), and Iotaka, who always manage to find the weirdest or most extreme hardware and setups that help make inxi much more robust.
       For the vastly underrated skill of output error/glitch catching, Pete Haddow. His patience and focus in going through inxi repeatedly to find errors and inconsistencies is much appreciated.
       All the inxi package maintainers, distro support people, forum moderators, and in particular, sys admins with their particular issues, which almost always help make inxi better, and any others who  contribute  ideas,  sugges‐
       tions, and patches.
       Without a wide range of diverse Linux kernel-based Free Desktop systems to test on, we could never have gotten inxi to be as reliable and solid as it's turning out to be.
       And of course, a big thanks to locsmif, who figured out a lot of the core methods, logic, and tricks originally used in inxi Gawk/Bash.
inxi        2020-08-16        INXI(1)
rtfm
:blush: :v:t4:
Who say’s it’s not reliable?
That’s known fact, i’m talking specifically about current RAM speed / timings, dmidecode results sadly are far from ideal depending on your hardware…
Read more on -m, --memory section in man inxi
Also there are lengthy rants on that all over the internet, for example CPU-X bugtracker
I don’t bother reading Rants lengthy or otherwise. I’m not sure what you are looking for i think it’s fine for me. It tells me what i need to know. My ram is 3200 & it’s set for 3200. If i didn’t set it in UEFI the default runs less.
I think dmidecode does a fair job at providing information. It tells me what the ram is with a lot of info and what it’s set at. Along with inxi i have enough information for my needs and there are other tools available.
Does this not give you enough info?
sudo dmidecode | grep -A 15 Memory
Like i said - no, and results highly depend on given motherboard / RAM.
Usually it reads SPD fine (which i don’t really care about 99% of time), but not the actual used values and certainly not currently used timings (i’ve seen people had some luck with some of DDR4 RAM models, but again dmidecode is just not reliable way of getting that info) - sure you can see it in BIOS if it’s supported (not all laptops with even unlocked / advanced BIOS still show that).
It’s needed mainly for checking new hardware / debug…Not usual use case for most people, but i would assume that Linux crowd should have some reliable way to get such info from OS level, for not it’s still not reality.
What i was asking about future.
P.S. Well if for you it’s enough info that’s fine, i have my reasons. :upside_down_face:
So you want to know what it’s actually running at? :thinking:
I think he is just talking about more detailed information that people have become accustomed to with similar winblows tools like CPU-Z. Speed, what channel dual quad ect, and timings / command rate all of which can greatly affect system performance in general and without having a way to see these things on a running system trouble shooting performance issues can be extremely hit or miss. For example, a command rate of 1T is almost always faster than 2T. However it can be set as 1T in a motherboards BIOS but not apply correctly on a booted system and being able to check these values would show it was indeed running 2T regardless of what was set in BIOS.
I’m not sure of any tools in Linux that provide that level of detail? I’m sure there is something maybe?
Nope, that’s the thing :frowning:
Since more or less all of them rely on dmidecode and similar ways, and like quoted from man inxi
maybe one day the kernel devs will put this data into /sys, and make it real data, taken from the actual system, not dmi data.
Unless that happens we’re stuck… :confused:
We need some direct data :yum:
The real issue is motherboard manufacturers not wanting to give acess to the details of the hardware so open source projects can be written to access and adequately read the data. For exaple why you sometimes cannot get cpu temps or other temps off a board. Without knowing what is doing what you don’t know what to pull the data from. This is by design as they align more towards winblows and it’s ability to say ā€œHey user shove it that chipset is no longer supported so buy a new motherboardā€ which motherboard manufacturers love :crazy_face:
That’s why i like what system76 is doing with open source hardware and coreboot. It’s a start.
Elloquin has this precisely right, NEVER compare closed source, propriietary, NDA protected tools you find on window with free software. If you talk to any serious kernel people, they HATE this situation, in fact, often they actually know what the data is, where it is, etc, and cannot use it because that data was given to them under NDA.
The sooner you realize free software is free as in freedom, not free as in a free windows replacement that does everything windows does only is free and open source, the sooner you can stop worrying about that reality.
This issue is also a big deal in sensors data, for example, it’s only in I believe 5.8 kernel that the full sensors range for ryzen boards and cpus is becoming available, and that data is truly stunning in its depth and range. inxi only has the most barebones structure built in (added 3.1.06 I think, or .05) to handle that big complicated range of data, which includes some disk temps [still VERY hard to map to specific disks, but it’s possible, just not easy].
RAM is HARD, period. The data in dmidecode is either quite reliable [for per stick reports, what you see under Array-x: line], but for actual array capacity etc, it’s total and utter copy and pasted in by oem gibberish, to get even remotely non absurd outputs for the memory array section, for example, took at least 1 month to get working so it wasn’t that wrong most of the time, and often is quite right. And that was probably with 100 datasets and active full distro support to help get that feature running, that distro is now largely gone, but that was actually one of their big contributions to the overall gnu/linux ecosystem.
ram and sensors were probably the two hardest features to develop and maintain in inxi. I too wished for years the ram data would be opened up, at least for root, in /sys, buut it never happened. May one day, but as of last time I checked, it hasn’t.
/sys has a LOT more data in it that it did 10 years ago though, and more appears all the time, inxi uses as much of it as possible because it’s not filtered by 3rd party tools and /sys reads are super fast and efficient, since it’s all in ram, not disk.
