Turkey in help over here.
So I wanted to reinstall endeavouros after quite some time. I was met with a problem : installing the nvidia driver using sudo nvidia-installer-dkms bricks my system. I cannot boot into the interface and I am stuck in the TTY. Another thihing is that I used the nvidia option in the live iso as well. Driver is “installed”, however the nvidia settings crashes. The card is seen by neofetch and the system itself.
Any help would be appreciated!
Edit: Using GTX 850m gpu
Gobble-Gobble?
TurkeyJohn:
You need to use AUR driver for that one, latest won’t work
manuel
September 5, 2021, 2:11pm
4
Latest driver seems to support it, but could you run command
nvidia-installer-check
to verify?
I’d try 390 ones
aur/nvidia-390xx
aur/nvidia-390xx-utils
or dkms
aur/nvidia-390xx-dkms
Gobble Gobble
It returns positive, aka my gpu supports the latest driver
“Your gpu (id: 1391) is supported by the nvidia-dkms driver”
Wait, but since it’s m it’s laptop, so it’s probably Optimus stuff?
Yeah, it’s an optimus laptop. But bumblebee works only with legacy stuff
It’s fairly rare for Optimus laptop to have ability to use Nvidia directly as normal single GPU, but if yours can - make sure Optimus is disabled in bios or something like that
razor
September 5, 2021, 2:15pm
10
My 840m is working flawless with latest Nvidia drives. Using nvidia prime for running apps with nvidia card.
I wish I could disable optimus. There is no option in my bios
razor
September 5, 2021, 2:17pm
12
In this configuration we have, optimus can’t be disabled. Because intregrated card is still in use.
You certainly can Gobble-Gobble!
@jonathon @dalto @linesma could maybe help in distress though…
I will try to install manjaro and see if this issue occurs on it too. Even tho it shouldn’t. Pop_os works great.
Ok so manjaro works. Okkk…so it’s an installer issue
razor
September 5, 2021, 2:39pm
17
Did u try using a lts kernel while installing eos?
If i recall corectlly, manjaro live iso usually uses a older kernel.
Dev0ut
September 5, 2021, 2:53pm
19
Can you post inxi -Gx from manjaro?
Also the xorg.conf file would be nice
command output :
Graphics: Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM107M [GeForce GTX 850M] vendor: Hewlett-Packard driver: nvidia v: 470.63.01 bus-ID: 0a:00.0
Device-3: Realtek HP Truevision HD laptop camera type: USB driver: uvcvideo bus-ID: 2-3:3
Display: x11 server: X.Org 1.20.13 driver: loaded: modesetting,nvidia s-res: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 21.2.1 direct render: Yes
