How to run installer ?
Welcome to forums!!
Can you give us more info regarding your problem?
Also, could you send logs from the live ISO
Ok. it’s not run, it’s not started it’s freeze. If I press Alt + F2 then I need to login. What the login and password in live cd ?
how are you creating the ISO??
You mean what i did with after download ? I using “Ventoy” it’s created bootable usb, and now every iso is just copyied into usb. That’s all.
So what the login and password in live ?
try
username: liveuser
it has no password.
@joekamprad correct me if I’m wrong
Thank You. So have You any idea how to solve it ? I tried write “quiet splash vga=792” in boot entry but it failed.
what is the display and GPU (Graphics) ?
Usually it should load the Desktop and installer automatically… if it doe snot start X on boot possible to add bootparameter on the boot menu but depending on efi or Bios/legacy the options are different… Bios using syslinux and efi systemd-boot…
yes no password set…
Just don’t use ventoy …
You think the installer will work when I use one of this https://discovery.endeavouros.com/installation/create-install-media-usb-key/2021/03/ method ? are you sure the installer will work ?
igor@OptiPlex-980:/media/all/iso$ dd bs=4M if=EndeavourOS_Cassini_22_12.iso of=/dev/sdg conv=fsync oflag=direct status=progress
[sudo] hasło użytkownika igor:
2038431744 bytes (2,0 GB, 1,9 GiB) copied, 215 s, 9,5 MB/s
486+1 przeczytanych rekordĂłw
486+1 zapisanych rekordĂłw
2041393152 bytes (2,0 GB, 1,9 GiB) copied, 215,673 s, 9,5 MB/s
the same booting process, the same situation, all the same, just use Ventoy !
Monitor LCD 15" HP L1506
igor@OptiPlex-980:~$ sudo lshw
optiplex-980
description: Mini Tower Computer
product: OptiPlex 980
vendor: Dell Inc.
width: 64 bits
capabilities: smbios-2.6 dmi-2.6 smp vsyscall32
configuration: administrator_password=enabled boot=normal chassis=mini-tower power-on_password=enabled
*-core
description: Motherboard
product: 0D441T
vendor: Dell Inc.
physical id: 0
version: A01
serial: ..CN7360407E01PC.
*-firmware
description: BIOS
vendor: Dell Inc.
physical id: 0
version: A18
date: 02/27/2018
capacity: 8128KiB
capabilities: pci pnp apm upgrade shadowing escd cdboot bootselect edd int13floppytoshiba int13floppy720 int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification netboot
*-cpu
description: CPU
product: Intel(R) Core(TM) i5 CPU 660 @ 3.33GHz
vendor: Intel Corp.
physical id: 400
bus info: cpu@0
slot: CPU
capacity: 3326MHz
width: 64 bits
clock: 133MHz
capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt aes lahf_lm pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid dtherm ida arat flush_l1d cpufreq
configuration: cores=2 enabledcores=2 threads=2
*-cache:0
description: L1 cache
physical id: 700
capacity: 128KiB
capabilities: internal write-through
configuration: level=1
*-cache:1
description: L2 cache
physical id: 701
capacity: 512KiB
capabilities: internal write-through unified
configuration: level=2
*-cache:2
description: L3 cache
physical id: 704
capacity: 4MiB
capabilities: internal write-back unified
configuration: level=3
*-memory
description: System Memory
physical id: 1000
slot: System board or motherboard
*-bank:0
description: DIMM DDR3 1333 MHz (0,8 ns)
product: KP223C-ELD
vendor: AMD
physical id: 0
serial: 5F3410CF
slot: DIMM 1
width: 64 bits
