So I’m installing EndeavourOS on my PC. I downloaded the image file EndeavourOS_Apollo_22_1.iso, verified its integrity using SHA512sum, created bootable USB stick using Balena Etcher. I choose priority to boot from USB,
there were 3 options:
- USB: Mass Storage Device 1.00,
- UEFI: Mass Storage Device 1.00,
- UEFI: Mass Storage Device 1.00, Partition 2
I chose option 1.
then default 64 bit install, and then I’m stuck in an a loop…
I was able to capture part of the output:
could not resolve keysum XF86…
top.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
gpg-agent: a gpg-agent is already running
libxfce4ui-warning ICE I/O error
failed to connect to session manager: failed to connect to the session manager: IO error occured opening connection
waiting for X server to shutdown (II) server terminated successfully (0). closing log file.umped) dbus-launch xfce4-sessioninit: connec…
closing log file.m session manager./home/liveuser/.xinitrc: line 2: 6572 Segmentation fault
(core dumped) dbus-launch xfce4-sessioninit: con…
Any ideas how to fix this?
PS. I’m back in BIOS setting. What should I do to avoid the above error during the next attempt to install?
