nvidia-340xx-utils y nvidia-utils están en con
flicto. ¿Quitar nvidia-utils? [s/N] N
error: se han detectado paquetes con conflictos s
in resolver
error: no se pudo preparar la operación (dependen
cias en conflicto)
:: nvidia-340xx-utils y nvidia-utils están en con
flicto
→ error al instalar: [/home/gabrielinux/.cache/
yay/nvidia-340xx-utils/nvidia-340xx-utils-340.108
-1-x86_64.pkg.tar.zst] - exit status 1
error compilando: nvidia-340xx-settings - exit st
atus 8
error al instalar: [/home/gabrielinux/.cache/yay/
nvidia-340xx-utils/nvidia-340xx-utils-340.108-1-x
It is in Spanish because I speak that language natively.
If you do want to try reinstalling use the default menu option in the menu not the nvidia option. Then it will install with nouveau open source drivers. Right after reinstalling you would checkinxi -Ga to see if the graphics are running on nouveau. You’ll also see if the resolution is back to normal as you said before it was working. I’m not sure what happened that caused it to not load using nouveau since you said you never installed nvidia drivers.
Although I remembered a possibly important fact, because I installed Steam and it gave me a choice (I don’t remember exactly what it was but it gave me the option of Amd, Nvidia, Etc). And I chose Nvidia because it was my graphics card. Maybe that has something to do with it
Okay so you can run on the opensource driver and the only other option for nvidia is the 340,xx version from the AUR. I personally don’t know if you will gain any benefit with the nvidia drivers or whether nouveau opensource works okay for you. Also not sure what messed up in the first place. There was just another new kernel with a bunch of updates.
[ricklinux@plasma-kde ~]$ uname -a
Linux plasma-kde 6.7.5-arch1-1 #1 SMP PREEMPT_DYNAMIC Sat, 17 Feb 2024 14:02:33 +0000 x86_64 GNU/Linux
