Why not? I can boot about 10 Linux distros from one stick, once it’s installed, adding a distro is a matter of just dropping the iso on the stick. It works, takes less time, and doesn’t wast my USB space. And it’s open source on top of that.
I see too many people try installing EOS and problems with using Ventoy. Don’t know why?
Edit: Besides I can boot 10 Distros on my desktop but i don’t want to so i only have 3 and they are EOS!
Don’t know why either. Probably they install ventoy wrong. I just use it to test new distros like fedora and such without wanting to install them. Once it works it’s faster to drag and drop an iso rather than to format a USB with other apps, although popsicle works pretty well and just takes a couple of minutes.
I use popsicle. Before i used etcher-bin or etcher on Windows.
+1 popsicle. Etcher on windows
Sure… why not. I still have Windows.
@Sololvl0 did you get a chance to try adding timeout to your mirrors? You can try that in the live iso, welcome app, update mirrors… note the dash before download is a double dash.