From my extensive datasets and user feedback from the ram component, my general tendency is to believe the per ram stick reports are reasonably accurate and based on what is really there, at least, what the stick reports to the system / dmitables, I don’t know if that’s truly live however, or if it’s coming from the stick as static dataa. You can determine this b overclocking your ram, well, first, don’t overclock it, check:
inxi -may
then reboot, update bios/uefi, to overclock the ram, if it supports it, and see if the reported speeds are right.
The notion that a simple 1 liner can deliver reasonably useful ram reports from dmidecode shows simply someone who has not seen enough datasets to realize that doesn’t work, for many reasons, many of which you can learn if you read the code in the RamData class. A lot of processing is required to turn those dmidecode values into filtered, useful information, though if you know what it all means, every line, and you know what is junk data and what is real, and what ram types are irrelevant, etc, you can fairly easily read the dmidecode ram output, but that knowledge is not common.
As an aside, I’d held off doing ram feature for years due to my hope it would appear in /sys, and that man mention is my giving up on that idea, and going with plan B, which is / was HARD, one of the very hardest features in inxi, along with, as mentioned, sensors, both of which serve up often total gibberish data, are very hard to organize, very hard to understand and predict at scale levels, I always laugh out loud any time I read someone say it’s easy, here’s a command or two, that always shows they have only seen their system, and maybe one or two others.
Future bright points:
/sys for sensors is expanding A LOT, it’s still very very difficult to really translate that to useful values for inxi, too hard for me at this point, but it’s closer than it’s ever been. The last inxi sensors refactor laid the ground work for that being possible, it was BIG change internally, totally changed how inxi handles sensors data internally, far more powerful, though most features are not yet enabled since they take a lot of dev time and focus, which I don’t currently have, but I know the way forwards there.
I can tell you this: inxi -m will be right far more often than it’s wrong, and it will correct blatantly and logically impossible values it got from dmidecode [always adding the: note: check, or note: est.] type qualifier which lets you know it synthesized the data and is not sure about it].
I also really like what system76 do, and I really respect the totally thankless work the kernel sensors guys do with lm-sensors and /sys sensors, talk about working with a gun held to your head, knowing the answers but not being able to use them due to legally binding NDAs.
In terms of really valuable newish features, check out
inxi -Gya
  Device-1: NVIDIA GT218 [GeForce 210] vendor: Gigabyte driver: nvidia
  v: 340.108 alternate: nvidiafb,nouveau bus ID: 09:00.0 chip ID: 10de:0a65
  Display: x11 server: X.Org 1.20.8 driver: nvidia display ID: :0.0 screens: 1
  Monitor-2: VGA-0 res: 1280x1024 hz: 60 dpi: 86 size: 376x301mm (14.8x11.9")
  diag: 482mm (19")
  OpenGL: renderer: GeForce 210/PCIe/SSE2 v: 3.3.0 NVIDIA 340.108
  direct render: Yes
This is another distro support guy requested advanced data feature, doesn’t work, mostly, for wayland since wayland has no consistent reporting tools, but it works super well for xorg systems.
The same guy requested the new -y1 output option, which helps users and support people see what actually belongs to what:
inxi -aGy1
    vendor: Gigabyte
    driver: nvidia
      v: 340.108
    bus ID: 09:00.0
    chip ID: 10de:0a65
  Display: x11
    driver: nvidia
    display ID: :0.0
    screens: 1
    Screen-1: 0
      s-res: 2560x1024
      s-dpi: 96
      Monitor-1: DVI-I-0
        res: 1280x1024
        hz: 60
        dpi: 96
        diag: 433mm (17")
      Monitor-2: VGA-0
        res: 1280x1024
        hz: 60
        dpi: 86
        diag: 482mm (19")
  OpenGL:
    direct render: Yes
both of these were really difficult to implement, but add great value to inxi as a debugging tool, so I consider both worth it.
As an aside, my primary debugging option is -v8 as well, because that will expose most mistakes I made when doing new inxi versions, which is always fyi in the inxi-perl branch, it’s called pinxi, not inxi, so I can run them next to each other. I don’t use inxi myself, I always use pinxi, but pinxi can break without my worrying about it, and it can have test features I dump when i realize it won’t work, but it will also always have the latest features, which become next inxi when I decide the time is right, or there’s a pressing bug, which there is in 3.1.06, it’s fixed in pinxi but I am still not fully satisfied the fix is cross distro [it’s the failure with 5.8 kernels to show compiler version in -Sx]
There is CPU-X :upside_down_face:
there is also corectrl
@ricklinux @Stephane
Yes, and all of them have exactly same problems obviously :woozy_face:
btw as GUI tool i love CPU-X best :yum:
I have the same laptop and CPU, but sudo inxi -Cay does not show the ā€œMHz base/boostā€ when I run, I wonder why that is:
  Info: 8-Core model: AMD Ryzen 7 4800U with Radeon Graphics bits: 64
  type: MT MCP arch: Zen family: 17 (23) model-id: 60 (96) stepping: 1
  microcode: 8600106 L2 cache: 4096 KiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 57518
  Speed: 1397 MHz min/max: 1400/1800 MHz boost: enabled Core speeds (MHz):
  1: 1397 2: 1398 3: 1397 4: 1396 5: 1397 6: 1396 7: 1397 8: 1396 9: 1397
  10: 1397 11: 1397 12: 1396 13: 1397 14: 1396 15: 1397 16: 1393
  Vulnerabilities: Type: itlb_multihit status: Not affected
  Type: spec_store_bypass
  mitigation: Speculative Store Bypass disabled via prctl and seccomp
  Type: spectre_v1
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  STIBP: conditional, RSB filling
I noticed that when running a 8k video, the CPU boosts up to 4.2 GHz so it looks like boost is working OK.