clock: 1333MHz (0.8ns)
*-bank:1
product: KP223C-ELD
vendor: AMD
physical id: 1
serial: 85346CCE
slot: DIMM 2
width: 64 bits
*-bank:2
description: DIMM DDR3 Synchronous [empty]
vendor: FFFFFFFFFFFF
physical id: 2
serial: FFFFFFFF
slot: DIMM 3
width: 64 bits
*-bank:3
physical id: 3
serial: FFFFFFFF
slot: DIMM 4
width: 64 bits
*-pci:0
description: Host bridge
product: Core Processor DRAM Controller
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 02
width: 32 bits
clock: 33MHz
*-pci:0
description: PCI bridge
product: Core Processor PCI Express x16 Root Port
physical id: 1
bus info: pci@0000:00:01.0
version: 02
width: 32 bits
clock: 33MHz
capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:16 ioport:d000(size=4096) memory:f6000000-f7efffff ioport:e8000000(size=167772160)
*-display
description: VGA compatible controller
product: GK208 [GeForce GT 720]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:27 memory:f6000000-f6ffffff memory:e8000000-efffffff memory:f0000000-f1ffffff ioport:dc80(size=128) memory:c0000-dffff
*-multimedia
description: Audio device
product: GK208 HDMI/DP Audio Controller
physical id: 0.1
bus info: pci@0000:01:00.1
version: a1
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:17 memory:f7dfc000-f7dfffff
*-communication:0
description: Communication controller
product: 5 Series/3400 Series Chipset HECI Controller
physical id: 16
bus info: pci@0000:00:16.0
version: 06
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver=mei_me latency=0
resources: irq:25 memory:feda6000-feda600f
*-ide:0
description: IDE interface
product: 5 Series/3400 Series Chipset PT IDER Controller
physical id: 16.2
bus info: pci@0000:00:16.2
version: 06
width: 32 bits
clock: 66MHz
capabilities: ide pm msi pci_native_mode-only_controller__supports_bus_mastering bus_master cap_list
configuration: driver=ata_generic latency=0
resources: irq:18 ioport:fe80(size=8) ioport:fe90(size=4) ioport:fea0(size=8) ioport:feb0(size=4) ioport:fef0(size=16)
*-communication:1
description: Serial controller
product: 5 Series/3400 Series Chipset KT Controller
physical id: 16.3
bus info: pci@0000:00:16.3
version: 06
width: 32 bits
clock: 66MHz
capabilities: pm msi 16550 bus_master cap_list
configuration: driver=serial latency=0
resources: irq:17 ioport:ec98(size=8) memory:f7fdb000-f7fdbfff
*-network
description: Ethernet interface
product: 82578DM Gigabit Network Connection
physical id: 19
bus info: pci@0000:00:19.0
logical name: eno1
version: 05
serial: 84:2b:2b:9a:da:82
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k firmware=0.12-2 latency=0 link=no multicast=yes port=twisted pair
resources: irq:24 memory:f7fe0000-f7ffffff memory:f7fdc000-f7fdcfff ioport:ecc0(size=32)
*-usb:0
description: USB controller
product: 5 Series/3400 Series Chipset USB2 Enhanced Host Controller
physical id: 1a
bus info: pci@0000:00:1a.0
version: 05
width: 32 bits
clock: 33MHz
capabilities: pm debug ehci bus_master cap_list
configuration: driver=ehci-pci latency=0
resources: irq:16 memory:f7fdd000-f7fdd3ff
*-usbhost
product: EHCI Host Controller
vendor: Linux 4.15.0-200-generic ehci_hcd
physical id: 1
bus info: usb@1
logical name: usb1
version: 4.15
capabilities: usb-2.00
configuration: driver=hub slots=3 speed=480Mbit/s
*-usb
description: USB hub
product: Integrated Rate Matching Hub
vendor: Intel Corp.
