Yes.
Could the problem be the type of keyboard? In US keyboard, is the numeric keypad locked in numeric mode at startup or do you have to lock it yourself?
I have a french keyboard.
@Patrick_F , Are you on systemd-boot?
If not, look at post 8 ici
Edit: I’ve checked it. Works.
The only difference that when you switched to systemd-boot (at worst case) and you are not asked
for crypto passkey these two commands are needed:
