[liveuser@eos-2021.02.03 ~]$ sudo efibootmgr -b 0004, 0001, 0000 -B~
Invalid bootnum value0004,
Sorry maybe it shouldnāt have the commaās
sudo efibootmgr -b 0005 0004 0001 0000 -B
Ok is this the expected output?
[liveuser@eos-2021.02.03 ~]$ sudo efibootmgr -b 0005 0004 0001 0000 -B
BootCurrent: 0006
Timeout: 0 seconds
BootOrder: 0006,0000,0001,0004
Boot0000* Manjaro
Boot0001 Windows Boot Manager
Boot0004 ubuntu
Boot0006* USB Drive (UEFI) - Philips USB Flash Drive PMAP
Noā¦ I was trying to delete them all at once and I obviously have the wrong command.
Try one only
efibootmgr -b 0000 -B
Edit: That should remove manjaro
[liveuser@eos-2021.02.03 ~]$ sudo efibootmgr -b 0000 -B
BootCurrent: 0006
Timeout: 0 seconds
BootOrder: 0006,0001,0004
Boot0004 ubuntu
[liveuser@eos-2021.02.03 ~]$ efibootmgr -b 0000 -B
Perfect so now do the others one at a time.
efibootmgr -b 0001 -B
then
efibootmgr -b 0004 -B
Ok cool. Now I am left with:
BootCurrent: 0006
Timeout: 0 seconds
BootOrder: 0006
Okay can you now run this command and post the link
inxi -Fxxxz --no-host | eos-sendlog
Okay perfect i just wanted to see what the hardware was. Iām not sure why itās failing at that spot but we have cleared entries from the nvram which saves the boot entries. Not sure itās going to work but what i would like you to do is reboot onto the live ISO and try the install process again.
Ok thanks. Should I use the default āerase discā option or the manual partitioning
It shouldnāt matter. But if it fails again Iām going to have to refer to one of the devs to get some insight into that particular error thatās coming up from Calamares. @joekamprad
Okay thanks. Install started, fingers crossed
Ohh it installed!
Okay so can you boot into it?
I rebooted and removed the USB drive.
Itās on a black screen saying:
Loading Linux linuxā¦
Loading initial ramdiskā¦
Been like this for some time now I wonder if it is hanged
What desktop did you installed?
Cinnamon (still on the same black screen. Should I reboot)
Do you know how to go into a tty? ctrl alt f2 and log in as root and then reboot
Yeah but sadly it isnāt working, ctrl alt f2
