Hello, I come to ask for help because I have a problem with the resolution of my screen. I downloaded EndeavorOS yesterday and had a wide number of resolutions to choose from, but today I turned on my computer and I have 640x480 and I looked at xrandr and it detected the None-1 monitor (although Screen0 also appeared). I have tried adding resolutions with the same xrandr but nothing changes.
My graphics card is one from Nvidia, specifically a Zotac GeForce 9500 GT. I would like to know if someone could help me
Extra:xrandr
Screen 0: minimum 320 x 200, current 640 x 480, maximum 4096 x 4096
None-1 connected primary 640x480+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
640x480 60.00*+
Are you running on the opensource nouveau driver?
inxi -Ga
I’m new to this and I don’t understand it well, so I put the command you mentioned and now I’ll tell you what appeared so I’ll know if it’s working or not.
$ inxi -Ga
Device-1: NVIDIA G96C [GeForce 9500 GT] vendor: ZOTAC driver: N/A
alternate: nouveau non-free: series: 340.xx
status: legacy (EOL~2019-12-xx) last: release: 340.108 kernel: 5.4
xorg: 1.20 arch: Tesla process: 40-80nm built: 2006-2013 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 bus-ID: 02:00.0 chip-ID: 10de:0640
class-ID: 0300
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_x11 driver: X: loaded: modesetting
alternate: fbdev,nouveau,nv,vesa gpu: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 640x480 s-dpi: 96 s-size: 169x127mm (6.65x5.00")
s-diag: 211mm (8.32")
Monitor-1: Unknown-1 mapped: None-1 res: 640x480 hz: 60 size: N/A
modes: 640x480
API: EGL v: 1.5 platforms: device: 0 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: swrast x11: drv: swrast inactive: wayland
API: OpenGL v: 4.5 vendor: mesa v: 23.3.5-arch1.1 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 16.0.6 128 bits)
device-ID: ffffffff:ffffffff memory: 3.74 GiB unified: yes
[quote="HauntingNest, post:3, topic:51207"]
class-ID: 0300
[/quote]
The problem likely is that it’s not showing the drivers as loaded. How did you install the drivers?
Edit: Didn’t? Or you did and they just aren’t loading properly.
Edit: It also shows no monitor picked up. What spec version is the DP cable?
modes: 640x480
Can you run nvidia-inst -t
and post the whole output it shows.
Edit: This is just a test so no changes will be done.
Edit: Since you are new then you need to use code tags around what you post from the output. Just put three back ticks ``` or three tilde ~~~ before and after what you copy and post from the output. Or you can use the preformatted text button above in the topic window.
I have not installed the drivers because, as I mentioned, everything worked correctly until yesterday with a large number of resolutions. I don’t know what the DP of a cable is, sorry.
Well i think you need to install the drivers. Can you please run nvidia-inst -t
and post the whole output.
I have put the command nvidia-inst -t and I get order not found.
You may have to install nvidia-inst
first.
When you installed did you use the default menu entry and not the nvidia one?
Edit: If you did it should be showing nouveau driver.
How do I do it? (of course, in case it is something more or less simple)
yay -S nvidia-inst
Edit: Then run the test and post the complete output.
nvidia-inst -t
2024-02-16 18:56:27: Info: Running: nvidia-inst v23.1-1
2024-02-16 18:56:27: Info: Command line: nvidia-inst -t
2024-02-16 18:56:27: Info: Selected mode: nvidia
NVIDIA card id: 0640
Fetching driver data from nvidia.com ...
Sorry, none of the Nvidia driver series [545, 470, 390] is supported.
More info:
https://www.nvidia.com/en-us/drivers/unix
https://download.nvidia.com/XFree86/Linux-x86_64/545.29.06/README/supportedchips.html
2024-02-16 18:56:33: Error: nvidia-driver-supported-branches could not fetch card ids from Nvidia.~~~
Okay so it’s showing that it’s not fetching the card ID. Give me a minute to look something up.
Ok
Edit:It seems I answered the wrong one
What happens if you run
Edit: Can you also run this one.
nvidia-installer-check
$ nvidia-driver-supported-branches
More info:
I think this card needs the 340.XX version so you need to install them from the AUR.
yay -S nvidia-340xx-dkms nvidia-340xx-utils nvidia-340xx-settings
Edit: This is using yay to install which will build the packages and install. Just press enter for each question since you are not familiar with it.
Edit2: Once it is all done then you’ll need to reboot and post this again.
inxi -Ga
It’s because the card is now unsupported via Nvidia so you have to install these drivers from the AUR.
Edit: It should have been running on the open source nouveau driver but somethings messed it up.
Wait