physical id: 1
bus info: usb@1:1
version: 0.00
configuration: driver=hub slots=6 speed=480Mbit/s
*-usb:0
description: Mass storage device
product: Mass Storage Device
vendor: Generic
physical id: 2
bus info: usb@1:1.2
logical name: scsi6
version: 1.00
serial: 058F63626420
capabilities: usb-2.00 scsi emulated scsi-host
configuration: driver=usb-storage maxpower=100mA speed=480Mbit/s
*-disk:0
description: SCSI Disk
product: SD/MMC
vendor: Generic-
physical id: 0.0.0
bus info: scsi@6:0.0.0
logical name: /dev/sdb
version: 1.00
capabilities: removable
configuration: logicalsectorsize=512 sectorsize=512
*-medium
physical id: 0
*-disk:1
product: Compact Flash
vendor: Generic-
physical id: 0.0.1
bus info: scsi@6:0.0.1
logical name: /dev/sdc
version: 1.01
*-medium
physical id: 0
*-disk:2
product: SM/xD Picture
vendor: Generic-
physical id: 0.0.2
bus info: scsi@6:0.0.2
logical name: /dev/sdd
version: 1.02
*-medium
physical id: 0
*-disk:3
product: MS/MS-Pro
vendor: Generic-
physical id: 0.0.3
bus info: scsi@6:0.0.3
logical name: /dev/sde
version: 1.03
*-medium
physical id: 0
*-usb:1
description: Mouse
product: Usb Mouse
vendor: SEMICCHIP
physical id: 4
bus info: usb@1:1.4
version: 1.10
capabilities: usb-1.10
configuration: driver=usbhid maxpower=98mA speed=1Mbit/s
*-multimedia
product: 5 Series/3400 Series Chipset High Definition Audio
physical id: 1b
bus info: pci@0000:00:1b.0
version: 05
width: 64 bits
clock: 33MHz
resources: irq:26 memory:ff87c000-ff87ffff
*-pci:1
product: 5 Series/3400 Series Chipset PCI Express Root Port 1
physical id: 1c
bus info: pci@0000:00:1c.0
version: 05
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
resources: irq:16 ioport:1000(size=4096) memory:f2000000-f21fffff ioport:f2200000(size=2097152)
*-pci:2
product: 5 Series/3400 Series Chipset PCI Express Root Port 5
physical id: 1c.4
bus info: pci@0000:00:1c.4
version: 05
width: 32 bits
clock: 33MHz
resources: irq:16 ioport:2000(size=4096) memory:f2400000-f25fffff ioport:f2600000(size=2097152)
*-usb:1
physical id: 1d
bus info: pci@0000:00:1d.0
version: 05
width: 32 bits
clock: 33MHz
resources: irq:23 memory:f7fde000-f7fde3ff
*-usbhost
physical id: 1
bus info: usb@2
logical name: usb2
version: 4.15
*-usb
vendor: Intel Corp.
physical id: 1
bus info: usb@2:1
version: 0.00
configuration: driver=hub slots=8 speed=480Mbit/s
*-usb:0
description: Keyboard
product: USB Keyboard
vendor: SINO WEALTH
physical id: 4
bus info: usb@2:1.4
version: 2.00
configuration: driver=usbhid maxpower=100mA speed=1Mbit/s
*-usb:1
vendor: Generic
physical id: 7
bus info: usb@2:1.7
logical name: scsi7
version: 1.01
serial: 7DCEAF22
configuration: driver=usb-storage maxpower=200mA speed=480Mbit/s
*-disk
product: Flash Disk
vendor: Generic
physical id: 0.0.0
bus info: scsi@7:0.0.0
logical name: /dev/sdf
version: 8.07
serial: 7
configuration: ansiversion=4 logicalsectorsize=512 sectorsize=512
*-medium
physical id: 0
capabilities: partitioned partitioned:dos
configuration: signature=5ab6cd03
*-volume:0
description: Empty partition
physical id: 1
logical name: /dev/sdf1
logical name: /media/igor/EOS_202212
capacity: 1841MiB
capabilities: primary bootable nofs
configuration: mount.fstype=iso9660 mount.options=ro,nosuid,nodev,relatime,nojoliet,check=s,map=n,blocksize=2048,uid=1000,gid=1000,dmode=500,fmode=400,iocharset=utf8 state=mounted
*-volume:1
description: Windows FAT volume
vendor: mkfs.fat
physical id: 2
logical name: /dev/sdf2
version: FAT16
serial: a59c-8529
capacity: 105MiB
capabilities: primary boot fat initialized
configuration: FATs=2 filesystem=fat label=ARCHISO_EFI
*-usb:2
description: Generic USB device
product: USB2.0 WLAN
vendor: ATHEROS
physical id: 8
bus info: usb@2:1.8
version: 1.08
serial: 12345
configuration: driver=ath9k_htc maxpower=500mA speed=480Mbit/s
