I am unable to find how to install proton experimental bleeding-edge. I already have proton experimental installed, but it is not the bleeding-edge one. Do you have to build that yourself or is there a way to obtain it via steam?
Awesome, thank you very much for the quick reply! I wanted to play Division 2 with DX12 which a fix for has been committed to VKD3D-Proton last night, but not anywhere else yet.
Beware!!!
You can cut yourself!
