How to dual boot endeavouros without usb
DISCLAIMER
I’m not responsible for any damage you end up doing to your system (if any).
PREREQUISITES
  • Windows is installed
  • Universal USB Installer 2.0.0.1 (specifically this version as it has the ability to install on drives (also will be referred to as UUI for convenience’s sake))
HOW-TO
  1. Get the EndeavourOS ISO.
  2. Open diskmgmt.msc and create a new 4GB partition and call it EOS_202406 otherwise it will refuse to boot. Make another one for the system itself.
  3. Open UUI and select Arch Linux in the first dropdown. Then, select “Show all ISOs?” and select your ISO.
  4. Let it do its thing and restart your PC
  5. Boot into the BIOS and turn off Secure Boot and restart into UEFI OS (at least it’s called that on Asus)
  6. Boot into any one of the options for you.
    That’s all! Enjoy using Endeavour.
if that doesn’t work you can always extract normally to eos_202406 and boot from there
also do note that if anything breaks the endeavour iso is still a partition that you can boot from if any breakage occurs
if you wanna replace windows just don’t make an empty partition and install endeavour on the c drive
That’s neat. Thanks for discovering this and sharing it. I do think that it will be better if you were to just get a USB flash drive and put EndeavourOS on it, but this can be a way too, I guess?
i only did this method bc i have no clue where to get an usb so i just did this and SOMEHOW it worked
i do still recommend getting an usb
At least in Europe, hypermarkets have a small section dedicated to technology. That’s where you get some USB flash drives. Google is your friend here, though.
i live in britain so i can find literally no usbs in shops
Again, Google is your best friend here. It is impossible for a computer/tech shop to not be nearby you.
they are but they’re few and far between
idk if the supermarket nearby has them i should check soon maybe
Britain has Walmart stores and Hardware stores so a USB fine should be easy.
And if not surely can get one delivered cheap, like i can order and have them at home 2 days tops
i live in the middle of nowhere i’m not walking to the nearest currys (2 miles away)
i’m considering that
Yer like this might be great for people with no other choice but when you shared you live in UK and make out USBs to be an issue makes me question the whole post. TBH I think this is spam/clickbait waiting to switch with the payload (I could be way off this is just how this whole post feels)
Yeah, USB thumbdrives aren’t exactly lost archeotech just yet here in Britain :laughing:
My usual go to for when I inevitably lose track of one of the absolutely countless USB sticks I’ve owned over the years is just to grab whatever is cheapest off of My Memory, although at the moment I’m rocking a very handy dual USB A/C model I picked up from who even knows where.
Comes in handy for tinkering with things that only have USB-C ports like the Steam Deck.
Yer I’m in oz but whole thing appears off, giving it benifit of doubt for now as they may live in a rural area but even mixed with the services available makes me question stuff
i literally just did this cuz i didn’t wanna get a usb and somehow it worked
  1. feels like it at times
  2. mymemory looks neat
not a rural area just a place where everything is miles away (including the nearest tesco)
also imma be real the uui method didn’t work for me at first so i just copied the files to a separate drive manually