*-pci:3
product: 82801 PCI Bridge
physical id: 1e
bus info: pci@0000:00:1e.0
version: a5
width: 32 bits
clock: 33MHz
capabilities: pci subtractive_decode bus_master cap_list
*-isa
description: ISA bridge
product: Q57 Chipset LPC Interface Controller
physical id: 1f
bus info: pci@0000:00:1f.0
version: 05
width: 32 bits
clock: 33MHz
capabilities: isa bus_master cap_list
configuration: driver=lpc_ich latency=0
resources: irq:0
*-ide:1
product: 5 Series/3400 Series Chipset 4 port SATA IDE Controller
physical id: 1f.2
bus info: pci@0000:00:1f.2
version: 05
width: 32 bits
clock: 66MHz
capabilities: ide pm isa_compatibility_mode_controller__supports_both_channels_switched_to_pci_native_mode__supports_bus_mastering bus_master cap_list
configuration: driver=ata_piix latency=0
resources: irq:18 ioport:1f0(size=8) ioport:3f6 ioport:170(size=8) ioport:376 ioport:fec0(size=16) ioport:eca0(size=16)
*-serial UNCLAIMED
description: SMBus
product: 5 Series/3400 Series Chipset SMBus Controller
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 05
width: 64 bits
clock: 33MHz
configuration: latency=0
resources: memory:f7fdf000-f7fdf0ff ioport:ece0(size=32)
*-ide:2
product: 5 Series/3400 Series Chipset 2 port SATA IDE Controller
physical id: 1f.5
bus info: pci@0000:00:1f.5
version: 05
width: 32 bits
clock: 66MHz
capabilities: ide pm pci_native_mode-only_controller__supports_bus_mastering bus_master cap_list
resources: irq:18 ioport:fe40(size=8) ioport:fe50(size=4) ioport:fe60(size=8) ioport:fe70(size=4) ioport:fed0(size=16) ioport:ecb0(size=16)
*-pci:1
product: Core Processor QuickPath Architecture Generic Non-core Registers
physical id: 101
bus info: pci@0000:3f:00.0
version: 02
width: 32 bits
clock: 33MHz
*-pci:2
product: Core Processor QuickPath Architecture System Address Decoder
physical id: 102
bus info: pci@0000:3f:00.1
version: 02
width: 32 bits
clock: 33MHz
*-pci:3
product: Core Processor QPI Link 0
physical id: 103
bus info: pci@0000:3f:02.0
version: 02
width: 32 bits
clock: 33MHz
*-pci:4
product: 1st Generation Core i3/5/7 Processor QPI Physical 0
physical id: 104
bus info: pci@0000:3f:02.1
version: 02
width: 32 bits
clock: 33MHz
*-pci:5
product: 1st Generation Core i3/5/7 Processor Reserved
physical id: 105
bus info: pci@0000:3f:02.2
version: 02
width: 32 bits
clock: 33MHz
*-pci:6
physical id: 106
bus info: pci@0000:3f:02.3
version: 02
width: 32 bits
clock: 33MHz
*-scsi:0
physical id: 1
logical name: scsi0
capabilities: emulated
*-disk
description: ATA Disk
product: ST3320418AS
vendor: Seagate
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: CC46
serial: 9VMMFNTL
configuration: ansiversion=5 logicalsectorsize=512 sectorsize=512 signature=7f24f7cf
*-volume:0
description: Windows NTFS volume
physical id: 1
bus info: scsi@0:0.0.0,1
logical name: /dev/sda1
version: 3.1
serial: 8c46-2c2d
capacity: 578MiB
capabilities: primary bootable ntfs initialized
configuration: clustersize=4096 created=2021-12-15 02:37:08 filesystem=ntfs label=ZastrzeĹĽone przez system modified_by_chkdsk=true mounted_on_nt4=true resize_log_file=true state=dirty upgrade_on_mount=true
*-volume:1
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
logical name: /media/win
version: 3.1
serial: 18d541cc-e4fa-0d4a-92b9-b5589e734373
capacity: 149GiB
capabilities: primary ntfs initialized
configuration: clustersize=4096 created=2021-12-15 02:37:19 filesystem=ntfs modified_by_chkdsk=true mount.fstype=fuseblk mount.options=rw,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096 mounted_on_nt4=true resize_log_file=true state=mounted upgrade_on_mount=true
*-volume:2
physical id: 3
bus info: scsi@0:0.0.0,3
logical name: /dev/sda3
logical name: /media/all
version: 3.1
serial: 76f38d80-c50b-b744-a8c7-4dcdf7c9d6c8
