How to dual boot endeavouros without usb
Yer was this is just how it appears to me, but I get it, I’ve lived in a few rural places and even though things were available they were a mission to get
And by the way, welcome to the forum @harley-whoneedsusbs
yeah that’s like the whole thing here
also thx (trying to do this was the biggest trial and error thing to do and i might be the first to do so for endeavouros also don’t use uui ill try and rewrite this someday)
Hey, newbs here, do i need to change the basic data part to efi system? Or just leave it as be
leave it be
The initial post should be more informative about what exactly this is doing… if inexperienced user think this is a solution to install EndeavourOS without USB at hand, it is a bit misleading…
And for sure you are welcome here :enos:
it extracts the iso to a partition basically
which is why i also listed just extracting it as a solution
i do understand exactly what it is doing, but as you post is looking like a tutorial new users will get confused what it is for… so could you add some more info to the initial post?
