How to stop `localsearch` (Cinnamon, GNOME, …) wasting CPU & WiFi bandwidth
Note: This describes the process for GNOME-based DEs (GNOME, Cinnamon, etc.). For a KDE solution, see @Pudge’s post below.
I wondered why, on my EOS/Cinnamon laptop, the fan went on so often, and a CPU load average of 1.5–2.0 was seen when I did nothing on the system, often for hours. Also, the (NFS auto-mounted) NAS folder icons for my Music and Video folders would suddenly appear on my desktop while I was not officially using my NAS.
Now I have my Music and Video NAS folders mounted onto ~/Music and ~/Videos, and htop showed 8 threads of localsearch-3 and localsearch-extractor-3 running, one of each eating 99.8% CPU all the time.
Turns out localsearch tries to index the hundreds of thousands of files on my NAS over WiFi, to build a local index for faster access. And it doesn’t see that these folders are actually remote. (Tools like find, rsync and ncdu, for instance, can very well recognize the difference.)
Unfortunately, the collected data is totally useless, since Cinnamon has Nemo instead of Nautilus, and we don’t use GNOME tools that would access the localsearch (ex Tracker3) data. But we can’t simply uninstall Nautilus, localsearch-3 and its companions due other dependencies that require them. :frowning:
I thought of masking & stopping the relevant services, but they apparently get started again via DBus.
GNOME’s localsearch command line reference finally gave me the hints needed.
  • Getting the localsearch status confirmed my suspicions:
    $ localsearch status
    Derzeit indiziert: 212683 Dateien, 34621 Ordner
    Verbleibender Speicherplatz auf der Partition mit der Datenbank: 102,6 GB (47,71%)
    Waiting for data... (^X or interrupt to abort)
    (tracker status:8896): Tracker-CRITICAL **: 08:00:45.446: Could not get miner progress for 'org.freedesktop.Tracker3.Miner.Files': Zeitüberschreitung wurde erreicht
    Alle Datensammler sind bereit, die Indizierung ist abgeschlossen
    969 registrierte Ausfälle
  • Checking the daemon status further confirms the fruitless task:
    $ localsearch daemon
    Indizierer:
    25 Jun 2025, 08:10:13:    1%  File System                - Crawling recursively directory 'file:///home/matthias/Musik/Tagged/Scheit,%20Das/Scheit,%20Das%20-%20A%20Darker%20Kind%20of%20Black%20(2016%20album,%20XW)'
  • So I checked what it tries to index:
    $ localsearch index
    Pfad                                                         Rekursiv
    /home/matthias/Schreibtisch                                  *
    /home/matthias/Dokumente                                     *
    /home/matthias/Musik                                         *
    /home/matthias/Bilder                                        *
    /home/matthias/Videos                                        *
    /home/matthias                                               -
    /home/matthias/Downloads                                     -
  • ~/Musik and ~/Videos are actually mounted NAS volumes, so let’s remove these from the indexer and verify:
    $ localsearch index --remove /home/matthias/Musik
    $ localsearch index --remove /home/matthias/Videos
    $ localsearch index
    Pfad                                                         Rekursiv
    /home/matthias                                               -
    Not in the list anymore, fine!
  • Now let’s reset the indexer, and clear out its cache:
    $ localsearch reset --filesystem
    0 PIDs gefunden …
  • Check localsearch status again:
    Derzeit indiziert: 518 Dateien, 43 Ordner
    Verbleibender Speicherplatz auf der Partition mit der Datenbank: 103,8 GB (48,3>
    12 registrierte Ausfälle
    Pfad                                     Nachricht
    …atch/screenshot-2025-02-13-11-01-07.png Could not get any metadata for uri:'fi…
    …atch/screenshot-2024-11-16-11-16-26.png Could not get any metadata for uri:'fi…
    …atch/screenshot-2025-03-19-10-07-05.png Could not get any metadata for uri:'fi…
    …atch/screenshot-2024-11-15-07-49-28.png Could not get any metadata for uri:'fi…
    …atch/screenshot-2025-02-18-14-56-08.png Could not get any metadata for uri:'fi…
    …atch/screenshot-2025-02-20-13-19-57.png Could not get any metadata for uri:'fi…
    …atch/screenshot-2025-03-17-16-04-09.png Could not get any metadata for uri:'fi…
    …atch/screenshot-2025-02-17-18-07-27.png Could not get any metadata for uri:'fi…
    …atch/screenshot-2024-11-03-20-25-14.png Could not get any metadata for uri:'fi…
    …er_lite_i2s_dfu_firmware_48k_v1.0.9.bin Could not get any metadata for uri:'fi…
    …er_lite_i2s_dfu_firmware_48k_v1.1.0.bin Could not get any metadata for uri:'fi…
    …firmware_48k_v1.1.0_ch0-asr_ch1-mww.bin Could not get any metadata for uri:'fi…
  • DONE. No more screeching fan, no more wasting CPU and WiFi bandwidth! Average CPU load now back at 0.1–0.2 when doing nothing, and no unneeded auto-mounts and NAS connections anymore. It also makes the laptop run much longer on batteries.
Nowadays often things get pre-installed that are supposed to “help” users, but in fact just waste lots of resources! Getting rid of these unwanted supposed-to-be “make user’s life easier” tools is often hours of work for diagnosing and learning how to handle these—just to turn them off. Wish more things were opt-in instead of opt-out. Really,
Thanks fo this service announcement, your time to find out and posting the solution here!
Yeah, took me a while. Hope this helps Cinnamon users get rid of it, and GNOME users to more finely tune their localsearch!
In general: Be aware of side effects when mounting anything into the XDG standard folders.
KDE will probably have something similar.
That would be baloo. To disable baloo
balooctl6 suspend
balooctl6 disable
balooctl6 purge
balooctl6 status
status should now read
Baloo is currently disabled. To enable, please run balooctl enable
Pudge
Thanks @Pudge! Now we have all solutions together. I edited the first post to link here.
In plasma just go into the File Search settings and exclude locations you don’t want indexed. I’m not even sure if baloo crosses filesystem boundaries like nfs. Just disabling baloo will break other functionality.
The real resource consumer is the indexing of file contents. I blogged on how to disable that (previously it was called tracker, but it’s updated for localsearch as well):
I noticed this localsearch issue today under XFCE (intermittent 100% cpu / 10gb more RAM usage) - this Arch post fixed things for me (mask the services)
As I also run the rc-local.serviceI also disable the executable bit on every boot for localsearch-3 / localsearch-extractor-3
