Well it is using amdgpu which should work.
So on boot it brings up the bootloader. Which has endeavor with Linux Linux, and another entry with fallback initramfs. Whatever that is
Yet Iāve got the black screen again on reboot, weird.
Canāt switch tty either
Well Itās got to be Graphics related or with the desktop manager. Unfortunately itās late here and i have to get up early. Maybe some help from someone else and or tomorrow.
Edit: At least we got the installation to succeed.
Ok thanks. Yeah Iāve done an all nighter here aha.
I might try to reinstall with a different de I guess
Sure ā¦you could try that also. Xfce would be a good choice too.
Okay, thanks again for all the help
Did some looking around and it seems I might need to downgrade the Linux kernel somehow
EDIT: Using the offline installer worked so the issue is with the newer kernel version it seems.
So if I run an update will it break again?
Along with update install another kernel as a fallback:
sudo pacman -Syu linux-lts linux-lts-headers
After reboot you will have boot menu entries for both kernels. If one doesnāt work, try the other.
By the way, the original problem likely was this:
When you deleted extra boot entries you got enough space to install the bootloader.
@neilh90
So you were able to successfully install Xfce with the offline installer and it is able to boot to a full desktop? As @manuel suggests if you run the update command with installing the lts kernel and lts headers as shown above you will have an option to boot to the lts kernel if the update happens to cause a black screen.
Loading Linux linuxā¦
Loading initial ramdiskā¦
So I used the online installer and on reboot it hung here. I could not switch tty.
I reinstalled with the offline installer but when I ran pacman -Syu it updated the Linux kernel so it seems that is the issue. Now I canāt boot again.
Iām not too experienced with Linux but let me know of you need any more info.
I have a radeon graphics card. Using a HP Pavilion laptop.
Thanks
You could try linux-lts
kernel. Therefore you can arch-chroot
into your system as described here . After that do a
and
in case you use grub.
Afterwards reboot and select the linux-lts entry.
Ok thanks guys I will try this nowā¦
@ricklinux yeah I was able to install it, I had no WiFi though and needed to tether. I guess my laptop has one of the few not supported out the box, I found an aur package for it and am trying to build it
https://aur.archlinux.org/packages/rtl8821ce-dkms-git/
THis is the one
EDIT: Ok I ran the commands
and
and that worked. I still cannot get into the newer kernel but the LTS one seems to be working for now. Do you guys think there might be a way to get the newer kernel working?
Iām not sure what the issue is so you may have to provide some boot logs. You can do that with the log tool that is in the menu.
You could also try a kernel parameter. Iām just guessing though as I donāt have any info. I might try amdgpu.dc=0 in the default grub command line. Then you have to update the grub with a command.
But first letās just look at a bootlog first. Itās the one journalctl - b -0
Edit: Itās probably not going to be helpful though as it does work on the lts kernel.
You can post inxi -N to show what wifi chips you have see if you got the right package.
Ah I chose send results to internet but it said no results to fetch
EDIT: http://ix.io/2RBg
Iām not sure but I donāt think it logged the failed attempt to boot into linux 511
I think the log is just the boot with the lts kernel. Did you get the wifi working with the Aur package? Not sure what chip it is? inxi -N will show it.
Yes thanks, the AUR package works.
Youāve helped me a lot, I was wondering if you could tell me good resources to learning more about Linux. Things like the terminal. I want to be more capable and understand how things work.
As for updates, since I have a aur package now, should I be running yay -Syu instead of Pacman, also how often should I be running -Syu?
The defacto package manager is pacman. yay is an AUR helper but you can also use it to update. The wiki has info on yay. You can also use the man pages. Normally i use pacman mostly.
sudo pacman -Syu
or
yay -Syu
Yay updates both the AUR packages and and packages in the Arch repo.
You can use the man pages for info on commands.
man pacman
or
man yay
or
man inxi
So maybe you leave the lts kernel for a while and when it updates the current kernel to a new one you could try booting it into the regular kernel again. Iām not sure what the issue is currently. You would have to get into some of the logs trying to boot on the regular kernel. In the mean time you can try learn what you can i guess.
Edit: I have a newer HP with Ryzen 4700U and have no issues.
You donāt even need the -Syu with yay actually. Just type yay and itāll update both repo and AUR packages.
