This is my first post here! By the way, I really like EndeavourOS!
I am running the latest version of the OS. I am always doing the updates when I got notifications.
I have a newbie question. My sound card does not seem to be detected at all. If I open PulseAudio Volume Control, on the Output Devices tab I only see HDMI output and my headset.
I need some guidance here from someone. I know also that this post is missing a lot of information about my system. Please tell me what to provide.
@jonathanpoulin
Welcome to the forum. Thanks for giving EndeavourOS a try. I hope you enjoy your time here.
As for pavucontrol, be sure that the window is wide enough to show all tabs. Most of the time the window is too narrow and hides the “Configuration” tab.
Device-1: NVIDIA GK208 HDMI/DP Audio vendor: Micro-Star MSI
driver: snd_hda_intel bus-ID: 2-1.5.1.2.2:13 v: kernel chip-ID: 1532:0537
pcie: speed: 5 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:0e0f
Device-2: Razer USA Kraken V3 X type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-3: Razer USA Seiren Mini type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 2-1.5.2:7
chip-ID: 1532:0531
Device-4: Razer USA Kiyo Pro type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 2-1.5.4:8 chip-ID: 1532:0e05
Sound Server-1: ALSA v: k5.18.9-arch1-1 running: yes
Sound Server-2: JACK v: 1.9.21 running: no
Sound Server-3: PulseAudio v: 16.1 running: yes
Sound Server-4: PipeWire v: 0.3.53 running: no
as @ricklinux mentioned already … usually you should run pipewire … or it is an old install from times before the switch.
And card and headset are detected and drivers are loaded…
The issue that you do no sound is may caused by a package mismatch … could prevent pulseadio alone to not work and could be blocking pipweire from working…
pacman -Qs pipewire will list installed pipewire packages pacman -Qs pulse pulseaudio packages.
local/gst-plugin-pipewire 1:0.3.53-3
Multimedia graph framework - pipewire plugin
local/pipewire 1:0.3.53-3
Low-latency audio/video router and processor
local/pipewire-media-session 1:0.4.1-2
Example session manager for PipeWire
And pacman -Qs pulse:
local/libcanberra 1:0.30+r2+gc0620e4-1
A small and lightweight implementation of the XDG Sound Theme Specification
local/libpulse 16.1-1
A featureful, general-purpose sound server (client library)
local/pavucontrol 1:5.0+r35+g964f298-1
local/pulseaudio 16.1-1
local/pulseaudio-alsa 1:1.2.7.1-1
ALSA Configuration for PulseAudio
local/pulseaudio-bluetooth 16.1-1
Bluetooth support for PulseAudio
local/pulseaudio-jack 16.1-1
Jack support for PulseAudio
local/xfce4-pulseaudio-plugin 0.4.3-2 (xfce4-goodies)
Pulseaudio plugin for the Xfce4 panel
I followed the following to install Pipewire. But still the same problem. puvacontrol does not show anything other than HDMI and my USB headset. In other words, no sound from the 3.5mm output jack on the computer.
By the way, for Pipewire, that was not installed and running probably because I installed EndeavourOS from a DVD that came with a magazine. On the disc, it says version “2021-08-27”. Sounds like this is a version before Pipewire became installed by default. Right?
chip-ID: 1532:0531
Do you have sound hooked up to the external sound output from the computer to speakers?
Edit: What is hooked up to it that is Razer?
It looks like a Razer Microphone and a Razer Headset? Is it a separate razer mic or just a combined headset?
This document attempts to describe everything you need to know about configuring audio-over-HDMI on recent NVIDIA GPUs and chipsets. A fair level of detail is provided, in an attempt to fully explain everything, rather than hiding useful details.
Yes, I have connected my external speakers to the 3.5mm green jack on the back of my computer. No sound is coming from that connector.
Yes, that’s a USB headset (with a mic) and a microphone. 2 devices (Device-2 and Device-3 respectively). I have also a webcam, my Razer Kiyo Pro (Device-4).
So I don’t see something related to the onboard sound card.
