Occasionally I use prepros for my work and I used it last time a month ago. Today I needed it and I couldn’t find it in my program list. I also tried to run it with “prepros” or “prepros-bin” in console without success.
Program is installed and I remember that it worked before. I ran it from all apications list If I remember correctly but I can’t find it there anymore.
[uros@Uros ~]$ pacman -Qi prepros-bin
Version : 7.8.5-1
Description : Prepros compiles your files, transpiles your JavaScript, reloads your browsers and makes it really easy to develop & test your websites so you can focus
on making them perfect.
Architecture : x86_64
URL : https://prepros.io
Licenses : custom:proprietary
Groups : None
Provides : None
Depends On : bash java-runtime electron25 perl lib32-gcc-libs lib32-glibc glibc gcc-libs zlib
Optional Deps : None
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 261,99 MiB
Packager : Unknown Packager
Build Date : sre 26 jul 2023 19:42:01
Install Date : sre 26 jul 2023 19:42:22
Install Reason : Explicitly installed
Install Script : No
Validated By : None
[uros@Uros ~]$ which prepros-bin
which: no prepros-bin in (/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl)
I also noticed some packages I don’t know what they are:
Electron 18
Electron 19
Electron 22
Electron 24
Electron 25
Currently I’m not at home to check it but I tried it on my EOS inside virtual box. I installed prepros and then searched for prepros.sh
I found that file inside “/home/uros/.cache/yay/prepros-bin”. Using that bash file I’m able to run prepros but I don’t see a point that I need to go to go to some cache folder find a bash script there and run it ?? Aren’t cache folder cleared from time to time?
Is there any particular reason for such approach ?
from what i see the PKGBUILD is not fully updated … maintainer removed desktop file but PKGBUILD still has a sed line that replaces the string “prepros %U” with “/opt/${pkgname%-bin}/${pkgname%-bin}” in the specified .desktop file… that is not there anymore… will be no issue if the rest is fine…
for me it starts up when using the sh starter script… but install does not have this anywhere i start it from the yay cache…
PKGBUILD is not okay … it does not pack the sh file nor the desktop file in the package so boith are missing on target
I’m a noob in this field so I will just wait for an package update . I tried to add prepros.desktop where I changed value of exec to “/home/uros/.cache/yay/prepros-bin/prepros.sh”. Program was displayed in applications list but it didn’t start.
I started to looking at nodejs, node-sass, autoprefixer and cssnano to achieve what prepros does.
