How to edit pkgbuild in yay
I did
yay --editmenu --nodiffmenu --save
and now, yay lets me edit pkgbuild, which I need, because a certain package I want to install has the wrong url, as noted in the comments.
https://aur.archlinux.org/packages/fax4cups/
The correct url is
http://mirror.transip.net/gentoo/gentoo/distfiles/fax4CUPS-1.29.tar.gz
I tried it, and it works.
But the pkgbuild still fails with 404 error, and I can’t figure out why.
shmuel@shmuel-arch ~ [1]> yay fax4cups
1 aur/fax4cups 1.29-1 (+1 0.00)
    Fax backend for CUPS supporting hylafax hylafaxplus mgetty-fax efax capisuite
==> Packages to install (eg: 1 2 3, 1-3 or ^4)
==> 1
:: Checking for conflicts...
:: Checking for inner conflicts...
[Aur:1]  fax4cups-1.29-1
  1 fax4cups                         (Build Files Exist)
==> Packages to cleanBuild?
==> a
:: Deleting (1/1): /home/shmuel/.cache/yay/fax4cups
:: (1/1) Downloaded PKGBUILD: fax4cups
:: (1/1) Parsing SRCINFO: fax4cups
==> PKGBUILDs to edit?
==> a
 -> $EDITOR is not set
 -> Add $EDITOR or $VISUAL to your environment variables
==> Edit PKGBUILD with?
==> nano
==> Proceed with install? [Y/n]
==> Making package: fax4cups 1.29-1 (Thu 26 Aug 2021 11:59:27 AM IDT)
==> Retrieving sources...
  -> Downloading fax4CUPS-1.29.tar.gz...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--    0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
curl: (22) The requested URL returned error: 404
==> ERROR: Failure while downloading http://mirror.transip.net/gentoo/gentoo/distfiles/fax4CUPS/fax4CUPS-1.29.tar.gz
    Aborting...
 -> error downloading sources: fax4cups
         context: exit status 1
==> Making package: fax4cups 1.29-1 (Thu 26 Aug 2021 11:59:28 AM IDT)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
    Aborting...
 -> error making: fax4cups
Why don’t you just download it and build the package manually?
See:
Try another mirror for fax4CUPS-1.29.tar.gz
EDIT : https://www.joonet.de/sources/fax4cups/oldsrc/fax4CUPS-1.29.tar.gz
I tried that already. It is supposed to set up a CUPS printer, and apparently, that works differently on Arch than on other distros, I got a lot of errors. I thought maybe yay could do it better.
This is the line I edited:
url='http://mirror.transip.net/gentoo/distfiles/fax4CUPS'
I just saw your EDIT I will try it
