I found the discussion to get the minimize options displayed, and they work. The minimize always puts the window in Activities. I’d prefer it on the desktop.
BTW: if you didn’t guess, I’m new to Linux:)
… Charlie
That is a feature, specific to the Gnome-DE. You won’t be able change it as long as running Gnome, AFAIK.
I don’t think you can minimize them to the desktop(Does any OS allow that?)
You could install a dock or panel extension in gnome and then they would additionally minimize to that dock or panel.
The only one working with latest Gnome is Dash-To-Panel, I believe.
To achieve that, one could install the gnome-shell-extensions package, along with gnome extension-manager.
This version of dash-to-dock works with gnome 42
Wow, that’s news to me, thanks @dalto !
Thanx all for the quick responses and suggies … Charlie
If you want to use dash to dock, you can also just install gnome-shell-extension-dash-to-dock . Works perfect on gnome 42 for me.
EDIT - Sorry I should have mentioned that it is an AUR package and you need to use yay or paru to install.
Gnome extension-manager tells me, “Dash to Dock” is not compatible with Gnome42. However, dalto’s suggestion of “Dash to Dock for COSMIC” is easily found and installed via expension-manager and works instantly for me. Previously I had “Dash To Panel” in use on Gnome42 which worked flawlessly.
Superkey will display like this
You can add Gnome Tweaks to get more fine tuning of Gnome.
sudo pacman -S gnome-tweaks
Go to Activities and start typing…
tweaks
Then do this
Happy to have another Gnome user on board and welcome @j831526 to ![]()
This may help @j831526 How I got Dash to Dock working on Gnome 42