capacity: 99GiB
configuration: clustersize=4096 created=2018-11-10 19:20:44 filesystem=ntfs mount.fstype=fuseblk mount.options=rw,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096 state=mounted
*-volume:3
description: Extended partition
physical id: 4
bus info: scsi@0:0.0.0,4
logical name: /dev/sda4
capacity: 48GiB
capabilities: primary extended partitioned partitioned:extended
*-logicalvolume:0
description: Linux swap volume
physical id: 5
logical name: /dev/sda5
version: 1
serial: e027a886-f6f0-4bcc-a180-d4358606e17b
capacity: 2GiB
capabilities: swap initialized
configuration: filesystem=swap pagesize=4096
*-logicalvolume:1
description: EXT4 volume
vendor: Linux
physical id: 6
logical name: /dev/sda6
logical name: /
version: 1.0
serial: e333a1c1-ec03-4382-b725-9ba193984779
capacity: 46GiB
capabilities: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
configuration: created=2023-01-05 20:06:20 filesystem=ext4 lastmountpoint=/ modified=2023-01-05 21:43:49 mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro,data=ordered mounted=2023-01-05 21:43:54 state=mounted
*-scsi:1
physical id: 2
logical name: scsi1
*-cdrom
description: DVD-RAM writer
product: DVD+-RW GH50N
vendor: HL-DT-ST
physical id: 0.0.0
bus info: scsi@1:0.0.0
logical name: /dev/cdrom
logical name: /dev/cdrw
logical name: /dev/dvd
logical name: /dev/dvdrw
logical name: /dev/sr0
version: B103
capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
configuration: ansiversion=5 status=nodisc
*-network
description: Wireless interface
physical id: 1
bus info: usb@2:1.8
logical name: wlx98ded01aa216
serial: 98:de:d0:1a:a2:16
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=ath9k_htc driverversion=4.15.0-200-generic firmware=1.4 ip=192.168.1.3 link=yes multicast=yes wireless=IEEE 802.11
by any chance you do used only the Nvidia Boot entry to try booting installer ISO?
Your GPU is a legacy Nvidia GPU:
only working with default boot entry, as the card is not supported by latest Nvidia driver
I tried all posibilities. The last version I run was endeavouros-2019.07.15-x86_64.iso. I have the same situation with latest linuxmint, garuda, archlinux.
Only latest arcolinux and manjaro run automaticly.
Now I using LinuxMint 19 - easy install, all easy, fast, everything working out od box, easy busy
not the answer of my question but okay…
It was
I tried every entry
No guarantees about anything. I just know that usually always when ventoy is being used and doesn’t work then normally i recommend trying another method to create the live usb. On most occassions that resolves the issue. In your case it didn’t. It’s older hardware and it’s Bios. That’s all i know.
@pldenity First of all welcome.
I moved this topic from forum and website to installation, since the issue covers the ISO and not a bug on the forum or websites
useless to try that it could work to install offline… but will not create a goo system at all…
The current released ISO should boot with your hardware, it could be something around install media creation or setup ion the Bios that prevents it from doing this.
I have some of these nvidia cards here a Gforce gt 710 and gt 720 both working fine using default boot entry on efi system and also on old Bios system.
But fine may EndeavourOS the next time you feel some deeper endeavour
I show You how I started graphical install maybe helpfull for someone.
I booted live iso, and choosed NVIDIA compatibility. There is never drivers 525.89.02-2 which don’t support NVIDIA GeForce GT 720
Alt + Ctrl + F2 to log on another console TTY - login liveuser without password.
yay -S nvidia-470xx-dkms nvidia-470xx-utils
sudo nvidia-modprove
sudo nvidia-xconfig
startx
Now you have graphical interface, and you can install
